[讨论] linux/config.h: No such file or directory解决办法
clark   2010-2-28 17:39 楼主
$ make make -C /lib/modules/2.6.18-1.2798a_FC6/build SUBDIRS=/home/njc/stuff/linux-labjack/driver/linux-2.6 modules make[1]: Entering directory `/usr/src/redhat/BUILD/kernel-2.6.181.2798a_FC6' CC [M] /home/njc/stuff/linux-labjack/driver/linux-2.6/labjack.o /home/njc/stuff/linux-labjack/driver/linux-2.6/labjack.c:43:26: error: linux/config.h: No such file or directory make[2]: *** [/home/njc/stuff/linux-labjack/driver/linux-2.6/labjack.o] Error 1 make[1]: *** [_module_/home/njc/stuff/linux-labjack/driver/linux-2.6] Error 2 make[1]: Leaving directory `/usr/src/redhat/BUILD/kernel-2.6.181.2798a_FC6' make: ***[default] Error 2 A solution, which I based from a discussion in this blog http://www.phoronix.com/redblog/?p=blog&;;i=NTUwMA, would be to copy a config.h header file to your /lib/modules/KERNEL-VERSION/build/include/linux directory. If you have a previous kernel build on your computer you can copy the file from your /lib/modules/OLD-KERNEL-VERSION/build/include/linux directory. Alternatively you can just copy the code below into a self made config.h file CODE #ifndef _LINUX_CONFIG_H #define _LINUX_CONFIG_H #include #endif 转自:嵌入式Android_Linux开发
DIY是一种信仰~~
回复评论
暂无评论,赶紧抢沙发吧
    写回复
