今天是:2024年10月14日(星期一)
2018年10月14日 | Tiny4412中断控制器(GIC)之PWM
2018-10-14 来源:eefocus
#include "regs.h"
void enable_mmu(unsigned long ttb);
void init_ttb(unsigned long *ttb_base);
void mmap(unsigned long *ttb_base, unsigned long va, unsigned long pa);
void memset(char *buf, char ch, int size);
void memcpy(char *dst, char *src, int size);
void do_irq(unsigned long regs[]);
void (*printf)(char *, ...) = 0x43e11434;
void main(void)
unsigned long vector_base = 0xffff0000;
unsigned long tt_base = 0x73000000;
unsigned long *pdo_irq = 0x75000000;
extern unsigned long vectors_start, vectors_end;
memset(tt_base, 0x00, 16 * 1024);
mmap(tt_base, vector_base, 0x70000000);
enable_mmu(tt_base);
memcpy(vector_base, vectors_start, 0x100);
*pdo_irq = do_irq;
__asm__ __volatile__ (
"cpsie i\n"
ICCICR_CPU0 = 1;
ICCPMR_CPU0 = 0xff; //Priority Unmask All Interrupt
ICDDCR = 1;
//------ Timer0's IrqID is 69------------------
ICDIPR17_CPU0 = ~(0xff << 8); // the Zero is Highest priority
ICDIPTR17_CPU0 = (1 << 8); // for CPU0, refer PG815
ICDISER2_CPU0 = (1 << 5); // enable interrupt 0
//---------- Configure PWM Timer 0 --------------
GPD0CON &= ~0xff;
GPD0CON |= (0x2 << 0);
TCFG0 = 0xff;
TCFG1 = 0x4;
TINT_CSTAT = 1; //开中断
//200000000 / 256 /16 = 48828,即1秒钟这么多次
TCNTB0 = 48828; //1秒钟产生一次中断
TCMPB0 = 24414; //一半的时候翻转
TCON = (1 << 1); //把上面两个寄存器值手动装入控制器
TCON = 1 | (1 << 2) | (1 << 3);//启动
printf("PWM Timer0: Time Out\n");
TINT_CSTAT |= (1 << 5);//清中断
unsigned long c1_flags;
init_ttb(ttb);
c1_flags = 1 | (1 << 3) | ( 1 << 11) | ( 1 << 13) | (1 << 28);
"mvn r0, #0 \n"
"mcr p15, 0, r0, c3, c0, 0\n"
"mcr p15, 0, %1, c2, c0, 0\n" //configure ttb
"mrc p15, 0, r0, c1, c0, 0\n"
"orr %0, r0, %0\n"
"mcr p15, 0, %0, c1, c0, 0\n" //enable mmu
: "r" (c1_flags), "r" (ttb)
: "r0"
unsigned long va, pa;
for (va = 0x00000000; va < 0x10000000; va += 0x100000) { //Others
pa = va;
ttb_base[ va >> 20] = (pa & 0xfff00000) | 2;
for (va = 0x10000000; va < 0x14000000; va += 0x100000) { //SFR
pa = va;
for (va = 0x40000000; va < 0x80000000; va += 0x100000) { //DRAM
pa = va;
int i;
for (i = 0; i < size; i ++)
buf[i] = ch;
int i;
dst[i] = src[i];
__asm__ (
"vectors:\n"
"b reset\n"
"b und\n"
"b swi\n"
"b pre_abt\n"
"b dat_abt\n"
".word 0\n"
"b irq\n"
"b fiq\n"
"reset:\n"
"und:\n"
"mov sp, #0x74000000\n"
"stmfd sp!, {r0-r12, lr}\n"
"mov r0, sp\n"
"mov r3, #0x74000000\n"
"ldr r3, [r3]\n"
"blx r3\n"
"ldmea sp, {r0-r12, pc}^\n"
"swi:\n"
"pre_abt:\n"
"dat_abt:\n"
"fiq:\n"
"irq:\n"
"mov sp, #0x75000000\n"
"sub lr, lr, #4 \n"
"mov r0, sp\n"
"mov r3, #0x75000000\n"
"ldr r3, [r3]\n"
"blx r3\n"
"EOV:\n"
"vectors_start:\n"
".word vectors\n"
"vectors_end:\n"
".word EOV\n"
Makefile文件:
default:
arm-linux-gcc -c test.c -o test.o
arm-linux-ld -Ttext=0x70003000 test.o -o test
arm-linux-objcopy -O binary test test.bin
clean:
rm -f test.o test test.bin *~
基于最新款飞思卡尔片子(MC9S08AC32)的实际应用代码 如题所说. 对于想使用这款飞思卡尔芯片,MC9S08AC32,FLASH有32K的同志位来说,我认为这个片子做得不错了,你们可以试着尝试一下,飞思卡尔是俺使用过的代码中,我觉得相对来说,抗干扰性较强的一款片子. 这里有一些代码,可以帮你迅速入门,迅速走入开发.… 查看全部问答> |
8255引脚电平变化无法读取 #define PA8255 (*((unsigned char xdata *)0x1fff))//总线地址 #define PB8255 (*((unsigned char xdata *)0x3fff))//总线地址用16位表示 p0是低八位 p2是高八位 #define PC8255 (*((unsigned char xdat ...… 查看全部问答> |
如题。 我自己定制了一个PB,编译好了后,把SDK导出了,但是这个SDK是要安装在VS2005的安装目录下吗??(我用的开发 工具是VS2005,但是是第一次使用)安装完了SDK,在启动VS2005,新建工程时,需要对它进行选择吗????… 查看全部问答> |
Getting Started with the MSP430 LaunchPad_Student Guide and Lab Manual 内容和大课堂的内容差不多,只不过是英文的。 大家看看!… 查看全部问答> |
S5PV210 uboot 启动分析 https://bbs.eeworld.com.cn/forum ... 2682&fromuid=478717 (出处: 电子工程世界-论坛) … 查看全部问答> |
