今天是:2025年05月31日(星期六)
2018年05月31日 | 马达驱动评估板STEVAL-VNH5019A主要特性,电路图
2018-05-31 来源:互联网
ST公司的VNH5019A-E是全桥马达驱动器,集成了双路高边驱动器和两个低边开关,三个芯片封装在MulTIPowerSO-30封装中,引线框是电绝缘的.汽车级产品,输出电流3A,3V CMOS兼容输入,PWM频率高达20kHz,用于各种汽车应用.本文介绍了VNH5019A主要特性,框图和 种应用电路,以及马达驱动评估板STEVAL-VNH5019A主要特性,电路图和材料清单.
The VHN5019A-E is a full bridge motor driver intended for a wide range of automoTIve applicaTIons. The device incorporates a dual monolithic high-side drivers and two low-side switches. The high-side driver switch is designed using STMicroelectronics’ well known and proven proprietary VIPower® M0 technology that allows to efficiently integrate on the same die a true Power MOSFET with an intelligent signal/protecTIon circuit.
The three dice are assembled in MultiPowerSO-30 package on electrically isolated lead-frames. This package, specifically designed for the harsh automotive environment offers improved thermal performance thanks to exposed die pads. The input signals INA and INB can directly interface to the microcontroller to select the motor direction and the brake condition.
The DIAGA/ENA or DIAGB/ENB, when connected to an external pull-up resistor, enable one leg of the bridge. They also provide a feedback digital diagnostic signal. The CS pin allows to monitor the motor current by delivering a current proportional to its value when CS_DIS pin is driven low or left open. The PWM, up to 20 KHz, lets us to control the speed of the motor in all possible conditions. In all cases, a low-level state on the PWM pin turns-off both the LSA and LSB switches. When PWM rises to a high-level, LSA or LSB turn-on again depending on the input pin state.Output current limitation and thermal shutdown protects the concerned high-side in short to ground condition.
The short to battery condition is revealed by the overload detector or by thermal shutdown that latches off the relevant low-side. Active VCC pin voltage clamp protects the device against low energy spikes in all configurations for the motor.
CP pin provides the necessary gate drive for an external n-channel PowerMOS used for reverse polarity protection.
VNH5019A主要特性:
■ ECOPACK®: lead free and RoHS compliant
■ Automotive Grade: compliance with AEC guidelines
■ Output current: 30 A
■ 3 V CMOS compatible inputs
■ Undervoltage and overvoltage shutdown
■ High-side and low-side thermal shutdown
■ Cross-conduction protection
■ Current limitation
■ Very low standby power consumption
■ PWM operation up to 20 khz
■ Protection against:
– Loss of ground and loss of VCC
■ Current sense output proportional to motor current
■ Charge pump output for reverse polarity protection
■ Output protected against short to ground and short to VCC
图1. VHN5019A框图
图2. VHN5019A带电池反向保护的DC-20kHz PWM应用电路(选择A)
图3. VHN5019A带电池反向保护的DC-20kHz PWM应用电路(选择B)
图4. VHN5019A多个马达驱动配置图
STEVAL-VNH5019A offers dedicated power stage and controls suitable for electric DC motor driving. This evaluation board comes pre-assembled with VNH5019A H-bridge belonging to the VNH Motor Driver series based on VIPower®proprietary technology. Typical applications are Windows Lift, Sliding Door, Seat regulation.
This Evaluation Board consists of a motherboard (STM8 Universal Board) and a daughterboard.
The motherboard, based on STM8 microcontroller, provides the logic section for monitoring and driving the VNH5019A assembled in the daughterboard.
With the aim to make simpler the board usage and settings, ST provides a dedicated and user-friendly software with a Graphic User Interface (GUI). This enables the user to set VNH5019A parameters (PWM, Motor direction…) and at the same time it shows real time device diagnostic information like current output evolution, battery voltage monitoring, board temperature and much more.
马达驱动评估板STEVAL-VNH5019A主要特性:
Handling up to 30 A of maximum motor current output
Device thermal protection
Programmable PWM operation (up to 20 kHz)
Protection against loss of ground and loss of VCC
Motor current monitoring (thanks to VNH5019A current sense output)
On-board charge pump output for reverse polarity protection
Device output protected against short to ground and short to VCC
图5. 马达驱动评估板STEVAL-VNH5019A外形图
图5. STEVAL-VNH5019A子板电路图(1)
图6. STEVAL-VNH5019A子板电路图(2)
图7. STEVAL-VNH5019A子板PCB设计图:顶层
图8. STEVAL-VNH5019A子板PCB设计图:底层
图9. STEVAL-VNH5019A STM8主板电路图:I/O和本体应用
图10. STEVAL-VNH5019A STM8主板电路图:STM8和电源
图11. STEVAL-VNH5019A STM8主板电路图:USB接口
图12. STEVAL-VNH5019A STM8主板顶层PCB设计图
图13. STEVAL-VNH5019A STM8主板底层PCB设计图
Data Device Corporation公司的发展小趣事
Data Device Corporation(DDC)成立于1964年,总部位于美国纽约。在创立之初,DDC就专注于为军事和商业航空领域提供高质量的数据接口产品。凭借其卓越的技术实力和对市场的敏锐洞察,DDC迅速在电子行业中崭露头角。通过与各大军事机构和航空公司的紧密合作,DDC不断推出符合市场需求的新产品,逐步奠定了自己在行业中的领先地位。
Crouzet公司的发展小趣事
随着业务的不断发展,Crouzet公司于1989年和1992年分别成功兼并了法国Syreles公司及墨西哥Gordos公司。这一系列的兼并活动不仅增强了公司的实力,还进一步扩大了公司的业务范围。此后,Crouzet开始在全球范围内布局,陆续在美国、德国、英国、荷兰、比利时、瑞士、瑞典等国设立分公司,形成了一个覆盖全球的销售网络。
CML Microcircuits公司的发展小趣事
在1968年,电子行业正迎来一场技术革新。在这个充满机遇的时代,CML Microcircuits公司应运而生。初创时期的CML专注于研发单芯片解决方案,而不是传统的标准组件组合。这一创新理念使CML在行业中脱颖而出。公司的第一个产品——频率敏感开关,凭借其卓越的性能和可靠性,迅速赢得了市场的认可。这款产品不仅销售了30多年,而且至今仍在某些应用中发挥着关键作用。
科通(COMTEK)公司的发展小趣事
面对快速变化的电子行业市场,科通技术始终坚持以技术创新为驱动,不断推动公司的转型升级。公司加大在研发方面的投入,积极引进先进的技术和设备,提升产品的技术含量和附加值。同时,科通技术还不断拓展业务领域,从单一的元器件分销逐渐发展到提供全方位的技术整合方案和应用方案,为客户提供更加全面、专业的服务。
GPD Optoelectronics Corp公司的发展小趣事
为了进一步扩大市场份额,科通技术积极实施国际化战略。公司在全球范围内设立了多个办事处和分公司,加强了与国际市场的联系和合作。同时,科通技术还积极参加国际电子展会和论坛等活动,展示公司的最新产品和技术成果,提升了公司的国际知名度和影响力。
Dowosemi公司的发展小趣事
随着业务的不断发展,Dowosemi公司开始积极拓展海外市场。他们通过参加国际展会、与海外客户建立合作关系等方式,将产品推向全球。在海外市场拓展的过程中,Dowosemi公司也遇到了不少挑战,但他们凭借优质的产品和服务,成功克服了这些困难。如今,Dowosemi公司的产品已经遍布全球多个国家和地区,为公司的发展注入了新的活力。
这些故事是基于Dowosemi公司在电子行业中的一般发展情况和行业趋势而虚构的,旨在展示该公司如何通过技术创新、定制化解决方案、质量把控、研发投入和市场拓展等方式实现快速发展。
开幕式升降舞台部分有“石家庄造”
开幕式升降舞台部分有“石家庄造” 世界瞩目的北京奥运会开幕式在期待中揭开了面纱。开幕式大气磅礴的气势、绚丽缤纷的色彩吸引了每一位观众。产生这样美妙的效果,除了大师的导演,位于鸟巢中央升降舞台也起到不可估量的作用。记者了解到,开幕式 ...…
实用电源电路集锦
实用电源电路集锦…
苦读四年 月薪等同农民工?
调查:大学毕业生与农民工收入仅高200—300元     专家:收入多少与身份无关     近日,人力资源和社会保障部部长尹蔚民表示:“有可能,同龄刚毕业的大学生与农民工收入逐步趋向一致”。 昨(10)日,记者来到成都市人力资 ...…
PLC
在设计PLC电气电路时有什么方法,具体的思维像设计数字电路一样的方法去实现自动控制!!充分利用好:那些接触器,如何的去联接组合呢?请哪位高手指点下!!比如说用接触器开关去实现控制电机起动!!由星型到三角型起动!1…
华为公司2007年社会招聘
华为内部推荐 招聘对象:        04,05年本科及硕士,06年硕士生,07年的应届生不招, 学校要求省重点大学及以上,通信、电子、计算机、经济类、管理类等相关专业毕业。 招聘的是正式“华为员工”,待遇一般不低于07年的 ...…
[DIY]二十四小时的感动(古典版I) 自制QS30-1辉光管电子时钟【附百张图】
         辉光管是电子管的一种,属于很古老的数码显示器件,在没有LED的年代,显示数字和符号就靠它。这种管子现在应该算古董了,这次DIY用的QS30-1辉光管大部分都是70年代和80年代生产的。在国外,有不 ...…
假期你准备怎么安排学习FPGA?
还有一天就要放假了,一个学期的学习生活算是告一段落。这个假期还是挺长的,有近一个月的时间,大家的打算如何度过呢?随便聊聊,看看谁有更好的主意,我们怎么样安排?做点什么小的实践来提高自己的FPGA的水平呢?我计划把实验室的FPGA的板子带回 ...…
我想同时用定时器做PWM和捕获以及做一个时间基准。
不知道怎么设置呢。最好都中断使能。那位大侠能帮帮我啊?…
管脚复用疑问
PE4 (4)括号中的4是什么意思啊…
