今天是:2025年04月22日(星期二)
正在发生
2018年04月22日 | TI公司的汽车信息娱乐电源系统参考设计
2018-04-22 来源:社区化
    TI公司的PMP15014是汽车信息娱乐电源系统参考设计,采用一级功率系统满足高输入电压的需求,并提供不同负载的低压多个输出,还提供瞬态和极性相反保护,工作频率2.1MHz,以避开AM频段,具有优异的EMI性能.参考设备选用LM53625-Q1/LM53635-Q1同步降压稳压器.本文介绍了LM53625-Q1/LM53635-Q1主要特性,功能框图,LM53635通用应用电路图和几种典型应用电路,以及汽车信息娱乐电源系统PMP15014主要特性,电路图,材料清单和PCB设计图.
  The LM53625-Q1/LM53635-Q1 synchronous buck regulator is opTImized for automoTIve applicaTIons, providing an output voltage of 5 V, 3.3 V, or an adjustable output. Advanced high-speed circuitry allows the LM53625-Q1/LM53635-Q1 to regulate from an input of 18 V to an output of 3.3 V at a fixed frequency of 2.1 MHz. Innovative architecture allows this device to regulate a 3.3-V output from an input voltage of only 3.55 V. All aspects of the LM53625-Q1/LM53635-Q1 are optimized for automotive and performance-driven industrial customers. An input voltage range up to 36 V, with transient tolerance up to 42 V, eases input surge protection design. The automotive-qualified Hotrod QFN package with wettable flanks reduces parasitic inductance and resistance while increasing efficiency, minimizing switch node ringing, and dramatically lowering electromagnetic interference (EMI)。 An open-drain reset output, with built-in filtering and delay, provides a true indication of system status. This feature negates the requirement for an additional supervisory component, saving cost and board space. Seamless transition between PWM and PFM modes and low quiescent current (only 15 µA for the 3.3 V option) ensure high efficiency and superior transient responses at all loads.
  LM53625-Q1/LM53635-Q1主要特性:
  AEC-Q100 Automotive Qualified:
  Device Temperature Grade 1: –40℃ to +125℃ Ambient Operating Temperature Range
  Device HBM Classification Level 2
  Device CDM Classification Level C6
  –40℃ to +150℃ Junction Temperature Range
  15-µA Quiescent Current at no Load (Typical) with 3.3-V Output
  4 mm × 5 mm, 0.5-mm Pitch VQFN Package WithWettable Flanks and 0.6-mm VIN Spacing
  Low EMI and Switch Noise
  Spread Spectrum Option
  External Frequency Synchronization
  RESET Output with Internal Filter and 3-ms Release Timer
  Pin-Selectable Forced PWM Mode
  Built-In Compensation, Soft Start, Current Limit, Thermal Shutdown, and UVLO
  0.6-V Dropout at 3.5 A at 105℃ TA
  ±1% Output Voltage Tolerance (–40℃ to 125℃ TJ)
  Available With Fixed 5-V, 3.3-V or Adjustable Output
图1.LM53625-Q1/LM53635-Q1功能框图
图2.LM53635通用应用电路图
图3.LM53635固定5V/3.5A输出电源电路图
图4.LM53635固定3.3V/3.5A输出电源电路图
图5.LM53635 6V输出电源电路图
汽车信息娱乐电源系统PMP15014
This solution is designed to be an automotive off-battery front end power supply for infotainment systems. It was created using a one stage power system meeting high voltage input needs and providing low voltage for multi output rails for different load needs. The system also provides transient and reverse polarity protection. The Wide Vin Buck stage is  working at 2.1Mhz to avoid AM band and has superior  EMI performance with an differential  EMI filter to support CISPER 25.
  图6.汽车信息娱乐电源系统PMP15014外形图
  汽车信息娱乐电源系统PMP15014主要特性:
  Wide Vin 2.1MHz Integrated , Low Iq Buck Converter
  Boost for 5V CAN supply
  Transient and Reverse Polarity Protection and EMI filter added
  The system disconnet the second stage power and keep 3.3V sustained when Input votlage lower than 4.5V
图7.汽车信息娱乐电源系统PMP15014电路图
汽车信息娱乐电源系统PMP15014材料清单:
图8.PMP15014 PCB设计图(1)
图9.PMP15014 PCB设计图(2)
图10.PMP15014 PCB设计图(3)
图11.PMP15014 PCB设计图(4)
图12.PMP15014 PCB设计图(5)
图13.PMP15014 PCB设计图(6)
图14.PMP15014 PCB设计图(7)
图15.PMP15014 PCB设计图(8)
图16.PMP15014 PCB设计图(9)
Hosiden Corporation公司的发展小趣事
近年来,Hosiden在技术创新方面取得了显著成果。特别是在汽车市场,公司积极参与并推动了MIPI A-PHY标准的验证与应用。Hosiden与Valens Semiconductor等领先企业合作,完成了其连接器和电缆对Valens VA7000芯片组的验证,这是市场上首个符合MIPI A-PHY的芯片组。这一里程碑式的成就不仅展示了Hosiden在技术创新方面的实力,也进一步巩固了其在汽车电子市场中的领先地位。
BSI公司的发展小趣事
近年来,随着环保意识的提高,电子行业对绿色发展的需求也日益迫切。BSI积极响应这一需求,推动了电子行业绿色标准的制定和实施。通过制定严格的环保标准,BSI引导电子产品制造企业采用更加环保的生产工艺和材料,减少了对环境的污染。同时,BSI还为企业提供了碳排放核查等服务,帮助企业了解自身的碳排放情况,制定了减排措施,推动了电子行业的绿色发展。
Custom Connector Corporation公司的发展小趣事
随着电子行业的不断发展,CCC始终将技术创新作为公司发展的核心驱动力。公司投入大量研发资金,引进先进技术和设备,不断提升产品的性能和品质。同时,CCC还积极与高校、科研机构合作,共同研发具有自主知识产权的新产品。这些创新成果不仅为CCC赢得了市场的认可,也推动了整个电子连接器行业的技术进步。
Electroswitch公司的发展小趣事
随着市场竞争的加剧,Electroswitch意识到仅仅依靠产品质量已经不足以赢得市场。因此,公司开始注重提升服务质量,为客户提供更加全面和专业的支持。通过加强售前咨询、售后服务以及技术支持等方面的投入,Electroswitch成功赢得了客户的信任和忠诚。这也使得公司在电子行业中的地位得到了进一步提升。
Dongguan City Niuhang Electronics Co.LTD公司的发展小趣事
在技术创新的基础上,Dongguan City Niuhang Electronics Co.LTD开始积极拓展市场。公司先后在安徽省池州市、江苏省扬州市和宿迁市等地设立生产基地,形成了覆盖全国的销售网络。同时,公司还加强品牌建设,通过参加行业展会、举办技术研讨会等方式,提升品牌知名度和影响力。随着市场的不断扩大,公司的销售业绩也实现了快速增长。
Benchmarq Microelectronics Inc公司的发展小趣事
在国内市场取得一定成绩后,Benchmarq Microelectronics Inc开始积极拓展国际市场。公司积极参加国际电子展会和交流活动,与国际同行建立合作关系,将产品打入国际市场。同时,公司还加强品牌建设,提升品牌知名度和美誉度。通过广告宣传、媒体报道等多种方式,公司成功塑造了专业、可靠的品牌形象,赢得了客户的信任和认可。
基于单片机控制的并联型有源电力滤波器
这是我的毕业设计 希望大家帮帮我 我现在已经焦头烂额了 网上都是基于DSP控制的滤波器 就是没有基于单片机控制的 真的郁闷 我的邮箱是westlife009@tom.com 我的QQ是232125740 欢迎大家一起交流 [ 本帖最后由 westlifeljb 于 2008-5-15 17:15 编 ...…
新手学堂:嵌入式开发都需要学习什么
这是一个初学者常问的问题,也是初学者问嵌入式该如何入门的根源。我感觉有两个方面,偏硬和偏软.我不认为嵌入式开发软件占绝对比重,相反,软硬件都懂,才是嵌入式高手所应该追求的,也是高手的必由之路。   硬件道路:   第一步: pcb设 ...…
热敏电阻如何做温度补偿?
通常要使用到热敏电阻的单片机系统中,热敏电阻都会与一个固定电阻串联,那么这个固定电阻是如何确定阻值的呢?请大家讨论讨论。…
AD和DA部分芯片合集(资料和程序)
AD和DA部分芯片合集(资料和程序),分享下…
关于vec调试。在线等
关于vec调试中,怎么调才能让频率正确(具体的参数) 例如:720*572(13.5hz)转换成vga 800*600(75hz)。大小可以跳出,但75hz调不出来 请教大虾指导。…
要做PCI的驱动,需要看DMA相关的东西吗?
没做过,对硬件不是很动,现在看接口部分,有些驱动程序里还有DMA的处理,不知道要不要看?…
分享湿度计的读写时序和编程
湿度计的读写时序包括读时序和写时序,写时序如下:向 SH T21写8 个数据位 ,然后在第9 个时钟周期 ,读取 SHT21 的应答位 ,应位为 0 ,表示SHT21正确接收到了一个字节 ,也就是 8 个写时序加 1 个读时序。SH T21 读写数据的规则是:DA TA在 SCK时钟的下 ...…
*****香版主:IAR422+st-linkII在中断内调试出问题
用IAR442,IAR5.X还未支持ST-LINK II,  ST-LINK II也不支高密度的FLASH,IAR422下用st-link II 在中断内断点调试,老是会跳不出中断!何解?打算以后用IAR5.X+WIGGLER+HJTAG.EXE 不知功能如何?有没有ST&nb ...…
LED照明智能控制解决方案
能量效率更高、功能更强的新型LED固态发光(SSL)产品的发展很快,被认为是照明市场上的主要革命性进步。在许多垂直应用中,如信号灯、汽车、LCD TV背光,LED已经毫无争议地成为传统光源的替代产品。但对于范围更广的通用照明,LED还没有被广泛接受 ...…
