[2015-09-07 16:43:58 - Helloworld] ------------------------------
[2015-09-07 16:43:58 - Helloworld] Android Launch!
[2015-09-07 16:43:58 - Helloworld] adb is running normally.
[2015-09-07 16:43:58 - Helloworld] Performing com.example1.helloworld.MainActivity activity launch
[2015-09-07 16:43:58 - Helloworld] Automatic Target Mode: launching new emulator with compatible AVD 'AVD1'
[2015-09-07 16:43:58 - Helloworld] Launching a new emulator with Virtual Device 'AVD1'
[2015-09-07 16:43:59 - Emulator]
[2015-09-07 16:43:59 - Emulator] the '-scale ' option is used to scale the emulator window to
[2015-09-07 16:43:59 - Emulator] something that better fits the physical dimensions of a real device. this
[2015-09-07 16:43:59 - Emulator] can be *very* useful to check that your UI isn't too small to be usable
[2015-09-07 16:43:59 - Emulator] on a real device.
[2015-09-07 16:43:59 - Emulator] there are three supported formats for :
[2015-09-07 16:43:59 - Emulator] * if is a real number (between 0.1 and 3.0) it is used as a
[2015-09-07 16:43:59 - Emulator] scaling factor for the emulator's window.
[2015-09-07 16:43:59 - Emulator] * if is an integer followed by the suffix 'dpi' (e.g. '110dpi'),
[2015-09-07 16:43:59 - Emulator] then it is interpreted as the resolution of your monitor screen. this
[2015-09-07 16:43:59 - Emulator] will be divided by the emulated device's resolution to get an absolute
[2015-09-07 16:43:59 - Emulator] scale. (see -help-dpi-device for details).
[2015-09-07 16:43:59 - Emulator] * finally, if is the keyword 'auto', the emulator tries to guess
[2015-09-07 16:43:59 - Emulator] your monitor's resolution and automatically adjusts its window
[2015-09-07 16:43:59 - Emulator] accordingly
[2015-09-07 16:43:59 - Emulator] NOTE: this process is *very* unreliable, depending on your OS, video
[2015-09-07 16:43:59 - Emulator] driver issues and other random system parameters
[2015-09-07 16:43:59 - Emulator] the emulator's scale can be changed anytime at runtime through the control
[2015-09-07 16:43:59 - Emulator] console. see the help for the 'window scale' command for details
[2015-09-07 16:44:08 - Helloworld] New emulator found: emulator-5554
[2015-09-07 16:44:08 - Helloworld] Waiting for HOME ('android.process.acore') to be launched...
我运行一个应用,出现上面的提示,就不往下走了。
还有我建了个AVD,好像比屏幕大,显示不下。
请问该如何解决?谢谢!
