今天是:2025年08月21日(星期四)
2018年08月21日 | STM32F407的GPIO操作
2018-08-21 来源:eefocus
#include "stm32f4_discovery.h"
#include "stm32f4xx_conf.h"
uint32_t Gb_TimingDelay;
void Delay(uint32_t nTime);
void main( )
SysTick_Config(SystemCoreClock / 1000); //设置systemtick 一毫秒中断
RCC->AHB1ENR |= 0x00000008; //使能GPIOD 时钟
RCC->APB2ENR |= (1<<14); //使能syscfg 时钟
GPIOD->MODER &= 0x00FFFFFF; //设置PD12,13,14,15 输出
GPIOD->MODER |= 0x55000000;
GPIOD->OTYPER &= 0xFFFF0FFF; //设置PD12,13,14,15 推挽输出
GPIOD->OSPEEDR &= 0x00FFFFFF; //PD12,13,14,15 速度100m
GPIOD->OSPEEDR |= 0xff000000;
SYSCFG->CMPCR = 0x00000001; //使用IO 补偿单元,
//当GPIO 速度超过50M 的时候要考虑使用此设置
GPIOD->PUPDR &= 0x00FFFFFF; //PD12,13,14,15 无上拉无下拉
GPIOD->BSRRH = 0xf000; //reset register GPIOx_BSRRH, write only
//set register GPIOx_BSRRL, write only
while(1)
GPIOD->BSRRL = 0x1000;
Delay(100);
GPIOD->BSRRL = 0x1000<<1;
Delay(100);
GPIOD->BSRRL = 0x1000<<2;
Delay(100);
GPIOD->BSRRL = 0x1000<<3;
Delay(100);
Gb_TimingDelay = nTime;
while(Gb_TimingDelay != 0);
void SysTick_Handler(void)
if (Gb_TimingDelay != 0x00)
Gb_TimingDelay--;
void main( )
//Initialize LEDs mounted on STM32F4-Discovery board
STM_EVAL_LEDInit(LED4);
STM_EVAL_LEDInit(LED3);
STM_EVAL_LEDInit(LED5);
STM_EVAL_LEDInit(LED6);
//Turn on LED4 and LED5
STM_EVAL_LEDOn(LED4);
STM_EVAL_LEDOn(LED5);
while(1)
//Toggle LED3 and LED6
STM_EVAL_LEDToggle(LED3);
STM_EVAL_LEDToggle(LED6);
//Insert a delay
Delay(100);
//Toggle LED4 and LED5
STM_EVAL_LEDToggle(LED4);
STM_EVAL_LEDToggle(LED5);
//Insert a delay
Delay(100);
GPIO_InitTypeDef GPIO_InitStructure;
//Enable the GPIO_LED Clock
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
//Configure the GPIO_LED pin
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOD, &GPIO_InitStructure);
//点亮这个灯
GPIOD->BSRRL = GPIO_Pin_12;
while(1)
GPIOD->ODR ^= GPIO_Pin_12;
//Insert a delay
Delay(100);
Gb_TimingDelay--;
CodeWarrior for Microcontrollers v10.0 Beta同时支持HCS08, RS08, CodeFire V1-V4 http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10&tid=vancwmcu10 http://www.freescale.com/webapp/sps/site/overview.jsp?code=C ...… 查看全部问答> |
如何在WinCE下用EVC连接并操作PC上的SQL Server数据库 很急的,要在PocketPC上开发一个程序,能够连接服务器上的SQLServer 数据库,并获取其中的记录数据进行显示,我查了一下资料,有的说在CE上不能直接连接PC上的数据库,有的说在CE上用SQL CE,然后与PC上的SQL连接,还有的说做个web service,那么究 ...… 查看全部问答> |
cc2430给的样例程序中的串口接收不是中断方式的。我写了一个串口中断方式接收的程序,发现明明收到东西了,可它怎么也不进中断。下面是我的程序,波特率。 void URX0Init(void) { U0CSR |= UART_ENABLE_RECEIVE; URX0I ...… 查看全部问答> |
本文主要包含如下内容:1. Debug 和 Release 编译方式的本质区别2. 哪些情况下 Release 版会出错3. 怎样“调试” Release 版的程序-------------------------------------- 关于Debug和Release ...… 查看全部问答> |
在用fpga产生正弦波,调用ISE 的ROM 内核,但是在仿真时,结果输出均为高阻态。ROM的数据由MATLAB产生,请问是为什么?? module sincose(data,we,clk,ce,reset,sine ); input we;//enabl ...… 查看全部问答> |
CortexA8+DSP BeagleBoard 板子+扩展板 去年十一月份chipsee购买,基本没用过,九成新,运行Android完美,wifi链接完美。 原价2700,出收价:2300,可淘宝链接: http://ershou.taobao.com/item.htm?id=14036298782 有诚意的加qq:307799870 板子详 ...… 查看全部问答> |
【求助】共享库查找路径被修改导致现在终端命令不可用,如何恢复共享库路径? 昨天为了安装qt的编译环境,对环境变量进行了设置,其中包括共享库的查找路径,本来是应该进行一个临时设置的,但是我当时为了省时间,就在/etc/bash.bashrc里修改了“LD_LIBRARY_PATH”,结果昨晚关机前忘了把这个路径改回来了,导致今天登陆ubunt ...… 查看全部问答> |
代码如下,不知道为什么开的是RX中断,却用TX中断向量接受,我下到片子里,发现连时钟都没有输出,我用的G2553的LaunchPad//****************************************************************************** // MSP430G2xx3 Demo - US ...… 查看全部问答> |
