今天是:2025年02月01日(星期六)
2018年02月01日 | STC89C58RD+ 内部EEPROM 放数据 FLASH-ISP-IAP
2018-02-01 来源:eefocus
#include <reg52.h>
#include <intrins.h> /* use _nop_() function */
//sfr16 DPTR = 0x82;
/* 新增特殊功能寄存器定义 */
sfr ISP_DATA = 0xe2;
sfr ISP_ADDRH = 0xe3;
sfr ISP_ADDRL = 0xe4;
sfr ISP_CMD = 0xe5;
sfr ISP_TRIG = 0xe6;
sfr ISP_CONTR = 0xe7;
/* 定义命令 */
#define READ_AP_and_Data_Memory_Command 0x01 /* 字节读数据存储区 */
#define PROGRAM_AP_and_Data_Memory_Command 0x02 /* 字节编程数据存储区 */
#define SECTOR_ERASE_AP_and_Data_Memory_Command 0x03 /* 扇区擦除数据存储区 */
typedef unsigned char INT8U; /* 8 bit 无符号整型 */
typedef unsigned int INT16U; /* 16 bit 无符号整型 */
#define DELAY_CONST 60000
/* 定义常量 */
#define ERROR 0
#define OK 1
sbit Begin_LED = P1^0;
sbit ERROR_LED = P1^3;
sbit OK_LED = P1^7;
/* 定义Flash 操作等待时间 */
#define MCU_CLOCK_40MHz
//#define MCU_CLOCK_20MHz
//#define MCU_CLOCK_10MHz
//#define MCU_CLOCK_5MHz
#ifdef MCU_CLOCK_40MHz
#define WAIT_TIME 0x00
#endif
#ifdef MCU_CLOCK_20MHz
#define WAIT_TIME 0x01
#endif
#ifdef MCU_CLOCK_10MHz
#define WAIT_TIME 0x02
#endif
#ifdef MCU_CLOCK_5MHz
#define WAIT_TIME 0x03
#endif
/* 调试控制项 */
//#define DEBUG_STC89C_LE58RD+
#define DEBUG_STC89C_LE52RC
//#define USED_BYTE_QTY_IN_ONE_SECTOR 1
//#define USED_BYTE_QTY_IN_ONE_SECTOR 2
//#define USED_BYTE_QTY_IN_ONE_SECTOR 4
//#define USED_BYTE_QTY_IN_ONE_SECTOR 8
//#define USED_BYTE_QTY_IN_ONE_SECTOR 16
//#define USED_BYTE_QTY_IN_ONE_SECTOR 32
//#define USED_BYTE_QTY_IN_ONE_SECTOR 64
#define USED_BYTE_QTY_IN_ONE_SECTOR 128
//#define USED_BYTE_QTY_IN_ONE_SECTOR 256
//#define USED_BYTE_QTY_IN_ONE_SECTOR 512
INT8U xdata protect_buffer[USED_BYTE_QTY_IN_ONE_SECTOR];
#ifdef DEBUG_STC89C_LE58RD+ //STC89C58RD+, 89LE58RD+
#define DEBUG_AP_Memory_Begin_Sector_addr 0x0000
#define DEBUG_AP_Memory_End_Sector_addr 0x7e00
#define DEBUG_AP_Memory_End_Byte_addr 0x7fff
#define DEBUG_Data_Memory_Begin_Sector_addr 0x8000
#endif
#ifdef DEBUG_STC89C_LE52RC //STC89C52RC, 89LE52RC
#define DEBUG_AP_Memory_End_Sector_addr 0x1e00
#define DEBUG_AP_Memory_End_Byte_addr 0x1fff
#define DEBUG_Data_Memory_Begin_Sector_addr 0x2000
#endif
/* 打开 ISP,IAP 功能 */
void ISP_IAP_enable(void)
EA = 0; /* 关中断 */
ISP_CONTR = ISP_CONTR & 0x18; /* 0001,1000 */
ISP_CONTR = ISP_CONTR | WAIT_TIME;
ISP_CONTR = ISP_CONTR | 0x80; /* 1000,0000 */
/* 关闭 ISP,IAP 功能 */
void ISP_IAP_dISAble(void)
ISP_CONTR = ISP_CONTR & 0x7f; /* 0111,1111 */
ISP_TRIG = 0x00;
EA = 1; /* 开中断 */
/* 字节读 */
INT8U byte_read(INT16U byte_addr)
ISP_ADDRH = (INT8U)(byte_addr >> 8);
ISP_ADDRL = (INT8U)(byte_addr & 0x00ff);
ISP_CMD = ISP_CMD & 0xf8; /* 1111,1000 */
ISP_CMD = ISP_CMD | READ_AP_and_Data_Memory_Command; /* 0000,0001 */
ISP_IAP_enable();
ISP_TRIG = 0x46;
ISP_TRIG = 0xb9;
_nop_();
ISP_IAP_disable();
return (ISP_DATA);
/* 扇区擦除 */
INT8U sector_erase(INT16U sector_addr)
INT16U get_sector_addr = 0;
get_sector_addr = (sector_addr & 0xfe00); /* 1111,1110,0000,0000; 取扇区地址 */
ISP_ADDRH = (INT8U)(get_sector_addr >> 8);
ISP_ADDRL = 0x00;
ISP_CMD = ISP_CMD | SECTOR_ERASE_AP_and_Data_Memory_Command; /* 0000,0011 */
ISP_IAP_enable();
ISP_TRIG = 0x46; /* 触发ISP_IAP命令 */
ISP_TRIG = 0xb9; /* 触发ISP_IAP命令 */
_nop_();
ISP_IAP_disable();
return OK;
/* 字节编程 */
INT8U byte_program(INT16U byte_addr, INT8U original_data)
ISP_CMD = ISP_CMD | PROGRAM_AP_and_Data_Memory_Command; /* 0000,0010 */
ISP_DATA = original_data;
ISP_IAP_enable();
_nop_();
ISP_IAP_disable();
return OK;
/* 字节编程并校验 */
INT8U byte_program_and_verify(INT16U byte_addr, INT8U original_data)
ISP_IAP_enable();
ISP_TRIG = 0x46;
ISP_TRIG = 0xb9;
_nop_();
ISP_DATA = 0x00;
_nop_();
ISP_IAP_disable();
if(ISP_DATA == original_data)
return OK;
else
return ERROR;
/* 写数据进 数据Flash存储器, 只在同一个扇区内写,不保留原有数据 */
/* begin_addr,被写数据Flash开始地址;counter,连续写多少个字节; array[],数据来源 */
INT8U sequential_write_flash_in_one_sector(INT16U begin_addr, INT16U counter, INT8U array[])
INT16U i = 0;
INT16U in_sector_begin_addr = 0;
INT16U sector_addr = 0;
/* 判是否是有效范围,此函数不允许跨扇区操作 */
if(counter > USED_BYTE_QTY_IN_ONE_SECTOR)
return ERROR;
in_sector_begin_addr = begin_addr & 0x01ff; /* 0000,0001,1111,1111 */
if( (in_sector_begin_addr + counter) > USED_BYTE_QTY_IN_ONE_SECTOR )
return ERROR;
/* 擦除 要修改/写入 的扇区 */
sector_addr = (begin_addr & 0xfe00); /* 1111,1110,0000,0000; 取扇区地址 */
ISP_ADDRH = (INT8U)(sector_addr >> 8);
ISP_ADDRL = 0x00;
ISP_IAP_enable();
_nop_();
for(i = 0; i< counter; i++)
/* 写一个字节 */
ISP_ADDRH = (INT8U)(begin_addr >> 8);
ISP_ADDRL = (INT8U)(begin_addr & 0x00ff);
ISP_DATA = array[i];
_nop_();
/* 读回来 */
ISP_DATA = 0x00;
_nop_();
/* 比较对错 */
if(ISP_DATA != array[i])
ISP_IAP_disable();
return ERROR;
begin_addr++;
ISP_IAP_disable();
return OK;
/* 写数据进数据Flash存储器(EEPROM), 只在同一个扇区内写,保留同一扇区中不需修改的数据 */
INT8U write_flash_with_protect_in_one_sector(INT16U begin_addr, INT16U counter, INT8U array[])
INT16U i = 0;
INT16U byte_addr = 0;
return ERROR;
/* 假定从扇区的第0个字节开始,到USED_BYTE_QTY_IN_ONE_SECTOR-1个字节结束,后面部分不用,程序易编写 */
return ERROR;
/* 将该扇区数据 0 - (USED_BYTE_QTY_IN_ONE_SECTOR-1) 字节数据读入缓冲区保护 */
byte_addr = sector_addr; /* 扇区地址为扇区首字节地址 */
ISP_IAP_enable();
for(i = 0; i < USED_BYTE_QTY_IN_ONE_SECTOR; i++)
ISP_TRIG = 0x46;
ISP_TRIG = 0xb9;
_nop_();
protect_buffer[i] = ISP_DATA;
byte_addr++;
/* 将要写入的数据写入保护缓冲区的相应区域,其余部分保留 */
for(i = 0; i < counter; i++)
protect_buffer[in_sector_begin_addr] = array[i];
in_sector_begin_addr++;
/* 擦除 要修改/写入 的扇区 */
ISP_ADDRL = 0x00;
_nop_();
/* 将保护缓冲区的数据写入 Data Flash, EEPROM */
for(i = 0; i< USED_BYTE_QTY_IN_ONE_SECTOR; i++)
/* 写一个字节 */
ISP_DATA = protect_buffer[i];
_nop_();
/* 读回来 */
ISP_DATA = 0x00;
_nop_();
/* 比较对错 */
if(ISP_DATA != protect_buffer[i])
ISP_IAP_disable();
return ERROR;
byte_addr++;
ISP_IAP_disable();
return OK;
/* 测试常量数组 */
INT8U code Test_array_total[512] =
0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f,
0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17,
0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f,
0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27,
0x28, 0x29, 0x2a, 0x2b, 0x2c, 0x2d, 0x2e, 0x2f,
0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37,
0x38, 0x39, 0x3a, 0x3b, 0x3c, 0x3d, 0x3e, 0x3f,
0x40, 0x41, 0x42, 0x43, 0x44, 0x45, 0x46, 0x47,
0x48, 0x49, 0x4a, 0x4b, 0x4c, 0x4d, 0x4e, 0x4f,
0x50, 0x51, 0x52, 0x53, 0x54, 0x55, 0x56, 0x57,
0x58, 0x59, 0x5a, 0x5b, 0x5c, 0x5d, 0x5e, 0x5f,
0x60, 0x61, 0x62, 0x63, 0x64, 0x65, 0x66, 0x67,
0x68, 0x69, 0x6a, 0x6b, 0x6c, 0x6d, 0x6e, 0x6f,
0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77,
0x78, 0x79, 0x7a, 0x7b, 0x7c, 0x7d, 0x7e, 0x7f,
0x80, 0x81, 0x82, 0x83, 0x84, 0x85, 0x86, 0x87,
0x88, 0x89, 0x8a, 0x8b, 0x8c, 0x8d, 0x8e, 0x8f,
0x90, 0x91, 0x92, 0x93, 0x94, 0x95, 0x96, 0x97,
0x98, 0x99, 0x9a, 0x9b, 0x9c, 0x9d, 0x9e, 0x9f,
0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6, 0xa7,
0xa8, 0xa9, 0xaa, 0xab, 0xac, 0xad, 0xae, 0xaf,
0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5, 0xb6, 0xb7,
0xb8, 0xb9, 0xba, 0xbb, 0xbc, 0xbd, 0xbe, 0xbf,
0xc0, 0xc1, 0xc2, 0xc3, 0xc4, 0xc5, 0xc6, 0xc7,
0xc8, 0xc9, 0xca, 0xcb, 0xCC, 0xcd, 0xce, 0xcf,
0xd0, 0xd1, 0xd2, 0xd3, 0xd4, 0xd5, 0xd6, 0xd7,
0xd8, 0xd9, 0xda, 0xdb, 0xdc, 0xdd, 0xde, 0xdf,
0xe0, 0xe1, 0xe2, 0xe3, 0xe4, 0xe5, 0xe6, 0xe7,
0xe8, 0xe9, 0xea, 0xeb, 0xec, 0xed, 0xee, 0xef,
0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5, 0xf6, 0xf7,
0xf8, 0xf9, 0xfa, 0xfb, 0xfc, 0xfd, 0xfe, 0xff,
0xff, 0xfe, 0xfd, 0xfc, 0xfb, 0xfa, 0xf9, 0xf8,
0xf7, 0xf6, 0xf5, 0xf4, 0xf3, 0xf2, 0xf1, 0xf0,
0xef, 0xee, 0xed, 0xec, 0xeb, 0xea, 0xe9, 0xe8,
0xe7, 0xe6, 0xe5, 0xe4, 0xe3, 0xe2, 0xe1, 0xe0,
0xdf, 0xde, 0xdd, 0xdc, 0xdb, 0xda, 0xd9, 0xd8,
0xd7, 0xd6, 0xd5, 0xd4, 0xd3, 0xd2, 0xd1, 0xd0,
0xcf, 0xce, 0xcd, 0xcc, 0xcb, 0xca, 0xc9, 0xc8,
0xc7, 0xc6, 0xc5, 0xc4, 0xc3, 0xc2, 0xc1, 0xc0,
0xbf, 0xbe, 0xbd, 0xbc, 0xbb, 0xba, 0xb9, 0xb8,
0xb7, 0xb6, 0xb5, 0xb4, 0xb3, 0xb2, 0xb1, 0xb0,
0xaf, 0xae, 0xad, 0xac, 0xab, 0xaa, 0xa9, 0xa8,
0xa7, 0xa6, 0xa5, 0xa4, 0xa3, 0xa2, 0xa1, 0xa0,
0x9f, 0x9e, 0x9d, 0x9c, 0x9b, 0x9a, 0x99, 0x98,
0x97, 0x96, 0x95, 0x94, 0x93, 0x92, 0x91, 0x90,
0x8f, 0x8e, 0x8d, 0x8c, 0x8b, 0x8a, 0x89, 0x88,
0x87, 0x86, 0x85, 0x84, 0x83, 0x82, 0x81, 0x80,
0x7f, 0x7e, 0x7d, 0x7c, 0x7b, 0x7a, 0x79, 0x78,
0x77, 0x76, 0x75, 0x74, 0x73, 0x72, 0x71, 0x70,
0x6f, 0x6e, 0x6d, 0x6c, 0x6b, 0x6a, 0x69, 0x68,
0x67, 0x66, 0x65, 0x64, 0x63, 0x62, 0x61, 0x60,
0x5f, 0x5e, 0x5d, 0x5c, 0x5b, 0x5a, 0x59, 0x58,
0x57, 0x56, 0x55, 0x54, 0x53, 0x52, 0x51, 0x50,
0x4f, 0x4e, 0x4d, 0x4c, 0x4b, 0x4a, 0x49, 0x48,
0x47, 0x46, 0x45, 0x44, 0x43, 0x42, 0x41, 0x40,
0x3f, 0x3e, 0x3d, 0x3c, 0x3b, 0x3a, 0x39, 0x38,
0x33, 0x36, 0x35, 0x34, 0x33, 0x32, 0x31, 0x30,
0x2f, 0x2e, 0x2d, 0x2c, 0x2b, 0x2a, 0x29, 0x28,
0x27, 0x26, 0x25, 0x24, 0x23, 0x22, 0x21, 0x20,
0x1f, 0x1e, 0x1d, 0x1c, 0x1b, 0x1a, 0x19, 0x18,
0x17, 0x16, 0x15, 0x14, 0x13, 0x12, 0x11, 0x10,
0x0f, 0x0e, 0x0d, 0x0c, 0x0b, 0x0a, 0x09, 0x08,
0x07, 0x06, 0x05, 0x04, 0x03, 0x02, 0x01, 0x00
void display_Begin_LED(void)
Begin_LED = 0; /* Begin_LED on */
void off_Begin_LED(void)
Begin_LED = 1; /* Begin_LED off */
void display_OK_LED(void)
OK_LED = 0; /* OK_LED on */
void off_OK_LED(void)
OK_LED = 1; /* OK_LED off */
void display_ERROR_LED(void)
ERROR_LED = 0; /* ERROR_LED on */
void off_ERROR_LED(void)
ERROR_LED = 1; /* ERROR_LED off */
void delay(INT16U counter)
INT16U temp = 0;
for(temp = counter; temp>0; temp--)
_nop_();
_nop_();
_nop_();
void main()
//sbit Begin_LED = P1^0;
//sbit ERROR_LED = P1^3;
//sbit OK_LED = P1^7;
display_Begin_LED();
delay(DELAY_CONST);
sector_erase(DEBUG_Data_Memory_Begin_Sector_addr);
if(byte_program_and_verify(DEBUG_Data_Memory_Begin_Sector_addr,0x55) == OK)
display_OK_LED();
else
display_ERROR_LED();
if(sequential_write_flash_in_one_sector(DEBUG_Data_Memory_Begin_Sector_addr, USED_BYTE_QTY_IN_ONE_SECTOR, Test_array_total))
display_OK_LED();
else
if(write_flash_with_protect_in_one_sector(DEBUG_Data_Memory_Begin_Sector_addr+0x3, USED_BYTE_QTY_IN_ONE_SECTOR-0x30, Test_array_total))
display_OK_LED();
else
while(1);
我在2440上移植了DM9000A的网卡,系统运行后能够被PING通。可是一运行IE就报如下错误: Data Abort: Thread=97d9aab4 Proc=81d96340 \'device.exe\' AKY=ffffffff PC=02b52178(dm9isa.dll+0x00002178) RA=02b52174(dm9isa.dll+0x00002174) BVA=06 ...… 查看全部问答> |
我现在需要用到2051接收来自PC的数据(长度不定,但长度信息是在接收的第一个字节里),打算用方式1,定时器2,串口超时了就表示接收已经完成,现在问题是:如何实现串口的超时处理? 是用另外一个定时器?还是在等待RI的过程中DJNZ某数以实现计时 ...… 查看全部问答> |
arm-linux平台上摄像头 quick capture interface的中断问题 我需要在pxa271平台上通过quick capture interface来获取摄像头图像,程序是从别的操作系统移植过来的,所以CIF寄存器初始化设置的逻辑应该没有问题,现在的问题是只要我设置了Start of Frame的中断,即 CICR0置位 ~(CICR0_SOFM), 再enable CIF接 ...… 查看全部问答> |
源例程,寻求帮助!!!谢谢 GPIO管脚能否配置采样速率? [ 本帖最后由 bjmonsoon 于 2011-1-13 19:35 编辑 ]… 查看全部问答> |
我在PB5.0下要修改代码,但是有的函数在其他文件里(例如在根目录下),我想看一下某个函数的实现体,我在函数上点击右键选择Go To Definition of \"函数名\", 但是出现对话框说要去project中的setting中设置, 我 ...… 查看全部问答> |
需要用5438产生一个64khz的方波,还要以8khz的频率采集电压,AD用的是内部自带的,同时每隔1m采集一次温度,在使用中断的时候,主函数里开启全局中断,但是定时器中断里要是不再打开中断的话,会只有定时器中断工作。但是要是定时器中断里使能全局 ...… 查看全部问答> |
