[求助] MSP430FR5720芯片下载程序有两种方式
zxtyr   2015-6-30 01:56 楼主
MSP430FR5720芯片下载程序有两种方式:SBW和JTAG,怎么选择为JTAG模式,TEST和RST引脚怎么连接?
现在的电路板将两个引脚都拉高,但是IAR总是显示错误:找不到设备!
求助各路大神!
回复评论 (4)
The MSP430 family supports the standard JTAG interface, which requires four signals for sending and receiving data. The JTAG signals are shared with general-purpose I/O. The TEST/SBWTCK pin is used to enable the JTAG signals. In addition to these signals, the RST/NMI/SBWTDIO is required to interface with MSP430 development tools and device programmers. The JTAG pin requirements are summarized in Table 6-4. For further details on interfacing to development tools and device programmers, see the MSP430 Hardware Tools User's Guide (SLAU278). For a complete description of the features of the JTAG interface and its implementation, see MSP430 Programming Via the JTAG Interface (SLAU320).
Table 6-4. JTAG Pin Requirements and Functions
DEVICE SIGNALDIRECTIONFUNCTION
PJ.3/TCKINJTAG clock input
PJ.2/TMSINJTAG state control
PJ.1/TDI/TCLKINJTAG data input, TCLK input
PJ.0/TDOOUTJTAG data output
TEST/SBWTCKINEnable JTAG pins
RST/NMI/SBWTDIOINExternal reset
VCC Power supply
VSSGround supply
点赞  2015-6-30 06:38
请问你的驱动安装成功了吗?您的仿真器用哪种,是ti的MSP_FET430UIF吗?这个需要设置的哦
点赞  2015-6-30 07:48
点赞  2015-6-30 07:48
驱动已经安装成功了,仿真器用的就是TI的。
重新连接jtag,IAR软件提示错误:chosen derivative(MSP430FR5720) and actual hardware (Device_unknown) do not match.
Continue to download?
如果继续,就报错。今天早上重新焊了一个单片机,虽然还提示这个错误,但可以进入调试界面了,这样算成功吗?
点赞  2015-6-30 19:29
    写回复
