今天是:2024年10月12日(星期六)
2018年10月12日 | Tiny210驱动之KEY测试
2018-10-12 来源:eefocus
second_drv.c驱动源码:
#include "linux/device.h"
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "asm/uaccess.h"
#include "asm/irq.h"
#include "asm/io.h"
static struct class *seconddrv_class;
volatile unsigned long *gph2con;
volatile unsigned long *gph2dat;
volatile unsigned long *gph3con;
volatile unsigned long *gph3dat;
static int second_drv_open(struct inode *inode, struct file *file)
// 配置GPH2_3为输入引脚
*gph2con &= ~(0xf<<(3*4));
// 配置GPH3_0,GPH3_1,GPH3_2,GPH3_3为输入引脚
*gph3con &= ~((0xf<<(0*4)) | (0xf<<(1*4)) | (0xf<<(2*4)) | (0xf<<(3*4)));
return 0;
ssize_t second_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos)
// 返回5个引脚的电平
unsigned char key_vals[5];
int regval;
if (size != sizeof(key_vals))
return -EINVAL;
// 读GPH2_3
regval = *gph2dat;
key_vals[0] = (regval & (1<<3)) ? 1 : 0;
// 读GPH3_0,GPH3_1,GPH3_2,GPH3_3
regval = *gph3dat;
key_vals[1] = (regval & (1<<0)) ? 1 : 0;
key_vals[2] = (regval & (1<<1)) ? 1 : 0;
key_vals[3] = (regval & (1<<2)) ? 1 : 0;
key_vals[4] = (regval & (1<<3)) ? 1 : 0;
copy_to_user(buf, key_vals, sizeof(key_vals));
return sizeof(key_vals);
static struct file_operations sencod_drv_fops = {
.owner = THIS_MODULE, // 这是一个宏,推向编译模块时自动创建的__this_module变量
.open = second_drv_open,
.read = second_drv_read,
int major;
static int second_drv_init(void)
major = register_chrdev(0, "second_drv", &sencod_drv_fops);
seconddrv_class = class_create(THIS_MODULE, "second_drv");
device_create(seconddrv_class, NULL, MKDEV(major, 0), NULL, "buttons"); // /dev/buttons
gph2con = (volatile unsigned long *)ioremap(0xe0200c40, 16);
gph2dat = gph2con + 1;
gph3con = (volatile unsigned long *)ioremap(0xE0200C60, 16);
gph3dat = gph3con + 1;
return 0;
static void second_drv_exit(void)
unregister_chrdev(major, "second_drv");
device_destroy(seconddrv_class, MKDEV(major, 0));
class_destroy(seconddrv_class);
iounmap(gph2con);
iounmap(gph3con);
return 0;
module_init(second_drv_init);
module_exit(second_drv_exit);
MODULE_LICENSE("GPL");
seconddrvtest.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
// seconddrvtest
int main(int argc, char **argv)
int fd;
int cnt = 0;
fd = open("/dev/buttons", O_RDWR);
if (fd < 0)
printf("can't open!\n");
while (1)
read(fd, key_vals, sizeof(key_vals));
if (!key_vals[0] || !key_vals[1] || !key_vals[2] || !key_vals[3] || !key_vals[4])
printf("d key pressed: %d %d %d %d %d\n", cnt++, key_vals[0],
key_vals[1], key_vals[2],
key_vals[3], key_vals[4]);
return 0;
上一篇:Tiny210驱动之按键中断实验
下一篇:Tiny210驱动之LED测试
手机是什么?几乎所有人都知道答案:就是那特烧钱、特不保值的玩意!SIM卡是什么?估计许多人无法给出一个比较完整的答案,只知道是一张小小的卡片!但是您也许不知道手机离开了这张小小的SIM卡是几乎做不了工作的,除了在特殊情况下用户可以通过不 ...… 查看全部问答> |
请教大家一个问题: 平台ARM9+WinCE5.0,使用90多张不同品牌不同大小的卡来做测试,其中有一张Nokia 2G的卡在读取某个文件的时候,有些时候数据是正确的,有些时候数据是错误的。 该文件有1.02MB,调用Readfile每次读取1024Bytes,在中间的某一 ...… 查看全部问答> |
用EVC开发,WINCE4.2 为何我调用动态链接库总是说\"找不到testdlg(或他的某一个组件)\" 其中testdlg调用testdll,在VC下试通过了啊 请各位帮帮忙,看看是什么原因,WINCE下调用动态链接库有什么特殊的地方么? … 查看全部问答> |
wince 如何支持向消息队列服务器发送消息?我有个设想,每次在pda上发送消息到消息队列服务器,消息队列服务器从接收到消息后,执行相应的处理。现在存在问题是:在pc机发送都很正常,但是移植到ppc模拟器上,却出现了找不到消息队列服务器错误,为 ...… 查看全部问答> |
modelsim的所有版本都可以在官网上下载,官网地址是http://model.com/,不过下载前要填写以下自己信息 破解方法和破解文件都在附件中,使用破解文件时要关闭全部杀毒啊 … 查看全部问答> |
今天做串口DMA的测试,用DMA1的channle4和channle5对串口1进行收、发测试。发现只要是出现收发同时发生时,发送就会出错。 也就是说DMA的各个通道不能同时使用。唉,这样的话STM的串口的收发效率也就太低了。… 查看全部问答> |
用TimerB0中断,让P4.1发脉冲,TBCCR0到大约30时,用示波器观察P4.1的脉冲波形,抖动严重,为什么? void Init_TimerB(void) { TBCTL = TBSSEL1 + TBCLR + TBIE; // 时钟源SMCLK, TBCCTL0 = CCIE; // C ...… 查看全部问答> |
LM3S系列单片机的定时器模块一共有三种工作模式:(1)定时器模式(2)输入捕捉模式(3)PWM模式这里主要研究一下输入捕捉功能。定时器的输入捕捉模式是用来捕捉外部事件发生的时间或者对外部事件进行计数。当定时器工作于输入捕捉模式时,定时器被配置为 ...… 查看全部问答> |
