[讨论]
单片机控制电子时钟LCD显示C程序.现贴上来,和大家分享一下~~~
/*By wysh
*Date 2008.8.20
#include
#define Lcd_Data P0 //定义八位数据口
#define Busy 0x80 //用于检测LCM状态字中的Busy标识
#define uchar unsigned char
#define uint unsigned int
sbit s1=P2^0; //定义三个按键
sbit s2=P2^1;
sbit s3=P2^2;
sbit Lcd_EN=P1^1;
sbit Lcd_RW=P1^2;
sbit Lcd_RS=P1^3;
char miao,shi,fen,nian,yue,ri,xq; //定义变量
uchar count,s1num;
uchar code table[]=" 2008-08-20 03";//年月日 星期
uchar code table1[]=" 12:00:00"; //时分秒
//通用延时子程序
void delay(uint N)
for(;N>0;N--);
//5ms延时
void Delay5Ms(void)
uchar i=5552;
while(i--);
//LCD检测忙子程序
uchar Lcd_WaitBusy(void)
Lcd_Data = 0xFF;
Lcd_RS = 0;
Lcd_RW = 1;
Lcd_EN = 0;
Lcd_EN = 1;
Lcd_EN = 1;
while (Lcd_Data & Busy); //检测忙信号
Lcd_EN = 0;
return(Lcd_Data); //若不处于忙状态显示字符
//LCD写指令子程序
void Lcd_WriteCmd(uchar W_Cmd,BusyC) //BusyC为0时忽略忙检测
if (BusyC) Lcd_WaitBusy(); //根据需要检测忙
Lcd_Data = W_Cmd;
Lcd_RS = 0;
Lcd_RW = 0;
Lcd_EN = 0;
Lcd_EN = 1; //开始执行写指令
Lcd_EN = 0;
//LCD写数据子程序
void Lcd_WriteData(uchar W_Data)
Lcd_WaitBusy(); //检测忙
Lcd_Data = W_Data;
Lcd_RS = 1;
Lcd_RW = 0;
Lcd_EN = 0; //若晶振速度太高可以在这后加小的延时
Lcd_EN = 1; //开始执行写数据
Lcd_EN = 0;
//LCD初始化子程序
void init()
uchar num;
delay(4000);
Lcd_WriteCmd(0x38,0); //显示模式设置,不检测忙信号
Delay5Ms(); //指令码38H设置16*2显示 5*7点阵 8位数据接口
Delay5Ms();
Lcd_WriteCmd(0x38,1); //显示模式设置,开始要求每次检测忙信号
Lcd_WriteCmd(0x08,1); //关闭显示
Lcd_WriteCmd(0x01,1); //显示清屏 指令码01H显示清屏
Lcd_WriteCmd(0x06,1); // 显示光标移动设置
Lcd_WriteCmd(0x0C,1); // 显示开及光标设置
for(num=0;num<15;num++)
Lcd_WriteData(table[num]);
delay(80);
Lcd_WriteCmd(0x80+0x40); //指令码0x80+0x40设置数据指针地址
for(num=0;num<12;num++)
Lcd_WriteData(table1[num]);
delay(80);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
//写时分秒数据子程序
void Write_Sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
Lcd_WriteCmd(0x80+0x40+add);
Lcd_WriteData(0x30+shi);
Lcd_WriteData(0x30+ge);
//写年月日星期数据子程序
void Write_Nyr(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
Lcd_WriteCmd(0x80+add);
//按键操作子程序
void keyscan()
if(s1==0)
delay(80);
if(s1==0)
s1num++;
while(!s1);
if(s1num==1)
TR0=0;
Lcd_WriteCmd(0x80+0x40+10); //调节秒的数据指针设置在(1,10)坐标处 理解0x80+0x40+10这条指令
Lcd_WriteCmd(0x0f); //即数据指针地址在第二行第11位处
if(s1num==2)
Lcd_WriteCmd(0x80+0x40+7); //调节时的数据指针设置在(1,7)坐标处
if(s1num==3)
Lcd_WriteCmd(0x80+0x40+4); //调节时的数据指针设置在(1,4)坐标处
if(s1num==4)
Lcd_WriteCmd(0x80+13);
if(s1num==5)
Lcd_WriteCmd(0x80+10);
if(s1num==6)
Lcd_WriteCmd(0x80+7);
if(s1num==7)
Lcd_WriteCmd(0x80+4);
if(s1num==8)
s1num=0;
Lcd_WriteCmd(0x0c); //按键4次后 开显示 光标不开不闪烁
TR0=1; //又开始计时
if(s1num!=0)
if(s2==0)
delay(80);
if(s2==0)
while(!s2);
if(s1num==1)
miao++;
if(miao==60)
miao=0;
Write_Sfm(10,miao);
if(s1num==2)
fen++;
if(fen==60)
fen=0;
Write_Sfm(7,fen);
if(s1num==3)
shi++;
if(shi==24)
shi=0;
Write_Sfm(4,shi);
if(s1num==4)
xq++;
if(xq==8)
xq=0;
Write_Nyr(13,xq);
if(s1num==5)
ri++;
if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)
if(ri==32)
ri=0;
else if(yue==2) //注意这里没有考虑闰年
if(ri==29)
ri=0;
else
if(ri==31)
ri=0;
Write_Nyr(10,ri);
if(s1num==6)
yue++;
if(yue==13)
yue=0;
Write_Nyr(7,yue);
if(s1num==7)
nian++;
if(nian==99)
nian=0;
Write_Nyr(4,nian);
if(s3==0)
delay(80);
if(s3==0)
while(!s3);
if(s1num==1)
miao--;
if(miao==-1)
miao=59;
Write_Sfm(10,miao);
if(s1num==2)
fen--;
if(fen==-1)
fen=59;
Write_Sfm(7,fen);
if(s1num==3)
shi--;
if(shi==-1)
shi=23;
Write_Sfm(4,shi);
if(s1num==4)
xq--;
if(xq==-1)
xq=7;
Write_Nyr(13,xq);
if(s1num==5)
ri--;
if(ri==-1)
ri=31;
if(ri==-1)
ri=28;
else
if(ri==-1)
ri=30;
Write_Nyr(10,ri);
if(s1num==6)
yue--;
if(yue==-1)
yue=12;
Write_Nyr(7,yue);
if(s1num==7)
nian--;
if(nian==-1)
nian=99;
Write_Nyr(4,nian);
//主函数
void main()
init();
while(1)
keyscan();
//计时器
void timer0() interrupt 1
count++;
if(count==18)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
ri++;
if(ri==31)
ri=0;
yue++;
xq++;
if(xq==8)
xq=1;
if(yue==12)
yue=0;
nian++;
Write_Nyr(4,nian);
Write_Nyr(7,yue);
Write_Nyr(13,xq);
if(ri==31)
ri=0;
yue++;
xq++;
if(xq==8)
xq=1;
if(yue==12)
yue=0;
nian++;
Write_Nyr(4,nian);
Write_Nyr(7,yue);
Write_Nyr(13,xq);
else
if(ri==31)
ri=0;
yue++;
xq++;
if(xq==8)
xq=1;
if(yue==12)
yue=0;
nian++;
Write_Nyr(4,nian);
Write_Nyr(7,yue);
Write_Nyr(13,xq);
Write_Nyr(10,ri);
Write_Sfm(4,shi);
Write_Sfm(7,fen);
Write_Sfm(10,miao);
/*程序难点就在对LCD1602指令集的认识,这里有不错到资料http://cn.ic-on-line.cn/IOL/datasheet/LCD1602A_398763.pdf,共享一下...另外时期的显示也比较繁琐,其中很多是为了保证全面,因此看起来有很多重复*/
Re: [分享] 单片机控制电子时钟LCD显示C程序.现贴上来,和大家分享一下~~~
不怎么详细,没图可看的!!!
回复 楼主 maker 的帖子
有硬件图没有,楼主
正好借鉴一下
