今天是:2024年09月10日(星期二)
2018年09月10日 | 关于STM8S使用硬件SPI收发问题
2018-09-10 来源:eefocus
在调试STM8S的SPI时候,由于在学习板上飞线,然后发现每次读SPI FLASH的设备ID等都是不对的.
在21IC发帖求救http://bbs.21ic.com/forum.php?mod=viewthread&tid=788880&epclose=1
总体来说是怀疑硬件飞线的干扰.于是今天又飞了一块板子,发现仍然有这样的问题.
好吧,真的只能打板了.
自己想想会不会在读取数据前SPI的硬件BUFFER中就存在有数据啊.
嗯,有可能, 于是在读数据前,先将SPI的数据先读出,清空缓存,具体代码如下
--Common functions
* Function: Wait_Flash_WarmUp
* Arguments: None.
* Description: Wait some time until flash read / write enable.
* Return Message: None.
void Wait_Flash_WarmUp()
uint32 time_cnt = FlashFullAccessTime;
while( time_cnt > 0 )
time_cnt--;
* Function: Initial_Spi
* Arguments: None
* Description: Initial spi flash state and wait flash warm-up
* (enable read/write).
void Initial_Spi()
#ifdef GPIO_SPI
WPn = 1; // Write potected initial high
SI = 0; // Flash input data
SCLK = 1; // Flash input clock
CSn = 1; // Chip Select
#endif
GPIO_Init(CS_PIN,GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_Init(SPI_SCK_PIN,GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_Init(SPI_MOSI_PIN,GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_Init(SPI_MISO_PIN,GPIO_MODE_IN_PU_NO_IT);
SPI_DeInit();
SPI_Init(SPI_FIRSTBIT_MSB,SPI_BAUDRATEPRESCALER_2,SPI_MODE_MASTER,SPI_CLOCKPOLARITY_HIGH,\
SPI_CLOCKPHASE_2EDGE,SPI_DATADIRECTION_2LINES_FULLDUPLEX,SPI_NSS_SOFT,0x07);
SPI_Cmd(TRUE);
// Wait flash warm-up
Wait_Flash_WarmUp();
* Function: CS_Low, CS_High
* Arguments: None.
* Description: Chip select go low / high.
void CS_Low()
#ifdef GPIO_SPI
CSn = 0;
#else
//--- insert your chip select code here. ---//
GPIO_WriteLow(CS_PIN);
#endif
void CS_High()
#ifdef GPIO_SPI
CSn = 1;
WPn = 1;
#else
GPIO_WriteHigh(CS_PIN);
#endif
* Function: InsertDummyCycle
* Arguments: dummy_cycle, number of dummy clock cycle
* Description: Insert dummy cycle of SCLK
void InsertDummyCycle( uint8 dummy_cycle )
#ifdef GPIO_SPI
uint8 i;
for( i=0; i < dummy_cycle; i=i+1 )
SCLK = 0;
SCLK = 1;
#else
//--- insert your code here. ---//
uint8 i;
for( i=0; i < dummy_cycle / 8 ; i=i+1 )
SPI_SendData(DUMMY_BYTE);
#endif
* Function: SendByte
* Arguments: byte_value, data transfer to flash
* transfer_type, select different type of I/O mode.
* Seven mode:
* SIO, single IO
* DIO, dual IO
* QIO, quad IO
* PIO, parallel
* DTSIO, double transfer rate SIO
* DTDIO, double transfer rate DIO
* DTQIO, double transfer rate QIO
* Description: Send one byte data to flash
void SendByte( uint8 byte_value, uint8 transfer_type )
while(SPI_GetFlagStatus(SPI_FLAG_TXE) == RESET);
SPI_SendData(byte_value);
#ifdef GPIO_SPI
uint16 i;
uint8 cycle_cnt;
switch( transfer_type )
#ifdef SIO
case SIO: // single I/O
cycle_cnt = 8;
for( i= 0; i < cycle_cnt; i++ )
if ( (byte_value & IO_MASK) == 0x80 ){
SI = 1;
else{
SI = 0;
SCLK = 0;
byte_value = byte_value << 1;
SCLK = 1;
break;
#endif
#ifdef DIO
case DIO: // dual I/O
cycle_cnt = 4;
SCLK = 0;
P1 = (( byte_value & 0xc0 ) >> 2) | (P1 & 0xcf);
byte_value = byte_value << 2;
SCLK = 1;
break;
#endif
#ifdef QIO
case QIO: // quad I/O
cycle_cnt = 2;
P1 = (byte_value & 0xf0); // CS# and SCLK must be zero at this phase
byte_value = byte_value << 4;
SCLK = 1;
break;
#endif
#ifdef PIO
case PIO: // Parallel I/O
SCLK = 0;
PO7 = ( (byte_value & IO_MASK) == IO_MASK )?1:0;
PO6 = ( (byte_value & 0x40) == 0x40 )?1:0;
P3 = (byte_value & 0x3f) | (P3 & 0xc0);
SCLK = 1;
break;
#endif
#ifdef DTSIO
case DTSIO: // Double transfer rate single I/O
cycle_cnt = 4;
SCLK = 0;
SI = ( (byte_value & IO_MASK) == IO_MASK )?1:0;
SCLK = 1;
break;
#endif
#ifdef DTDIO
case DTDIO: // Double transfer rate dual I/O
cycle_cnt = 2;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DTQIO
case DTQIO: // Double transfer rate quad I/O
SCLK = 0;
SCLK = 1;
break;
#endif
default:
break;
#else
#ifdef SIO
case SIO: // Single I/O
//--- insert your code here for single IO transfer. ---//
break;
#endif
#ifdef DIO
case DIO: // Dual I/O
//--- insert your code here for dual IO transfer. ---//
break;
#endif
#ifdef QIO
case QIO: // Quad I/O
//--- insert your code here for quad IO transfer. ---//
break;
#endif
#ifdef PIO
//--- insert your code here for parallel IO transfer. ---//
break;
#endif
#ifdef DTSIO
case DTSIO: // Double transfer rate Single I/O
//--- insert your code here for DT single IO transfer. ---//
break;
#endif
#ifdef DTDIO
case DTDIO: // Double transfer rate Dual I/O
//--- insert your code here for DT dual IO transfer. ---//
break;
#endif
#ifdef DTQIO
case DTQIO: // Double transfer rate Quad I/O
//--- insert your code here for DT quad IO transfer. ---//
break;
#endif
default:
break;
#endif /* End of GPIO_SPI */
* Function: GetByte
* Arguments: byte_value, data receive from flash
* Seven mode:
* SIO, single IO
* DIO, dual IO
* QIO, quad IO
* PIO, parallel IO
* Description: Get one byte data to flash
* Return Message: 8 bit data
uint8 GetByte( uint8 transfer_type )
uint8 data_buf;
data_buf = SPI_ReceiveData();//必须先读取一下,防止接收缓存中存有数据
SendByte( DUMMY_BYTE, SIO );
while(SPI_GetFlagStatus(SPI_FLAG_RXNE) == RESET);
#ifdef GPIO_SPI
uint16 i;
uint8 cycle_cnt;
data_buf = 0;
cycle_cnt = 8 >> transfer_type;
#ifdef SIO
// Set VIP 8051 GPIO as input ( need pull to high )
SO = 1;
// End VIP 8051 GPIO
SCLK = 0;
if ( SO == 1 ){
data_buf = (data_buf | (0x80 >> i));
SCLK = 1;
break;
#endif
#ifdef DIO
SIO0 = 1;
SIO1 = 1;
SCLK = 0;
data_buf = data_buf << 2;
data_buf = ( data_buf | ((P1 & 0x30) >> 4 ) );
SCLK = 1;
break;
#endif
#ifdef QIO
SIO0 = 1;
SIO1 = 1;
SIO2 = 1;
SIO3 = 1;
SCLK = 0;
data_buf = P1 & 0xf0;
SCLK = 1;
SCLK = 0;
data_buf = ((P1 & 0xf0)>> 4)| data_buf;
SCLK = 1;
break;
#endif
#ifdef PIO
PO7 = 1;
PO6 = 1;
PO5 = 1;
PO4 = 1;
PO3 = 1;
PO2 = 1;
PO1 = 1;
PO0 = 1;
SCLK = 0;
data_buf = (( P1 & 0x20 )<< 2) | ((P1 & 0x02 ) << 5) | (P3 & 0x3f );
SCLK = 1;
break;
#endif
#ifdef DTSIO
SO = 1;
cycle_cnt = 4;
SCLK = 0;
if ( SO == 1 ){
data_buf = (data_buf | ( 0x80 >> (i*2) ));
SCLK = 1;
if ( SO == 1 ){
data_buf = (data_buf | (0x80 >> ((i*2) + 1) ));
break;
#endif
#ifdef DTDIO
SIO0 = 1;
SIO1 = 1;
cycle_cnt = 2;
SCLK = 0;
data_buf = ( data_buf | ( (P1 & 0x30) >> 4 ) );
SCLK = 1;
break;
#endif
#ifdef DTQIO
case DTQIO: // DTR qual I/O
SIO0 = 1;
SIO1 = 1;
SIO2 = 1;
SIO3 = 1;
SCLK = 0;
SCLK = 1;
data_buf = ( (P1 & 0xf0) >> 4 )| data_buf;
break;
#endif
default:
break;
#else
#ifdef SIO
//--- insert your code here for single IO receive. ---//
break;
#endif
#ifdef DIO
//--- insert your code here for dual IO receive. ---//
break;
#endif
#ifdef QIO
//--- insert your code here for qual IO receive. ---//
break;
#endif
#ifdef PIO
//--- insert your code here for parallel IO receive. ---//
break;
#endif
#ifdef DTSIO
//--- insert your code here for DT single IO receive. ---//
break;
#endif
#ifdef DTDIO
//--- insert your code here for DT dual IO receive. ---//
break;
#endif
#ifdef DTQIO
case DTQIO: // Double transfer rate Qual I/O
//--- insert your code here for DT quad IO receive. ---//
#endif
default:
break;
return data_buf;
* Function: WaitFlashReady
* Arguments: ExpectTime, expected time-out value of flash operations.
* No use at non-synchronous IO mode.
* Description: Synchronous IO:
* If flash is ready return TRUE.
* If flash is time-out return FALSE.
* Non-synchronous IO:
* Always return TRUE
* Return Message: TRUE, FALSE
BOOL WaitFlashReady( uint32 ExpectTime )
#ifndef NON_SYNCHRONOUS_IO
uint32 temp = 0;
while( IsFlashBusy() )
if( temp > ExpectTime )
return FALSE;
temp = temp + 1;
return TRUE;
#else
return TRUE;
#endif
* Function: WaitRYBYReady
BOOL WaitRYBYReady( uint32 ExpectTime )
uint32 temp = 0;
#ifdef GPIO_SPI
while( SO == 0 )
#else
// Insert your code for waiting RYBY (SO) pin ready
#endif
return FALSE;
temp = temp + 1;
return TRUE;
#else
return TRUE;
#endif
* Function: IsFlashBusy
* Arguments: None.
* Description: Check status register WIP bit.
* If WIP bit = 1: return TRUE ( Busy )
* = 0: return FALSE ( Ready ).
BOOL IsFlashBusy( void )
uint8 gDataBuffer;
CMD_RDSR( &gDataBuffer );
if( (gDataBuffer & FLASH_WIP_MASK) == FLASH_WIP_MASK )
return TRUE;
else
return FALSE;
* Function: IsFlashQIO
* Arguments: None.
* Description: If flash QE bit = 1: return TRUE
* = 0: return FALSE.
BOOL IsFlashQIO( void )
#ifdef FLASH_NO_QE_BIT
return TRUE;
#else
uint8 gDataBuffer;
if( (gDataBuffer & FLASH_QE_MASK) == FLASH_QE_MASK )
return TRUE;
else
return FALSE;
#endif
* Function: IsFlash4Byte
* Arguments: None
* Description: Check flash address is 3-byte or 4-byte.
* If flash 4BYTE bit = 1: return TRUE
BOOL IsFlash4Byte( void )
#ifdef FLASH_CMD_RDSCUR
#ifdef FLASH_4BYTE_ONLY
return TRUE;
#elif FLASH_3BYTE_ONLY
return FALSE;
#else
uint8 gDataBuffer;
CMD_RDSCUR( &gDataBuffer );
if( (gDataBuffer & FLASH_4BYTE_MASK) == FLASH_4BYTE_MASK )
return TRUE;
else
return FALSE;
#endif
#else
return FALSE;
#endif
* Function: SendFlashAddr
* Arguments: flash_address, 32 bit flash memory address
* io_mode, I/O mode to transfer address
* addr_4byte_mode,
* Description: Send flash address with 3-byte or 4-byte mode.
void SendFlashAddr( uint32 flash_address, uint8 io_mode, uint8 addr_4byte_mode )
/* Check flash is 3-byte or 4-byte mode.
4-byte mode: Send 4-byte address (A31-A0)
3-byte mode: Send 3-byte address (A23-A0) */
if( addr_4byte_mode == TRUE ){
SendByte( (flash_address >> 24), io_mode ); // A31-A24
/* A23-A0 */
SendByte( (flash_address >> 16), io_mode );
SendByte( (flash_address >> 8), io_mode );
SendByte( (flash_address), io_mode );
* ID Command
* Function: CMD_RDID
* Arguments: Identification, 32 bit buffer to store id
* Description: The RDID instruction is to read the manufacturer ID
* of 1-byte and followed by Device ID of 2-byte.
* Return Message: FlashOperationSuccess
ReturnMsg CMD_RDID( uint32 *Identification )
uint32 temp;
uint8 gDataBuffer[3];
// Chip select go low to start a flash command
CS_Low();
// Send command
SendByte( FLASH_CMD_RDID, SIO );
// Get manufacturer identification, device identification
gDataBuffer[0] = GetByte( SIO );
gDataBuffer[1] = GetByte( SIO );
gDataBuffer[2] = GetByte( SIO );
// Chip select go high to end a command
CS_High();
// Store identification
temp = (u32)(gDataBuffer[0]);
temp = (u32)((temp << 8) | gDataBuffer[1]);
*Identification = (u32)((temp << 8) | gDataBuffer[2]);
return FlashOperationSuccess;
* Function: CMD_RES
* Arguments: ElectricIdentification, 8 bit buffer to store electric id
* Description: The RES instruction is to read the Device
* electric identification of 1-byte.
ReturnMsg CMD_RES( uint8 *ElectricIdentification )
CS_Low();
// Send flash command and insert dummy cycle
SendByte( FLASH_CMD_RES, SIO );
InsertDummyCycle( 24 );
// Get electric identification
*ElectricIdentification = GetByte( SIO );
// Chip select go high to end a flash command
CS_High();
* Function: CMD_REMS
* Arguments: REMS_Identification, 16 bit buffer to store id
* fsptr, pointer of flash status structure
* Description: The REMS instruction is to read the Device
* manufacturer ID and electric ID of 1-byte.
ReturnMsg CMD_REMS( uint16 *REMS_Identification, FlashStatus *fsptr )
uint8 gDataBuffer[2];
CS_Low();
// Send flash command and insert dummy cycle ( if need )
// ArrangeOpt = 0x00 will output the manufacturer's ID first
// = 0x01 will output electric ID first
SendByte( FLASH_CMD_REMS, SIO );
InsertDummyCycle( 16 );
SendByte( fsptr->ArrangeOpt, SIO );
// Get ID
// Store identification informaion
*REMS_Identification = (gDataBuffer[0] << 8) | gDataBuffer[1];
CS_High();
* Register Command
* Function: CMD_RDSR
* Arguments: StatusReg, 8 bit buffer to store status register value
* Description: The RDSR instruction is for reading Status Register Bits.
ReturnMsg CMD_RDSR( uint8 *StatusReg )
uint8 gDataBuffer;
CS_Low();
// Send command
SendByte( FLASH_CMD_RDSR, SIO );
gDataBuffer = GetByte( SIO );
CS_High();
*StatusReg = gDataBuffer;
* Function: CMD_WRSR
* Arguments: UpdateValue, 8/16 bit status register value to updata
* Description: The WRSR instruction is for changing the values of
* Status Register Bits (and configuration register)
* Return Message: FlashIsBusy, FlashTimeOut, FlashOperationSuccess
#ifdef SUPPORT_WRSR_CR
ReturnMsg CMD_WRSR( uint16 UpdateValue )
#else
ReturnMsg CMD_WRSR( uint8 UpdateValue )
#endif
// Check flash is busy or not
if( IsFlashBusy() ) return FlashIsBusy;
// Setting Write Enable Latch bit
CMD_WREN();
CS_Low();
// Send command and update value
SendByte( FLASH_CMD_WRSR, SIO );
SendByte( UpdateValue, SIO );
SendByte( UpdateValue >> 8, SIO ); // write configuration register
#endif
CS_High();
if( WaitFlashReady( WriteStatusRegCycleTime ) )
else
return FlashTimeOut;
* Function: CMD_RDSCUR
* Arguments: SecurityReg, 8 bit buffer to store security register value
* Description: The RDSCUR instruction is for reading the value of
* Security Register bits.
ReturnMsg CMD_RDSCUR( uint8 *SecurityReg )
uint8 gDataBuffer;
CS_Low();
//Send command
SendByte( FLASH_CMD_RDSCUR, SIO );
CS_High();
*SecurityReg = gDataBuffer;
* Function: CMD_WRSCUR
* Arguments: None.
* Description: The WRSCUR instruction is for changing the values of
* Security Register Bits.
* Return Message: FlashIsBusy, FlashOperationSuccess, FlashWriteRegFailed,
* FlashTimeOut
ReturnMsg CMD_WRSCUR( void )
uint8 gDataBuffer;
CMD_WREN();
CS_Low();
// Write WRSCUR command
SendByte( FLASH_CMD_WRSCUR, SIO );
CS_High();
if( WaitFlashReady( WriteSecuRegCycleTime ) ){
// Check security register LDSO bit
if( (gDataBuffer & FLASH_LDSO_MASK) == FLASH_LDSO_MASK )
else
return FlashWriteRegFailed;
else
* Read Command
* Function: CMD_READ
* target_address, buffer address to store returned data
* byte_length, length of returned data in byte unit
* Description: The READ instruction is for reading data out.
* Return Message: FlashAddressInvalid, FlashOperationSuccess
ReturnMsg CMD_READ( uint32 flash_address, uint8 *target_address, uint32 byte_length )
uint32 index;
uint8 addr_4byte_mode;
// Check flash address
if( flash_address > FlashSize ) return FlashAddressInvalid;
// Check 3-byte or 4-byte mode
if( IsFlash4Byte() )
addr_4byte_mode = TRUE; // 4-byte mode
else
addr_4byte_mode = FALSE; // 3-byte mode
CS_Low();
// Write READ command and address
SendByte( FLASH_CMD_READ, SIO );
SendFlashAddr( flash_address, SIO, addr_4byte_mode );
// Set a loop to read data into buffer
for( index=0; index < byte_length; index++ )
// Read data one byte at a time
*(target_address + index) = GetByte( SIO );
CS_High();
* Function: CMD_DREAD
* Description: The DREAD instruction enable double throughput of Serial
* Flash in read mode
ReturnMsg CMD_DREAD( uint32 flash_address, uint8 *target_address, uint32 byte_length )
uint32 index;
else
CS_Low();
// Write 2-I/O Read command and address
SendByte( FLASH_CMD_DREAD, SIO );
InsertDummyCycle( 8 ); // Wait 8 dummy cycle
// Set a loop to read data into data buffer
*(target_address + index) = GetByte( DIO );
CS_High();
* Function: CMD_FASTREAD
* Description: The FASTREAD instruction is for quickly reading data out.
ReturnMsg CMD_FASTREAD( uint32 flash_address, uint8 *target_address, uint32 byte_length )
uint32 index;
else
CS_Low();
// Write Fast Read command, address and dummy cycle
SendByte( FLASH_CMD_FASTREAD, SIO );
InsertDummyCycle ( 8 ); // Wait dummy cycle
CS_High();
* Function: CMD_RDSFDP
* Description: RDSFDP can retrieve the operating characteristics, structure
* and vendor-specified information such as identifying information,
* memory size, operating voltages and timinginformation of device
ReturnMsg CMD_RDSFDP( uint32 flash_address, uint8 *target_address, uint32 byte_length )
uint32 index;
else
CS_Low();
// Write Read SFDP command
SendByte( FLASH_CMD_RDSFDP, SIO );
InsertDummyCycle ( 8 ); // Insert dummy cycle
CS_High();
* Program Command
* Function: CMD_WREN
* Arguments: None.
* Description: The WREN instruction is for setting
* Write Enable Latch (WEL) bit.
ReturnMsg CMD_WREN( void )
CS_Low();
// Write Enable command = 0x06, Setting Write Enable Latch Bit
SendByte( FLASH_CMD_WREN, SIO );
CS_High();
* Function: CMD_WRDI
* Arguments: None.
* Description: The WRDI instruction is to reset
ReturnMsg CMD_WRDI( void )
CS_Low();
// Write Disable command = 0x04, resets Write Enable Latch Bit
SendByte( FLASH_CMD_WRDI, SIO );
CS_High();
* Function: CMD_PP
* source_address, buffer address of source data to program
* byte_length, byte length of data to programm
* Description: The PP instruction is for programming
* the memory to be "0".
* The device only accept the last 256 byte ( or 32 byte ) to program.
* If the page address ( flash_address[7:0] ) reach 0xFF, it will
* program next at 0x00 of the same page.
* Some products have smaller page size ( 32 byte )
* Return Message: FlashAddressInvalid, FlashIsBusy, FlashOperationSuccess,
* FlashTimeOut
ReturnMsg CMD_PP( uint32 flash_address, uint8 *source_address, uint32 byte_length )
uint32 index;
else
CMD_WREN();
CS_Low();
// Write Page Program command
SendByte( FLASH_CMD_PP, SIO );
// Set a loop to down load whole page data into flash's buffer
// Note: only last 256 byte ( or 32 byte ) will be programmed
SendByte( *(source_address + index), SIO );
CS_High();
if( WaitFlashReady( PageProgramCycleTime ) )
else
* Erase Command
* Function: CMD_SE
* Description: The SE instruction is for erasing the data
* of the chosen sector (4KB) to be "1".
* FlashTimeOut
ReturnMsg CMD_SE( uint32 flash_address )
else
CMD_WREN();
CS_Low();
//Write Sector Erase command = 0x20;
SendByte( FLASH_CMD_SE, SIO );
CS_High();
if( WaitFlashReady( SectorEraseCycleTime ) )
else
* Function: CMD_BE
* Description: The BE instruction is for erasing the data
* of the chosen sector (64KB) to be "1".
* FlashTimeOut
ReturnMsg CMD_BE( uint32 flash_address )
else
CMD_WREN();
CS_Low();
//Write Block Erase command = 0xD8;
SendByte( FLASH_CMD_BE, SIO );
CS_High();
if( WaitFlashReady( BlockEraseCycleTime ) )
else
* Function: CMD_CE
* Arguments: None.
* Description: The CE instruction is for erasing the data
* of the whole chip to be "1".
* Return Message: FlashIsBusy, FlashOperationSuccess, FlashTimeOut
ReturnMsg CMD_CE( void )
CMD_WREN();
CS_Low();
//Write Chip Erase command = 0x60;
SendByte( FLASH_CMD_CE, SIO );
CS_High();
if( WaitFlashReady( ChipEraseCycleTime ) )
else
* Mode setting Command
* Function: CMD_DP
* Arguments: None.
* Description: The DP instruction is for setting the
* device on the minimizing the power consumption.
ReturnMsg CMD_DP( void )
CS_Low();
// Deep Power Down Mode command
SendByte( FLASH_CMD_DP, SIO );
CS_High();
* Function: CMD_RDP
* Arguments: None.
* Description: The Release from RDP instruction is
* putting the device in the Stand-by Power mode.
ReturnMsg CMD_RDP( void )
CS_Low();
SendByte( FLASH_CMD_RDP, SIO );
CS_High();
* Function: CMD_ENSO
* Arguments: None.
* Description: The ENSO instruction is for entering the secured OTP mode.
ReturnMsg CMD_ENSO( void )
CS_Low();
// Write ENSO command
SendByte( FLASH_CMD_ENSO, SIO );
CS_High();
* Function: CMD_EXSO
* Arguments: None.
* Description: The EXSO instruction is for exiting the secured OTP mode.
ReturnMsg CMD_EXSO( void )
CS_Low();
// Write EXSO command = 0xC1
SendByte( FLASH_CMD_EXSO, SIO );
CS_High();
* Reset setting Command
* Security Command
注意在uint8 GetByte( uint8 transfer_type )函数的这句话
好了,调试一下,果然成功获取该SPI FLASH的值.
那我用IO方式验证一下.代码如下:
--Common functions
* Arguments: None.
time_cnt--;
* Arguments: None
void Initial_Spi()
#ifdef GPIO_SPI
#endif
//SPI_DeInit();
//SPI_Init(SPI_FIRSTBIT_MSB,SPI_BAUDRATEPRESCALER_2,SPI_MODE_MASTER,SPI_CLOCKPOLARITY_HIGH,\
// SPI_CLOCKPHASE_2EDGE,SPI_DATADIRECTION_2LINES_FULLDUPLEX,SPI_NSS_SOFT,0x07);
//SPI_Cmd(TRUE);
* Arguments: None.
void CS_Low()
#ifdef GPIO_SPI
CSn = 0;
#else
#endif
void CS_High()
#ifdef GPIO_SPI
CSn = 1;
WPn = 1;
#else
#endif
#ifdef GPIO_SPI
uint8 i;
SCLK = 0;
SCLK = 1;
#else
uint8 i;
#if 0
#else
GPIO_WriteLow(SPI_SCK_PIN);
GPIO_WriteHigh(SPI_SCK_PIN);
#endif
#endif
* Seven mode:
* SIO, single IO
* DIO, dual IO
* QIO, quad IO
* PIO, parallel
uint16 i;
uint8 cycle_cnt;
#if 0
#else
cycle_cnt = 8;
GPIO_WriteHigh(SPI_MOSI_PIN);
else{
GPIO_WriteLow(SPI_MOSI_PIN);
#endif
#ifdef GPIO_SPI
#ifdef SIO
cycle_cnt = 8;
SI = 1;
else{
SI = 0;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DIO
cycle_cnt = 4;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef QIO
cycle_cnt = 2;
SCLK = 1;
break;
#endif
#ifdef PIO
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DTSIO
cycle_cnt = 4;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DTDIO
cycle_cnt = 2;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DTQIO
SCLK = 0;
SCLK = 1;
break;
#endif
default:
break;
#else
#ifdef SIO
break;
#endif
#ifdef DIO
break;
#endif
#ifdef QIO
break;
#endif
#ifdef PIO
break;
#endif
#ifdef DTSIO
break;
#endif
#ifdef DTDIO
break;
#endif
#ifdef DTQIO
break;
#endif
default:
break;
* Function: GetByte
* Seven mode:
* SIO, single IO
* DIO, dual IO
* QIO, quad IO
* PIO, parallel IO
uint8 data_buf;
uint16 i;
uint8 cycle_cnt;
data_buf = 0;
#if 0
#else
cycle_cnt = 8;
if ( GPIO_ReadInputPin(SPI_MISO_PIN) == 1 ){
#endif
#ifdef GPIO_SPI
#ifdef SIO
SO = 1;
SCLK = 0;
if ( SO == 1 ){
SCLK = 1;
break;
#endif
#ifdef DIO
SIO0 = 1;
SIO1 = 1;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef QIO
SIO0 = 1;
SIO1 = 1;
SIO2 = 1;
SIO3 = 1;
SCLK = 0;
SCLK = 1;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef PIO
PO7 = 1;
PO6 = 1;
PO5 = 1;
PO4 = 1;
PO3 = 1;
PO2 = 1;
PO1 = 1;
PO0 = 1;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DTSIO
SO = 1;
cycle_cnt = 4;
SCLK = 0;
if ( SO == 1 ){
SCLK = 1;
if ( SO == 1 ){
break;
#endif
#ifdef DTDIO
SIO0 = 1;
SIO1 = 1;
cycle_cnt = 2;
SCLK = 0;
SCLK = 1;
break;
#endif
#ifdef DTQIO
SIO0 = 1;
SIO1 = 1;
SIO2 = 1;
SIO3 = 1;
SCLK = 0;
SCLK = 1;
break;
#endif
default:
break;
#else
#ifdef SIO
break;
#endif
#ifdef DIO
break;
#endif
#ifdef QIO
break;
#endif
#ifdef PIO
break;
#endif
#ifdef DTSIO
break;
#endif
#ifdef DTDIO
break;
#endif
#ifdef DTQIO
#endif
default:
break;
return data_buf;
uint32 temp = 0;
return FALSE;
temp = temp + 1;
return TRUE;
#else
return TRUE;
#endif
uint32 temp = 0;
#ifdef GPIO_SPI
while( SO == 0 )
#else
#endif
return FALSE;
temp = temp + 1;
return TRUE;
#else
return TRUE;
#endif
* Arguments: None.
uint8 gDataBuffer;
return TRUE;
else
return FALSE;
* Arguments: None.
return TRUE;
#else
uint8 gDataBuffer;
return TRUE;
else
return FALSE;
#endif
* Arguments: None
return TRUE;
return FALSE;
#else
uint8 gDataBuffer;
return TRUE;
else
return FALSE;
#endif
#else
return FALSE;
#endif
* addr_4byte_mode,
/* A23-A0 */
* ID Command
uint32 temp;
CS_Low();
// Send command
CS_High();
* Function: CMD_RES
CS_Low();
CS_High();
CS_Low();
// Get ID
CS_High();
* Register Command
uint8 gDataBuffer;
CS_Low();
// Send command
CS_High();
#else
#endif
CMD_WREN();
CS_Low();
#endif
CS_High();
else
uint8 gDataBuffer;
CS_Low();
//Send command
CS_High();
* Arguments: None.
* FlashTimeOut
uint8 gDataBuffer;
CMD_WREN();
CS_Low();
CS_High();
else
else
* Read Command
uint32 index;
else
CS_Low();
CS_High();
uint32 index;
else
CS_Low();
CS_High();
uint32 index;
else
CS_Low();
CS_High();
uint32 index;
else
CS_Low();
CS_High();
* Program Command
* Arguments: None.
CS_Low();
CS_High();
* Arguments: None.
CS_Low();
CS_High();
* Function: CMD_PP
* FlashTimeOut
uint32 index;
else
CMD_WREN();
CS_Low();
CS_High();
else
* Erase Command
* Function: CMD_SE
* FlashTimeOut
else
CMD_WREN();
CS_Low();
CS_High();
else
* Function: CMD_BE
* FlashTimeOut
else
CMD_WREN();
CS_Low();
CS_High();
else
* Function: CMD_CE
* Arguments: None.
CMD_WREN();
CS_Low();
CS_High();
else
* Function: CMD_DP
* Arguments: None.
CS_Low();
CS_High();
* Function: CMD_RDP
* Arguments: None.
CS_Low();
CS_High();
* Arguments: None.
CS_Low();
CS_High();
* Arguments: None.
CS_Low();
CS_High();
* Security Command
验证结果也正确的.
对了减少大家的顾虑,积极的参与,而且对于新手来说可能芯币缺乏等原因,对于下载这次matlab的内容,网友只要留下回复,我都会第一时间给你们加芯币,算是免费下载学习的机会吧!!!不过由于一天只能够发2000芯币,希望大家珍惜机会,先报到,先享 ...… 查看全部问答> |
最近一直在学习VHDL ,强烈推荐以下书 1.VHDL硬件描述语言与数字逻辑电路设计(修订版) 侯伯亨 顾新编著 西安电子科技大学出版社 简介:系统地介绍了VHDL 2.现代电子技术 --VHDL与数字系统设计 杨刚 龙海燕编著 电子工 ...… 查看全部问答> |
本帖最后由 jameswangsynnex 于 2015-3-3 19:56 编辑 欧美日均有3D频道之后,中国的3D电视节目也在酝酿中,内容匮乏的问题现出一线曙光。国家广电总局科技委副主任、副总工程师杜百川日前在“索尼3D世界”发布会上透露,中国今年肯定有部分地区进 ...… 查看全部问答> |
VHDL中可将参数定义在generic语句中,一般是将位宽定义在此,其他参数可定义在package中。这里不做讨论。VHDL中一个很好的语句others,对于参数化或者大位宽赋值全0、全1、全X、全Z很方便(这里X、Z为大写),以如下的方式: &n ...… 查看全部问答> |
职能要求: 1.大专以上学历,电子、自动化等相关专业。有三年以上电子类工业产品相关设计工作经验。 2.熟悉电子线路设计,单片机编程; 熟悉PIC、AVR等各种类型单片机。 3.熟练掌握PROTEL、C语言、汇编等各种专业软件。 4.具有产品设计、分析 ...… 查看全部问答> |
现在正做毕业设计,需要传输距离几十米,但SPI 穿的距离太近,问老师,老实说:一般可以加一个引脚少的廉价单片机连接器件,使用 单片机的串口利用485接口实现远程通讯。具体加什么器件,怎么实现,求高人,或者告诉我怎么扩展SPI传输距离,拜谢… 查看全部问答> |
