今天是:2024年11月26日(星期二)
2018年11月26日 | TQ2440裸奔程序:串口UART打印printf测试程序
2018-11-26 来源:eefocus
// NAME: main.c
// DESC: TQ2440串口UART打印printf测试程序
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include
#include
static volatile int uart_port = 0;
void uart_init(int pclk,int buad,int ch)
//UART初始化:端口使能、功能设定、波特率、设置数据格式
rGPHCON = (rGPHCON & ~(0xfff<<4)) | (0xaaa<<4);//端口RX[0:2]、TX[0:2]功能
rGPHUP = rGPHUP | (0x7<<1); //端口GPH[1:3]禁止上拉
rUFCON0 = 0x0; //禁止FIFO
rUFCON1 = 0x0; //禁止FIFO
rUFCON2 = 0x0; //禁止FIFO
rUMCON0 = 0x0; //禁止AFC
rUMCON1 = 0x0; //禁止AFC
//Normal:No parity:One stop:8-bits 中断响应 UART clock: PCLK
rULCON0 = (rULCON0 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
rUCON0 = (rUCON0 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
rUBRDIV0 = ((int)(pclk/16./buad+0.5)-1);
rULCON1 = (rULCON1 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
rUCON1 = (rUCON1 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
rUBRDIV1 = ((int)(pclk/16./buad+0.5)-1);
rULCON2 = (rULCON2 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
rUCON2 = (rUCON2 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
rUBRDIV2 = ((int)(pclk/16./buad+0.5)-1);
uart_port = ch; //设置串口端口号
void uart_send_byte(int data)
if(0 == uart_port)
if(data == 'n')
while(!(rUTRSTAT0 & 0x2));
rUTXH0 = 'n';
rUTXH0 = data;
else if(1 == uart_port)
if(data == 'n')
while(!(rUTRSTAT1 & 0x2));
rUTXH1 = 'n';
rUTXH1 = data;
else if(2 == uart_port)
if(data == 'n')
while(!(rUTRSTAT2 & 0x2));
rUTXH2 = 'n';
rUTXH2 = data;
void uart_send_string(char *string)
while(*string)
uart_send_byte(*string++);
void uart_printf(char *fmt,...)
va_list ap;
char string[256];
va_start(ap,fmt);
vsprintf(string,fmt,ap);
uart_send_string(string);
va_end(ap);
void Main(void)
int plck_val = 50000000;
int buad_val = 115200;
int ch_val = 0;
uart_init(plck_val,buad_val,ch_val);
uart_printf("PCLK is %d,buad is %d,uart_port is %d n",plck_val,buad_val,ch_val);
while(1);
引用《移动在线》 GSM数字移动通信发展非常迅速,从早期规划的大区制,到后来的小区制,直到现在的微蜂窝、微微蜂窝,相对应的天线从早期架设在屋面铁塔上,到后来天线降到屋面上,直到现在要把天线设置在屋面下的外墙侧面上。所有的这些变化都说 ...… 查看全部问答> |
印制电路板(转)PS:谁还有PCB的有关知识,劳驾补充学习下~ 印制电路板,又称印刷电路板,印刷线路板,英文简称PCB或PWB,是重要的电子部件,是电子元器件的支撑体,是电子元器件电气连接的提供者。由于它是采用电子印刷术制作的,故被称为“印刷”电路板。 历史 印制电路板的发明者是奥地利人保罗·爱斯 ...… 查看全部问答> |
1.4 深度睡眠模式设置步骤 处理通过调用WFI 指令即可进入睡眠模式,但要进入深度睡眠实现最低的功耗需要正确配置,其步骤如下: 1. 使能ACG 自动时钟门控。这样睡眠模式和深度睡眠模式的外设时钟可以单独控制。 2. 配置寄存器DCGC0、 DCGC1 和DC ...… 查看全部问答> |
新买的博创公司的270A开发板,用的是pxa270芯片,我按照它上面的介绍烧写WINCE5.0后,发现显示屏不停的开关,并没有出现像他们说的烧写完后自动运行.下面是超级终端出现的代码,各位帮忙解答一下,我对这是个绝对的菜 FlashWrite: dwLengt ...… 查看全部问答> |
51单片机的全局变量在主程序中输入值改变后,在中断中却没有改变 我的主程序中,在AD转换后赋值一全局变量,在输入值改变后,它是随着改变的,在串口中断中发送给上位机,中断发出的值为什么不随输入的改变而改变呢?请有经验的人给以指点.非常感谢!!… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 09:00 编辑 请问广州哪里有零售漆包线、绝缘纸和绝缘漆的地方?? 昨天下午走了一下午,传说中有这些东西的解放中,都没看见有卖忘各位朋友指出哪里有得买 … 查看全部问答> |
