[数字麦克风] MEMS研究设计创新方案介绍——0.001秒实时3D形貌检测
lyceetec   2017-11-16 14:54 楼主
MEMS Analysis Tool是一个后分析软件。它提供了量化和精确的3D空间和频率分析,时间序列的形貌图(4D),通过DHM®同时拍摄面内和离面运动,离面运动精度达到MEMS激光测振仪精度,面内运动精度则远超MEMS测振仪精度,达到了1nm
MEMS Analysis Tool是基于DHM数字全息显微镜一款软件,数字全息显微镜DHM基于菲涅尔衍射的重建算法,仅需0.001秒采集单张全息图即可得到实时3D形貌信息,无需扫描,在MEMS的设计与研究中有着独特的优势。此外,在形貌检测、形变测量、实时大面积形貌监测等也有广泛应用。
案例:MEMS MicrophoneA MEMS microphone is composed by a diaphragm vibrating between two holed back-plates. Measurement of topography and vibration modes of each of them are challenging :
  • The diaphragm has a one millimeter diameter and has to be measured through the grid of 7 microns diameter holes of the back-plate.
  • The 1 micrometer thin back-plate silicon membranes is transparent for visible and near IR illumination. It is a source of measurement artifacts due to multiple reflection through and by the plates.
MEMS-Acoustic-Devices-Microphone-250kHz-sample2.gif              MEMS-Acoustic-De(11-06-10-25-48)(1).gif MEMS microphone : Diaphragm ⌀1mm, lateral resolution 0.5 µm               Crop : detail of ⌀7 µm back-plate holes
Stitched up measurement in stroboscopic modeStitching algorithms enable to combine multiple individual measurements to produce a high lateral resolution topography map of the microphone over its complete surface. It enables diaphragm characterization through the back-plate holes.
Combining stitching with stroboscopic synchronization acquisition provides a time sequence of both the diaphragm and the back-plates topographies along the excitation period of the microphone. Complete vibration analysis of each of them can be performed.
Movie:
  • Field of view : 1 x 1 mm
  • Lateral resolution : 0.5 μm
  • 32 topographies are recorded along the excitation period
  • 10×10 stitching : each topography measurement has a super high resolution of 30 MpxUV laser sourceThe thin silicon back-plate membranes is totally reflective using a DHM® operating with UV light sources. It prevents from any measurement artifact observed using blue, green, red or NIR wavelengths.
    • Thin silicon membrane (<1 μm)
回复评论 (2)
楼主能具体说说用这个软件分析MEMS的方法吗?
虾扯蛋,蛋扯虾,虾扯蛋扯虾
点赞  2017-11-16 15:42
软件主要是配合硬件全息显微镜进行分析的,全息显微镜测动态形貌和运动参数,软件再做一些运动、共振、形貌分析等
点赞  2017-11-24 11:24
    写回复
