今天是:2025年04月15日(星期二)
2018年04月15日 | ARM9的系统时钟和串口(非流控 + 非FIFO + 查询方式)
2018-04-15 来源:eefocus
实验的目的:
设置系统时钟,并在串口上输入一个字符,单板接收后将它的ASCII值加1后,从串口输出。
实验的源程序:
s3c24xx.h
/* WOTCH DOG register */
#define WTCON (*(volatile unsigned long *)0x53000000)
/* SDRAM regisers */
#define MEM_CTL_BASE 0x48000000
#define SDRAM_BASE 0x30000000
/* NAND Flash registers */
#define NFCONF (*(volatile unsigned int *)0x4e000000)
#define NFCMD (*(volatile unsigned char *)0x4e000004)
#define NFADDR (*(volatile unsigned char *)0x4e000008)
#define NFDATA (*(volatile unsigned char *)0x4e00000c)
#define NFSTAT (*(volatile unsigned char *)0x4e000010)
/*GPIO registers*/
#define GPBCON (*(volatile unsigned long *)0x56000010)
#define GPBDAT (*(volatile unsigned long *)0x56000014)
#define GPFCON (*(volatile unsigned long *)0x56000050)
#define GPFDAT (*(volatile unsigned long *)0x56000054)
#define GPFUP (*(volatile unsigned long *)0x56000058)
#define GPGCON (*(volatile unsigned long *)0x56000060)
#define GPGDAT (*(volatile unsigned long *)0x56000064)
#define GPGUP (*(volatile unsigned long *)0x56000068)
#define GPHCON (*(volatile unsigned long *)0x56000070)
#define GPHDAT (*(volatile unsigned long *)0x56000074)
#define GPHUP (*(volatile unsigned long *)0x56000078)
/*UART registers*/
#define ULCON0 (*(volatile unsigned long *)0x50000000)
#define UCON0 (*(volatile unsigned long *)0x50000004)
#define UFCON0 (*(volatile unsigned long *)0x50000008)
#define UMCON0 (*(volatile unsigned long *)0x5000000c)
#define UTRSTAT0 (*(volatile unsigned long *)0x50000010)
#define UTXH0 (*(volatile unsigned char *)0x50000020)
#define URXH0 (*(volatile unsigned char *)0x50000024)
#define UBRDIV0 (*(volatile unsigned long *)0x50000028)
/*interrupt registes*/
#define SRCPND (*(volatile unsigned long *)0x4A000000)
#define INTMOD (*(volatile unsigned long *)0x4A000004)
#define INTMSK (*(volatile unsigned long *)0x4A000008)
#define PRIORITY (*(volatile unsigned long *)0x4A00000c)
#define INTPND (*(volatile unsigned long *)0x4A000010)
#define INTOFFSET (*(volatile unsigned long *)0x4A000014)
#define SUBSRCPND (*(volatile unsigned long *)0x4A000018)
#define INTSUBMSK (*(volatile unsigned long *)0x4A00001c)
/*external interrupt registers*/
#define EINTMASK (*(volatile unsigned long *)0x560000a4)
#define EINTPEND (*(volatile unsigned long *)0x560000a8)
/*clock registers*/
#define LOCKTIME (*(volatile unsigned long *)0x4c000000)
#define MPLLCON (*(volatile unsigned long *)0x4c000004)
#define UPLLCON (*(volatile unsigned long *)0x4c000008)
#define CLKCON (*(volatile unsigned long *)0x4c00000c)
#define CLKSLOW (*(volatile unsigned long *)0x4c000010)
#define CLKDIVN (*(volatile unsigned long *)0x4c000014)
/*PWM & Timer registers*/
#define TCFG0 (*(volatile unsigned long *)0x51000000)
#define TCFG1 (*(volatile unsigned long *)0x51000004)
#define TCON (*(volatile unsigned long *)0x51000008)
#define TCNTB0 (*(volatile unsigned long *)0x5100000c)
#define TCMPB0 (*(volatile unsigned long *)0x51000010)
#define TCNTO0 (*(volatile unsigned long *)0x51000014)
#define GSTATUS1 (*(volatile unsigned long *)0x560000B0)
serial.c
#include "s3c24xx.h"
#include "serial.h"
#define TXD0READY (1<<2)
#define RXD0READY (1)
#define PCLK 50000000 // init.c中的clock_init函数设置PCLK为50MHz
#define UART_CLK PCLK // UART0的时钟源设为PCLK
#define UART_BAUD_RATE 115200 // 波特率
#define UART_BRD ((UART_CLK / (UART_BAUD_RATE * 16)) - 1)
* 初始化UART0
* 115200,8N1,无流控
void uart0_init(void)
GPHCON |= 0xa0; // GPH2,GPH3用作TXD0,RXD0
GPHUP = 0x0c; // GPH2,GPH3内部上拉
ULCON0 = 0x03; // 8N1(8个数据位,无较验,1个停止位)
UCON0 = 0x05; // 查询方式,UART时钟源为PCLK
UFCON0 = 0x00; // 不使用FIFO
UMCON0 = 0x00; // 不使用流控
UBRDIV0 = UART_BRD; // 波特率为115200
* 发送一个字符
void putc(unsigned char c)
/* 等待,直到发送缓冲区中的数据已经全部发送出去 */
while (!(UTRSTAT0 & TXD0READY));
/* 向UTXH0寄存器中写入数据,UART即自动将它发送出去 */
UTXH0 = c;
* 接收字符
unsigned char getc(void)
/* 等待,直到接收缓冲区中的有数据 */
while (!(UTRSTAT0 & RXD0READY));
/* 直接读取URXH0寄存器,即可获得接收到的数据 */
return URXH0;
* 判断一个字符是否数字
int isDigit(unsigned char c)
if (c >= '0' && c <= '9')
return 1;
else
return 0;
* 判断一个字符是否英文字母
int isLetter(unsigned char c)
if (c >= 'a' && c <= 'z')
return 1;
else if (c >= 'A' && c <= 'Z')
return 1;
else
return 0;
serial.h
void uart0_init(void);
void putc(unsigned char c);
unsigned char getc(void);
int isDigit(unsigned char c);
int isLetter(unsigned char c);
init.c
* init.c: 进行一些初始化
void disable_watch_dog(void);
void clock_init(void);
void memsetup(void);
void copy_steppingstone_to_sdram(void);
* 关闭WATCHDOG,否则CPU会不断重启
WTCON = 0; // 关闭WATCHDOG很简单,往这个寄存器写0即可
#define S3C2410_MPLL_200MHZ ((0x5c<<12)|(0x04<<4)|(0x00))
#define S3C2440_MPLL_200MHZ ((0x5c<<12)|(0x01<<4)|(0x02))
* 对于MPLLCON寄存器,[19:12]为MDIV,[9:4]为PDIV,[1:0]为SDIV
* 有如下计算公式:
* S3C2410: MPLL(FCLK) = (m * Fin)/(p * 2^s)
* S3C2440: MPLL(FCLK) = (2 * m * Fin)/(p * 2^s)
* 其中: m = MDIV + 8, p = PDIV + 2, s = SDIV
* 对于本开发板,Fin = 12MHz
* 设置CLKDIVN,令分频比为:FCLK:HCLK:PCLK=1:2:4,
* FCLK=200MHz,HCLK=100MHz,PCLK=50MHz
// LOCKTIME = 0x00ffffff; // 使用默认值即可
CLKDIVN = 0x03; // FCLK:HCLK:PCLK=1:2:4, HDIVN=1,PDIVN=1
/* 如果HDIVN非0,CPU的总线模式应该从“fast bus mode”变为“asynchronous bus mode” */
__asm__(
"mrc p15, 0, r1, c1, c0, 0\n" /* 读出控制寄存器 */
"orr r1, r1, #0xc0000000\n" /* 设置为“asynchronous bus mode” */
"mcr p15, 0, r1, c1, c0, 0\n" /* 写入控制寄存器 */
/* 判断是S3C2410还是S3C2440 */
if ((GSTATUS1 == 0x32410000) || (GSTATUS1 == 0x32410002))
MPLLCON = S3C2410_MPLL_200MHZ; /* 现在,FCLK=200MHz,HCLK=100MHz,PCLK=50MHz */
else
MPLLCON = S3C2440_MPLL_200MHZ; /* 现在,FCLK=200MHz,HCLK=100MHz,PCLK=50MHz */
* 设置存储控制器以使用SDRAM
void memsetup(void)
volatile unsigned long *p = (volatile unsigned long *)MEM_CTL_BASE;
/* 这个函数之所以这样赋值,而不是像前面的实验(比如mmu实验)那样将配置值
* 写在数组中,是因为要生成”位置无关的代码”,使得这个函数可以在被复制到
* SDRAM之前就可以在steppingstone中运行
/* 存储控制器13个寄存器的值 */
p[0] = 0x22011110; //BWSCON
p[1] = 0x00000700; //BANKCON0
p[2] = 0x00000700; //BANKCON1
p[3] = 0x00000700; //BANKCON2
p[4] = 0x00000700; //BANKCON3
p[5] = 0x00000700; //BANKCON4
p[6] = 0x00000700; //BANKCON5
p[7] = 0x00018005; //BANKCON6
p[8] = 0x00018005; //BANKCON7
/* REFRESH,
* HCLK=12MHz: 0x008C07A3,
* HCLK=100MHz: 0x008C04F4
p[9] = 0x008C04F4;
p[10] = 0x000000B1; //BANKSIZE
p[11] = 0x00000030; //MRSRB6
p[12] = 0x00000030; //MRSRB7
unsigned int *pdwSrc = (unsigned int *)0;
unsigned int *pdwDest = (unsigned int *)0x30000000;
while (pdwSrc < (unsigned int *)4096)
*pdwDest = *pdwSrc;
pdwDest++;
pdwSrc++;
head.S
@ File:head.S
@ 功能:设置SDRAM,将程序复制到SDRAM,然后跳到SDRAM继续执行
.extern main
.text
.global _start
_start:
Reset:
ldr sp, =4096 @ 设置栈指针,以下都是C函数,调用前需要设好栈
bl disable_watch_dog @ 关闭WATCHDOG,否则CPU会不断重启
// bl是位置无关码,相当于:PCnew = PC + 偏移
// PCnew = (4+8) + 0x28 = 0x34
//ldr pc, =disable_watch_dog /* 这样写将出错 */
bl clock_init @ 设置MPLL,改变FCLK、HCLK、PCLK
bl memsetup @ 设置存储控制器以使用SDRAM
bl copy_steppingstone_to_sdram @ 复制代码到SDRAM中
ldr pc, =on_sdram @ 跳到SDRAM中继续执行
on_sdram:
ldr sp, =0x34000000 @ 设置栈指针
ldr lr, =halt_loop @ 设置返回地址
ldr pc, =main @ 调用main函数
halt_loop:
b halt_loop
main.c
#include "serial.h"
int main()
unsigned char c;
uart0_init(); // 波特率115200,8N1(8个数据位,无校验位,1个停止位)
putc('T');
putc('e');
putc('s');
putc('t');
putc(':');
putc('\n');
putc('\r');
while(1)
// 从串口接收数据后,判断其是否数字或字母,若是则加1后输出
c = getc();
if (isDigit(c) || isLetter(c))
putc(c+1);
return 0;
uart.lds
SECTIONS {
. = 0x30000000;
.text : { *(.text) }
.rodata ALIGN(4) : {*(.rodata)}
.data ALIGN(4) : { *(.data) }
.bss ALIGN(4) : { *(.bss) *(COMMON) }
Makefile
objs := head.o init.o serial.o main.o
uart.bin: $(objs)
arm-linux-ld -Tuart.lds -o uart_elf $^
arm-linux-objcopy -O binary -S uart_elf $@
arm-linux-objdump -D -m arm uart_elf > uart.dis
%.o:%.c
arm-linux-gcc -Wall -O2 -c -o $@ $<
%.o:%.S
clean:
rm -f uart.bin uart_elf uart.dis *.o
实验的问题总结:
I.关于系统时钟的设置,我们主要看clock_init()函数。
1>
__asm__( //C语言内嵌汇编,这段话是根据s3c2440用户手册上的说明来写的
2>
GSTATUS1寄存器为芯片序列信号,可查看s3c2440用户手册
3>
MPLLCON的目的是设置FCLK和Fin的倍数,关于其值的设置,可以参考s3c2440用户手册关于PLL值选择表
II.关于UART,我们主要分析如下:
我们主要分析serial.c文件,我们主要使用的方式是:非流控 + 非FIFO + 查询方式。
在uart0_init()函数中,关于这几个寄存器的配置,你可以对照s3c2440手册进行一一配置即可
其中,UTRSTAT0寄存器是判断发送缓冲器或接收缓冲器中是否有数据
UTXH0为发送缓冲寄存器,我们若想发送数据,直接往UTXH0寄存器里边赋值即可。
URXH0为接收缓冲寄存器,我们若想读数据,直接往URXH0寄存器里边读数据即可。
上一篇:ARM9的IIC
下一篇:ARM9的中断体系结构
我从本论坛下了一个单片机电子万年历的资料有问题想请教下各位高手 具体的问题是电路数码管有的亮有的不亮,还有程序不运行请教下各位是什么问题啊 谢谢!!电路图和程序都在附件中请大家帮帮忙看下市怎么回事?… 查看全部问答> |
这些天在研究论坛里曾经组织过的活动----魔幻光影棒 看了那个用MSP430F1232的电路图 看不明白了~ 问几个笨笨的问题: 1. LVC573(74LCX573)的作用到底是什么呢?请详细的说下~~ 2. ULN2003的作用呢?在网上查资料 貌似 ...… 查看全部问答> |
带个DC12V的电池就ok了 比如摩托车电池 还有很多系统里面都带有后备电池都是DC12V的 要是这些都没有也可以去商店买8个1.5V的干电池传联起来用也可以 用电池供电可以保证电的质量 用这个方法可以帮助判断很多可能是电源引起的故障… 查看全部问答> |
想把5.0的bsp移植到6.0,除了kitl,其他目录都编译通过了, 在整kitl时,发现了个问题,如下~~~ 这个是kitl目录下的source文件 [code] TARGETNAME=KITL TARGETTYPE=DYNLINK DLLENTRY=KitlDllMain DEFFILE= NOLIBC=1 SOURCES= TARGETLIBS ...… 查看全部问答> |
情况是这样的: 我一个在linux下跑的C程序 主要是完成GSM发短信的功能~~~ 短信短一点的情况 可以成功发出去“HELLO WORLD”这样~~ 长一点 就发布过去“fwefjweifjweofjwoiejfioewfjwoejfweo”就发不出去了~ 但是我在minicom 下是可以发送出去 ...… 查看全部问答> |
