cpu_a.s
; uC/CPU
; CPU CONFIGURATION & PORT LAYER
; (c) Copyright 2004-2011; Micrium, Inc.; Weston, FL
; All rights reserved. Protected by international copyright laws.
; uC/CPU is provided in source form to registered licensees ONLY. It is
; illegal to distribute this source code to any third party unless you receive
; written permission by an authorized Micrium representative. Knowledge of
; the source code may NOT be used to develop a similar product.
; Please help us continue to provide the Embedded community with the finest
; software available. Your honesty is greatly appreciated.
; You can contact us at
www.micrium.com.
; CPU PORT FILE
; ARM-Cortex-M3
; GNU C Compiler
; Filename : cpu_a.s
; Version : V1.29.00.00
; Programmer(s) : JJL
; PUBLIC FUNCTIONS
EXPORT CPU_IntDis
EXPORT CPU_IntEn
EXPORT CPU_SR_Save
EXPORT CPU_SR_Restore
EXPORT CPU_WaitForInt
EXPORT CPU_WaitForExcept
EXPORT CPU_CntLeadZeros
EXPORT CPU_CntTrailZeros
EXPORT CPU_RevBits
; CODE GENERATION DIRECTIVES
PRESERVE8
AREA |.text|, CODE, READONLY
THUMB
;$PAGE
; DISABLE and ENABLE INTERRUPTS
; Description : Disable/Enable interrupts.
; Prototypes : void CPU_IntDis(void);
; void CPU_IntEn (void);
;.thumb_func
CPU_IntDis
CPSID I
BX LR
;.thumb_func
CPU_IntEn
CPSIE I
BX LR
; CRITICAL SECTION FUNCTIONS
; Description : Disable/Enable interrupts by preserving the state of interrupts. Generally speaking, the
; state of the interrupt disable flag is stored in the local variable 'cpu_sr' & interrupts
; are then disabled ('cpu_sr' is allocated in all functions that need to disable interrupts).
; The previous interrupt state is restored by copying 'cpu_sr' into the CPU's status register.
; Prototypes : CPU_SR CPU_SR_Save (void);
; void CPU_SR_Restore(CPU_SR cpu_sr);
; Note(s) : (1) These functions are used in general like this :
; void Task (void *p_arg)
; CPU_SR_ALLOC(); /* Allocate storage for CPU status register */
; CPU_CRITICAL_ENTER(); /* cpu_sr = CPU_SR_Save(); */
; CPU_CRITICAL_EXIT(); /* CPU_SR_Restore(cpu_sr); */
;.thumb_func
CPU_SR_Save
MRS R0, PRIMASK ; Set prio int mask to mask all (except faults)
CPSID I
BX LR
;.thumb_func
CPU_SR_Restore ; See Note #2.
MSR PRIMASK, R0
BX LR
;$PAGE
; WAIT FOR INTERRUPT
; Description : Enters sleep state, which will be exited when an interrupt is received.
; Prototypes : void CPU_WaitForInt (void)
; Argument(s) : none.
;.thumb_func
CPU_WaitForInt
WFI ; Wait for interrupt
BX LR
; WAIT FOR EXCEPTION
; Description : Enters sleep state, which will be exited when an exception is received.
; Prototypes : void CPU_WaitForExcept (void)
;.thumb_func
CPU_WaitForExcept
WFE ; Wait for exception
BX LR
;$PAGE
; CPU_CntLeadZeros()
; COUNT LEADING ZEROS
; Description : Counts the number of contiguous, most-significant, leading zero bits before the
; first binary one bit in a data value.
; Prototype : CPU_DATA CPU_CntLeadZeros(CPU_DATA val);
; Argument(s) : val Data value to count leading zero bits.
; Return(s) : Number of contiguous, most-significant, leading zero bits in 'val'.
; Caller(s) : Application.
; This function is an INTERNAL CPU module function but MAY be called by application
; function(s).
; Note(s) : (1) (a) Supports 32-bit data value size as configured by 'CPU_DATA' (see 'cpu.h
; CPU WORD CONFIGURATION Note #1').
; (b) For 32-bit values :
; b31 b30 b29 ... b04 b03 b02 b01 b00 # Leading Zeros
; 1 x x x x x x x 0
; 0 1 x x x x x x 1
; 0 0 1 x x x x x 2
; 0 0 0 1 x x x x 27
; 0 0 0 0 1 x x x 28
; 0 0 0 0 0 1 x x 29
; 0 0 0 0 0 0 1 x 30
; 0 0 0 0 0 0 0 1 31
; 0 0 0 0 0 0 0 0 32
; (2) MUST be defined in 'cpu_a.asm' (or 'cpu_c.c') if CPU_CFG_LEAD_ZEROS_ASM_PRESENT is
; #define'd in 'cpu_cfg.h' or 'cpu.h'.
;.thumb_func
CPU_CntLeadZeros
CLZ R0, R0 ; Count leading zeros
BX LR
;$PAGE
; CPU_CntTrailZeros()
; COUNT TRAILING ZEROS
; Description : Counts the number of contiguous, least-significant, trailing zero bits before the
; Prototype : CPU_DATA CPU_CntTrailZeros(CPU_DATA val);
; Argument(s) : val Data value to count trailing zero bits.
; Return(s) : Number of contiguous, least-significant, trailing zero bits in 'val'.
; function(s).
; b31 b30 b29 b28 b27 ... b02 b01 b00 # Trailing Zeros
; x x x x x x x 1 0
; x x x x x x 1 0 1
; x x x x x 1 0 0 2
; x x x x 1 0 0 0 27
; x x x 1 0 0 0 0 28
; x x 1 0 0 0 0 0 29
; x 1 0 0 0 0 0 0 30
; 1 0 0 0 0 0 0 0 31
; (2) MUST be defined in 'cpu_a.asm' (or 'cpu_c.c') if CPU_CFG_TRAIL_ZEROS_ASM_PRESENT is
;.thumb_func
CPU_CntTrailZeros
RBIT R0, R0 ; Reverse bits
BX LR
;$PAGE
; CPU_RevBits()
; REVERSE BITS
; Description : Reverses the bits in a data value.
; Prototypes : CPU_DATA CPU_RevBits(CPU_DATA val);
; Argument(s) : val Data value to reverse bits.
; Return(s) : Value with all bits in 'val' reversed (see Note #1).
; This function is an INTERNAL CPU module function but MAY be called by application function(s).
; Note(s) : (1) The final, reversed data value for 'val' is such that :
; 'val's final bit 0 = 'val's original bit N
; 'val's final bit 1 = 'val's original bit (N - 1)
; 'val's final bit 2 = 'val's original bit (N - 2)
; 'val's final bit (N - 2) = 'val's original bit 2
; 'val's final bit (N - 1) = 'val's original bit 1
; 'val's final bit N = 'val's original bit 0
;.thumb_func
CPU_RevBits
BX LR
;$PAGE
; CPU ASSEMBLY PORT FILE END
END
