今天是:2024年12月28日(星期六)
2018年12月28日 | stm32滴答时钟SYStick的优先级设定方法详解
2018-12-28 来源:eefocus
以ST的V3.50固件为对象,:
1.     滴答寄存器的定义和地址分配在内核.H文件中如下
typedef struct
  __IO uint32_t CTRL;                         /*!< Offset: 0x00  SysTick Control and Status Register */
  __IO uint32_t LOAD;                         /*!< Offset: 0x04  SysTick Reload Value Register     */
  __IO uint32_t VAL;                          /*!< Offset: 0x08  SysTick Current Value Register     */
  __I  uint32_t CALIB;                        /*!< Offset: 0x0C  SysTick Calibration Register      */
} SysTick_Type;
#define SysTick             ((SysTick_Type *)       SysTick_BASE)
定义结构指针SYSTICK,并赋值为物理存储器首地址0xE000E010,由于结构是顺序的所以可以用结构指针来访问寄存器。
因为滴答事件是内核的异常所以还要牵扯到另一个寄存器SCB寄存器(系统控制块)
typedef struct
__I  uint32_t CPUID;        /*!< Offset: 0x00  CPU ID Base Register                          */
  __IO uint32_t ICSR;       /*!< Offset: 0x04  Interrupt Control State Register                      */
  __IO uint32_t VTOR;     /*!< Offset: 0x08  Vector Table Offset Register                          */
  __IO uint32_t AIRCR;    /*!< Offset: 0x0C  Application Interrupt / Reset Control Register        */
  __IO uint32_t SCR;    /*!< Offset: 0x10  System Control Register                               */
  __IO uint32_t CCR;     /*!< Offset: 0x14  Configuration Control Register                        */
  __IO uint8_t  SHP[12];    /*!< Offset: 0x18  System Handlers Priority Registers (4-7, 8-11, 12-15) */
  __IO uint32_t SHCSR;  /*!< Offset: 0x24  System Handler Control and State Register             */
  __IO uint32_t CFSR;  /*!< Offset: 0x28  Configurable Fault Status Register                    */
  __IO uint32_t HFSR;   /*!< Offset: 0x2C  Hard Fault Status Register                            */
  __IO uint32_t DFSR;   /*!< Offset: 0x30  Debug Fault Status Register                           */
  __IO uint32_t MMFAR; /*!< Offset: 0x34  Mem Manage Address Register                           */
  __IO uint32_t BFAR; /*!< Offset: 0x38  Bus Fault Address Register                            */
  __IO uint32_t AFSR; /*!< Offset: 0x3C  Auxiliary Fault Status Register                        */
  __I  uint32_t PFR[2]; /*!< Offset: 0x40  Processor Feature Register                           */
  __I  uint32_t DFR;  /*!< Offset: 0x48  Debug Feature Register                              */
  __I  uint32_t ADR; /*!< Offset: 0x4C  Auxiliary Feature Register                            */
  __I  uint32_t MMFR[4]; /*!< Offset: 0x50  Memory Model Feature Register                    */
  __I  uint32_t ISAR[5]; /*!< Offset: 0x60  ISA Feature Register                                  */
} SCB_Type;
这里面寄存器很多,在这里大部分我们不用去管,有一个数组SHP[12],一定要看清他是8位数组啊!这个数组是很重要的,他是用来设置内核异常的优先级别,并不是想的在NVIC里设置,那个是大于15号中断的优先组别,换句话就是外部中断什么看门狗,定时器,串口啥的,外设的中断优先级设置在NVIC地IP数组中,而小于这个的都是内部异常,他不归NVIC管制,他受谁管呢?就是这个SHP[12],滴答属于内核的异常所以他要用SHP[12]来设置,和内核手册中讲到的那三个(SHRP1-SHRP3)32位寄存器一一对应,算下来正好有12个字节,最后一个字节就是我要的SYStick的优先级设置,他只用了他的高四位,而第四位保留,所以他的范围是0-15之间的任意数!!
2.系统设置函数:
NVIC_SetPriority (SysTick_IRQn, (1<<__NVIC_PRIO_BITS) - 1);
这就是固件库里对SYSTICK的优先级设置,,后面参数,这里的__NVIC_PRIO_BITS=4,变形=(1《《4-1)=0xf;第一个参数是表明这是对滴答进行设置,SysTick_IRQn=-1,看实体:
static __INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
if(IRQn < 0) {
    SCB->SHP[((uint32_t)(IRQn) & 0xF)-4] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff); } /* set Priority for Cortex-M3 System Interrupts */
  else {
NVIC->IP[(uint32_t)(IRQn)] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);    }
这里有个IF,就是这个IF来判别是内核异常还是外部异常的优先级,如果是内核异常那么由SCB解决,如果不是那么有NVIC解决。显然这个是由SCB解决的。
SHP[((uint32_t)(IRQn) & 0xF)-4]变换=SHP[f-4]=SHP[11],那么这个SHP[11]就是设置滴答的优先级!他的优先级是多少?
((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);=(priority<<4)=(f<<4)=0xf0;
显然这就是他的优先级是15!!!!!!!!!!!!!!!
有了优先级就了解滴答了,即使没有固件库函数依然可以设置看看自己设置的函数:
void mysystickint()
SysTick->LOAD=71999;//加载值=1ms
SCB->SHP[11]=15;//设置SYSTICK的优先级为15,注意SYSTICK属于系统异常,所以他的优先级在SCB里设置。
SysTick->CTRL=7;//开启中断,开启定时器,时钟设置为HCLK=72mhz
}这是中断模式,另外也可以选择查询模式,只是占CPU时间,查询模式下根本不用设置什么优先级!他只要开开滴答,查询标志位即可!
安碁科技(AKER)公司的发展小趣事
品质是企业的生命线。安碁科技自成立以来,一直注重品质管理和技术创新。2000年,公司引进了全自动化制程设备,正式生产SMD产品,并通过了ISO9002认证。此后,安碁科技陆续通过了多项国际认证,如TL-9000、TS16949等,证明了其在品质管理方面的卓越表现。同时,公司也不断投入研发资源,推动技术创新和产品升级,以满足市场不断变化的需求。
Connector City公司的发展小趣事
随着全球环保意识的不断提高,电子行业对绿色环保的要求也越来越高。Connector City公司积极响应国家环保政策,加强了对生产过程的环保管理。公司引进了先进的环保设备和技术,减少了生产过程中的废弃物排放和能源消耗。同时,公司还注重产品的环保性能设计,推出了多款符合环保标准的新型连接器产品。通过坚持绿色环保和可持续发展理念,公司赢得了社会的广泛赞誉和支持。
这五个故事仅是对Connector City公司可能发展路径的一种虚构描述,实际情况可能因市场变化、公司策略调整等多种因素而有所不同。在实际发展中,公司需要根据自身情况和市场环境做出灵活的调整和决策。
Crystalfontz America Inc公司的发展小趣事
Crystalfontz America Inc公司自成立以来,一直致力于LCD、OLED等显示模块的研发和生产。在早期的发展阶段,公司面临着技术上的诸多挑战。然而,通过持续的技术投入和研发团队的不懈努力,公司成功突破了多项关键技术,推出了一系列具有竞争力的显示模块产品。这些产品在市场上获得了广泛认可,为公司的快速发展奠定了坚实基础。
Crane Connectors公司的发展小趣事
在日益严峻的环保形势下,Crane Connectors公司积极响应国家环保政策,将绿色环保理念融入企业的生产经营活动中。公司采用环保材料和节能技术,减少生产过程中的污染物排放和资源消耗。同时,公司还加强废弃物的回收和处理工作,实现资源的循环利用。这些环保举措不仅提升了公司的社会形象,也为公司的可持续发展奠定了坚实的基础。
Ceramics公司的发展小趣事
“全球陶瓷”公司凭借其卓越的产品质量和国际化战略,成功拓展了海外市场。该公司积极参与国际展览和交流活动,与多国电子企业建立了合作关系。同时,全球陶瓷还针对不同国家和地区的市场需求,推出了定制化的陶瓷电子材料解决方案。这一国际化战略不仅提升了公司的品牌影响力,也为其在全球范围内的业务拓展提供了有力支持。
华瓷(Chinocera)公司的发展小趣事
面对日益激烈的市场竞争和不断变化的市场需求,华瓷始终坚持创新引领的发展战略。公司加强与高校、科研机构的合作,共同研发新型陶瓷材料和生产技术。同时,华瓷还积极引进国内外先进的生产设备和制造工艺,不断提升自身的产业水平和核心竞争力。
实验室经验谈----什么样的示波器适合你?
实验室,最常用的示波器,大家很熟悉了,但有谁知道示波器也有使用范围和使用方向的问题,比如数电,模电实验用的示波器常是低频的,在通信,高频实验室用的示波器才是频率很大的示波器,下面讲示波器的知识吧。 什么样的示波器适合你?    示 ...…
我想在ARM-Linux上做图形界面,是用Qt做简单还是MiniGUI做简单?
来自EEWORLD合作群:arm linux fpga 嵌入0(49900581) 群主:wangkj 我以前只在没有操作系统的单片机上写过程序,用C写的,还没学过C++.不知道以上哪个入门简单啊?…
NK.bin大于32M,无法正常下载
我现在有一个35M的nk.bin文件,想下到FLASH上,可总是不能下载,之前大于30M后,串口会给出“无效映像”的消息,后来改了EBOOT的一个参数后,倒是不出现这个消息了,但还是不能下载,EBOOT好像是卡在VerifyChecksum这个函数就不动了,想请问各位高 ...…
红外接收头的相关疑问,牛人请指教!
遥控是TC9012,它采用的38kHz的载波(一个载波周期35us),载波占空比1/3,经过调制后发送波形是9ms的引导码(前4.5ms由载波构成,后4.5ms是载波关断)和33bit的数据构成。比特1是0.56ms的载波和1.69ms的载波关断构成,比特0是0.56ms的载波和0.565ms的 ...…
David_Lee 我那个跑马灯程序要你如何优化??
请全盘脱出好不??我晚上自己回味下,,,最好你写个完整的....麻烦…
请问香主,stm32f103zet6一共有几路硬件PWM
【讨论】关于MSP430的延时问题
在做片选或是别的问题的时候遇到过延时问题。我用的是 for (s=0;s<50;s++); 或 for (s=0;s<50;s++) { 。 。 。 。 } 我想问的是这个时间间隔怎么 来算,不用定时器,就只是一个简单的时间延时 谢谢!!…
无线模块24L01资料
无线模块24L01资料…
