今天是:2025年05月31日(星期六)
2018年05月31日 | KIT33905D5EKEVBE主要特性,建立框图,电路图,和PCB元件
2018-05-31 来源:互联网
Freescale公司的MC33903/4/5是第二代的系统基础芯片(SBC),能作为MCU的先进电源管理,并集成了几种先进的集成电路如传感器和CAN收发器,内置了增强高速CAN接口(ISO11898-2和-5),以及本地和总线故障诊断,保护与故障安全操作模式.主要用在航空和水下系统,汽车和机器人系统,农场设备,灯和电感负载控制,DC马达控制,工业激励控制等.本文介绍了MC33903/4/5系列产品主要特性,框图和简化应用框图,评估板
KIT33905D5EKEVBE主要特性,建立框图,电路图,材料清单和PCB元件布局图和走线图.
The 33903/4/5 is the second generaTIon family of the System Basis Chip (SBC). It combines several features and enhances present module designs. The device works as an advanced power management unit for the MCU with addiTIonal integrated circuits such as sensors and CAN transceivers. It has a built-in enhanced high-speed CAN interface (ISO11898-2 and -5) with local and bus failure diagnosTIcs, protecTIon, and fail-safe operation modes. The SBC may include zero, one or two LIN 2.1 interfaces with LIN output pin switches. It includes up to four wake-up input pins that can also be configured as output drivers for flexibility. This device is powered by SMARTMOS technology.
This device implements multiple Low-power (LP) modes, with very low-current consumption. In addition, the device is part of a family concept where pin compatibility adds versatility to module design.
The 33903/4/5 also implements an innovative and advanced fail-safe state machine and concept solution.
MC33903/4/5系列产品主要特性:
•Voltage regulator for MCU, 5.0 or 3.3 V, part number selectable, with possibility of usage external PNP to extend current capability and share power dissipation
•Voltage, current, and temperature protection
•Extremely low quiescent current in LP modes
•Fully-protected embedded 5.0 V regulator for the CAN driver
•Multiple undervoltage detections to address various MCU specifications and system operation modes (i.e. cranking)
•Auxiliary 5.0 or 3.3 V SPI configurable regulator, for additional ICs, with overcurrent detection and undervoltage protection
•MUX output pin for device internal analog signal monitoring and power supply monitoring
•Advanced SPI, MCU, ECU power supply, and critical pins diagnostics and monitoring.
•Multiple wake-up sources in LP modes: CAN or LIN bus, I/O transition, automatic timer, SPI message, and VDD overcurrent detection.
•ISO11898-5 high-speed CAN interface compatibility for baud rates of 40 kb/s to 1.0 Mb/s
•Scalable product family of devices ranging from 0 to 2 LINs which are compatible to J2602-2 and LIN 2.1
/4/5系列产品应用:
•Aircraft and marine systems
•Automotive and robotic systems
•Farm equipment
•Industrial actuator controls
•Lamp and inductive load controls
•DC motor control applications requiring diagnostics
•Applications where high-side switch control is required
图1.MC33905内部框图
图2.MC33904内部框图
图3.MC33903内部框图
图4.MC33905D简化应用框图
图5.MC33905S简化应用框图
图6.MC33904简化应用框图
图7.MC33903简化应用框图
评估板KIT33905D5EKEVBE
The KIT33905D5EKEVBE supports the 33905D5 and 33904 devices, which are the second generation family of System Basis Chips, which combine several features and enhance present module designs. The devices work as an advanced power management unit for the MCU and additional integrated circuits such as sensors, CAN transceivers. They have a built-in enhanced high speed CAN interface (ISO11898-2 and -5), with local and bus failure diagnostics, protection, and fail safe operation mode. The SBCs may include one or two LIN 2.0 interfaces with LIN output pin switches. The 33904/5 include 2 or 3 wake-up input pins than can also be configured as output drivers for flexibility.
评估板KIT33905D5EKEVBE主要特性:
Nominal operating supply voltage range of 5.5 V to 27 V
Individually routed power supply inputs for VSUP1 and VSUP2
5.0/3.3 V regulator for MCU with an external PNP ballast transistor to increase current capability
Multiple CAN Bus termination options supported via socket
Two high/low side I/Os (SPI configurable) accessible through test points
Status of I/O-0 and I/O-1 indicated by an LED (dependent on jumper configuration)
Debug mode/watchdog configuration via jumper settings
MUX output voltage accessible through a test point and external resistor selectable through jumper
3.3 V or 5.0 V output voltage test point VAUX (SPI configurable)
I_WAKE_I test point to enable a FET and load VDD with current to wake-up the SBC
LIN1_T and LIN2_T test points to monitor I/O voltages (SPI configurable)
I/O-0, I/O-1, VAUX, 5V_CAN, SAFE, and VDD status indicated by LED
100 mil 2x8 pin standard header connector for SPI communication
100 mil 16 pin standard header connector for custom MCU board connections
图8. 评估板KIT33905D5EKEVBE/KIT33905BD3EVBE外形图
评估板KIT33905D5EKEVBE/KIT33905BD3EVBE包括:
•KIT33905D5EKEVBE or KIT33905BD3EVBE Hardware
•CD33905 (includes SPIGen Software)
•CABLE, RIBBON FLAT 16 PIN ASSY, 0.100" PITCH, 6" LENGTH
图9. 评估板KIT33905D5EKEVBE/KIT33905BD3EVBE建立配置图
图10. 评估板KIT33905D5EKEVBE电路图
评估板KIT33905D5EKEVBE材料清单:
图11. 评估板KIT33905D5EKEVBE顶层PCB元件布局图
图12. 评估板KIT33905D5EKEVBE顶层PCB走线图
图13. 评估板KIT33905D5EKEVBE底层PCB走线图
Display Engineering Services公司的发展小趣事
以下是五个电子行业里Display Engineering Services公司发展起来的相关故事:
故事一:
在科技日新月异的今天,XX公司凭借其在Display Engineering Services领域的专业技术和创新能力,逐渐崭露头角。起初,XX公司只是一家专注于显示屏研发的小型技术公司,但在市场需求的驱动下,公司意识到为客户提供定制化的显示屏解决方案具有巨大潜力。于是,XX公司开始将重心转移到Display Engineering Services上,通过深入了解客户需求,提供从设计、制造到安装的全流程服务。经过数年的努力,XX公司不仅积累了丰富的经验,还建立起一支专业的技术团队,赢得了业界的广泛认可。
故事二:
YY公司的发展历程颇具传奇色彩。该公司最初只是一家为电子产品提供显示屏配件的供应商。然而,随着市场竞争的加剧,YY公司意识到单纯提供配件已无法满足客户需求。于是,公司决定转型为Display Engineering Services提供商,致力于为客户提供显示屏的定制设计和优化服务。YY公司凭借其卓越的技术实力和敏锐的市场洞察力,成功转型,并在短时间内实现了业务的快速增长。如今,YY公司已成为行业内的佼佼者,其显示屏解决方案广泛应用于各个领域。
故事三:
ZZ公司是一家专注于Display Engineering Services的创业公司。在创立之初,公司面临着资金短缺、技术瓶颈等诸多困难。然而,创始人凭借对技术的热爱和对市场的敏锐洞察,带领团队攻克了一个又一个技术难题。同时,ZZ公司还积极寻求外部合作,与多家知名企业建立了紧密的合作关系,共同开发具有市场竞争力的显示屏产品。在团队成员的共同努力下,ZZ公司逐渐在Display Engineering Services领域崭露头角,成为了一家备受瞩目的创新型企业。
故事四:
AA公司的发展历程充满了挑战与机遇。在成立初期,公司面临着激烈的市场竞争和不断变化的客户需求。为了应对这些挑战,AA公司决定加大研发投入,不断提升自身的技术实力。同时,公司还积极拓展国际市场,与全球多家知名企业建立了合作关系。通过不断的技术创新和市场拓展,AA公司逐渐在Display Engineering Services领域树立了良好的品牌形象,赢得了客户的信赖和支持。
故事五:
BB公司是一家历史悠久的Display Engineering Services企业。多年来,公司始终坚持以客户需求为导向,不断提升服务质量和技术水平。为了保持竞争优势,BB公司不断引进先进的生产设备和技术人才,加强内部管理和质量控制。同时,公司还积极参与行业交流和合作,与国内外多家知名企业建立了良好的合作关系。在多年的发展中,BB公司积累了丰富的经验和技术优势,成为了行业内的领军企业之一。其显示屏解决方案广泛应用于各个领域,并获得了多项国内外技术专利和荣誉。
Electronic公司的发展小趣事
华为,作为中国的科技巨头,其在电子行业的发展历程中展现出了强大的技术实力和全球视野。华为在通信领域取得了多项技术突破,如5G技术的领先和智能手机拍照技术的创新。同时,华为还积极拓展全球市场,与全球运营商建立了广泛的合作关系。然而,面对国际市场的复杂环境和竞争压力,华为也面临着诸多挑战和不确定性。
FOTEK公司的发展小趣事
福禄克并未止步于传统电子测试工具领域,而是积极探索新的增长点。2005年,公司推出了一系列室内空气质量(IAQ)测试工具,旨在为HVAC、建筑物维修和IAQ专业人员提供综合的精密仪器产品组合。这些产品凭借其精确性、可靠性和易用性,迅速获得了市场的认可。此后,福禄克进一步拓展至生物医学领域,推出了电气安全性测试仪、病患模拟器等先进设备,在生物医学测试和模拟产品领域取得了领先地位。
普芯达电子(Chipswinner)公司的发展小趣事
在电子行业中,技术创新是企业持续发展的关键。普芯达电子深知这一点,因此始终将技术创新作为公司发展的核心驱动力。公司不断加大研发投入,引进先进技术和设备,培养了一支高素质的研发团队。通过持续的技术创新和产品升级,普芯达电子不断推出具有市场竞争力的新产品,为客户提供了更加优质和多样化的选择。
ERNI公司的发展小趣事
进入21世纪,ERNI继续深耕连接器技术。他们成功研发出世界上第一个DIN连接器,并随后发展了各种电路板连接器和输入/输出连接器。其中,2mm连接器成为ERNI的明星产品之一。凭借其优越的性能和可靠的品质,ERNI的2mm连接器在国内军工领域得到广泛应用,并赢得了广大客户的信赖和好评。
CHENMKO公司的发展小趣事
DSP也超频
今天把自己做的DM642板超了一下频。用的-7后缀的SDRAM(143M),调整了一下PLL芯片的倍频设置。将原先的133M频率调为150M,并将电路板上的四个钽电容全部拆下,剩下全板3.3V、1.8V、1.4V共18个10u瓷片电容及其他小瓷片电容。 150M已经超过 ...…
请教电源一个职业规划问题--迷途之中的一只小书虫
请教 一个职业规划问题:     \"闻道有先后,术业有专攻\",书虫也是慕名而来.目的只有一个,请斑竹赐教.     目前我在公司负责LED的驱动的电源一块,听别人说的,开关电源是头头,于是,苦命研究此类电源,不想各类此电源还真纷繁复 ...…
学习DMB-T中。。。。
DMB-T的学习,希望大家给些指引,谢谢…
wince下建立和访问数据库的问题,请大家看我的代码
代码是复制一个实验教程上的例子,教程上使用vs2005做的,我是用evc4, 在wince里我已经将adoce31.dll,adoxce31.dll等8个dll通过如下方式注册成功: ok3=CreateProcess(_T(\"\\RegSvrCe\"),_T(\"/s \\Windows\\\\Adocedb31.dll\"),(8个都成功了 ...…
有朋友在WinCE下做过证书倒入和认证么?请教个问题。。。
有个项目,要在WinCE6.0上面写个VC的应用程序,倒入一个X.509的证书,DER格式的。然后用这个证书对一个文件进行签名,请问有人做过么? 我看了看MSDN,好像要用到CryptToAPI的函数,一大堆,看了以后还是很晕,希望有经验的朋友能够指点一下,如果 ...…
CreateFile为什么返回参数错误?
CString strLastError; CString strFilePath = _T(\"\\\\windows\\\\wz.txt\");         HANDLE hIDFile =  CreateFile(strFilePath,GENERIC_READ,FILE_SHARE_READ,NULL,           &nb ...…
MSP430 LaunchPad学习插曲——资料放送
MSP430F123单相多费率电表   MSP430FE42X单相多功能防窃电电表方案   MSP430程序设计思路   MSP430基础时钟   利尔达三表方案   位移测量   无线点滴监测系统   智能家居方案   直接上传 ...…
cc2520接收问题,一直接收不到正确数据?
cc2520接收问题,一直接收不到正确数据?能发送出正确的数据和设置信道,但是接收只能进中断,每次只能读出很奇怪的数据,下面是接收程序。那位帮忙看看!       CS_CC2520 = 0;     SSI0_Enable();  &n ...…
