1、 roscore
2、 sudo chmod a+rw /dev/ttyACM0
3、 rosrun rosserial_python serial_node.py /dev/ttyACM0
4、 rosrun turtlesim turtle_teleop_key
代码:::
#include
#include
#include
//定义五中运动状态
#define STOP 0
#define FORWARD 1
#define BACKWARD 2
#define TURNLEFT 3
#define TURNRIGHT 4
//定义需要用到的引脚
int leftMotor1 = 4;
int leftMotor2 = 5;
int rightMotor1 = 6;
int rightMotor2 = 7;
//x轴方向的速度
double lin_vel = 0.0;
//y轴方向的速度
double ang_vel = 0.0;
//定义接受的键
int cmd_ctrl = 0;
//注册ROS节点
ros::NodeHandle nh;
//回调函数
void messageCb(constgeometry_msgs::Twist& vel) {
lin_vel = vel.linear.x;
ang_vel = vel.angular.z;
cmd_ctrl = 1 * lin_vel + 3 * ang_vel;
//设置订阅的消息类型和发布的主题
ros::Subscriber
void setup() {
//put your setup code here, to run once:
//设置控制电机的引脚为输出状态
pinMode(leftMotor1, OUTPUT);
pinMode(leftMotor2, OUTPUT);
pinMode(rightMotor1, OUTPUT);
pinMode(rightMotor2, OUTPUT);
nh.initNode();
nh.subscribe(sub);
void loop() {
//put your main code here, to run repeatedly:
nh.spinOnce();
switch(cmd_ctrl)
case 2:
motorRun(4);
delay(2000);//每个命令执行2s
motorRun(5);
break;
case -2:
motorRun(3);
motorRun(5);
break;
case 6:
motorRun(1);
motorRun(5);
break;
case -6:
motorRun(2);
motorRun(5);
break;
default:
motorRun(5);
break;
cmd_ctrl = 0;
//运动控制函数
void motorRun(int cmd)
switch(cmd){
case FORWARD:
digitalWrite(leftMotor1, LOW);
digitalWrite(leftMotor2, HIGH);
digitalWrite(rightMotor1, LOW);
digitalWrite(rightMotor2, HIGH);
break;
case BACKWARD:
digitalWrite(leftMotor1, HIGH);
digitalWrite(leftMotor2, LOW);
digitalWrite(rightMotor1, HIGH);
digitalWrite(rightMotor2, LOW);
break;
case TURNLEFT:
break;
case TURNRIGHT:
break;
default:
