[求助] 请教下ADUC7060的问题,谢谢!
kami03372   2018-6-14 14:30 楼主
刚上手ADUC7060,调试UART的时候,收发采样查询的方式,都可以操作,
但是想用中断接收,确始终进不了中断~~
int main(void)
        POWKEY1 = 0x1;        //before to write data to POWCON0,must first write 0x01 to the POWKEY1
        POWCON0 = 0x68;                   // Set core to max CPU speed of 10.24Mhz
        POWKEY2 = 0xF4;
        //reset wifi module
        ResetWifi();
        //init uart 115200bps N 8
        GP1CON =0x11;//P1.0,P1.1?
        COMCON0 = BIT7;                        // Enable access to COMDIV registers
        COMDIV0 = 0x02;                        // Set baud rate to 115200.
        COMDIV1 = 0x00;
        COMDIV2 = 0x8b1c;   // Enable fractional divider for more accurate baud rate setting
        COMCON0 = BIT0 + BIT1;
//串口中断接收
        COMIEN0 = BIT0 + BIT1;         // Enable UART interrupts when Rx full and Tx buffer empty.
//        IRQP1 = 0;//priority set
        IRQEN = BIT11; // Enable UART interrupt source
//        IRQCONN = 0x01;//interrupt nesting
        bSendResultToUART = 0;
        Ct_temp = 0;
        while(1)
/*查询模式,可以使用*/
//                if ((COMSTA0 & 0x01) == 0x01)          // If the Rx buffer full bit is set
//                           RecDataTemp = COMRX;                          // read COMRX register
//                     COMTX = RecDataTemp+1;                        // Load Tx buffer
//                          while ((COMSTA0 & 0x40) == 0x00);          // Wait for Tx buffer empty bit to be se
                if(bSendResultToUART)
                        while ((COMSTA0 & 0x40) == 0x00);          // Wait for Tx buffer empty bit to be set
void IRQ_Handler(void) __irq
        IRQSTATUS = IRQSTA;           // Read off IRQSTA register
        ucCOMIID0 = COMIID0;   // Read the UART IRQ ID register
//        if ((IRQSTATUS & BIT11) == BIT11)        //UART interrupt source
        //        if ((ucCOMIID0 & 0x4) == 0x4)          // Receive buffer Full
                        bSendResultToUART = 1;                  // Set flag to return a string to the PC
有用过的朋友,帮忙分析啊
回复评论
暂无评论,赶紧抢沙发吧
    写回复
