今天是:2025年04月29日(星期二)
2018年04月29日 | 三相马达驱动用的栅极驱动器DRV8305-Q1的主要特性
2018-04-29 来源:社区化
TI公司的DRV8305-Q1是三相马达驱动用的栅极驱动器,提供三个半桥驱动器,每个能驱动高边和低边N沟MOSFET;电荷泵驱动器支持100%占空比。器件满足AEC-Q100标准,4.4-V 到45-V工作电压,栅极峰值电流1.25A和1A,工作温度–40℃到150℃,主要用在三相BLDC和PMSM马达,汽车油泵和水泵,风扇和鼓风电动机。本文介绍了DRV8305-Q1主要特性,功能框图,典型应用电路图以及DRV8305-Q1EVM汽车三相马达栅极驱动评估模块主要特性,框图,电路图和材料清单。
The DRV8305-Q1 device is a gate driver IC for three-phase motor-drive applicaTIons. The device provides three high-accuracy half-bridge drivers, each capable of driving a high-side and low-side N-channel MOSFET. A charge pump driver supports 100% duty cycle and low-voltage operaTIon for cold crank situaTIons. The device can tolerate load dump voltages up to 45-V.
The DRV8305-Q1 device includes three bidirectional current-shunt amplifiers for accurate low-side current measurements that support variable gain settings and an adjustable offset reference.
The DRV8305-Q1 device has an integrated voltage regulator to support an MCU or other system power requirements. The voltage regulator can be interfaced directly with a LIN physical interface to allow low-system standby and sleep currents.
The gate driver uses automatic handshaking when switching to prevent current shoot through. The VDS of both the high-side and low-side MOSFETs is accurately sensed to protect the external MOSFETs from overcurrent conditions. The SPI provides detailed fault reporting, diagnostics, and device configurations such as gain options for the current shunt amplifier, individual MOSFET overcurrent detection, and gate-drive slew-rate control.
Device Options:
DRV8305NQ: Grade 1 with voltage reference
DRV83053Q: Grade 1 with 3.3-V, 50-mA LDO
DRV83055Q: Grade 1 with 5-V, 50-mA LDO
DRV8305NE: Grade 0 with voltage reference
DRV8305-Q1主要特性:
AEC-Q100 Qualified for Automotive Applications
Ambient Operating Temperature Ranges:
Temperature Grade 0(E): –40℃ to 150℃
Temperature Grade 1(Q): –40℃ to 125℃
4.4-V to 45-V Operating Voltage
1.25-A and 1-A Peak Gate Drive Currents
Smart Gate Drive Architecture (IDRIVE & TDRIVE)
Programmable High- and Low-Side Slew-Rate Control
Charge-Pump Gate Driver for 100% Duty Cycle
Three Integrated Current-Shunt Amplifiers
Integrated 50-mA LDO (3.3-V and 5-V Option)
3-PWM or 6-PWM Input Control up to 200 kHz
Single PWM-Mode Commutation Capability
Serial Peripheral Interface (SPI) for Device Settings and Fault Reporting
Thermally-Enhanced 48-Pin HTQFP
Protection Features:
Fault Diagnostics and MCU Watchdog
Programmable Dead-Time Control
MOSFET Shoot-Through Prevention
MOSFET VDS Overcurrent Monitors
Gate-Driver Fault Detection
Reverse Battery-Protection Support
Limp Home-Mode Support
Overtemperature Warning and Shutdown
DRV8305-Q1应用:
Three-Phase BLDC and PMSM Motors
Automotive Fuel and Water Pumps
Automotive Fans and Blowers
图1.DRV8305-Q1功能框图
图2.DRV8305-Q1典型应用电路图
The DRV8305-Q1EVM evaluation module (EVM) is a 4.4 V to 45 V, 25 A, 3-phase motor drive and control system based on the DRV8305-Q1 automotive motor gate driver, TMS320F28027 motor control microcontroller, and CSD18540Q5B NexFET™ power MOSFET. The EVM allows for simple evaluation of the DRV8305-Q1 with a wide array of test points, interfaces, and configurability.
The EVM has onboard reverse battery protection, a regulated 3.3 V supply from the TPS7B6933-Q1 LDO, interface header for all control and feedback signals , and onboard XDS100v2 emulator. The EVM has individual DC bus and phase voltage sense as well as individual low-side current shunt sense for sensorless BLDC control algorithms. The drive stage is fully protected with short circuit, thermal, shoot-through, and undervoltage protection and is easily configurable via an SPI interface.
The EVM is ideal for evaluation and rapidly developing with the DRV8305-Q1, with primary software support through MotorWare using the InstaSPIN-FOC sensorless control solution.
图3.DRV8305-Q1EVM外形图
DRV8305-Q1EVM主要特性:
4.4 V to 45 V Operating Supply Voltage Range
Supports up to 25 A Continuous Output Current
Provides Phase Voltage and Current Feedback ForSensorless BLDC Control Solutions
Complete Brushless DC Control and Drive Stage
Onboard XDS100v2 Emulator
What’s Included
DRV8305-Q1 Evaluation Board
Micro-USB Cable
图4.DRV8305-Q1EVM框图
图5.DRV8305-Q1EVM电路图(1)
图6.DRV8305-Q1EVM电路图(2):MCU DRV
图7.DRV8305-Q1EVM电路图(3):电源
图8.DRV8305-Q1EVM电路图(4):桥
DRV8305-Q1EVM材料清单:
1.802.15简介 2.Microchip ZigBee 协议栈更改版 3.Ti原版开发板说明 4.Zigbee毕业设计提纲 5.ZigBee概述 6.ZigBee技術規格與測試方案之發展 7.单极天线的PCB设计说明(new) 8.基于CC2430的经济实用型Zigbee开发套件 9.基于MSP430 的ZigBee80 ...… 查看全部问答> |
电脑的reset按钮都是非常非常小的,不过Windows出生以后,人们对于reset按钮的应用就频繁起来。当然我们也可以应用Ctrl + Alt + Del,但对于Windows 98致命的Kernel 32毛病,我们还是不得不弯下腰寻找那渺小的reset按钮。国外一名玩友看来厌倦了这 ...… 查看全部问答> |
初学CE,平台是S3C2440 + wince5.0 在网上找了个周立功的按键中断流驱动程序,就按着这个程序开始写了个串口流驱动,程序在WaitForSingleObject()处停止了,无法进入线程处理。可能是什么原因呀? com0是CE调试串口,我写的驱动是对com1操作。 ...… 查看全部问答> |
WinCE5.0 我的CE Device已经有FAT32的分区了 请问如何把CE Device在连接PC后,当作U盘? 看到很多大侠已经实现了: “WinCE5有,支持那个U盘的。那个core os service下面那个usb host support加一个usb storeage class driver,然后加一个devic ...… 查看全部问答> |
请各位参加工作的朋友们给小弟指明一条路~~感谢! 偶现在大三下了,今年11月份就开始找工作了。。眼前想抓紧时间学点东西,好找个好工作·但不知道学什么好,望各位朋友给点建议~ 我想做嵌入式开发,软件,硬件,现在还没有定,准备都要好好学 ...… 查看全部问答> |
三星44B0X+SL811HST,无操作系统,可以正确识别到1.1的U盘,但因为现在大多是2.0的U盘,发现有的2.0的U盘在做完 GetMaxLUN后,如果做Inquiry,也可以成功,但接下来做ReadFormatCapacity时,BulkIn会产生STALL,也就是读不到 FormatCapacity的内 ...… 查看全部问答> |
做一个控制摄像头的单片机... 控制IC的参数 调节参数是白天适当的变暗 晚上适当的变亮 使效果最佳 \'要求I2C接口\' 市面上哪些型号的单片机能满足功能而又实惠的&n ...… 查看全部问答> |
【低功耗】满足低功耗FPGA需求,Actel推出5μW产品延长电池寿命 为了满足便携式应用对功耗的严苛要求,Actel公司宣布推出业界最低功耗的现场可编程门阵列(FPGA)--IGLOO系列。这个以Flash为基础的产品系列的静态功耗为5μW,是最接近竞争产品功耗的四分之一;与目前领先的PLD产品比较,更可延长便携式应用的电池寿 ...… 查看全部问答> |
