今天是:2025年06月08日(星期日)
2018年06月08日 | STM32的串口1发送、接收DMA模式函数配置
2018-06-08 来源:eefocus
**函数名称:void USART1_Config(void)
**函数功能:USART1串口引脚初始化
**输入参数:无
**返回参数:无
**函数调用:内部调用
static void USART1_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
RCC_APB2PeriphClockCmd(USART1_RCC | RCC_APB2Periph_USART1, ENABLE); //打开串口时钟
/* USART1 GPIO config */
/* Configure USART1 Tx (PA.9) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = USART1_TX;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(USART1_PORT, &GPIO_InitStructure);
/* Configure USART1 Rx (PA.10) as input floating */
GPIO_InitStructure.GPIO_Pin = USART1_RX;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USART1 mode config */
USART_InitStructure.USART_BaudRate = BOOTRATE;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
//USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //使能串口1中断
USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE); //使能USART1发送DMA请求
USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE); //使能USART1接收DMA请求
USART_Cmd(USART1, ENABLE); //启动串口
**函数名称:void USART1_NVIC_Configuration(void)
**函数功能:USART1串口中断初始化
**输入参数:无
**返回参数:无
**函数调用:内部调用
static void USART1_NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
//设置NVIC优先级分组为Group2:0-3抢占式优先级,0-3的响应式优先级
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //串口接收中断打开
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = USART1_IRQn_Priority; //设置中断优先级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
**函数名称:void USART1_Init(void)
**函数功能:USART1串口初始化
**输入参数:无
**返回参数:无
**函数调用:内部调用
static void USART1_Init(void)
USART1_Config(); //USART1引脚功能初始化
USART1_NVIC_Configuration(); //USART1中断初始化
**函数名称:static void DMA1_USART1_TX_Configuration(void)
**函数功能:DMA1_USART1_TX初始化
**输入参数:无
**返回参数:无
**函数调用:外部调用
DMA_InitTypeDef DMA_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //开启DMA时钟
* DMA设置:
* 设置DMA源:内存地址&串口数据寄存器地址
* 方向:内存-->外设
* 每次传输位:8bit
* 传输大小DMA_BufferSize=SENDBUFF_SIZE
* 地址自增模式:外设地址不增,内存地址自增1
* DMA模式:一次传输,非循环
* 优先级:高
DMA_DeInit(DMA1_Channel4); //串口1的DMA传输通道是通道4
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART1->DR); //设置DMA源
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)USART1_SendBuff; //DMA内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //外设作为DMA的目的端
DMA_InitStructure.DMA_BufferSize = USART1_SENDBUFF_SIZE; //传输大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址不增加
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址自增1
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //外设数据宽度8bit
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //内存数据宽度8bit
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //DMA_Mode_Normal(只传送一次), DMA_Mode_Circular (不停地传送)
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //(DMA传送优先级为高)
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //非内存到内存
DMA_Init(DMA1_Channel4, &DMA_InitStructure);
DMA_ITConfig(DMA1_Channel4, DMA_IT_TC, ENABLE); //使能DMA通道4传输完成中断
**函数名称:static void DMA1_USART1_TX_NVIC_Configuration(void)
**函数功能:DMA中断初始化
**输入参数:无
**返回参数:无
**函数调用:外部调用
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
**函数名称:static void DMA1_USART1_TX_Init(void)
**函数功能:USART1串口初始化
**输入参数:无
**返回参数:无
**函数调用:外部调用
DMA1_USART1_TX_Configuration();
DMA1_USART1_TX_NVIC_Configuration();
**函数名称:static void DMA1_USART1_RX_Configuration(void)
**函数功能:DMA1_RX初始化
**输入参数:无
**返回参数:无
**函数调用:外部调用
DMA_DeInit(DMA1_Channel5);
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&USART1->DR; //DMA外设基地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)USART1_RecvBuff; //DMA内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外设作为数据传输的来源
DMA_InitStructure.DMA_BufferSize = USART1_RECVBUFF_SIZE; //DMA缓存大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;//外设数据宽度8bit
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //优先级:高
DMA_Init(DMA1_Channel5, &DMA_InitStructure); //初始化DMA
DMA_ITConfig(DMA1_Channel5, DMA_IT_TC, ENABLE); //使能DMA通道5传输完成中断
DMA_Cmd(DMA1_Channel5, ENABLE); //使能DMA通道5
** 函数名称 :DMA1_USART1_RX_NVIC_Configuration(void)
** 功能说明 :NVIC初始化
** 输入参数 :无
** 输出参数 :无
** 返回参数 :无
** 注 意 :无
static void DMA1_USART1_RX_NVIC_Configuration(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel5_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
**函数名称:void DMA1_USART1_RX_Init(void)
**函数功能:USART1串口初始化
**输入参数:无
**返回参数:无
**函数调用:外部调用
static void DMA1_USART1_RX_Init(void)
DMA1_USART1_RX_Configuration();
DMA1_USART1_RX_NVIC_Configuration();
**函数名称:static void DMA1_USART1_Init(void)
**函数功能:DMA1串口初始化
**输入参数:无
**返回参数:无
**函数调用:外部调用
DMA1_USART1_TX_Init();
DMA1_USART1_RX_Init();
**函数名称:void USART1_Send_Buf(u8 *buf , unsigned int len)
**函数功能:通过DMA发送串口数据
**输入参数:data -- 发送数据
**返回参数:0--发送不成功
** 1--发送成功
**函数调用:外部调用
* DMA设置:
* 方向:内存-->外设
* 每次传输位:8bit
* DMA模式:一次传输,非循环
* 优先级:高
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)buf; //DMA内存基地址
DMA_InitStructure.DMA_BufferSize = len; //传输大小
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //DMA_Mode_Normal(只传送一次), DMA_Mode_Circular (不停地传送)
DMA_Cmd(DMA1_Channel4, ENABLE);
大家好,MicrosoftActiveSync 我设置文件同步后,我的桌面会有“WM_Administrat My Documents”这个文件, 可是,我电脑重启以后,我还要重新设置文件同步,“WM_Administrat My Documents”就已经没用了, 这是怎么回事啊,我现在需要一个固定的 ...… 查看全部问答> |
STM8,PA2外部输入高,GPIO_ReadInputPin(GPIOA,GPIO_PIN_2)返回多少? 函数原型是 BitStatus GPIO_ReadInputPin(GPIO_TypeDef* GPIOx, GPIO_Pin_TypeDef GPIO_Pin)… 查看全部问答> |
请问大家,2812是一个32位的处理器,是不是意味着再想起内部saram存取数据时都是一次存取32位吗?如果是的话,我现在用的AD是16位的,那存进ram时是不是2812的高16位清0啊,还是分两个字节存取阿?还有就是2812的数据线只有16根,这就意味着2812访 ...… 查看全部问答> |
【M4开发板Hanker试用狂-Shower.Xu】-10、《寄人》-从SD卡更新字库到Flash 最近学习遇到障碍了,换了个方向,捣鼓了一下汉字库的更新,方法很多,从SD更新可能方便些。谁知道本以为简单的一个程序,也花费了快一周的时间....老规矩,图,视频,代码$(\'swf_dyb\').innerHTML=AC_FL_RunContent(\'width\', \'550\', \'height ...… 查看全部问答> |
2600-PCT-x/4200-PCT-x参数曲线跟踪仪配置 可配置功率电平 : – From 200V to 3kV – From 1A to 100A • 动态范 围宽: – From μV to 3kV – From fA to 100A • 电容-电压方法: – ±400V多 频C-V – 200V斜 坡速率 C-V – 20V甚 低频 (VLF ) C-V R ...… 查看全部问答> |
