今天是:2025年04月22日(星期二)
正在发生
2018年04月22日 | SPC563M64L7主要特性及框图_Discovery Plus开发板
2018-04-22 来源:社区化
ST公司的SPC563M64L7是用于汽车动力总成的32位Power Architecture MCU,是系统级芯片(SoC),采用许多新特性的高性能90nm CMOS技术,以降低成本和提高性能,Power Architecture®技术具有支持DSP的附加指令,以及诸如增强的时间处理单元,增强排队的模数转换器,控制局域网(CAN)和增强的模块输入/输出系统.此外,器件还集成了94KB SRAM和1.5MB闪存.本文介绍了SPC563M64L7主要特性,框图,以及SPC563Mxx系列Discovery Plus开发板SPC563M-DISP主要特性和电路图,PCB顶层布局图.
  These 32-bit automoTIve microcontrollers are a family of System-on-Chip (SoC) devices that contain many new features coupled with high performance 90 nm CMOS technology to provide substanTIal reducTIon of cost per feature and significant performance improvement. The advanced and cost-efficient host processor core of this automoTIve controller family is built on Power Architecture® technology. This family contains enhancements that improve the architecture’s fit in embedded applications, includes additional instruction support for Digital Signal Processing (DSP), integrates technologies—such as an enhanced time processor unit, enhanced queued analog-to-digital converter, Controller Area Network, and an enhanced modular input-output system—that are important for today’s lower-end powertrain applications. The device has a single level of memory hierarchy consisting of up to 94 KB on-chip SRAM and up to 1.5 MB of internal flash memory. The device also has an External Bus Interface (EBI) for ‘calibration’。
    SPC563M64L7主要特性:
  Single issue,32-bit Power Architecture® Book E compliant e200z335 CPU core complex
  – Includes Variable Length Encoding (VLE) enhancements for code size reduction 
  32-channel Direct Memory Access controller (DMA) 
  Interrupt Controller (INTC) capable of handling 364 selectable-priority interrupt sources: 191 peripheral interrupt sources, 8 software interrupts and 165 reserved interrupts. 
  Frequency-Modulated Phase-Locked Loop (FMPLL) 
  Calibration External Bus Interface (EBI)(a) 
  System Integration Unit (SIU) 
  Up to 1.5 Mbyte on-chip Flash with Flash controller
  – Fetch Accelerator for single cycle Flash access @80 MHz
  Up to 94 Kbyte on-chip static RAM (including up to 32 Kbyte standby RAM) 
  Boot Assist Module (BAM) 
  32-channel second-generation enhanced Time Processor Unit (eTPU)
  – 32 standard eTPU channels
  – Architectural enhancements to improve code efficiency and added flexibility 
  16-channels enhanced Modular Input-Output System (eMIOS) 
  Enhanced Queued Analog-to-Digital Converter (eQADC) 
  Decimation filter (part of eQADC) 
  Silicon die temperature sensor 
  2 Deserial Serial Peripheral Interface (DSPI) modules (compatible with Microsecond Bus)
  2 enhanced Serial Communication Interface (eSCI) modules compatible with LIN
  2 Controller Area Network (FlexCAN) modules that support CAN 2.0B 
  Nexus Port Controller (NPC) per IEEE-ISTO 5001-2003 standard 
  IEEE 1149.1 (JTAG) support  Nexus interface 
  On-chip voltage regulator controller that provides 1.2 V and 3.3 V internal supplies from a 5 V external source.
  Designed for LQFP144, and LQFP176
  The SPC563Mxx series microcontrollers are system-on-chip devices that are built on Power Architecture® technology and:
  Are 100% user-mode compatible with the Power Architecture instruction set Contain enhancements that improve the architecture’s fit in embedded applications 
  Include additional instruction support for digital signal processing (DSP)
  Integrate technologies such as an enhanced time processor unit, enhanced queued analog-to-digital converter, Controller Area Network, and an enhanced modular input-output system 
  Operating Parameters
  – Fully static operation, 0 MHz
  – 80 MHz (plus 2% frequency modulation - 82 MHz)
  – –40 C–150 C junction temperature operating range
  – Low power design
  Less than 400 mW power dissipation (nominal)
  Designed for dynamic power management of core and peripherals
  Software controlled clock gating of peripherals
  Low power stop mode, with all clocks stopped
  – Fabricated in 90 nm process
  – 1.2 V internal logic 
  High performance e200z335 core processor 
  Advanced microcontroller bus architecture (AMBA) crossbar switch (XBAR) 
  Enhanced direct memory access (eDMA) controller 
  Interrupt controller (INTC)
  – 191 peripheral interrupt request sources, plus 165 reserved positions
  – Low latency—three clocks from receipt of interrupt request from peripheral to interrupt request to processor 
  Frequency Modulating Phase-locked loop (FMPLL) 
  Calibration bus interface (EBI) (available only in the calibration package) System integration unit (SIU) centralizes control of pads, GPIO pins and external interrupts. 
  Error correction status module (ECSM) provides configurable error-correcting codes (ECC) reporting
  Up to 1.5 MB on-chip flash memory 
  Up to 94 KB on-chip static RAM 
  Boot assist module (BAM) enables and manages the transition of MCU from reset to user code execution from internal flash memory, external memory on the calibration bus or download and execution of code via FlexCAN or eSCI.
  Periodic interrupt timer (PIT)
  – 32-bit wide down counter with automatic reload
  – 4 channels clocked by system clock
  – 1 channel clocked by crystal clock 
  System timer module (STM)
  – 32-bit up counter with 8-bit prescaler
  – Clocked from system clock
  – 4 channel timer compare hardware 
  Software watchdog timer (SWT) 32-bit timer 
  Enhanced modular I/O system (eMIOS)
  – 16 standard timer channels (up to 14 channels connected to pins in LQFP144)
  – 24-bit timer resolution 
  Second-generation enhanced time processor unit (eTPU2)
  – High level assembler/compiler
  – Enhancements to make ‘C’ compiler more efficient
  – New ‘engine relative’ addressing mode 
  Enhanced queued A/D converter (eQADC)
  – 2 independent on-chip RSD Cyclic ADCs
  – Up to 34 input channels available to the two on-chip ADCs
  – 4 pairs of differential analog input channels 
  2 deserial serial peripheral interface modules (DSPI)
  – SPI provides full duplex communication ports with interrupt and DMA request support
  – Deserial serial interface (DSI) achieves pin reduction by hardware serialization and deserialization of eTPU, eMIOS channels and GPIO 
  2 enhanced serial communication interface (eSCI) modules 
  2 FlexCAN modules 
  Nexus port controller (NPC) per IEEE-ISTO 5001-2003 standard  IEEE 1149.1 JTAG controller (JTAGC)
  图1.SPC563Mxx系列框图
  The SPC563M-DISP Discovery kit helps you to discover SPC56 M line Power Architecture® Microcontrollers. The discovery board is based on SPC563M64L7, a 32-bit Power Architecture Book E compliant e200z335 CPU core with 1.5Mbyte on-chip in an LQFP176 package. The numerous interfaces including CAN/SCI/K-LINE/DSPI/GPIO make the SPC56M-Discovery an excellent starter kit for customer quick evaluation and project development. The SPC56 M family is designed to address cost sensitive powertrain and transmission applications. The SPC56 M line key functionality is Time processing units (eTPU) a coprocessor to create events in sync with internal or external signals without flooding the CPU with interrupt to serve.
图2.Discovery Plus开发板SPC563M-DISP外形图
图3.Discovery Plus开发板SPC563M-DISP硬件概述图
图4.Discovery Plus开发板SPC563M-DISP电路图
图5.Discovery Plus开发板SPC563M-DISP顶层PCB布局图
Carlo Gavazzi公司的发展小趣事
随着技术的不断进步和市场需求的不断变化,Carlo Gavazzi公司始终保持着创新的活力。公司不断推出新产品,从最初的电气元件到后来的控制和自动化解决方案,再到能源管理和节能方案,产品线日益丰富。这种多元化的产品策略不仅满足了客户的多样化需求,也为公司带来了更广阔的市场空间。
ENOCEAN公司的发展小趣事
自推出第一代产品以来,EnOcean凭借其卓越的性能和独特的优势,在欧洲市场上取得了良好的销售业绩。随后,随着公司不断推出新产品和技术,其产品的应用领域也逐渐扩大至全球范围。如今,EnOcean的无线模块已被全球100多家制造商选中,用于实现他们的建筑和工业系统理念。无线组件已经在超过20万栋建筑中使用,为节能建筑和创新产业提供了重要支持。
DuPont公司的发展小趣事
早在20世纪初,DuPont公司就开始涉足电子材料的研发。当时,随着电子技术的飞速发展,对于高性能、高可靠性的电子材料的需求日益迫切。DuPont凭借其深厚的化学技术积累,成功开发了一系列具有优异性能的电子材料,如高性能绝缘材料、导电材料和封装材料等。这些材料的推出,不仅极大地推动了电子行业的发展,也为DuPont公司在电子材料领域奠定了坚实的基础。
申风(everanalog)公司的发展小趣事
随着技术实力的不断提升和产品线的日益丰富,申风(everanalog)公司开始积极拓展市场。公司凭借优质的产品和服务,逐渐在国内市场上树立了良好的品牌形象。同时,公司也积极开展国际合作,与国际知名企业建立了战略合作关系,共同推动集成电路产业的发展。这些合作不仅为公司带来了更多的商业机会,也提升了公司在国际市场上的竞争力。
AMI [American Megatrends Inc]公司的发展小趣事
作为一家有社会责任感的企业,申风(everanalog)公司始终关注社会发展和环境保护问题。公司积极参与公益事业和环保活动,致力于为社会做出积极贡献。同时,公司也注重可持续发展战略的制定和实施,在生产经营过程中注重节能减排和资源循环利用等方面的工作。这些举措不仅提升了公司的社会形象,也为公司的长期发展奠定了坚实的基础。
请注意,以上故事框架仅为示例,并未包含具体的细节和数据。如需了解更多关于申风(everanalog)公司的具体信息和发展历程,请查阅相关新闻报道或官方资料。
HIT(日立)公司的发展小趣事
在电路中设置过流、过压等保护电路,以防止电路在异常情况下损坏或引发安全事故。
菜鸟求救,一个和gprs有关的问题
用gprs接入特定的专网(就是有一个自己的apn)和接入cmnet在方法上有什么区别吗?…
WM5 VC2005 如何在dialog中加WebBrowser?
我想在VC程序中访问网页,通过在dialog中加入一个WebBrowser控件实现,但启动dialog时报错,如何解决?…
wince5.0在pxa270上的双串口使用问题
各位同仁,我在做pxa270平台上wince5.0串口驱动的过程中,发现两个串口(FFUART,BTUART)不能同时 正常的收发数据。 现在的情况: 1。platform.reg注释掉两个串口之一可以启动内核。 2。platform.reg两个串口都打开,如果BTUART作为debug口, ...…
用C#如何编写PocketPC 上的四个方向键?
  平台:VS2005 + ComponentOne for Mobile +MSDN2005+Mobile 5.0 SDK       我在PocketPC项目中新建了一个form,在里面放了9个button按钮(自己写了一个带有图片的BUTTON)是个三行三列的。    我想 ...…
IS61LPS51236A SSRAM fpga控制 分析
IS61LPS51236A  DATASHEET 如下:   上图为SSRAM 模块图,清晰表示了SSRAM各个管脚的关系,一目了然,下面这张图说明管脚功能:   看看SSRAM 读写时序图:   从上面分析,FPGA 怎样读SSRAM, 1。 首先保证时钟 ...…
请高手不吝赐教,谢谢
  问题:为什么上面会说“由于T0的管压降UCE0与其b-e间电压UBE0相等,从而保证T0工作在放大状态”?  共射极放大电路三极管要工作在放大区不是应该满足Ue<Ub<Uc ,即UCE>UBE吗?他让集电极和基极短接,不就UCE=UBE,这样三极管还 ...…
器件非线性度的问题
小弟菜鸟,恳请前辈们解答。     假设一个器件的非线性度比如是600ppm,输入电压的范围是0到10v,输出=输入 乘以 1。假如我输入5v的电压,则输出会在5v上下6mv的范围内。我想问:如果进行多次重复测量,这个偏离(输出实际值减去输出理 ...…
秒杀到的EK-LM3S811:请教如何开始学习呢?
有幸秒到LM3S811,可是以前没有接触过ARM,不知如何玩转它,请各位高手指点指点! 比如:用keil如何开始下载第一个程序,那些库文件如何使用…… 大家也可以在这讨论一下用这个小板做些什么…… 希望高手们不吝赐教! …
硬件I2C G2553
想知道,硬件I2C只需要把数据写入UCB0TXBUF,然后再从UCB0BAXBUF读出就可以了吗???不需要其他的类似转换吗???…
