为什么我如果在一个定时器上用两个中断控制时间的时候,在温度高于27和低于27时,流水灯间隔闪烁的时间一样,都是间隔了1秒?
#include
#define uchar unsigned char
#define uint unsigned int
sbit DS=P2^2;
uint temp;
uchar mm;
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={ 0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
0x87,0xff,0xef};
void delay(uint count)
uint i;
while(count)
i=200;
while(i>0)
i--;
count--;
void dsreset(void)
uint i;
DS=0;
i=103;
while(i>0)i--;
DS=1;
i=4;
while(i>0)i--;
bit tmpreadbit(void)
uint i;
bit dat;
DS=0;i++;
DS=1;i++;i++;
dat=DS;
i=8;while(i>0)i--;
return (dat);
uchar tmpread(void)
uchar i,j,dat;
dat=0;
for(i=1;i<=8;i++)
j=tmpreadbit();
dat=(j<<7)|(dat>>1);
return(dat);
void tmpwritebyte(uchar dat)
uint i;
uchar j;
bit testb;
for(j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if(testb)
DS=0;
i++;i++;
DS=1;
i=8;while(i>0)i--;
else
DS=0;
i=8;while(i>0)i--;
DS=1;
i++;i++;
void tmpchange(void)
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0x44);
uint tmp()
float temp;
uchar a,b;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0xbe);
a=tmpread();
b=tmpread();
// temp=b;
// temp<<=8;
// temp=temp|a;
// tt=temp*0.0625;
// temp=tt*10+0.5;
temp=((b<<8)|a)*(0.0625*10);
return temp;
void readrom()
uchar sn1,sn2;
dsreset();
delay(1);
tmpwritebyte(0x33);
sn1=tmpread();
sn2=tmpread();
void delay10ms(uint z )
uchar a,b;
for(a=10;a>0;a--)
for(b=60;b>0;b--);
void display(uint temp)
uchar A1,A2,A2t,A3;
A1=temp/100;
A2t=temp%100;
A2=A2t/10;
A3=A2t%10;
dula=0;
P0=table[A1];
dula=1;
dula=0;
wela=0;
P0=0xfe;
wela=1;
wela=0;
delay(1);
dula=0;
P0=table1[A2];
dula=1;
dula=0;
wela=0;
P0=0xfd;
wela=1;
wela=0;
delay(1);
P0=table[A3];
dula=1;
dula=0;
P0=0xfb;
wela=1;
wela=0;
delay(1);
void xianshi( )
dula=1;
P0=table[3];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delay10ms(1);
dula=1;
P0=table1[0];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delay10ms(1);
dula=1;
P0=table[0];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delay10ms(1);
void deal()
// if(mm==20)
// mm=0;
if(temp<270)
if(mm==20)
mm=0;
P1=~P1;
else
if(mm==60)
mm=0;
P1=~P1;
// else
// P1=0xff;}
void main()
{ uchar a;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=1;
EA=1;
ET0=1;
do
tmpchange();
for(a=10;a>0;a--)
display(tmp());
xianshi( );
deal();
} while(1);
void time0() interrupt 1
mm++;
// if(temp<300)
// if(mm==20)
// mm=0;
// P1=~P1}
没有注释的代码就是天书呀!问题最好写全面一点,否则也难以理解自然大家就不会去帮你想了!
小伙子,这种东西光贴这么多代码是没用的,你要说清楚,你想干什么,是怎么搞得,然后现象是怎么样,想要的是怎么样,然后个人感觉问题是哪里,然后才把你的关键代码贴出来,记住是关键的,你这些延时,显示什么的,有用吗?
