今天是:2025年04月29日(星期二)
正在发生
2018年04月29日 | 基于LV8907无传感器三相无刷直流马达控制方案
2018-04-29 来源:社区化
    On Semi公司的LV8907是高性能AEC-Q100许可的无传感器三相无刷直流(BLDC)马达控制器,集成了用来驱动外接N-MOSFET的栅极驱动器,两级电荷泵提供各种低RDS(ON)外接N-MOSFET所需的栅极电压,工作结温高达175ºC,工作电压5.5V 到 20V,主要用在汽车泵(燃料泵,油泵和水泵),风扇(HVAC,散热器,电池冷却,LED头灯冷却)以及白色家电和工业BLDC马达控制。本文介绍了LV8907主要特性,框图,典型应用电路以及评估板LV8907UWGEVK主要特性,电路图和材料清单。
  The LV8907 is a high performance, AEC-Q100 qualified, sensor-less three-phase BLDC motor controller with integrated gate drivers for driving external N-MOSFETs. An on-chip two-stage charge pump provides required gate voltage for a wide range of low RDS(ON) type external N-MOSFETs. The device offers a rich set of system protecTIon and diagnosTIc funcTIons such as over-current, over-voltage, short-circuit, under-voltage, over-temperature and many more. It supports open-loop as well as closed-loop speed control with user configurable startup, speed setTIng and proportional/integral (PI) control coefficients, making it suitable for a wide range of motor and load combinations. With a built-in linear regulator for powering external circuits, a watchdog timer, and a LIN (Local Interconnect Network) transceiver, the LV8907 offers a very small system solution. The LV8907 stores system parameters in embedded one-time programmable (OTP) non-volatile memory in addition to RAM system memory. An SPI interface is provided for parameter setting and monitoring the system status. With the operating junction temperature tolerance up to 175ºC and electrically LIN compatible control signals (PWM and Enable), the LV8907 is an ideal solution for stand-alone BLDC motor control systems.
  LV8907主要特性:
  AEC-Q100 qualified and PPAP capable. 
  Operating junction temperature up to 175ºC 
  Operating voltage range from 5.5V to 20V with tolerance from 4.5V to 40V 
  Embedded proprietary sensor-less trapezoidal and pseudo-sinusoidal commutation 
  Supports open-loop as well as closed-loop speed control 
  Integrated gate drivers for driving six N-MOSFETs 
  Two-stage charge pump for continuous 100% duty cycle operation 
  5V/3.3V regulator, LIN transceiver and Watchdog timer applications using an external microcontroller.
  Configurable speed settings and PI control coefficients 
  Various system protection features including:
  Shoot through protection using configurable dead-time
  Drain-source short detection
  Cycle-by-cycle current limit and over-current shutdown
  Over-voltage and under-voltage shutdown
  Over-temperature warning and shutdown
  Input PWM fault detection
  LV8907典型应用:
  Automotive pumps (Fuel, Oil, and Hydraulic) 
  Fans (HVAC, Radiator, Battery Cooling, LED Headlight Cooling) 
  White goods and industrial BLDC motor control
图1.LV8907框图
图2.LV8907单独使用配置图
  图3.LV8907基于LIN的控制配置图
  LV8907UW评估板LV8907UWGEVK
  The LV8907UWGEVK Evaluation Kit v1.0 is designed to provide an easy and quick development platform for three phase sensor-less BLDC motor control applications using the LV8907UW. The LV8907UW is a stand-alone solution that does not need a microcontroller for operation. An Atmel microcontroller is included in the kit to communicate via USB with the PC based graphical user interface (GUI) and support some peripheral functions such as current and voltage measurement, and external temperature monitoring for easier system development. For quick-start and basic The kit consists of:
  1. LV8907UW Evaluation Board (EVB)
    2. USB cable Type A to mini B.
  3. Graphical User Interface.
  评估板LV8907UWGEVK主要特性:
  • Motor operation: 7V to 20V (40V transient)。
  • Max current: 30A.
  • Maximum continuous power: 400W.
图4.评估板LV8907UWGEVK外形图
图5.评估板LV8907UWGEVK电路图(1)
图6.评估板LV8907UWGEVK电路图(2)
评估板LV8907UWGEVK材料清单:
Anvo-Systems公司的发展小趣事
Anvo-Systems在发展过程中始终注重企业文化建设和社会责任履行。公司倡导创新、协作、诚信的企业精神,为员工创造了一个积极向上的工作环境。同时,Anvo-Systems还积极参与社会公益活动,关注环保和可持续发展等问题。通过这些举措,Anvo-Systems不仅提升了企业的社会形象,也为社会的和谐发展做出了积极贡献。
请注意,以上故事纯属虚构,不代表现实中任何公司或行业的真实情况。在实际应用中,应根据具体公司的历史和发展情况进行调整和完善。
Colibrys SA公司的发展小趣事
近年来,Colibrys与Sensonor展开了紧密的协同合作,共同生产MEMS惯性传感器产品。两家公司在专业知识、市场地位、客户和技术方面的互补性,使得这种合作成为了一种双赢的选择。通过合力发展,Colibrys和Sensonor已经向航空、航天、国防、运输、移动和工业领域交付了超过2000万颗MEMS传感器,进一步扩大了公司的市场份额和影响力。
这些故事只是Colibrys SA公司在电子行业中发展起来的一部分事实,它们展示了公司从初创到成为行业领导者的艰辛历程和辉煌成就。然而,公司的发展还在继续,未来还将有更多的故事等待我们去书写和见证。
對餘科技(DIOFIT)公司的发展小趣事
随着科技的不断发展,DIOFIT公司始终将技术创新作为发展的核心驱动力。他们不断投入研发资金,引进先进技术和人才,致力于研发具有自主知识产权的电子产品。在物联网、人工智能等前沿领域,DIOFIT公司取得了一系列突破性的成果,推出了一系列具有竞争力的产品,成为行业内的技术创新引领者。
EA Elektro-Automatik公司的发展小趣事
进入21世纪后,EA Elektro-Automatik加大了对研发的投入,致力于技术突破和产品创新。公司成功开发出一系列具有高精度、高可靠性和高性能的电力测试解决方案,如高速模拟稳压器、直流/交流源、并联操作设备等。这些产品不仅满足了市场对精密测试设备的需求,也进一步巩固了EA Elektro-Automatik在电子测量领域的领先地位。
Fuji Teminal Industry Co Ltd公司的发展小趣事
随着产品的不断优化和市场的不断扩大,EA Elektro-Automatik开始将目光投向国际市场。公司积极寻求与全球知名企业的合作机会,建立长期且稳定的战略合作关系。通过参与各类国际展会和交流活动,EA Elektro-Automatik的产品和技术得到了更广泛的推广和应用。如今,EA Elektro-Automatik的产品已经出口到全球多个国家和地区,为当地的市场和客户提供了优质的解决方案。
Component Research Co公司的发展小趣事
Component Research Co最初只是一家小型电子元件研发公司,面临着激烈的市场竞争。然而,公司研发团队在一次实验中意外发现了一种新型半导体材料,这种材料具有出色的导电性能和稳定性。公司迅速将这一发现转化为实际产品,并推向市场。新产品因其卓越性能迅速受到客户青睐,Component Research Co因此名声大噪,逐渐在电子元件市场占据一席之地。
关于GetModuleFileName一直返回NULL的问题
下面这个函数目的是获取当前运行的应用程序的目录,但使用GetModuleFileName返回的总是0.不知道为何。 bool GetCurrentPath(LPTSTR szPath)   {           HMODULE handle = GetModuleHandle(NULL); &nbs ...…
请教两个问题
1、Ndis库没有向nids微端口驱动的接口函数(如初始化函数等)下发irp,那代码中的irp是从哪里来的?ndis微端口驱动自己组建的吗? 2、如何看到ndis微端口驱动中irp中包含的是什么板侧的指令?如断链指令…
3G工程师成为大学毕业生择业首选
中国3G时代即将到来,社会对3G嵌入式软件人才的渴求使3G人才已经成为业界关注“3G软环境”的焦点之一。目前,我国的3G核心人才仅有不足万人,而且基本上都被几大运营商和设备厂商所掌握。广大手持端设备制造商所急需的嵌入式开发人才、软件开发商所 ...…
大家在做网络设计时候一般是用哪款工具来调试网络程序的?
准备用44b0来学习网络通讯软件编程序. 好像有一款工具是专门探测电脑网络数据.就象Bus Hound看USB数据一样. 但不记得这款软件的名称. 大家在做网络设计时候一般是用哪款工具来调试网络程序的?…
大虾们推荐一本关于制版方面经典的书呗?
不是那种进阶版的;就是普通的入门提高级的。讲解环境最好是DXP,或者往上版本的。谢过了。…
GPIO的输入中断(上升沿和下降沿触发)能区分上升沿和下降
                                 GPIO的输入中断(上升沿和下降沿触发)能区分上升沿和下降沿吗?…
STM8勘误表去那找,谢谢(最好直接给出链接)
                                 RT…
有关长整形(long int)?
今天编程时发现用long int 定义的变量当大于 32768时就会益处!难道iar c语言中没有真正的long int吗??…
片子单向可控硅被烧的原因
日光灯用到一个白炽灯声控开关上,为什么会把片子单向可控硅都烧了?求答案。…
