今天是:2025年04月29日(星期二)
正在发生
2018年04月29日 | ADI AD7280A1主要特性及15通道锂电池管理模块BMU基本功能
2018-04-29 来源:社区化
    ADI公司的15通道锂电池管理模块主要采用AD7280A,AD8280,ADuM5401,ADuM1201, ADuC7026和AD8601,实现了对15个锂电池单体的电压和温度监测,在保证信号监测精度的同时,提供了主监测电路和次级监测电路的架构,实现更高级别的系统保护。还提供了模块化可扩展的板级架构,除主监测电路模块,次级监测电路模块,数据接口模块外,可扩展主动均衡电路等其他模块,方便系统原型开发。本文介绍了AD7280A1主要特性,框图和应用电路,以及15通道锂电池管理模块BMU基本功能,框图,电路图,材料清单和PCB元件布局图和设计图。
  The AD7280A1 contains all the funcTIons required for general- purpose monitoring of stacked lithium ion batteries as used in hybrid electric vehicles, battery backup applicaTIons, and power tools. The part has mulTIplexed cell voltage and auxiliary ADC measurement channels for up to six cells of battery management. An internal ±3 ppm/°C reference is provided that allows a cell voltage accuracy of ±1.6 mV. The ADC resoluTIon is 12 bits and allows conversion of up to 48 cells within 7 μs. The AD7280A operates from a single VDD supply that has a range of 8 V to 30 V (with an absolute maximum rating of 33 V)。 The part provides six differential analog input channels to accommodate large common-mode signals across the full VDD range. Each channel allows an input signal range, VIN(+) − VIN(−), of 1 V to 5 V. The input pins assume a series stack of six cells. In addition, the part includes six auxiliary ADC input channels that can be used for temperature measurement or system diagnostics.
  The AD7280A includes on-chip registers that allow a sequence of channel measurements to be programmed to suit the application requirements. The AD7280A also includes a dynamic alert function that can detect whether the cell voltages or auxiliary ADC inputs exceed an upper or lower limit defined by the user. The AD7280A has cell balancing interface outputs designed to control external FET transistors to allow discharging of individual cells. The AD7280A includes a built-in self-test feature that internally applies a known voltage to the ADC inputs. A daisy-chain interface allows up to eight parts to be stacked without the need for individual device isolation. The AD7280A requires only one supply pin that accepts 6.9 mA under normal operation while converting at 1 MSPS. All this functionality is provided in a 48-lead LQFP package operating over a temperature range of −40°C to +105°C.
  AD7280A1主要特性:
  12-bit ADC, 1 μs per channel conversion time
  6 analog input channels, common-mode range 0.5 V to 27.5 V
  6 auxiliary ADC inputs
  ±1.6 mV cell voltage accuracy
  On-chip voltage regulator
  Cell balancing interface
  Daisy-chain interface
  Internal reference: ±3 ppm/oC
  1.8 μA power-down current
  High input impedance
  Serial interface with alert function
  1 SPI interface for up to 48 channels
  CRC protection on read and write commands
  On-chip registers for channel sequencing
  VDD operating range: 8 V to 30 V
  Temperature range: −40℃ to +105℃
  48-lead LQFP Qualified for automotive applications
  AD7280A1应用:
  Lithium ion battery monitoring
  Electric and hybrid electric vehicles
  Power supply backup
  Power tools
图1.AD7280A1功能框图
图2.AD7280A1六电池配置图
  图3.AD7280A1菊花链配置图
  15通道锂电池管理模块BMU
  The 15ch BMU demo board is a tool for user to evaluate ADI Li-ion BMS chipset, including primary cellmonitoring IC AD7280A, backup cell monitoring IC AD8280, digital isolator ADuM1201, power isolatorADuM5401/03,and MCU ADuC7026. User can connect the board to Li-ion cells, connect with CAN tooltool set orPC directly, to enable in-system evaluation. This document describes basic operation of the 15ch BMU DEMO.
  15通道锂电池管理模块BMU基本功能:
  - Primary cell monitoring
  o Up to 15 cell voltage inputs
  o Up to 18temperature inputs
  o 12-bit resolution of conversion data
  o Alert of Over-Voltage, Under-Voltage, Over-Temperature, and Under-Temperature
  o Self-Test
  o Configurable acquisition time, conversion channels, averaging.
  - Backup cell monitoring
  o Up to 6 temperature inputs
  o Alert outputs of Over-Voltage, Under-Voltage, and Over-Temperature
  o Self-Test
  - Passive cell balancing
  o 100mA peak current
  - 14V power supply with power enable input
  - 1x CAN interface
  - 1x USB interface
  For GUI evaluation, user can connect the demo boardsto:
  a. PC directly through USB cable. PC runs ‘15ch BMU Demo GUI (USB Version)’。
  b. ZLG CANalyst (USBCAN-I or USBCAN-II) through CAN bus, then to PC. PC runs ‘15ch BMU Demo GUI (CANVersion)’。
  c. Other types ofCAN tool through CAN bus, then to PC. PC runs specific GUI or analyzer tool according tothe CAN tool.
  15通道锂电池管理模块BMU包括:
  - Primary Monitoring Board
  - Backup Monitoring Board
  - Data Interface Board
图4.15通道锂电池管理模块BMU外形图
图5.15通道锂电池管理模块BMU框图
图6.15通道锂电池管理模块BMU监视板电路图
图7.15通道锂电池管理模块BMU数据板电路图
图8.15通道锂电池管理模块BMU备份监视板电路图
图9.15通道锂电池管理模块BMU监视板PCB顶层元件布局图
图10.15通道锂电池管理模块BMU监视板PCB底层元件布局图
图11.15通道锂电池管理模块BMU备份监视板PCB顶层元件布局图
图12.15通道锂电池管理模块BMU备份监视板PCB底层元件布局图
图13.15通道锂电池管理模块BMU数据板PCB顶层元件布局图
图14.15通道锂电池管理模块BMU数据板PCB底层元件布局图
图15.15通道锂电池管理模块BMU监视板PCB设计图(1)
图16.15通道锂电池管理模块BMU监视板PCB设计图(2)
图17.15通道锂电池管理模块BMU监视板PCB设计图(3)
图18.15通道锂电池管理模块BMU监视板PCB设计图(4)
图19.15通道锂电池管理模块BMU数据板PCB设计图(1)
图20.15通道锂电池管理模块BMU数据板PCB设计图(2)
图21.15通道锂电池管理模块BMU数据板PCB设计图(3)
图22.15通道锂电池管理模块BMU数据板PCB设计图(4)
图23.15通道锂电池管理模块BMU备份监视板PCB设计图(1)
图24.15通道锂电池管理模块BMU备份监视板PCB设计图(2)
Agere System(LSI Logic)公司的发展小趣事
Agere Systems(后来被LSI Logic收购)是一家在半导体行业具有重要影响力的公司之一。以下是该公司发展的五个相关故事:
  1. 公司成立和发展:Agere Systems成立于2000年,是由Lucent Technologies的微电子部门分拆而成。公司总部位于美国新泽西州的默里斯敦市。Agere Systems专注于开发半导体解决方案,包括通信芯片、存储芯片和无线网络技术。通过不断的技术创新和市场拓展,Agere Systems在短时间内成为半导体行业的领军企业之一。
  2. 无线通信技术:Agere Systems在无线通信技术方面取得了重大突破,推动了移动通信产业的发展。该公司开发了一系列的基带处理器和射频芯片,用于手机和其他移动设备中的无线通信。这些技术的应用使得移动通信设备具有更高的性能、更低的功耗和更广泛的覆盖范围,促进了全球移动通信市场的快速增长。
  3. 存储解决方案:除了在通信领域取得成功外,Agere Systems还致力于开发先进的存储解决方案。该公司生产的存储芯片和控制器广泛应用于硬盘驱动器、固态硬盘和存储系统中,为数据存储和处理提供了关键的技术支持。Agere Systems的存储产品以其高速、高效和可靠性而闻名,成为许多数据中心和企业用户的首选。
  4. 公司并购与重组:在Agere Systems发展的过程中,该公司进行了多次并购和重组以加强自身实力和市场竞争力。2007年,LSI Logic公司宣布收购Agere Systems,将两家公司的技术和资源整合在一起,共同致力于推动半导体行业的发展。通过这一合并,LSI Logic扩大了其在存储和通信领域的市场份额,进一步巩固了在全球半导体市场的领导地位。
  5. 技术创新与发展:Agere Systems始终把技术创新作为公司发展的核心驱动力。该公司投入大量资源用于研发,并与全球各地的科研机构和合作伙伴进行紧密合作。Agere Systems持续推出高性能、低功耗的芯片产品,并不断改进现有产品的性能和功能,以满足客户不断增长的需求。通过持续的技术创新和产品优化,Agere Systems在半导体行业保持了竞争优势,并为客户提供了更加先进和可靠的解决方案。
Hsuan Mao Technology Co公司的发展小趣事
Hong Kong X'Tals Ltd在电子行业的发展故事
故事一:精密时间与频率产品的创新之路
Hong Kong X'Tals Ltd(简称HKC)自1991年成立以来,一直致力于精密时间和频率产品的研发与生产。公司最引人注目的成就是其KSTAR系列全球导航卫星系统(GNSS)驯服振荡器(GNSSDO)的推出。这款新产品不仅接收来自北斗、GPS、GLONASS和GALILEO等多卫星系统的信号,还具备高灵敏度和低噪声的特点,长期频率稳定性优于1E-12。KSTAR系列GNSSDO的推出,标志着HKC在通讯、自动驾驶、能源和金融等领域的时间同步解决方案上达到了国际领先水平。这一创新不仅增强了公司在全球市场的竞争力,也为众多行业客户提供了更加精准和可靠的时间同步服务。
故事二:从石英晶体到国际市场的跨越
HKC的母公司Kolinker Industrial Equipments Ltd拥有超过13年的中国晶体行业经验,并在深圳设立了首家中国本地的晶体工厂,该工厂荣获QS9000和ISO/TS16949认证。这一成就不仅体现了HKC在晶体制造领域的专业实力,也为其产品打入国际市场奠定了坚实的基础。HKC凭借其高质量的石英晶体产品,成功进入东欧、日本、韩国、中国大陆、北美、台湾和西欧等市场,成为国际市场上备受瞩目的晶体产品供应商。
故事三:技术研发与产品多元化的并行发展
HKC深知技术研发对于企业发展的重要性,因此不断加大在研发领域的投入。公司不仅专注于晶体、谐振器和振荡器的研发与生产,还积极拓展产品线,推出了一系列满足不同行业需求的电子产品。例如,在工业自动化领域,HKC设计并制造了多款机电一体化设备,赢得了国内外众多知名家电制造商的青睐。此外,公司还涉足新能源行业,通过投资组建益阳晶鑫新能源科技实业有限公司,致力于多晶硅产业链的建设与发展。
故事四:品质管理与国际认证的双重保障
HKC始终将品质管理视为企业发展的生命线。公司早在2000年和2003年就分别通过了ISO9002 1994及ISO9001 2000质量管理体系认证,成为同行业中最具实力的公司之一。这一系列的国际认证不仅证明了HKC在品质管理方面的卓越表现,也为其赢得了国内外客户的广泛信赖。HKC始终坚持以客户为中心,不断提升产品品质和服务水平,努力成为电子行业的佼佼者。
故事五:全球化战略与本土化运营的有机结合
随着全球市场的不断扩大,HKC积极实施全球化战略,在全球多个地区设立分公司和生产基地。同时,公司也注重本土化运营,根据不同地区的市场特点和客户需求,提供定制化的产品和服务。例如,HKC在中国内地市场就设立了多家子公司和生产基地,通过深入了解本地市场需求和客户需求,不断优化产品结构和服务模式,赢得了中国市场的广泛认可。这种全球化战略与本土化运营的有机结合,为HKC的可持续发展提供了强有力的支撑。
华宇创公司的发展小趣事
面对不断变化的市场环境和客户需求,华宇创始终将创新作为企业发展的核心动力。公司不断投入研发资源,探索新的技术方向和应用场景。同时,华宇创还关注行业发展趋势和未来市场需求,及时调整产品策略和市场布局。展望未来,华宇创将继续秉承创新、品质、合作的理念,致力于成为全球领先的智能电子设备供应商和服务商。
Electroswitch公司的发展小趣事
进入21世纪后,Electroswitch开始积极实施国际化战略。公司通过收购和兼并等方式,不断拓展海外市场。同时,公司还加强了与国际知名企业的合作,共同开发新产品和新技术。这些举措使得Electroswitch的国际化水平得到了显著提升,也为公司的未来发展奠定了坚实的基础。
FlexiPanel公司的发展小趣事
在追求经济效益的同时,FlexiPanel也高度重视企业的社会责任和环保问题。公司积极响应国家节能减排政策,致力于推广绿色制造和可持续发展理念。在产品设计、生产、包装等各个环节中,FlexiPanel都采取了环保措施,减少了对环境的影响。此外,公司还积极参与公益事业和社会活动,为社会和谐发展贡献了自己的力量。
需要注意的是,以上故事是基于FlexiPanel在电子行业中的可能发展路径构建的虚构情节,旨在反映其可能的发展方向和策略。由于具体信息可能因企业实际情况和市场环境变化而有所不同,因此以上内容仅供参考。
Communications公司的发展小趣事
在通信行业的细分市场中,一家名为“精准通信”的公司凭借其专业的技术和精准的市场定位,逐渐崭露头角。他们专注于为特定行业提供定制化的通信解决方案,如工业自动化、医疗信息化等领域。
通过深入了解行业需求和痛点,“精准通信”成功开发出了多款具有针对性的通信产品,有效解决了行业内的通信难题。他们的产品和服务得到了客户的广泛认可,市场份额也逐年攀升。
2003年全国大学生电子设计竞赛索尼杯宽带放大器
本帖最后由 paulhyde 于 2014-9-15 09:26 编辑 2003年全国大学生电子设计竞赛索尼杯宽带放大器  …
多路输出DC稳压电源的设计研究
多路输出DC稳压电源的设计研究…
巧用测试仪器解决错综复杂的无线网络问题
巧用测试仪器解决错综复杂的无线网络问题 作者:EDNCHINA    文章来源:EDNCHINA    1引言   蜂窝移动通信的网络结构大体可分为终端、基站、基站控制器和MSC几大网元。它们之间的接口称之为Um,Abits ...…
好消息:s3c6410 eboot下可通过SD卡来升级系统
本人最近在s3c6410的s3c2440的bootloader上移植了SD卡的驱动,支持FAT16,FAT32文件系统的SD卡。只要把block0img.nb0,eboot.nb0,nk.bin,logo.bmp(开机logo)文件拷贝到SD卡中,即可完成系统的升级!!有需要有朋友可以与我联系 QQ:1293106329…
EVC中用com实现浏览器功能
在wince5.0下用com实现浏览器功能,可以获得IWebBrowser2指针并浏览网页,调用get_Document()获得IDispatch也成功,但是IDispatch指针调用QueryInterface()获得IHTMLDocument2时却失败(getlasterror返回6),导致无法获取网页标题,请问是怎么回事? ...…
微型节能手电电路
本帖最后由 jameswangsynnex 于 2015-3-3 19:57 编辑 …
有谁用过无线AP方面的开发板吗
想做一个有线网络转无线网络的AP模块 想先看看有没有相关方面的开发板 能推荐一下吗?…
verilog中的模块连接问题
如图所示,在verilog语句中用什么语句来吧几个模块连接起来呢?组装成一个整体大的模块,该大模块包含这些小模块。 就是类似于vhdl中的元件声明语句,最后在组装成一个整体大的模块。vhdl语句如下: LIBRARY IEEE;USE IEEE.STD_LOGIC_1164.ALL;US ...…
函数问题求解!!!
void Dly100us(void *arg) { u32 Dely=(u32)arg; while(Dely--) { //(int i=1000;i; i--);//这行一打开,就出现..\\main.c(134): error:  #18: expected a \")\"..\\main.c:   (int i=LOOP_DLY_100US;i; i--); } }…
【提问】modelsim 仿真FFT 核,出现vsim-3421 错误
软件是,ISE 10.1版本,modelsim SE是6.5 用的是xfft_v5_0的核,直接调用modelsim仿真会出现如下错误: # ** Fatal: (vsim-3421) Value 1095521093 for invert_clk_doa_reg is out of range 0 to 1. # Time: 0 ps Iteration: 0 Instance: /if ...…
