今天是:2025年02月01日(星期六)
2018年02月01日 | STC12C5A60S2 AD转换示例程序
2018-02-01 来源:eefocus
#include
#define uint   unsigned int
#define uchar unsigned char
sbit CS=P2^0;         //LCD12864串行通信片选
sbit SID=P2^1;         //LCD12864串行通信数据口
sbit SCLK=P2^2;         //LCD12864串行通信同步时钟信号
sbit PSB=P2^5;         //LCD12864并/串选择:H并行 L串行
unsigned int temp1,sh1,ge1,n1,m1;
unsigned char ad_result_data[10];   //AD转换高八位
unsigned char ad_result_low2[10];   //AD转换低八位
unsigned char ad_result_total[10];   //AD转换总十位
unsigned char ad_average_result;   //AD转换十次的平均值
unsigned char Ain,Vin;
unsigned char b,t,R;
char tp=0;
unsigned char code ma1[6]={0xb5,0xe7,0xd1,0xb9,0xa1,0xc3}; //电压:
unsigned char code ma2[]={"."};
uchar code disp1[]={"提示: 按1 键进入"};
uchar code disp2[]={"功能选择界面. "};
unsigned char code num0[]={0xa3,0xb0};
unsigned char code num1[]={0xa3,0xb1};
unsigned char code num2[]={0xa3,0xb2};
unsigned char code num3[]={0xa3,0xb3};
unsigned char code num4[]={0xa3,0xb4};
unsigned char code num5[]={0xa3,0xb5};
unsigned char code num6[]={0xa3,0xb6};
unsigned char code num7[]={0xa3,0xb7};
unsigned char code num8[]={0xa3,0xb8};
unsigned char code num9[]={0xa3,0xb9};
//-------模块延时程序---------------------------- 1ms
void delay1ms(uint delay1ms) //STC11F60XE,22.1184M,延时1ms
uint i,j;
for(;delay1ms>0;delay1ms--)
   for(i=0;i<7;i++)
     for(j=0;j<210;j++);
void delay(uint delay) //STC11F60XE,22.1184M,延时170us
uint i,j;
for(;delay>0;delay--)
   for(i=0;i<124;i++);
     for(j=0;j<124;j++);
                  AD转换程序
void AD_initiate() //初始化函数
ES=0;
TMOD=0x21; //定时计数器方式控制寄存器,"自动重装,16位计数器".
SCON=0x50; //串行控制寄存器,方便在串口助手那观察
TH1=0xfa;
TL1=0xfa;
TR1=1;
void ADC_Power_On()      //AD转换电
ADC_CONTR|=0x80;
delay(5);     //必要的延时
void get_ad_result() //取AD结果函数,它是十位AD转换,每十次平均,最后取低八位作为AD采样数据
uint i,q=0;
for(i=0;i<10;i++)
       tp=0;
       ADC_RES=0;     //高八位数据清零,STC12C5A60S2 AD数据寄存名与STC12C54××系列不同
    ADC_RESL=0;    //低两位清零
       ADC_CONTR|=0x08; //启动AD转换
       while(!tp)     //判断AD转换是否完成
           tp=0x10;
           tp&=ADC_CONTR;
      ADC_CONTR&=0xe7;
   ad_average_result=ADC_RES;
   q=q+ad_average_result;
   ad_average_result=q/10;
   //ad_average_result=ad_average_result*4*5000/1024;
/************************AD转换结束***********************/
void send_ad_result() //取AD结果函数发送到串口,方便调试
   SBUF=n1;
   while(TI==0) ;
    TI=0;
   delay1ms(100);
   //SBUF=R>>4;
//---------------------电压采样程序-------------------------
void caiyangP10()     //测电压
P1M0|=0x01;         //设P1_0为开漏模式 如: P1_0= #00000000B
P1M1|=0x01;
ADC_CONTR=0xe0;   //设置P1.0为输入AD转换口
delay(2);
get_ad_result();        //取转换数据
Vin=ad_average_result;
R=Vin;
/*-----------写控制字到LCD12864------------*/
void write_cmd(uchar cmd)
uchar i;
uchar i_data;
i_data=0xf8;          //命令控制字:11111000写指令 11111010写数据 11111100读状态 11111110读数据
CS=1;          //片选置高,才能进行读写操作
SCLK=0;
/*----------写命令控制字-----------------*/
for(i=0;i<8;i++)       //循环八次,每次读取一位数据
   SID=(bit)(i_data&0x80);     //bit表示取其最高位
   SCLK=0;
   SCLK=1;         //正跳变写入指令
   i_data=i_data<<1;      //左移一位
/*----------写指令高四位-----------------*/
i_data=cmd;
i_data=i_data&0xf0;       //把低四位置0
   SCLK=0;
   SCLK=1;         //正跳变写入指令
/*----------写指令低四位-----------------*/
i_data=cmd;
i_data=i_data<<4;       //左移四位,把低四位的数据移到高四位,再把低四位置0
   SCLK=0;
   SCLK=1;        //正跳变写入指令
CS=0;         //把片选置低
delay1ms(5);       //延时是因为没有进行忙检测,适当的延时可以不进行忙检测
/*------------写数据到LCD12864-------------*/
void write_dat(uchar dat)
uchar i;
uchar i_data;
i_data=0xfa;
CS=1;
for(i=0;i<8;i++)
   SCLK=0;
   SCLK=1;
   i_data=i_data<<1;
i_data=dat;
i_data=i_data&0xf0;
for(i=0;i<8;i++)
   SCLK=0;
   SCLK=1;
   i_data=i_data<<1;
i_data=dat;
i_data=i_data<<4;
for(i=0;i<8;i++)
   SCLK=0;
   SCLK=1;
   i_data=i_data<<1;
CS=0;
delay1ms(5);
/*--------------显示坐标-------------------*/
void lcd_pos(uchar x,uchar y)      //汉字显示坐标,x为哪一行,y为哪一列
uchar pos;
if(x==0)
   x=0x80;         //第一行
else if(x==1)
   x=0x90;         //第二行
else if(x==2)
   x=0x88;         //第三行
else if(x==3)
   x=0x98;         //第四行
pos=x+y;         //显示哪一行(总共有4行)哪一竖(总共有8竖,每16列为1竖)
write_cmd(pos);
/*--------------显示8个汉字-------------------*/
void disp_hanzi(uchar code *chn)
   uchar i;
   write_cmd(0x30);    //基本指令操作方式
   for(i=0;i<16;i++)   //16列*8个汉字=128(刚好)
       write_dat(chn[i]);
/*--------------显示数字-------------------*/
void disp_num(uchar code *chn)
uchar i;
   for(i=0;i<2;i++)      //1个数字
       write_dat(chn[i]);
void disp_number(uchar num)
   switch(num)
case 0: disp_num(num0);break;
case 1: disp_num(num1);break;
case 2: disp_num(num2);break;
case 3: disp_num(num3);break;
case 4: disp_num(num4);break;
case 5: disp_num(num5);break;
     case 6: disp_num(num6);break;
case 7: disp_num(num7);break;
case 8: disp_num(num8);break;
case 9: disp_num(num9);break;
default: break;
/*----------- --LCD初始化------------------*/
void lcd_init()
PSB=0;
write_cmd(0x02);       //地址归位
write_cmd(0x06);       //游标右移
write_cmd(0x0c);       //整体显示
write_cmd(0x01);       //清屏
void displayP10()
float ad1;
//unsigned int temp1,sh1,ge1,n1,m1;
//uchar code dis2[]={0x01,0x02,0x00};
//ad1=x*7.8125;   //电压修正
uchar i;
ad1=Vin*3.9608;   //具体线性参数由输入电压值调整,该值的测量范围为0-10.00V,5V左右的测量比较准确,
                      //两端的最大误差为70mv,其他一般在40mv以内
temp1=(int)ad1;
sh1=temp1/1000;    //十位
ge1=(temp1%1000)/100;   //个位
n1=((temp1%1000)%100)/10; //小数点后一位
m1=((temp1%1000)%100)%10; //小数点后二位
//write_cmd(0x01);
lcd_pos(0,0);
   for(i=0;i<6;i++)        write_dat(ma1[i]);
lcd_pos(0,3);
disp_number(sh1);
lcd_pos(0,4);
disp_number(ge1);
lcd_pos(0,5);
for(i=0;i<2;i++)    write_dat(ma2[i]);
lcd_pos(0,6);
disp_number(n1);
lcd_pos(0,7);
disp_number(m1);
/*lcd_pos(2,0);
disp_hanzi(disp1);
lcd_pos(3,0);
disp_hanzi(disp2);*/
void main()
     EA=1;
AD_initiate();   //初始化
ADC_Power_On();     //开AD电源
//init();
lcd_init();
delay(10);
while(1)
     caiyangP10();    //测电压
     send_ad_result();
   //Vin=Vin*4007;
   displayP10();
   delay(10);
AVG [AVG Semiconductors(HITEK)]公司的发展小趣事
AVG Semiconductors自创立之初,就始终坚持以技术创新为核心竞争力。公司不断投入研发资源,推出了一系列具有划时代意义的半导体产品。其中,AVG的某款高效能低功耗芯片在市场上引起了广泛关注,其独特的节能设计和卓越的性能使得AVG在激烈的市场竞争中脱颖而出。这款芯片的成功不仅提升了AVG的品牌形象,也为公司带来了可观的收益,进一步推动了公司的研发创新步伐。
广州盛炬(GZSJ)公司的发展小趣事
上海晶岳(AFSEMI)公司的发展小趣事
上海晶岳电子有限公司自2010年成立以来,就将目标锁定在60V以下MOSFET产品线及锂电池保护IC系列产品。在公司创始人的领导下,晶岳电子团队凭借对技术的深入理解和市场的敏锐洞察,迅速在行业中崭露头角。他们不仅注重产品的研发和设计,还积极与上下游企业合作,优化供应链,确保产品质量和交货期的稳定。经过几年的努力,晶岳电子在MOSFET领域建立了良好的口碑,为后续的发展奠定了坚实的基础。
FOX [Fox Electronics]公司的发展小趣事
随着全球对环保和可持续发展的重视,Fox Electronics积极响应行业趋势,将绿色生产理念融入企业运营中。公司投资引进先进的环保设备和生产工艺,减少生产过程中的废弃物排放和能源消耗。同时,Fox Electronics还推出了一系列符合RoHS(限制有害物质)指令的产品,满足市场对环保产品的需求。这些举措不仅提升了公司的社会责任感,也为其在绿色电子市场赢得了良好的声誉。
广州奥松公司的发展小趣事
奥松电子拥有一支近200名工程师组成的专职研发团队,并配备了超过7000㎡的研发实验室。实验室中配置了步进式投影光刻机、双面光刻机等先进设备,为公司的产品研发提供了有力的支持。这些设备不仅满足了产品研发、小试以及中试各个阶段的试验条件,也为公司的技术创新提供了坚实的基础。
东通电子公司的发展小趣事
深圳市东通电子有限公司(以下简称“东通电子”)成立于1998年5月,最初主要涉足电子元器件的生产和销售。随着市场的不断变化和技术的飞速发展,公司意识到仅仅依靠传统业务已无法满足市场需求。于是,在2002年,东通电子决定将重心转向有机薄膜电容器的研发和生产。这一转型为公司的后续发展奠定了坚实的基础。
音乐集成FD9300是什么样的芯片?
请教音乐集成FD9300是什么样的芯片?有谁知道管脚排列及功能?…
你有意念移物能力吗
恐怖电影里经常出现这样的场面:物体咯咯作响、好像长腿似的移动起来,甚至在空中呼啸而过。一些人能够用思维影响物质的说法已存在了几百年,从移动家具到把勺子“看”弯,但是对这种现象的调查却一直存在争议。在普林斯顿大学从事全球意识研究计 ...…
DSP C语言入门谈
年初到现在,接触DSP已经半年了,由于公司没有人指导,做了这么久都没出什么大的成果,也走了不少的弯路。以前做单片机用C编过一些程序,个人觉得还可以。现在看来也只是在吃以前在学校里面一些C语言皮毛的老本,加上一些网上说的所谓的技巧什么的 ...…
请问ROM/bin文件的格式是什么如何被执行处理的?
请问ROM/bin文件的格式是什么如何执行处理的? 例如在【显示设置】中的 1234512345,在手机/MP4的ROM中发现是DF5FBBB9BA的,请问做了那些处理?变换的方式是什么? 二进制的: 1234512345 0001 0010 0011 0100 0101 0001 0010 0011 0100 01 ...…
想找个兼职,VC、单片机、arm嵌入式开发
想找个兼职,VC、单片机、arm嵌入式开发 作过基于microchip系列、msp430系列、S3C44B0、AT91RM9200、ST710等mcu的项目, 包括电力系统监控、税控等行业. 可承担四层板电路设计,底层嵌入式程序设计及上位机配套程序编写。 13816950690 msn:xh_du ...…
安捷伦武汉招聘销售工程师!
安捷伦武汉招聘销售工程师! Job Title                         Sales Engineer Type                &n ...…
初学者请教个中断的问题,谢谢!
电平触发方式的中断不是应该保持中断状态么?咋我这个接地之后只是变化的慢了而不是完全不动呢? #include void delay(unsigned int z); //延迟子程序声明 sbit dula=P1^0; //段锁位 sbit A1=P2^2; sbit B1=P2^3; sbit C1=P2^4; ...…
有没有做过1G采样系统的PCB
有没有做过1G采样系统的PCB啊?不知道现在做的这样高频的人多不多?技术怎么样啊?…
MSP430开发板用途
我学习这款单片机主要的用途是用了调试CC2500模块,学会怎么调试和配置那个模块,主要用来传输DMX512信号数据;…
