我用cordic 核实现开方功能,但是用modelsim 仿真的时候输出一直是蓝线,提示很多很多warning # Loading work.sqare_test_tb # Loading work.square_test # Loading work.square # Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_REG_FD_V7_0 # Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_SHIFT_RAM_V7_0 # Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_ADDSUB_V7_0 # Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_MUX_BIT_V7_0 # Loading D:\X\ISE\verilog\mti_se\unisims_ver.LUT4 # Loading D:\X\ISE\verilog\mti_se\unisims_ver.BUF # Loading work.glbl # ** Warning: (vsim-3017) square.v(872): [TFMPC] - Too few port connections. Expected 10, found 4. # Region: /sqare_test_tb/uut/YourInstanceName/BU20 # ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'SINIT'. # ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'SSET'. # ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'SCLR'. # ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'AINIT'. # ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'ASET'. # ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'CE'. # ** Warning: (vsim-3017) square.v(902): [TFMPC] - Too few port connections. Expected 10, found 4. # Region: /sqare_test_tb/uut/YourInstanceName/BU89 # ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'SINIT'. # ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'SSET'. # ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'SCLR'. # ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'AINIT'. # ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'ASET'. # ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'CE'. # ** Warning: (vsim-3017) square.v(932): [TFMPC] - Too few port connections. Expected 10, found 4. ..... 另请教高手们,我现在要实现的算法,好像不大容易避免开方,有没有别的办法实现开方 或者 对一个复数求模值呢 |
引用: HDLWorld 发表于 2015-7-21 09:49
COrdic求开方已经是最方便的算法了,没有其他更好的办法。 你把你代码贴上去我可以帮你看看。
