[求助] 用stc121c5a60s2 的ads1118一直显示错误数据
岳思轩   2015-7-28 10:21 楼主
#include "ads1118.h"
void delay_ms(uint m)
    uint i, j,k;
    for(i=m;i>0;i--)
          for(k=6;k>0;k--)
        for(j=140;j>0;j--);
void delay100us()    // 11.0592MHz ????100us
uint j;
for(j=78;j>0;j--)
   _nop_();
void ADS1118_Init(void)
        CS_H;
        SCLK_H;
        MOSI_L;
void delay10us()    // 11.0592MHz ????10us
uint j;
for(j=1;j>0;j--)
   _nop_();
union aa{
           uint dat1[2];
                       ulong dat2;
uint Write_ADS1118(uint dat,uchar mode)
//        uint temp;
        union aa temp;
        union aa temp1;
//        ulong Value;
        uchar i;
  if(mode == 1)dat |= 0x8000;
        temp.dat1[1] = dat;
  temp.dat1[0] = dat;
        SCLK_L;
        CS_L;
        delay_ms(1);delay_ms(1);
        for(i=0;i<32;i++)
                if(temp.dat2 & 0x80000000)MOSI_H;
                else MOSI_L;
                temp.dat2 <<= 1;
                delay100us();
                SCLK_H;
                delay100us();
                SCLK_L;
                delay100us();
                temp1.dat2 <<= 1;delay10us();
                if(READ_MISO)temp1.dat2 |= 0x01;
  CS_H;
        SCLK_L;
        MOSI_L;
        MISO_L;
        printf("temp %d\n\r",temp1.dat1[0]);
        printf("temp %#X\n\r",temp1.dat1[1]);
        return temp1.dat1[0];
//oˉêyÃû3Æ£oADS_SEL_Read£¨£©
//oˉêy1|Äü£o¶á衸÷·μçÑ1£¬í¨1yὸöswitchÑ¡Ôñ¶áè¡2»í¬μÄí¨μà
//êä    èë£oroad:Ôöòæ·Å′óÆ÷ὶËμÄμçÑ1Ñ¡Ôñ£¬2¢Ñ¡Ôñ2a¼¸Â·μçÑ1
//          Ref: Ñ¡Ôñ2ο¼μçÑ1£¬óD6ÖÖÑ¡Ôñ
//êä    3ö£odat£o16λad×a»»êy¾Y
//±¸    ×¢£oÕaò»′ζá3öμÄ×a»»êy¾YêÇéÏò»′ÎμÄ×a»»êy¾Y£¬2»òa»ìÏy.ÕaàïÑ¡ÔñμÄêÇμ¥′Î
            ×a»»μçÑ1Ö죬μ±è»£¬ò2¿éòÔÑ¡Ôñ¶à′Î×a»»,í¨1y¼Ä′æÆ÷μÄμú8λ¿éòÔéèÖÃ
//èÕ    Æú£o2013.6.8
int ADS_SEL_Read(uchar road,uchar Ref)         //2a¼¸Â·μçÑ1
    int dat = 0;
    uint Config_Value = 0x008b;                     //ĬèÏμí8룬DOUT′øéÏà-μç×è
    switch(road)
    case 0:  Config_Value += 0x0000;break;    //AINP = AIN0 and AINN = AIN1 (default)
    case 1:  Config_Value += 0x1000;break;    //AINP = AIN0 and AINN = AIN3
    case 2:  Config_Value += 0x2000;break;    //AINP = AIN1 and AINN = AIN3
    case 3:  Config_Value += 0x3000;break;    //AINP = AIN2 and AINN = AIN3
    case 4:  Config_Value += 0x4000;break;    //AINP = AIN0 and AINN = GND
    case 5:  Config_Value += 0x5000;break;    //AINP = AIN1 and AINN = GND
    case 6:  Config_Value += 0x6000;break;    //AINP = AIN2 and AINN = GND
    case 7:  Config_Value += 0x7000;break;    //AINP = AIN3 and AINN = GND
    default : break;
    switch(Ref)
    case 0:  Config_Value += 0x0000;break;    //000 : FS = ¡à6.144V(1)
    case 1:  Config_Value += 0x0200;break;    //001 : FS = ¡à4.096V(1)
    case 2:  Config_Value += 0x0400;break;    //002 : FS = ¡à2.048V(1)
    case 3:  Config_Value += 0x0600;break;    //003 : FS = ¡à1.024V(1)
    case 4:  Config_Value += 0x0800;break;    //004 : FS = ¡à0.512V(1)
    case 5: case 6: case 7: Config_Value += 0x0a00;break;    //005 : FS = ¡à0.256V(1)
    default : break;
    CS_L;
    dat = Write_ADS1118(Config_Value,1);
    delay100us();
    CS_H;
    return dat;
回复评论 (1)
无论有没有输入始终是这个问题,是时序问题,可时序到底哪里错了呀?????????
点赞  2015-7-28 10:22
    写回复
