今天是:2024年09月10日(星期二)
正在发生
2018年09月10日 | STM32L0低功耗设计5: STOP_RTC模式的真实功耗
2018-09-10 来源:eefocus
    本例程测试STOP_RTC模式的真实功耗,主程序如下:
int main(void)
while(1)
    HAL_Delay(5000);
Target.HAL.Rtc.EnterStopRtcMode();
Target.HAL.SystemClock.SetMode(2);
    系统进入主循环后,先进行5秒延时,然后进入低功耗模式,低功耗模式设置的RTC时间为4秒,4秒过后退出低功耗模式,重新进行时钟设置。
    在进入main函数之前,执行了3个操作:时钟设置、低功耗设置和RTC设置,如下面程序:
class CHAL
public:
CSystemClock SystemClock;
CSystemLowPower SystemLowPower;
CRtc Rtc;
    时钟设置相关程序如下:
void CClock::SetMode(uint8_t mode)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef PeriphClkInit;
__HAL_RCC_PWR_CLK_ENABLE();
if (mode  == 0)
//Configure the main internal regulator output voltage
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
//Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_8;
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_3;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Target.ErrorHandler(__FILE__, __LINE__);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
//Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
//SysTick_IRQn interrupt configuration
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
else if (mode  == 1)
|RCC_PERIPHCLK_USB;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL;
else if (mode == 2)
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI | RCC_OSCILLATORTYPE_HSE | RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 0x10; //HSIÐÞÕýÖµ
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2|RCC_PERIPHCLK_RTC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
    低功耗设置相关程序如下:
CLowPower::CLowPower(uint8_t mode)
if (mode == 1)
GPIO_InitTypeDef GPIO_InitStructure;
HAL_PWREx_EnableUltraLowPower(); //ʹÄܳ¬µÍ¹¦ºÄ
    HAL_PWREx_EnableFastWakeUp(); //ʹÄÜ¿ìËÙ»½ÐÑ
__HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI); //½«HSIʱÖÓ×÷Ϊ»½ÐѺóµÄÖ÷ʱÖÓ
//½«ËùÓÐÒý½Å¶¼ÅäÖÃΪģÄâÊäÈëģʽ
    __HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
GPIO_InitStructure.Pin = GPIO_PIN_All;
GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
GPIO_InitStructure.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
__HAL_RCC_GPIOA_CLK_DISABLE();
__HAL_RCC_GPIOB_CLK_DISABLE();
__HAL_RCC_GPIOC_CLK_DISABLE();
__HAL_RCC_GPIOD_CLK_DISABLE();
__HAL_RCC_GPIOH_CLK_DISABLE();
    RTC设置相关程序如下:
CRtc::CRtc(void)
  this->hRTC.Instance = RTC;
pRTC = &this->hRTC;
this->hRTC.Init.HourFormat = RTC_HOURFORMAT_24;
this->hRTC.Init.AsynchPrediv = 124;
this->hRTC.Init.SynchPrediv = 295;
this->hRTC.Init.OutPut = RTC_OUTPUT_DISABLE;
this->hRTC.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE; //²»½øÐÐÊä³öÒý½ÅÖØÓ³Éä
this->hRTC.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
this->hRTC.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&this->hRTC) != HAL_OK)
    程序运行后,5秒为正常功耗,4秒为低功耗,测得实际功耗2.4uA,手册中指出的STOP_RTC模式为1uA,产生差错的原因在《STM32L0低功耗设计3: Stop模式下的真实功耗》中已经介绍过,2.4uA已经能够满足项目本身的设计了,还算不错。
A-BRIGHT公司的发展小趣事
在快速发展的同时,A-BRIGHT公司深知品质的重要性。公司加大了对品质管理的投入,引入了先进的生产线和检测设备,并建立了严格的质量管理体系。通过持续改进和优化生产流程,A-BRIGHT的产品质量得到了显著提升,赢得了客户的信任和好评。
ZTE高新兴(Gosuncn)公司的发展小趣事
随着全球环保意识的提高,A-BRIGHT公司积极响应环保号召,将环保理念融入到产品研发和生产中。公司研发了一系列节能环保的电子产品,不仅满足了客户的需求,也为全球环保事业做出了贡献。这一举措提升了A-BRIGHT的品牌形象,也为其在竞争激烈的市场中赢得了更多客户的青睐。
这些故事虽然是虚构的,但它们基于电子行业的发展趋势和可能情况,展示了A-BRIGHT公司可能的发展路径和成功因素。希望这些故事能够满足您的需求。
APSA公司的发展小趣事
APSA公司在创业初期,专注于电子行业中某一特定领域的技术研发。通过团队的不懈努力和持续创新,公司成功开发出一款具有竞争力的产品,填补了市场空白。这一技术突破不仅为APSA公司赢得了首批客户,也为公司的后续发展奠定了坚实的基础。
FEIG ELECTRONIC公司的发展小趣事
自1997年以来,FEIG ELECTRONIC开始加速其全球扩张的步伐。通过不断的技术创新和市场推广,FEIG的产品逐渐覆盖了全球多个行业,包括物流、零售、医疗、制造等。FEIG凭借其高质量的产品和卓越的服务,赢得了全球客户的广泛认可,逐渐发展成为全球RFID领域的领军企业。
汇顶科技(GOODiX)公司的发展小趣事
FEIG ELECTRONIC成立于1978年,作为德国射频识别(RFID)系统的先驱,公司从一开始就专注于RFID技术的研发与制造。在创立初期,FEIG凭借其独特的技术视角和对市场需求的敏锐洞察,成功开发了一系列RFID系统,为物流、零售等行业提供了有效的解决方案。通过不断的技术创新和市场拓展,FEIG逐渐在RFID领域崭露头角。
Gould Fiber Optics公司的发展小趣事
确保电源电路中的接地良好,避免接地不良引起的噪声和干扰。对于数字电路和模拟电路共存的电源系统,应采用模拟地和数字地分开接地的方式。
一款音质卓越的立体声语音模块
见附件: ◆  语音为 MP3 格式,音质优美,通用性好,占据容量小,容易制作◆  SD 卡作为存储语音的载体,存储容量大,性能高,安全性高◆  语音更新十分方便,只需 SD 卡与电脑连接即可.◆  存储内容按文件夹的形 ...…
什么叫做虚拟内存(原创)
本帖最后由 jameswangsynnex 于 2015-3-3 19:58 编辑 么叫做虚拟内存呢?有很多朋友会从“虚拟磁盘”、“虚拟光驱”等概念简单推广到内存方面,认为用做内存交换和扩展空间的“磁盘页面文件”就是“虚拟内存”,因为不是内存芯片,却要做内存的用 ...…
555振荡电路设计
我想用555定时器设计一个每秒产生15个15KHZ的脉冲震荡电路, 小弟我刚接触这方面的内容,请各位DX给些意见。 先谢谢了!!…
关于用一台电脑控制另一台电脑键盘的问题
目前有个棘手的问题,需要控制一台电脑的键盘事件。但是这台电脑不允许安装其他软件,所以采用安装软件方式控制键盘是没办法了,只能通过可编程键盘连接控制电脑和被控制电脑,在控制电脑发送相应键值,以达到被控电脑的相关操作。就是需要数据线( ...…
新手提问,编译LINK的时候出现了下面的错误,请赐教。
编译的环境是STANDARDSDK_42  Win32(WCE ARMV4I)Release  STANDARDSDK_420 Emulator Linking... MFCCE400d.lib(mfcce400d.dll) : fatal error LNK1112: module machine type \'THUMB\' conflicts with target machine type \ ...…
如何在ARM处理器上实现如malloc函数的功能
如何在ARM处理器上实现如malloc函数的功能 标准库中的malloc函数是不需要提前分配好存储空间的,我测试过,一段代码有没有malloc只跟代码段的大小有关,而跟数据段都没有关系的。 但是在ucos和freeRtos里面,类似于malloc函数的实现,都是提前分 ...…
ARM如何保留特定地址的内存?
需要将两个数组分配到指定的内存地址中,如何做?…
用c语言写的c51闹钟程序
#include<reg51.h>uchar code tab[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}void view()                 /*七段数码管显示程序 七个管轮流 ...…
[分享]LM3S811学习过程体验
LM3S811使用心得(一)   仅仅就心得写八百字确实有难度,于是乎把使用的过程加上滥竽充数,希望对大伙有所帮助。 我们的口号延续以往竞赛精神:只要懂C语言就会开发ARM! 内容适合入门级菜鸟,老鸟就别看了,浪费时间。附带代码。   ...…
承接嵌入式笔划输入法开发 嵌入式 笔划输入法 源代码
承接嵌入式笔划输入法开发(另外附送数字输入法、英文大小写输入法和符号输入法,与手机的输入法效果完全一模一样),共有触屏型与按键型两种笔划输入法。 有意者可详谈,用旺旺或者QQ:1309563701。 详情可见http://item.taobao.com/item.htm?i ...…
