今天是:2025年08月13日(星期三)
正在发生
2018年08月13日 | STM32F103 5个串口同时使用
2018-08-13 来源:eefocus
硬件平台:STM32F103(自带5串口)
5个串口同时工作不丢包-_-
相关宏定义
typedef enum
    UartPort1,
    UartPort2,
    UartPort3,
    UartPort4,
    UartPort5,
    UartPort_USB,
}UARTPORT;
#define   RXTIMEOUT    10         // 接收超时时间,如10mSec内未接收任何数据,当作一个接收包
#define   UART_TXBUFFERLEN  0x100         //发送缓冲区大小
#define   UART_RXBUFFERLEN  0x400          //接接缓冲区大小
typedef struct
    //接收
    volatile Uint       rxHead;
    volatile Uint       rxTail;
    volatile Uchar      rxBuf[UART_RXBUFFERLEN];
    volatile Uchar      rxTimeOut_Base;
    volatile Uchar      rxTimeOut;
    //发送
    volatile Uint       txHead;
    volatile Uint       txTail;
    volatile BOOLEAN    txEmpty;
    volatile Uchar      baudrate;
    volatile Uchar      txIdleTimeOut;
    volatile Uchar      txIdleTimeOut_Base;
    volatile Uchar      txBuf[UART_TXBUFFERLEN];
}UART_STRUCT;
static UART_STRUCT uart1;
static UART_STRUCT uart2;
static UART_STRUCT uart3;
static UART_STRUCT uart4;
static UART_STRUCT uart5;
串口1初始化
    USART_InitTypeDef USART_InitStruct;
    GPIO_InitTypeDef GPIO_InitStruct;
    NVIC_InitTypeDef NVIC_InitStruct;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1, ENABLE );
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    /* Configure USART1 Tx (PA9) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_USART1_TXD;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init( PORT_USART1_TXD, &GPIO_InitStruct );
    /* Configure USART1 Rx (PA10) as input floating */
    GPIO_InitStruct.GPIO_Pin = PIN_USART1_RXD;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init( PORT_USART1_RXD, &GPIO_InitStruct );
    USART_StructInit(&USART_InitStruct);
    USART_InitStruct.USART_BaudRate = 115200;
    USART_InitStruct.USART_WordLength = USART_WordLength_8b;
    USART_InitStruct.USART_StopBits = USART_StopBits_1;
    USART_InitStruct.USART_Parity = USART_Parity_No ;
    USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_Init(USART1, &USART_InitStruct);
    /* Enable the USARTx Interrupt */
#if 1
//  USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStruct);
#endif
    USART_Cmd(USART1, ENABLE);
串口2初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART2, ENABLE );
    /* Configure USART2 CTS (PA0) as input floating */
#if UART2_HARDWARE_FLOW
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_CTS;
    GPIO_Init( PORT_USART2_CTS, &GPIO_InitStruct );
#endif
    /* Configure USART2 Rx (PA3) as input floating */
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_RXD;
    GPIO_Init( PORT_USART2_RXD, &GPIO_InitStruct );
    /* Configure USART2 RTS (PA1) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_RTS;
    GPIO_Init( PORT_USART2_RTS, &GPIO_InitStruct );
#endif
    /* Configure USART2 Tx (PA2) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_USART2_TXD;
    GPIO_Init( PORT_USART2_TXD, &GPIO_InitStruct );
    USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_RTS;
#else
#endif
    USART_Init(USART2, &USART_InitStruct);
#if 1
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = USART2_IRQn;
#endif
    USART_Cmd(USART2, ENABLE);
串口3初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART3, ENABLE );
    /* Configure USART1 Tx (PC10) as alternate function push-pull */
    GPIO_InitStruct.GPIO_Pin = PIN_UART3_TXD;
    GPIO_Init( PORT_UART3_TXD, &GPIO_InitStruct );
    /* Configure USART1 Rx (PC11) as input floating */
    GPIO_InitStruct.GPIO_Pin = PIN_UART3_RXD;
    GPIO_Init( PORT_UART3_RXD, &GPIO_InitStruct );
    USART_Init(USART3, &USART_InitStruct);
#if 1
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = USART3_IRQn;
#endif
    USART_Cmd(USART3, ENABLE);
串口4初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART4, ENABLE );
#if 0
    GPIO_InitStruct.GPIO_Pin = PIN_UART4_CTS;
    GPIO_Init( PORT_UART4_CTS, &GPIO_InitStruct );
//    GPIO_ResetBits(PORT_UART4_CTS,PIN_UART4_CTS);
#endif
    GPIO_InitStruct.GPIO_Pin = PIN_UART4_TXD;
    GPIO_Init( PORT_UART4_TXD, &GPIO_InitStruct );
    GPIO_InitStruct.GPIO_Pin = PIN_UART4_RXD;
    GPIO_Init( PORT_UART4_RXD, &GPIO_InitStruct );
    USART_Init(UART4, &USART_InitStruct);
#if 1
    USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = UART4_IRQn;
#endif
    USART_Cmd(UART4, ENABLE);
串口5初始化
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART5, ENABLE );
    GPIO_InitStruct.GPIO_Pin = PIN_UART5_TXD;
    GPIO_Init( PORT_UART5_TXD, &GPIO_InitStruct );
    GPIO_InitStruct.GPIO_Pin = PIN_UART5_RXD;
    GPIO_Init( PORT_UART5_RXD, &GPIO_InitStruct );
    USART_Init(UART5, &USART_InitStruct);
#if 1
    USART_ITConfig(UART5, USART_IT_RXNE, ENABLE);
    NVIC_InitStruct.NVIC_IRQChannel = UART5_IRQn;
#endif
    USART_Cmd(UART5, ENABLE);
中断处理
void USART_Irq_Function(UART_STRUCT *uart,USART_TypeDef *uartdef)
    //接收到数据USART_ GetITStatus
    while (USART_GetITStatus(uartdef, USART_IT_RXNE))
        Uchar temp;
        USART_ClearFlag(uartdef, USART_FLAG_RXNE | USART_FLAG_ORE);
        temp = USART_ReceiveData(uartdef);
        if (((uart->rxHead + 1) % UART_RXBUFFERLEN) != uart->rxTail)
            uart->rxBuf[uart->rxHead] = temp;
            uart->rxHead = (uart->rxHead + 1) % UART_RXBUFFERLEN;
            uart->rxTimeOut = uart->rxTimeOut_Base;
    //发送数据
    if (USART_GetITStatus(uartdef,USART_IT_TXE))
        // USART_ClearFlag(uartdef, USART_FLAG_TXE);
        if (uart->txHead == uart->txTail)
            uart->txEmpty = TRUE;
            USART_ITConfig(uartdef, USART_IT_TXE, DISABLE);
        else
            USART_SendData(uartdef, uart->txBuf[uart->txTail]);
            uart->txTail = (uart->txTail + 1) & (UART_TXBUFFERLEN - 1);
            uart->txIdleTimeOut = uart->txIdleTimeOut_Base;
extern void USART1_IRQHandler(void)
    USART_Irq_Function(&uart1,USART1);
extern void USART2_IRQHandler(void)
    USART_Irq_Function(&uart2,USART2);
extern void USART3_IRQHandler(void)
#ifdef INCLUDE_UARTPORT3
    USART_Irq_Function(&uart3,USART3);
#endif
extern void UART4_IRQHandler(void)
#ifdef INCLUDE_UARTPORT4
    USART_Irq_Function(&uart4,UART4);
#endif
extern void UART5_IRQHandler(void)
#ifdef INCLUDE_UARTPORT5
    USART_Irq_Function(&uart5,UART5);
#endif
超时检查
//函  数:检查是否有收到数据包,1ms调用一次
//参  数无
//返  回:无
extern void checkUartRxTimeOut()
    if (uart1.rxTimeOut)
        if (--uart1.rxTimeOut == 0)
            pushEvent(evCOM1,uart1.rxHead);
    if (uart2.rxTimeOut)
        if (--uart2.rxTimeOut == 0)
            pushEvent(evCOM2,uart2.rxHead);
    if (uart3.rxTimeOut)
        if (--uart3.rxTimeOut == 0)
            pushEvent(evCOM3,uart3.rxHead);
    if (uart4.rxTimeOut)
        if (--uart4.rxTimeOut == 0)
            pushEvent(evCOM4,uart4.rxHead);
    if (uart5.rxTimeOut)
        if (--uart5.rxTimeOut == 0)
            pushEvent(evCOM5,uart5.rxHead);
    if (uart1.txIdleTimeOut) uart1.txIdleTimeOut--;
    if (uart2.txIdleTimeOut) uart2.txIdleTimeOut--;
    if (uart3.txIdleTimeOut) uart3.txIdleTimeOut--;
#endif
    if (uart4.txIdleTimeOut) uart4.txIdleTimeOut--;
#endif
    if (uart5.txIdleTimeOut) uart5.txIdleTimeOut--;
#endif
BEKA Associates Ltd公司的发展小趣事
BCD Semi(Diodes)在电子行业中以其卓越的技术实力和持续的产品创新而闻名。近年来,公司成功研发出一系列高性能的模拟半导体产品,这些产品在市场上取得了显著的成功。通过不断优化生产工艺和设计理念,BCD Semi成功提升了产品的性能和可靠性,赢得了客户的广泛认可。同时,公司还积极开拓新的应用领域,将产品应用于汽车、通信、工业控制等多个领域,进一步扩大了市场份额。
Coiltronics公司的发展小趣事
随着市场的不断扩大,Coiltronics公司意识到单凭自身的力量难以满足日益增长的市场需求。于是,公司开始积极寻求与其他企业的战略合作。通过与知名电子设备制造商建立合作关系,Coiltronics成功将其线圈技术应用于更广泛的领域,进一步提升了市场份额。同时,这种合作也带来了双方在技术研发、市场推广等方面的深入交流,为公司的长远发展奠定了坚实基础。
Dialog公司的发展小趣事
到了1981年,Dialog公司从洛克希德导弹航空公司中独立出来,成为了一个子公司,并开始独立经营。在独立发展的初期,Dialog公司继续专注于通信技术的研发,并逐渐将业务范围拓展到了个人便携式应用、低功耗短程无线应用以及LED固态照明、显示和汽车应用等领域。
ADI Electronics Inc公司的发展小趣事
在ADI的发展过程中,并购重组成为其实现规模扩张和增强竞争力的重要手段。其中,2017年对凌力尔特(Linear Technology)的收购是ADI历史上最具影响力的一次并购。这次收购使ADI快速进入电源管理芯片市场,并一跃成为全球第二大模拟芯片厂商。通过并购,ADI不仅扩大了自身的产品线,也提高了其在全球市场的份额和影响力。
Gem Asia Enterprise Co Ltd公司的发展小趣事
Gem Asia Enterprise最初是一家专注于电子元件生产的小型制造商。面对激烈的市场竞争,公司决定加大研发投入,专注于开发新型半导体材料。经过数年努力,Gem Asia成功研发出一种高效能、低功耗的半导体材料,并成功应用于智能手机和可穿戴设备中。这一创新不仅显著提升了产品的市场竞争力,还吸引了多家国际知名电子品牌的合作,使Gem Asia迅速在电子行业中崭露头角。
达方(DARFON)公司的发展小趣事
达方电子股份有限公司于1997年在台北市创立,初始阶段主要致力于IT周边组件的研发与生产。创始人凭借对市场趋势的敏锐洞察,决定专注于笔记本键盘的生产,并逐步在行业中崭露头角。通过不断的技术创新和产品优化,达方电子的笔记本键盘逐渐获得了市场的认可,为公司的发展奠定了坚实的基础。
菜鸟求教简单的问题
刚学99SE,不知道若运放,双联电位器怎么设置才能够是一个元件,就是电路土和PCB中一致…
MSP430单片
msp430 单片机学习啊!…
在win ce中如何 结束进程
在win ce中如何结束进程 要求在一个进程中结束另一个进程…
VS2005下如何把WM5的项目转WM2003编译?
我在VS2005下已做好WM5的项目,可转WM2003编译供WM2003的PDA使用,但找不到选项更改?! 我想到的笨办法是要另建一个WM2003的同名项目,再把WM5的项目中的同名文件覆盖过来,然后在项目不添加后加的文件,但工作量好象不小。 特此请教!…
求购光电转换装置
求购光电转换装置:要求该装置能输出与光通量成比例的电压(或电流)信号.此信号能被普通单片机识别. 大虾们推荐推荐.…
一个热爱电子的学子提问:关于三角波的测量
我想设计一个电路用来测量三角波的幅度,频率,以及斜率,我觉得对幅度来说可以用数模转换,在不同的幅度输出不同的值;在频率方面,用时钟电路来做计时,在一个波完时再对时钟中断;而在斜率方面,就不太清楚了,也不知道对不对,请给个方向吧!但 ...…
半导体的集成程度怎么区分
请问大家.半导体集成,它的集成程度分为小规模集成,中规模集成,大规模集成,超大规模集成,特大规模集成,巨大规模集成.请问是如何区分的.请举个具体型号的例子.谢谢 [ 本帖最后由 jirongchang 于 2010-8-26 13:15 编辑 ]…
ARM.RealView.Development.Suite.v4.0 不能在win7下使用么?
发现安装都不能进行,不知道有没有人在Windows7下安装成功呢?…
可以连接到目标板,但进不了调试模式
各位大哥,帮忙解释下撒 Start Debugging后找不到调试的黄色小箭头…
