Linux version 2.4.20-uc0 (root@Local) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 20010318 from http://f (uClinux XIP and shared lib patches from http://www.snapgear.com/)) #20 三 6月 1 8 00:58:31 CST 2003 Processor: Samsung S3C4510B revision 6 Architecture: SNDS100 On node 0 totalpages: 4096 zone(0): 0 pages. zone(1): 4096 pages. zone(2): 0 pages. Kernel command line: root=/dev/rom0 Calibrating delay loop... 49.76 BogoMIPS Memory: 16MB = 16MB total Memory: 14348KB available (1615K code, 156K data, 40K init) Dentry cache hash table entries: 2048 (order: 2, 16384 bytes) Inode cache hash table entries: 1024 (order: 1, Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 4096 (order: 2, 16384 bytes) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd Samsung S3C4510 Serial driver version 0.9 (2001-12-27) with no serial options en abled ttyS00 at 0x3ffd000 (irq = 5) is a S3C4510B ttyS01 at 0x3ffe000 (irq = 7) is a S3C451 Blkmem copyright 1998,1999 D. Jeff Dionne Blkmem copyright 1998 Kenneth Albanowski Blkmem 1 disk images: 0: BE558-1A5D57 [VIRTUAL BE558-1A5D57] (RO) RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize Samsung S3C4510 Ethernet driver version 0.1 (2002-02-20) <mac@os.nctu.edu.tw> eth0: 00:40:95:36:35:34 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 1024) VFS: Mounted root (romfs Freeing init memory: 40K |
Boot loader v0.12 NOTE: this boot loader is designed to boot kernels made with the 2.4.xx releases bootloader for XV Built at Nov 20 2005 10:12:35 |
Loaded to 0x90060000 |
Found boot configuration |
Booted from parallel flash |
CPU clock rate: 200 MHz |
DRAM size is 128MB (128MB/0MB) |
先说明一下内存地址数字情况,主要是为了方便记忆。 可以访问的内存为4G。 0x40000000是1GB处;0x00040000是256K处,0x00020000是128K处,0x90000000是2GB多的地方。 1M->0x00100000, 2M->0x00200000, 8M->0x00800000 16M->0x01000000, 32M->0x02000000 256M->0x10000000 64K->0x00010000 4K->0x00001000 这个是个快速记忆的方法,你可以根据地址中1的位置和其后0的个数来快速知道换算后的地址是在多少兆的地方。比如,1的后面5个0,代表1M的大小,6个0,代表16M,以此类推。 |
ROMFS found at 0x46040000, Volume name = rom 43f291aa |
File linux.bin.gz found |
Unzipping image from 0x4639DE60 to 0x90090000, size = 1316021 |
Inptr = 0x00000014(20) Inflating.... |
Outcnt = 0x0030e7c8(3205064) Final Inptr = 0x001414ad(1316013) Original CRC = 0xcbd73adb Computed CRC = 0xcbd73adb |
Boot kernel at 0x90090000 with ROMFS at 0x46040000 |
Press 'enter' to boot |
Linux version 2.4.22-uc0 (root@local) (gcc version 2.95.3 20010315 (release)) #33 .?1.. 20 12:09:106 |
Found bootloader memory map at 0x10000fc0. |
Processor: ARM pt110 revision 0 |
On node 0 totalpages: 20480 zone(0): 20480 pages. zone(0): Set minimum memory threshold to 12288KB Warning: wrong zone alignment (0x90080000, 0x0000000c, 0x00001000) zone(1): 0 pages. zone(2): 0 pages. |
Kernel command line: root=/dev/mtdblock3 |
Console: colour dummy device 80x30 |
serial_xx: setup_console @ 115 |
Calibrating delay loop... 82.94 BogoMIPS |
Memory: 80MB = 80MB total Memory: 76592KB available (1724K code, 2565K data, 72K init) |
Dentry cache hash table entries: 16384 (order: 5, 131072 bytes) Inode cache hash table entries: 8192 (order: 4, 65536 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 32768 (order: 5, 131072 bytes) |
POSIX conformance testing by UNIFIX |
NET4: Linux TCP/IP 1.0 for NET4.0 |
IP Protocols: ICMP, UDP, TCP, IGMP |
IP: routing cache hash table of 512 buckets, 4Kbytes |
TCP: Hash tables configured (established 8192 bind 8192) |
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. |
cramfs: wrong magic |
2.4 cramfs_read_super(。。。) /* Do sanity checks on the superblock */ if (super.magic != CRAMFS_MAGIC) { /* check at 512 byte offset */ memcpy(&super, cramfs_read(sb, 512, sizeof(super)), sizeof(super)); if (super.magic != CRAMFS_MAGIC) { printk(KERN_ERR "cramfs: wrong magic\n"); goto out; } } |
2.6 if (super.magic != CRAMFS_MAGIC) { if (!silent) printk(KERN_ERR "cramfs: wrong magic\n"); goto out; } |
FAT: bogus logical sector size 21072 |
UMSDOS: msdos_read_super failed, mount aborted. |
VFS: Mounted root (romfs filesystem) readonly |
Mounted devfs on /dev |
Freeing init memory: 72K |
你可以用进程查看命令来验证 # ps aux PID Uid VmSize Stat Command 1 0 SW init 2 0 SW [keventd] 3 0 SWN [ksoftirqd_CPU0] 4 0 SW [kswapd] 5 0 SW [bdflush] 6 0 SW [kupdated] 7 0 SW [rbwdg] 9 0 SW [mtdblockd] 10 0 SW [khubd] 80 0 SW [loop0] |
