[资料分享] CRC大全以及CRC16代码,针对单片机优化了的
songbo   2008-6-17 13:21 楼主
网站上的算法大都是查512字节表的,对单片机来讲,太浪费空间了。
根据老古网上资料,修改并测试通过以下算法:
unsigned int crc_ta[16]={
0x0000,0x1021,0x2042,0x3063,0x4084,0x50a5,0x60c6,0x70e7,
0x8108,0x9129,0xa14a,0xb16b,0xc18c,0xd1ad,0xe1ce,0xf1ef,
unsigned int Crc16(unsigned char *ptr, unsigned char len)
unsigned int crc;
unsigned char da;
crc=0;
while(len--!=0)
   da=crc>>12;
   crc<<=4;
   crc^=crc_ta[da^(*ptr/16)];
   da=crc>>12;
   crc<<=4;
   crc^=crc_ta[da^(*ptr&0x0f)];
   ptr++;
return(crc);
以下是资料和代码:
回复评论 (4)
回复 楼主 的帖子
我推荐一个简单的
unsigned int fcs_calc(unsigned char *pr)  /* CRC16.c */
{ unsigned int number_of_databytes;
  unsigned int calculate_or_check_crc;
  unsigned int i, j;
  unsigned int fcs;
  number_of_databytes =UsbLength;
  calculate_or_check_crc = CALC_CRC;
  if(calculate_or_check_crc == CALC_CRC)
  { number_of_databytes = UsbLength;  /* 数组长 */
  else    /* check CRC */
  { number_of_databytes = UsbLength + 2;
  fcs = PRESET_VALUE;
  for(i = 1; i < number_of_databytes; i++)
  { fcs = fcs ^ ((unsigned int)(pr));
    for (j = 0; j < 8; j++)
    { if (fcs & 0x0001)
      { fcs = (fcs >> 1) ^ POLYNOMIAL;
      else
      { fcs = (fcs >> 1);
    } /* for j */
  } /* for i */
  fcs = ~fcs;
  return(fcs);
} /* fcs_calc */
点赞  2008-6-17 13:22
学习学习
点赞  2008-6-19 21:31
xiexiexxxxxxxxxxxxxxxxxxxxxxx
点赞  2008-6-24 18:14
谢谢!!!!!!!!!!!!!!!!!!!!
点赞  2008-6-26 13:05
    写回复
