我是新手,看了下controlSUITE里的example 中的 fpu_hardware
看了下前面的注释
- // Description:
- //! \addtogroup f2833x_example_list
- //! <h1>Floating Point Unit (fpu_hardware)</h1>
- //! The code calculates two y=mx+b equations. The variables are all
- //! 32-bit floating-point.
- //! The compiler will generate floating point instructions to do these calculations.
- //! To compile the project for floating point, the following Build Options were used:
- //! -# Project->Properties-> C/C++ Build window-> Basic Settings->
- //! C2000 Compiler Vx.x \n
- //! In All Options textbox: add "--float_support=fpu32" . \n
- //! OR in Runtime Model Options, under "Specify floating point support
- //! (--float_support) pull-down menu: Select "fpu32".
- //! C2000 Linker Vx.x-> File Search Path \n
- //! In "Include linker file or command file as input (--library, -l)"
- //! box, click green plus sign and add rts2800_fpu32.lib
- //! (run-time support library).
- //! -# Not included in this example: If the project includes any other libraries,
- //! they must also be compiled with floating point instructions.
- //! \b Watch \b Variables \n
- //! - y1
- //! - y2
- //! - FPU registers (optional)
貌似需要配置CCS,但是我按照这个顺序来
发现根本木有C/C++ Build window-
也没找到Specify floating point support 和有选择fpu32的下拉菜单
请问要用到浮点运算应该怎么做呢?
