描述:linux源码spi.c中有这样的一个函数spi_register_master,其中定义了一个原子量dyn_bus_id(如下面代码的蓝色字体)。
源码如下:
int spi_register_master(
struct spi_master
*master)
static atomic_t dyn_bus_id = ATOMIC_INIT((
1<<15)
- 1);
struct device
*dev
= master
->dev.parent;
int status
= -ENODEV;
int dynamic
= 0;
if (
!dev)
return -ENODEV;
/* even if it's just one always-selected device, there must
* be at least one chipselect
if (master
->num_chipselect
== 0)
return -EINVAL;
/* convention: dynamically assigned bus IDs count down from the max */
if (master
->bus_num
< 0) {
/* FIXME switch to an IDR based scheme, something like
* I2C now uses, so we can't run out of "dynamic" IDs
master
->bus_num
= atomic_dec_return(
&dyn_bus_id);
dynamic
= 1;
/* register the device, then userspace will see it.
* registration fails if the bus ID is in use.
dev_set_name(
&master
->dev,
"spi%u", master
->bus_num);
status
= device_add(
&master
->dev);
if (status
< 0)
goto done;
dev_dbg(dev,
"registered master %s%s\n", dev_name(
&master
->dev),
dynamic
? " (dynamic)" : "");
/* populate children from any spi device tables */
scan_boardinfo(master);
status
= 0;
done:
return status;
EXPORT_SYMBOL_GPL(spi_register_master);
问题:为什么要定义原子量,其是防止怎样的情况发生,举个例子?
说明:1.原子量的作用我是知道的,我想知道的是这里利用原子量想防止什么情况发生,举个例子。
2.源码中这样的注释也不了解
谢谢大神救小弟于苦恼!
