今天是:2025年06月03日(星期二)
2018年06月03日 | STM32 I2C 硬件中断方式实现方法
2018-06-03 来源:eefocus
流程图如下:
I2C 中断处理函数如下:
* @brief This function handles I2C1 Event interrupt request, tx, rx
* buffer and number of bytes will be changed.
* @param None
* @retval None
void I2C1_EV_IRQHandler(void)
#ifdef ARC_I2C_IRQ
uint32_t i2cEvent;
I2C_param_struct __IO *pI2C_param;
pI2C_param = ARC_get_I2C_param();
i2cEvent = I2C_GetLastEvent(I2C1);
switch (i2cEvent)
case I2C_EVENT_MASTER_MODE_SELECT:/* EV5 */
if(pI2C_param->I2C_DIRECTION == ARC_I2C_DIRECTION_TX)
I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Transmitter);
else
I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Receiver);
break;
/* Master Transmitter -------------------------------------------------------*/
case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
I2C_SendData(I2C1, pI2C_param->SubAddr);
if(pI2C_param->TxNumOfBytes == 0)
I2C_ITConfig(I2C1, I2C_IT_BUF, DISABLE);
break;
case I2C_EVENT_MASTER_BYTE_TRANSMITTING: /* Without BTF, EV8 */
if(pI2C_param->TX_I2C_Index < pI2C_param->TxNumOfBytes)
I2C_SendData(I2C1, pI2C_param->TxData[pI2C_param->TX_I2C_Index++]);
else
break;
case I2C_EVENT_MASTER_BYTE_TRANSMITTED: /* With BTF EV8-2 */
if(pI2C_param->TX_Generate_stop == 1)
I2C_GenerateSTOP(I2C1, ENABLE);
I2C_ITConfig(I2C1, I2C_IT_EVT, DISABLE);
else
pI2C_param->I2C_DIRECTION = ARC_I2C_DIRECTION_RX;
I2C_ITConfig(I2C1, I2C_IT_BUF, ENABLE);
I2C_GenerateSTART(I2C1, ENABLE);
break;
/* Master Receiver -------------------------------------------------------*/
case I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED:
if(pI2C_param->RX_I2C_Index == (pI2C_param->RxNumOfBytes - 1))
I2C_AcknowledgeConfig(I2C1, DISABLE);
break;
case I2C_EVENT_MASTER_BYTE_RECEIVED:
pI2C_param->RxData[pI2C_param->RX_I2C_Index++] = I2C_ReceiveData (I2C1);
break;
default:
break;
#endif
上一篇:STM32 I2C硬件
来源:http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=657257&bbs_page_no=1&bbs_id=9999 终于调通了!哈哈: 我也拿出来跟大家分享一下! 里面的内容什么都不用该,就该一下前面宏定义就可以了! 只需调用gettemp();就可以了!出口参数 ...… 查看全部问答> |
我现在手里有一块s3c2410(arm920t,flash:16m,sdrom:64m)的开发板,现在用PPCBOOT2.0.0引导LINUX启动一切正常。我现在想把用这块开发板,运行vxworks,应该如何做呢,请高手帮忙,谢谢!!!!急… 查看全部问答> |
在用stm32f103vc 100pin做项目的时候,遇到一个问题。 我们想用103vc的fmsc挂5个外设。这5个外设的地址有4个只需要2根地址线,另外一个需要10根地址线。它们的数据线都是8位的。 因为用的103vc 100pin的,所以它的A0~A15和D0~D15是复用的, ...… 查看全部问答> |
RT.不知道为什么.如果不用TIM2计时.直接用DMA串口接收.是没问题的.但是用TIM2延时一阵子.就不能收到了... 大家帮帮忙,有必要我就上程序… 查看全部问答> |
最近测试TI的一款LED驱动,型号为LM3429. 测试条件: 输入电压:6~9V(实际使用电池供电) 输出电压:24V 输出电流:0.35A 外部PWM频率:25K 使用TI的WEBENCH设计电路如下: LM3429可调光电路如下: 问题如下: 在实际测试应用不带 ...… 查看全部问答> |
