今天是:2024年10月11日(星期五)
正在发生
2018年10月11日 | 自己写bootloader之OK6410
2018-10-11 来源:eefocus
start.S源码:
.globl _start
_start:
// 硬件相关的设置
    // Peri port setup
    ldr r0, =0x70000000
    orr r0, r0, #0x13
    mcr p15,0,r0,c15,c2,4       @ 256M(0x70000000-0x7fffffff)
// 关看门狗
// 往WTCON(0x7E004000)写0
    ldr r0, =0x7E004000
    mov r1, #0
    str r1, [r0]
    // 设置栈
    ldr sp, =8*1024
    // 设置时钟
    bl clock_init
    bl ddr_init
    bl init_uart
// 清BSS
// 把BSS段对应的内存清零
clean_bss:
    ldr r0, =bss_start
    ldr r1, =bss_end
    mov r3, #0
    cmp r0, r1
    b copy_kernel
clean_loop:
    str r3, [r0], #4
    cmp r0, r1
    bne clean_loop
copy_kernel:
    mov r0, #0x200000
    ldr r1, =(0x50008000 - 64)
    mov r2, #0x500000
    bl copykernel2ddr
    cmp r0, #0
    bne halt
    bl set_params
    mov r0, #0
    ldr r1, =1626
    ldr r2, =0x50000100
    ldr pc, =0x50008000
halt:
    b halt
clock.S源码:
.globl clock_init
clock_init:
    // 1.设置LOCK_TIME
    ldr r0, =0x7E00F000  // APLL_LOCK
    ldr r1, =0x0000FFFF
    str r1, [r0]
    str r1, [r0, #4]            // MPLL_LOCK
    str r1, [r0, #8]            // EPLL_LOCK
#define OTHERS        0x7e00f900
    @ set async mode     // 当CPU时钟 != HCLK时,要设为异步模式
    ldr r0, =OTHERS
    ldr r1, [r0]
    bic r1, #0xc0
    str r1, [r0]
loop1:                            // 等待,直到CPU进入异步模式
    ldr r0, =OTHERS
    ldr r1, [r0]
    and r1, #0xf00
    cmp r1, #0
    bne loop1
    // SYNC667
    // MISC_CON[19] = 0
#define ARM_RATIO    0     // ARMCLK = DOUTAPLL / (ARM_RATIO + 1)
#define HCLKX2_RATIO 1   // HCLKX2 = HCLKX2IN / (HCLKX2_RATIO + 1)
#define HCLK_RATIO   1     // HCLK = HCLKX2 / (HCLK_RATIO + 1)
#define PCLK_RATIO   3     // PCLK   = HCLKX2 / (PCLK_RATIO + 1)
#define MPLL_RATIO   0    // DOUTMPLL = MOUTMPLL / (MPLL_RATIO + 1)
    ldr r0, =0x7E00F020        // CLK_DIV0
    ldr r1, =(ARM_RATIO) | (MPLL_RATIO << 4) | (HCLK_RATIO << 8) | (HCLKX2_RATIO << 9) | (PCLK_RATIO << 12)
    str r1, [r0]
    // 2.配置时钟
    // 2.1 配置APLL
    // 2.1.1 设置APLL
    // 2.1.2 MUXAPLL
    // 2.1.3 SYNC667
    // 2.1.4 DIVAPLL
#define APLL_CON_VAL  ((1<<31) | (266 << 16) | (3 << 8) | (1))
    ldr r0, =0x7E00F00C
    ldr r1, =APLL_CON_VAL
    str r1, [r0]        // APLL_CON, FOUTAPL = MDIV * Fin / (PDIV*2^SDIV) = 266*12/(3*2^1) = 532MHz
    // 2.2 配置MPLL
    // 2.2.1 设置MPLL
    // 2.2.2 MUXMPLL
    // 2.2.3 SYNCMUX
    // 2.2.4 SYNC667
    // 2.2.5 HCLKX2_RATIO
    // 2.2.6 PCLK_RATIO
#define MPLL_CON_VAL  ((1<<31) | (266 << 16) | (3 << 8) | (1))
    ldr r0, =0x7E00F010
    ldr r1, =MPLL_CON_VAL
    str r1, [r0]        // MPLL_CON, FOUTMPL = MDIV * Fin / (PDIV*2^SDIV) = 266*12/(3*2^1) = 532MHz
    // 3.选择PLL的输出作为时钟源
    ldr r0, =0x7E00F01C
    ldr r1, =0x03
    str r1, [r0]
    mov pc, lr
sdram.c源码:
#include "common.h"
#define MEMCCMD        0x7e001004
#define P1REFRESH         0x7e001010
#define P1CASLAT           0x7e001014
#define MEM_SYS_CFG    0x7e00f120
#define P1MEMCFG         0x7e00100c
#define P1T_DQSS           0x7e001018
#define P1T_MRD            0x7e00101c
#define P1T_RAS              0x7e001020
#define P1T_RC                0x7e001024
#define P1T_RCD              0x7e001028
#define P1T_RFC               0x7e00102c
#define P1T_RP                 0x7e001030
#define P1T_RRD              0x7e001034
#define P1T_WR                0x7e001038
#define P1T_WTR              0x7e00103c
#define P1T_XP                 0x7e001040
#define P1T_XSR               0x7e001044
#define P1T_ESR               0x7e001048
#define P1MEMCFG2       0X7e00104c
#define P1_chip_0_cfg      0x7e001200
#define P1MEMSTAT       0x7e001000
#define P1MEMCCMD     0x7e001004
#define P1DIRECTCMD    0x7e001008
#define HCLK    133000000
#define nstoclk(ns)    (ns/( 1000000000/HCLK)+1)
int ddr_init( void )
    // tell dramc to configure
    set_val( MEMCCMD, 0x4 );
    // set refresh period
    set_val( P1REFRESH, nstoclk(7800) );
    // set timing para
    set_val( P1CASLAT, ( 3 << 1 ) );
    set_val( P1T_DQSS, 0x1 );    // 0.75 - 1.25
    set_val( P1T_MRD, 0x2 );
    set_val( P1T_RAS, nstoclk(45) );
    set_val( P1T_RC, nstoclk(68) );
    u32 trcd = nstoclk( 23 );
    set_val( P1T_RCD, trcd | (( trcd - 3 ) << 3 ) );
    u32 trfc = nstoclk( 80 );
    set_val( P1T_RFC, trfc | ( ( trfc-3 ) << 5 ) );
    u32 trp = nstoclk( 23 );
    set_val( P1T_RP, trp | ( ( trp - 3 ) << 3 ) );
    set_val( P1T_RRD, nstoclk(15) );
    set_val( P1T_WR, nstoclk(15) );
    set_val( P1T_WTR, 0x7 );
    set_val( P1T_XP, 0x2 );
    set_val( P1T_XSR, nstoclk(120) );
    set_val( P1T_ESR, nstoclk(120) );
    // set mem cfg
    set_nbit( P1MEMCFG, 0, 3, 0x2 );  // 10 column address
    // set_nbit: 把从第bit位开始的一共len位消零,然后把这几位设为val
    set_nbit( P1MEMCFG, 3, 3, 0x3 );   // 14 row address
    set_zero( P1MEMCFG, 6 );              // A10/AP
    set_nbit( P1MEMCFG, 15, 3, 0x2 ); // Burst 4
    set_nbit( P1MEMCFG2, 0, 4, 0x5 );
    set_2bit( P1MEMCFG2, 6, 0x1 );     // 32 bit
    set_nbit( P1MEMCFG2, 8, 3, 0x3 ); // Mobile DDR SDRAM
    set_2bit( P1MEMCFG2, 11, 0x1 );
    set_one( P1_chip_0_cfg, 16 );          // Bank-Row-Column organization
    // memory init
    set_val( P1DIRECTCMD, 0xc0000 );  // NOP
    set_val( P1DIRECTCMD, 0x000 );      // precharge
    set_val( P1DIRECTCMD, 0x40000 );  // auto refresh
    set_val( P1DIRECTCMD, 0xa0000 );  // EMRS
    set_val( P1DIRECTCMD, 0x80032 );  // MRS
    set_val( MEM_SYS_CFG, 0x0 );
    // set dramc to "go" status
    set_val( P1MEMCCMD, 0x000 );
    // wait ready
    while( !(( read_val( P1MEMSTAT ) & 0x3 ) == 0x1));
    return 0;
nand.c源码:
#define MEM_SYS_CFG     (*((volatile unsigned long *)0x7E00F120))
#define NFCONF                (*((volatile unsigned long *)0x70200000))
#define NFCONT                (*((volatile unsigned long *)0x70200004))
#define NFCMMD              (*((volatile unsigned long *)0x70200008))
#define NFADDR               (*((volatile unsigned long *)0x7020000C))
#define NFDATA               (*((volatile unsigned char *)0x70200010))
#define NFSTAT                (*((volatile unsigned long *)0x70200028))
void nand_select(void)
    NFCONT &= ~(1<<1);
void nand_deselect(void)
    NFCONT |= (1<<1);
void nand_cmd(unsigned char cmd)
    NFCMMD = cmd;
void nand_addr(unsigned char addr)
    NFADDR = addr;
unsigned char nand_get_data(void)
    return NFDATA;
void nand_send_data(unsigned char data)
    NFDATA = data;
void wait_ready(void)
    while ((NFSTAT & 0x1) == 0);
void nand_reset(void)
    // 选中
    nand_select();
    // 发出0xff命令
    nand_cmd(0xff);
    // 等待就绪
    wait_ready();
    // 取消选中
    nand_deselect();
void nand_init(void)
#if 1
#define TACLS        7
#define TWRPH0    7
#define TWRPH1    7
    NFCONF &= ~((7<<4) | (7<<8) | (7<<12) | (1<<30));
    NFCONF |= ((TACLS<<12) | (TWRPH0<<8) | (TWRPH1<<4));
    // 使能nand flash controller
    NFCONT |= 1;
    NFCONT &= ~(1<<16);
    nand_reset();
#else
    // 让xm0csn2用作nand flash cs0 片选引脚
    MEM_SYS_CFG &= ~(1<<1);
    // 设置时间参数
#define TACLS     0
#define TWRPH0    1
#define TWRPH1    0
    NFCONF &= ~((1<<30) | (7<<12) | (7<<8) | (7<<4));
    NFCONT |= 1;
    NFCONT &= ~(1<<16); // 森止soft lock
    nand_reset();
#endif
void nand_send_addr(unsigned int addr)
#if 0
    unsigned int page = addr / 2048;
    // 这两个地址表示从页内哪里开始
    nand_addr(addr & 0xff);
    nand_addr((addr >> 8) & 0xff);
    // 下面三个地址表示哪一页
    nand_addr(page & 0xff);
    nand_addr((page >> 8) & 0xff);
    nand_addr((page >> 16) & 0xff);
#elif 0
    nand_addr(addr & 0xff);              // a0~a7
    nand_addr((addr >> 8) & 0x7);   // 程序的角度: a8~a10
    nand_addr((addr >> 11) & 0xff); // 程序的角度: a11~a18
    nand_addr((addr >> 19) & 0xff); // 程序的角度: a19~a26
    nand_addr((addr >> 27) & 0xff); // 程序的角度: a27~
#elif 1
    nand_addr((addr >> 8) & 0x7);    // 程序的角度: a8~a11
    nand_addr((addr >> 12) & 0xff);  // 程序的角度: a12~a19
    nand_addr((addr >> 20) & 0xff);  // 程序的角度: a20~a27
    nand_addr((addr >> 28) & 0x01); // 程序的角度: a28~
#endif
int nand_read(unsigned int nand_start, unsigned int ddr_start, unsigned int len)
    unsigned int addr = nand_start;
    int i = nand_start % 4096;
    int count = 0;
    unsigned char *dest = (unsigned char *)ddr_start;
    // 选中芯片
    nand_select();
    while (count < len)
        // 发出命令0x00
        nand_cmd(0x00);
        // 发出地址
        nand_send_addr(addr);
        // 发出命令0x30
        nand_cmd(0x30);
        // 等待就绪
        wait_ready();
        // 读数据
        for (; i < 4096 && count < len; i++)
            dest[count++] = nand_get_data();
            addr++;
        i = 0;
    // 取消片选
    nand_deselect();
    return 0;
int nand_erase_block(unsigned long addr)
    int page = addr / 4096;
    nand_select();
    nand_cmd(0x60);
    nand_cmd(0xd0);
    wait_ready();
    nand_deselect();
    return 0;
int nand_write(unsigned int nand_start, unsigned char * buf, unsigned int len)
    unsigned long count = 0;
    unsigned long addr  = nand_start;
    nand_select();
    while (count < len)
        nand_cmd(0x80);
            nand_send_data(buf[count++]);
            addr++;
        nand_cmd(0x10);
        wait_ready();
        i = 0;
    nand_deselect();
    return 0;
int copykernel2ddr(unsigned int nand_start, unsigned int ddr_start, unsigned int len)
    int ret;
    // 初始化nand flash controller
    nand_init();
    // 读nand flash
    ret = nand_read(nand_start, ddr_start, len);
    return ret;
params.c源码:
#include "setup.h"
static struct tag *params;
static void setup_start_tag (void)
    params = (struct tag *)0x50000100;
    params->hdr.tag = ATAG_CORE;
    params->hdr.size = tag_size (tag_core);
    params->u.core.flags = 0;
    params->u.core.pagesize = 0;
    params->u.core.rootdev = 0;
    params = tag_next (params);
static void setup_memory_tags (void)
    params->hdr.tag = ATAG_MEM;
    params->hdr.size = tag_size (tag_mem32);
    params->u.mem.start = 0x50000000;
    params->u.mem.size = 256*1024*1024;
char * strcpy(char * dest,const char *src)
    char *tmp = dest;
    while ((*dest++ = *src++) != '\0')
    // nothing ;
    return tmp;
int strlen(const char * s)
    const char *sc;
    for (sc = s; *sc != '\0'; ++sc)
    // nothing ;
    return sc - s;
static void setup_commandline_tag (void)
    char *commandline = "noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0,115200";
    params->hdr.tag = ATAG_CMDLINE;
    params->hdr.size = (sizeof (struct tag_header) + strlen (commandline) + 1 + 3) >> 2;
    strcpy (params->u.cmdline.cmdline, commandline);
static void setup_end_tag (void)
    params->hdr.tag = ATAG_NONE;
    params->hdr.size = 0;
void set_params(void)
    setup_start_tag();
    setup_memory_tags();
    setup_commandline_tag();
    setup_end_tag();
uart.c源码:
#include "s3c6410_regs.h"
//#define ENABLE_FIFO
void init_uart(void)
    GPACON &= ~0xff;
    GPACON |= 0x22;
    // ULCON0
    ULCON0 = 0x3;                 // 数据位:8, 无较验, 停止位: 1, 8n1
    UCON0  = 0x5 | (1<<9);   // 使能UART发送、接收, tx interrupt request type = level
#ifdef ENABLE_FIFO
    UFCON0 = 0x07 | (1<<6); // FIFO enable, tx fifo trigger level = 16 bytes
#else
    UFCON0 = 0x00;               // FIFO disable
#endif
    UMCON0 = 0;
    // 波特率
    // DIV_VAL = (PCLK / (bps x 16 ) ) - 1
    // bps = 57600
    // DIV_VAL = (66500000 / (115200 x 16 ) ) - 1
    //         = 35.08
    UBRDIV0   = 35;
    // x/16 = 0.08
    // x = 1
    UDIVSLOT0 = 0x1;
unsigned char getc(void)
#ifdef ENABLE_FIFO
    while ((UFSTAT0 & (1<<6)) == 0 && (UFSTAT0 & 0x3f) == 0);
#else
    while ((UTRSTAT0 & (1<<0)) == 0);
#endif
    return URXH0;
自己写bootloader启动内核,QT文件系统:
测试:把内核源码放到ubuntu先解压:
tar xzf linux-3.0.1-2012-09-23.tar.gz
cd linux-3.0.1-2012-09-23/
make uImage
会在arch/arm/boot/目录下生成uImage文件
把开发板设为SD卡启动,从SD卡启动后按空格键运行SD卡里的u-boot来烧写文件:
tftp 52000000 boot.bin
nand erase 0 200000
nand write 52000000 0 200000
tftp uImage 52000000
nand erase 200000 500000
nand write 52000000 200000 500000
断电把开发板设为nand flash启动,上电等uboot从nand flash中拷贝内核到DDR中再跳到DDR中运行即可看到内核启动信息,要提前用SD卡把QT文件系统烧写到nand flash中,内核才能挂载文件系统成功。
Aerovox Corporation公司的发展小趣事
Aerovox Corporation成立于1922年,是一家专业生产电容器和电子元件的公司。以下是关于Aerovox Corporation发展的五个相关故事:
  1. 成立与初期发展: Aerovox Corporation于1922年在美国马萨诸塞州波士顿成立,最初名为"Northeast Electric Company",后来改名为"Aerovox Corporation"。公司的创始人是W·H·J·Gilbert先生,他致力于开发高性能的电容器。起初,Aerovox主要生产电感线圈和电容器,为无线电和电视等新兴行业提供支持。
  2. 二战期间的发展: 在二战期间,Aerovox Corporation转向军事市场,为美国军方生产电容器和其他电子元件,支持军事通信和雷达系统的发展。这一时期,公司迅速扩张并积累了丰富的技术经验。
  3. 技术创新与扩张: 随着电子技术的不断发展,Aerovox Corporation不断进行技术创新,推出了一系列具有创新性的产品,包括高压电容器、电感器和电源解决方案。公司不仅在军事领域取得了成功,还在民用市场上获得了广泛的应用。
  4. 全球化和市场拓展: Aerovox Corporation通过建立全球销售网络和合作伙伴关系,拓展了国际市场。公司在美国以外的地区设立了生产基地和销售办事处,提供定制化的解决方案,满足客户不断增长的需求。
  5. 持续创新与领先地位: 如今,Aerovox Corporation仍然致力于持续创新,不断开发新的产品和解决方案,以满足不断变化的市场需求。公司在电力电子、医疗设备、工业自动化、交通运输等领域拥有广泛的应用,保持着行业领先地位。
这些故事展示了Aerovox Corporation作为一家具有悠久历史和丰富经验的电子公司,在不同时期和领域的持续发展和创新。
DDK公司的发展小趣事
DDK公司在发展过程中,始终牢记社会责任,积极履行企业公民的义务。公司积极参与公益事业,关注环境保护和社会发展,为社会做出了积极贡献。同时,DDK公司还积极推动行业健康发展,与同行企业共同维护市场秩序和公平竞争环境。这种社会责任的担当,让DDK公司在电子行业中树立了良好的企业形象。
Hexawave公司的发展小趣事
在电子行业中,产品质量是企业生存和发展的关键。DDK公司深知这一点,因此始终将产品质量放在首位。公司建立了严格的质量管理体系,从原材料采购到产品生产、检测的每一个环节都严格把控,确保每一件产品都符合高标准、严要求。这种对品质的执着追求,让DDK公司的产品在市场上赢得了良好的声誉,赢得了消费者的信任和忠诚。
成都芯进(CrossChip)公司的发展小趣事
2023年6月,成都芯进电子宣布完成超1亿元A轮融资。这一轮融资的成功,不仅为公司的发展提供了充足的资金保障,也吸引了更多知名产业机构和投资基金的关注。公司借此机会扩大了研发团队和生产规模,进一步提升了产品的研发和生产能力。
APX Technologies公司的发展小趣事
面对日益激烈的市场竞争,APX Technologies积极寻求与其他企业的合作。公司与一家知名的电子设备制造商达成战略合作协议,共同开发一款具有创新功能的新型智能手机。这款手机的成功上市不仅提升了APX Technologies的品牌知名度,也为其带来了可观的利润。
EDAL公司的发展小趣事
EDAL公司成立于XXXX年,由一群富有远见和创新精神的电子工程师创立。公司初期专注于电子设计自动化(EDA)工具的研发,致力于提升集成电路设计的效率和质量。EDAL公司凭借其独特的算法和高效的设计工具,在EDA领域崭露头角,吸引了众多客户的关注。
我国成功发射第二颗北斗导航卫星
4月15日0时16分,我国在西昌卫星发射中心用“长征三号丙”运载火箭,成功将第二颗北斗导航卫星送入预定轨道。新华社记者李刚摄 15日零时16分,我国在西昌卫星发射中心用“长征三号丙”运载火箭,成功将第2颗北斗导航卫星送入预定轨道。 中国卫 ...…
智能型节能灯泡
部分亮电灯泡,更加环保节能 我们家里使用的灯,基本都是全部亮的,房子的每个地方 都可以照到。不过实际上,我们需要照明的地方可能就只 有某一部分地方,那么其它地方的光似乎就有些浪费了。 现在有了这种可以部分亮电灯泡,就环保节能多了。 ...…
cache 是用来干什么的, 他和DDR有什么区别?
cache 是用来干什么的, 他和DDR有什么区别?…
问一个初级问题,ADC校验后校验值有没有用?
                                 有用的话是用在什么地方?…
5402求助帖
各位大虾请帮忙!我用SEED-XDS510PLUS调试5402板子为什么不能与CCS连接?请出出主意应该从哪些方面考虑出现的问题呢?谢谢了~~…
开发心得
能有一个全面功能的开发板,是顺利开发产品的最佳捷径.…
TI 最新太阳能逆变板预览
附件中是TI提供的太阳能逆变板资料,里面面有电路图,也没有源代码,   由于这块板子还没上市,听说更多详细资料要等之后几个月更新controlsuite才有   电源 连接线   附带的U盘和灯,U盘里面就是附件中的资料   ...…
layout设计
何为layout设计,鄙人是菜鸟,望见怪…
读《Exploring GNU radio》笔记
Exploring GNU radio(GNU radio探密)是GNU radio创始人Eric Blossom所写的,为我们用GNU radio工具构建软件无线电系统做了简明扼要的介绍。读完之后有几点需要自己注意的地方:1、ADC的主要特性:采样率和动态范围。采样率是ADC测量模拟信号的速度 ...…
S5PV210 多媒体预留内存空间 1 - FIMC控制器
由于GPU 多媒体解码 camera输入以及overlay显示等操作需要大块的连续物理内存,S5PV210开发板在初始化的过程中,会为这些多媒体相关驱动预留内存,这些预留的物理内存不能再被系统的其他部件使用,因此调整这些预留空间使之既能满足项目的需求,同 ...…
