今天是:2025年04月29日(星期二)
2018年04月29日 | LTC2311特性及演示板2425A主要特性
2018-04-29 来源:社区化
Linear公司的LTC2311-16是低噪音高速16位SAR5MspsADC,差分输入和宽输入共模范围,单电源3.3V或5V工作,差分输入范围8VP-P,fIN = 2.2MHz时的SNR为81dB,THD为-90dB,16位时±3LSB INL,不会丢失码,主要用在高速数据采集系统,通信,遥控数据采集,图像,光网络,汽车电子和对相马达控制。本文介绍了LTC2311特性,框图,应用电路以及演示板2425A主要特性,连接图,电路图,材料清单和PCB元件布局图。
The LTCR2311-16 is a low noise, high speed 16-bitsuccessive approximaTIon register (SAR) ADC withdifferenTIal inputs and wide input common mode range.
OperaTIng from a single 3.3V or 5V supply, the LTC2311-16 has an 8VP-P differenTIal input range, making it idealfor applications which require a wide dynamic range withhigh common mode rejection. The LTC2311-16 achieves±3LSB INL typical, no missing codes at 16 bits and 81dBSNR typical.
The LTC2311-16 has an onboard low drift (20ppm/℃ max)2.048V or 4.096V temperature-compensated reference andprovides an external 1.25V buffered reference input. TheLTC2311-16 also has a high speed SPI-compatible serialinterface that supports CMOS or LVDS. The fast 5Mspsthroughput with one-cycle latency makes the LTC2311-16ideally suited for a wide variety of high speed applications.
The LTC2311-16 dissipates only 50mW with a 5V supplyand offers nap and sleep modes to reduce the powerconsumption to 5μW for further power savings duringinactive periods.
LTC2311特性:
5Msps Throughput Rate
±3LSB INL (Typ), ±8LSB INL Guaranteed
Guaranteed 16-Bit, No Missing Codes
8VP-P Differential Inputs with Wide Input CommonMode Range
81dB SNR (Typ) at fIN = 2.2MHz
–90dB THD (Typ) at fIN = 2.2MHz
Guaranteed Operation –40℃ to 125℃
Single 3.3V or 5V Supply
Low Drift (20ppm/℃ Max) 2.048V or 4.096V InternalReference with 1.25V External Reference Input
1.8V to 2.5V I/O Voltages
CMOS or LVDS SPI-Compatible Serial I/O
Power Dissipation 50mW at VDD = 5V (Typ)
Small 16-Lead (4mm × 5mm) MSOP Package
LTC2311应用:
High Speed Data Acquisition Systems
Communications
Remote Data Acquisition
Imaging
Optical Networking
Multiphase Motor Control
图1.LTC2311框图:CMOS I/O模式
图2.LTC2311框图:LVDS I/O模式
图3.LTC2311全差分应用电路
演示板2425A
Demonstration circuit 2425A features the LTC®2311 family.With up to 5Msps, these differential, single channel, 16-bit,serial, high speed successive approximation register(SAR) ADCs are available in a 16-lead MSOP package.
The LTC2311 family has an internal 20ppm/°C maximumdrift reference and an SPI-compatible serial interface thatsupports CMOS and LVDS logic. Note the demo board isconfigured for CMOS operation by default; see the noteunder JP3 for LVDS operation. The following text refersto the LTC2311, but applies to all members of the family,the only difference being the sample rate and/or thenumber of bits. The DC2425A demonstrates the DC andAC performance of the LTC2311 in conjunction with theDC890 PScope™ data collection board.
Alternatively, byconnecting the DC2425A into a customer application, theperformance of the LTC2311 can be evaluated directly inthat circuit.
图4.演示板2425A连接示意图
图5.演示板2425A电路图(1)
图6.演示板2425A电路图(2)
演示板2425A材料清单(BOM):
图7.演示板2425A PCB元件布局
我在分析解调移频信号的上下边频信息,可是边频精度总是不能达到要求,希望得到高人指点,报酬没有问题! 您可以直接和我联系,邮箱:liukaihuaaaa@163.com 我是在DSP(TI的28系列)上实现的。… 查看全部问答> |
一款功能强大的STM32F103ZE开发板(第2版,功能更强大)原理图和用户手册 http://item.taobao.com/auction/item_detail-0db2-bd07cdab392006dcd5619d61bdbff81c.jhtml 硬件资源: ■8M晶振作为MCU的时钟,32768晶振用于RTC ■1M字节SRAM,16M字节NOR Flash,128M字节NADN Flash ■2M字节串行Flash,256字 ...… 查看全部问答> |
目前在做1317测试,不知变压器是如何取值;输出3*1W和1×3W 的LED驱动; 还有是否可以附带一些安规,和EMI的一些资料谢谢 我之前沿用的是以下文档的计算方式;之前好像在论坛上发过;由于各个IC的供电电压不一致,可能绕法不会相同;… 查看全部问答> |
2010年4月24日下午,华清远见武汉华嵌中心联手ARM公司在武汉大学举办了一场大型的关于“ARM+Linux+Android”的嵌入式盛宴,由ARM公司技术专家和武汉华嵌知名技术专家联袂奉献,本次讲座的技术主题是目前嵌入式市场上最风靡也是许多大型企业正在使用 ...… 查看全部问答> |
系统是WINCE NET 5.0CORE之前发贴不能回复了,所以再发贴问下! 系统是WINCE NET 5.0CORE 之前问过,没有人能帮忙,现在问下,这个功能能实现吗? 我想我复制到导航仪上的SD卡的文件别人不能复制出来,或者离开我这个SD卡不能够运行。和我的SD卡的ID号码或者别的什么特定的东西绑定。谁能帮忙下啊, 顺便问下 ...… 查看全部问答> |
各位大侠,小弟毕业设计布置了这个任务,老师进度抓地太紧,我有限的知识实在来不及了。 需要在模拟器下实现,TCPMP的0.72RC1源码我已经在EVC下编译好并能成功运行了,下面就是界面问题。 界面设计原型和切片的图片都有了,而且只需要实现音频播 ...… 查看全部问答> |
我定制了一个wince5.0操作系统映像,运行时用远程工具拷贝进去一个应用程序和一个动态库,应用程序调用动态库,在别人定制的设备上运行没有问题,但是在我定制的设备上就不行,加载动态库失败. 如果应用不加载动态库就没有问题.请问定制wince5.0映像时 ...… 查看全部问答> |
