今天是:2024年12月21日(星期六)
2018年12月21日 | STM32中断数据回调函数接收处理
2018-12-21 来源:eefocus
1.定义一个空的指针函数 指针函数的参数是uint8_t 类型ch
typedef void (* usart_recv_callback)(uint8_t ch);
2.声明这个类型
usart_recv_callback usart1_recv_cb;
3.串口配置时,一个形参为串口中断接收回调
void Usart_Config(USART_TypeDef* USARTx, uint32_t baudRate, usart_recv_callback cb)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
if(USARTx == USART1)
usart1_recv_cb = cb;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
/* Configure USART1 Tx (PA.09) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure USART1 Rx (PA.10) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitStructure.USART_BaudRate = baudRate;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
if(cb)
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
/* Enable the USARTy Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_Cmd(USART1, ENABLE);
分析:usart1_recv_cb = cb;这句语句是将形参指针函数 cb 赋值给 usart1_recv_cb
if(cb):是判断回调函数指针是否为空,如果不为空则中断初始化
4.串口中断函数
void USART1_IRQHandler(void)
uint8_t ch;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
/* Read one byte from the receive data register */
ch = USART_ReceiveData(USART1);
usart1_recv_cb(ch);
USART_ClearITPendingBit(USART1, USART_IT_RXNE);
分析:将串口1中断接收到的值赋值给ch,然后ch作为usart1_recv_cb函数的输入参数
5.
void HCHO_Test(uint8_t recv_data)
if((sensorstr.hcho_addr == 0) && (recv_data != 0xff))
sensorstr.hcho_addr = 0;
return;
if((sensorstr.hcho_addr == 1) && (recv_data != 0x17))
return;
if((sensorstr.hcho_addr == 2) && (recv_data != 0x04))
return;
sensorstr.hcho_packet[sensorstr.hcho_addr++] = recv_data;
分析:void HCHO_Test(uint8_t recv_data)函数就是我们所说的回调函数,此函数和 1.里所定义的void (* usart_recv_callback)(uint8_t ch)函数指针是对应的。
6.
int main(void)
Usart_Config(PM_UART, 9600, PM_Test);
PM_Test函数首地址就是usart_recv_callback cb的形参
在pcb布线的过程中,总线方式布线是怎样的方式!?在县卡,主板上看到其布线很漂亮,经询问说是总线方式布线,不懂。请教。在protel中用shift+空格转换… 查看全部问答> |
各位vxworks的前辈们,小弟刚刚接触vxworks,目前使用一块MPC852的板子,自带了bootrom,无源码,无仿真器,板子启动后bootrom可以正常运行,现在我自己修改了一个MPC852的BSP,并基于此做了个vxworks镜像。 ...… 查看全部问答> |
关于一个单片机串口接收FPGA配置文件的问题,希望大家不吝赐教 各位高手,小弟有疑问相求,最近被安排做个小东西,目的是把几个FPGA的配置文件利用串口发给单片机,单片机接收后将其存入几片EEPROM里,再根据需求选择用哪个文件来配置FPGA,感觉上位机程序的功能和串口调试助手有点像。疑问就在于: 1.是否可以 ...… 查看全部问答> |
综合布线是一种模块化的、灵活性极高的建筑物内或建筑群之间的信息传输通道。它既能使语音、数据、图像设备和交换设备与其它信息管理系统彼此相连, 也能使这些设备与外部相连接。它还包括建筑物外部网络或电信线路的连接点与应用系统设备之间的所有 ...… 查看全部问答> |
我看了FL2440屏幕初始化的代码,在bootloader,eboot还有wince驱动中都有,但是只有bootloader中的初始化调用了,eboot还有wince驱动中都没有调用初始化函数。。但是我现在用spi接口的屏幕照样做,bootloader中可以点亮,但是到了wince中就会熄灭, ...… 查看全部问答> |
