今天是:2024年12月28日(星期六)
2018年12月28日 | STM32双机SPI中断通信机制
2018-12-28 来源:eefocus
研究STM32F4的SPI有一阵子了,进步很缓慢,前几天终于鼓起勇气,用手抄了一遍官方的代码,然后自己一个字字的敲进去,然后再调试。历时大约一个星期,终于把SPI的中断发送和中断接收给整清楚了。在没有正确运行出结果之前,一切都是辣么痛苦。此文鼓励我继续往前进步。
先说主机端,首先当然是写SPI驱动文件,也就是SPI的配置,具体文件如下:
SPI.c
#include
#include "usart.h"
#include "spi.h"
  u8 Master_Temp =0;
  extern SPI_InitTypeDef  SPI_InitStructure;
 u8 Slave_Temp=0;
 static __IO uint32_t TimingDelay;
 void SPI_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Peripheral Clock Enable -------------------------------------------------*/
  /* Enable the SPI clock */
  SPIx_CLK_INIT(SPIx_CLK, ENABLE);
  /* Enable GPIO clocks */
  RCC_AHB1PeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK, ENABLE);
  /* SPI GPIO Configuration --------------------------------------------------*/
  /* Connect SPI pins to AF5 */
  GPIO_PinAFConfig(SPIx_SCK_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
  GPIO_PinAFConfig(SPIx_MOSI_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
  GPIO_PinAFConfig(SPIx_MISO_GPIO_PORT, SPIx_MISO_SOURCE, SPIx_MISO_AF);
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  /* SPI SCK pin configuration */
  GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN;
  GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
  /* SPI  MOSI pin configuration */
  GPIO_InitStructure.GPIO_Pin =  SPIx_MOSI_PIN;
  GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
  /* SPI  MISO pin configuration  */
  GPIO_InitStructure.GPIO_Pin =  SPIx_MISO_PIN;
  GPIO_Init(SPIx_MISO_GPIO_PORT,&GPIO_InitStructure);
  /* SPI configuration -------------------------------------------------------*/
  SPI_I2S_DeInit(SPIx);
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS  = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
 /* Configure the Priority Group to 1 bit */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  /* Configure the SPI interrupt priority */
  NVIC_InitStructure.NVIC_IRQChannel = SPIx_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
SPI.H
  * @file    SPI/SPI_TwoBoards/DataExchangeInterrupt/main.h
  * @author  MCD Application Team
  * @version V1.0.0
  * @date    30-September-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2011 STMicroelectronics
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __SPI_H_
#define __SPI_H_
#ifdef __cplusplus
 extern "C" {
#endif
/* Includes ------------------------------------------------------------------*/
#include "stm32f4xx.h"
#include "stm324xg_eval.h"
#include "stm324xg_eval_ioe.h"
/* Exported typedef -----------------------------------------------------------*/
#define countof(a)   (sizeof(a) / sizeof(*(a)))
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Exported define ------------------------------------------------------------*/
/* Uncomment the line below if you will use the SPI peripheral as a Master */
 #define SPI_MASTER
/* Uncomment the line below if you will use the SPI peripheral as a Slave */
//#define SPI_SLAVE
/* USER_TIMEOUT value for waiting loops. This timeout is just guarantee that the
   application will not remain stuck if the USART communication is corrupted.
   You may modify this timeout value depending on CPU frequency and application
   conditions (interrupts routines, number of data to transfer, baudrate, CPU
   frequency...). */
#define USER_TIMEOUT                    ((uint32_t)0x64) /* Waiting 1s */
/* SPIx Communication boards Interface */
#define SPIx                           SPI2
#define SPIx_CLK                       RCC_APB1Periph_SPI2
#define SPIx_CLK_INIT                  RCC_APB1PeriphClockCmd
#define SPIx_IRQn                      SPI2_IRQn
#define SPIx_IRQHANDLER                SPI2_IRQHandler
#define SPIx_SCK_PIN                   GPIO_Pin_1
#define SPIx_SCK_GPIO_PORT             GPIOI
#define SPIx_SCK_GPIO_CLK              RCC_AHB1Periph_GPIOI
#define SPIx_SCK_SOURCE                GPIO_PinSource1
#define SPIx_SCK_AF                    GPIO_AF_SPI2
#define SPIx_MISO_PIN                  GPIO_Pin_2
#define SPIx_MISO_GPIO_PORT            GPIOI
#define SPIx_MISO_GPIO_CLK             RCC_AHB1Periph_GPIOI
#define SPIx_MISO_SOURCE               GPIO_PinSource2
#define SPIx_MISO_AF                   GPIO_AF_SPI2
#define SPIx_MOSI_PIN                  GPIO_Pin_3
#define SPIx_MOSI_GPIO_PORT            GPIOI
#define SPIx_MOSI_GPIO_CLK             RCC_AHB1Periph_GPIOI
#define SPIx_MOSI_SOURCE               GPIO_PinSource3
#define SPIx_MOSI_AF                   GPIO_AF_SPI2
#define TXBUFFERSIZE   (countof(TxBuffer) - 1)
#define RXBUFFERSIZE   TXBUFFERSIZE
/* Define numbers of bytes to transmit from TxBuffer */
#define CMD_RIGHT_SIZE                   0x01
#define CMD_LEFT_SIZE                    0x05
#define CMD_UP_SIZE                      0x14
#define CMD_DOWN_SIZE                    0x1E
#define CMD_SEL_SIZE                     TXBUFFERSIZE
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
#ifdef SPI_MASTER
 uint8_t GetVar_NbrOfData(void);
#endif
#ifdef __cplusplus
#endif
void SPI_Config( void);
void SysTickConfig(void);
void Fill_Buffer(__IO uint8_t *pBuffer, uint16_t BufferLength);
#endif /* __MAIN_H */
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
  stm32f4xx_it.c
  * @file    stm32fxxx_it.c
  * @version V2.1.0
  * @date    19-March-2012
  * @brief   This file includes the interrupt handlers for the application
#include "usb_bsp.h"
#include "usb_hcd_int.h"
#include "usbh_core.h"
#include
#include "stm32fxxx_it.h"
#include "spi.h"
#include "main.h"
extern __IO uint8_t CmdTransmitted;
extern __IO uint8_t Tx_Idx;
extern __IO uint8_t CmdStatus;
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
extern USB_OTG_CORE_HANDLE          USB_OTG_Core;
extern USBH_HOST                    USB_Host;
extern uint8_t TxBuffer[];
extern __IO uint32_t TimeOut;
extern __IO uint8_t Counter;
/* Private function prototypes -----------------------------------------------*/
extern void USB_OTG_BSP_TimerIRQ (void);
void SysTick_Handler(void)
  /* Decrement the timeout value */
  if (TimeOut != 0x0)
    TimeOut--;
  if (Counter < 10)
    Counter++;
  else
    Counter = 0x00;
    STM_EVAL_LEDToggle(LED1);
void SPIx_IRQHANDLER(void)
#ifdef SPI_MASTER
if(SPI_I2S_GetITStatus(SPIx,SPI_I2S_IT_TXE) == SET)
if(CmdStatus == 0x00)
SPI_I2S_SendData(SPIx,CmdTransmitted);
CmdStatus = 0x01;
else
if(Tx_Idx < GetVar_NbrOfData())
// printf("send data%c\n",TxBuffer[Tx_Idx]);
SPI_I2S_SendData(SPIx,TxBuffer[Tx_Idx++]);
// printf("%d\n",Tx_Idx);
// Tx_Idx++;
else
{ printf(" DISABLE IR\n"); SPI_I2S_ITConfig(SPIx,SPI_I2S_IT_TXE,DISABLE); }
#endif
  * @brief  DebugMon_Handler
  *         This function handles Debug Monitor exception.
  * @param  None
  * @retval None
void DebugMon_Handler(void)
  * @brief  PendSV_Handler
  *         This function handles PendSVC exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  EXTI1_IRQHandler
  *         This function handles External line 1 interrupt request.
  * @param  None
  * @retval None
void EXTI1_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line1) != RESET)
      USB_Host.usr_cb->OverCurrentDetected();
      EXTI_ClearITPendingBit(EXTI_Line1);
  * @brief  TIM2_IRQHandler
  *         This function handles Timer2 Handler.
  * @param  None
  * @retval None
void TIM2_IRQHandler(void)
  USB_OTG_BSP_TimerIRQ();
  * @brief  OTG_FS_IRQHandler
  *          This function handles USB-On-The-Go FS global interrupt request.
  *          requests.
  * @param  None
  * @retval None
#ifdef USE_USB_OTG_FS
void OTG_FS_IRQHandler(void)
#else
void OTG_HS_IRQHandler(void)
#endif
  USBH_OTG_ISR_Handler(&USB_OTG_Core);
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
  stm32f4xx_it.h
  * @file    stm32fxxx_it.h
  * @version V2.1.0
  * @brief   This file contains the headers of the interrupt handlers.
  * @attention
© COPYRIGHT 2012 STMicroelectronics
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
#ifndef __STM32Fxxx_IT_H
#define __STM32Fxxx_IT_H
#ifdef __cplusplus
 extern "C" {
#endif
#include "usb_conf.h"
void NMI_Handler(void);
void HardFault_Handler(void);
void MemManage_Handler(void);
void BusFault_Handler(void);
void UsageFault_Handler(void);
void SVC_Handler(void);
void DebugMon_Handler(void);
void PendSV_Handler(void);
void SysTick_Handler(void);
void SPIx_IRQHANDLER(void);
#ifdef __cplusplus
#endif
#endif /* __STM32Fxxx_IT_H */
   main.c
  * @file    main.c
  * @version V2.1.0
  * @brief   USB host MSC class demo main file
  * @attention
#include
#include
#include "main.h"
#include "usbh_usr.h"
#include "usbh_msc_core.h"
#include "nvic.h"
#include "usart.h"
#include "spi.h"
#include "dma.h"
#include "KBD.h"
#include "terminal.h"
//DMA_InitTypeDef DMA_InitStructure;
uint8_t TxBuffer[] ="SPI Interrupt Example: Communication between two SPI using Interrupts";
//__IO uint32_t TimeOut = 0x0;
//#ifdef SPI_SLAVE
// __IO uint8_t uint8_t RxBuffer[RXBUFFERSIZE];
// __IO uint8_t Rx_Idx = 0;
//#endif
#ifdef SPI_MASTER
__IO uint8_t Tx_Idx =0;
__IO uint8_t CmdTransmitted = CMD_NONE;
__IO uint8_t CmdStatus = 0x00;
__IO uint8_t NumberOfByte = 0;
#endif
//static void SPI_Config(void);
#ifdef SPI_MASTER
static void  TimeOut_UserCallback(void);
#endif
//#ifdef SPI_SLAVE
// static TestStatus Buffercmp(uint8_t *pBuffer1,__IO uint8_t *pBuffer2,uint16_t BufferLength);
// static void Fill_Buffer(__IO uint8_t *pBuffe,uint16_t BufferLength);
//#endif
#define Buff_SIZE 32
const uint8_t Buff[Buff_SIZE]= {
0xA0,0x00,0x00,0xAA,
                                    0x55,0x55,0x55,0x55,
                                    0x55,0x00,0x00,0x00,
                                    0x00,0x00,0x00,0x00,
                                    0xAA,0xAA,0xAA,0xAA,
                                    0x00,0x00,0xA0,0xAA };
uint32_t DST_Buffer[BUFFER_SIZE];
/** @addtogroup USBH_USER
/** @defgroup USBH_USR_MAIN
* @brief This file is the MSC demo main file
/** @defgroup USBH_USR_MAIN_Private_TypesDefinitions
/** @defgroup USBH_USR_MAIN_Private_Defines
/** @defgroup USBH_USR_MAIN_Private_Macros
/** @defgroup USBH_USR_MAIN_Private_Variables
//#ifdef SPI_MASTER
// static void TimeOut_UserCallback(void);
//#endif
#ifdef USB_OTG_HS_INTERNAL_DMA_ENABLED
  #if defined ( __ICCARM__ ) /*!< IAR Compiler */
    #pragma data_alignment=4
  #endif
#endif /* USB_OTG_HS_INTERNAL_DMA_ENABLED */
__ALIGN_BEGIN USB_OTG_CORE_HANDLE      USB_OTG_Core __ALIGN_END;
  #endif
__ALIGN_BEGIN USBH_HOST                USB_Host __ALIGN_END;
/** @defgroup USBH_USR_MAIN_Private_FunctionPrototypes
/** @defgroup USBH_USR_MAIN_Private_Functions
* @brief  Main routine for MSC class application
* @param  None
* @retval int
int main(void)
  uint32_t KEY;
KBD_Init();
  SPI_Config();
SysTickConfig();
// STM_EVAL_LEDInit(LED1);
// SPI1_DMA_Configuration();
usart3.initialize(9600);
terminal.initialize();
  /* Init Host Library */
USBH_Init(&USB_OTG_Core,
            USB_OTG_FS_CORE_ID,
#else
            USB_OTG_HS_CORE_ID,
#endif
            &USB_Host,
            &USBH_MSC_cb,
            &USR_cb);
#ifdef SPI_MASTER
SPI_Init(SPIx,&SPI_InitStructure);
SPI_Cmd(SPIx,ENABLE);
while(1)
/* Host Task handler */
  USBH_Process(&USB_OTG_Core, &USB_Host);
//  SPI2_ReadWriteByte(0xAA);
KEY = KBD_GetKeys();
switch(KEY)
case WAKEUP:
CmdTransmitted = CMD_UP;
NumberOfByte = CMD_UP_SIZE;
printf("\r\n WAKEUP");
break;
case TAMPER:
CmdTransmitted = CMD_SEL;
NumberOfByte = CMD_SEL_SIZE;
printf("\r\n TAMPER");
break;
default:
// CmdTransmitted = CMD_LEFT;
// NumberofByte = CMD_LEFT_SIZE;
break;
CmdStatus = 0x00;
Tx_Idx = 0;
if(CmdTransmitted != CMD_NONE)
SPI_I2S_ITConfig(SPIx,SPI_I2S_IT_TXE,ENABLE);
while(Tx_Idx
#endif
  /* Set SysTick Timer for 10ms interrupts  */
  if (SysTick_Config(SystemCoreClock / 100))
    /* Capture error */
    while (1);
  /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);
#ifdef USE_FULL_ASSERT
* @brief  assert_failed
*         Reports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @param  File: pointer to the source file name
* @param  Line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
  ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
  return NumberOfByte;
  /* User can add his own implementation to manage TimeOut Communication failure */
  /* Block communication and all processes */
  while (1)
main.h
#ifndef __MAIN_H
#define __MAIN_H
#ifdef __cplusplus
 extern "C" {
#endif
#define SPI_MASTER
/* Joystick Commands */
#define CMD_RIGHT                        0x55
#define CMD_LEFT                         0xAA
#define CMD_UP                           0x33
#define CMD_DOWN                         0xCC
#define CMD_SEL                          0xFF
#define CMD_NONE                         0x00
#define CMD_ACK                          0x66
#ifdef __cplusplus
#endif
   从机的SPI的驱动跟主机的是一样的,修改一下主从机就行了。
stm32fxx_it.c的关键代码如下:
void SPI1_IRQHandler(void)
#ifdef SPI_SLAVE
if (SPI_I2S_GetITStatus(SPIx, SPI_I2S_IT_RXNE) == SET)
// printf("enter RECEIVE IR \r\n");
RxBuffer[Rx_Idx++] = SPI_I2S_ReceiveData(SPIx);
//   printf("%x\r\n",SPI2_ReadWriteByte(0x55));
// Delay(10);
// SPI_I2S_ITConfig(SPIx, SPI_I2S_IT_RXNE, DISABLE);
#endif
   main.c的关键代码如下:
*¹¤³ÌÃû³Æ£ºARM Cortex-M4 GPIO²âÊÔ
*×÷    ÕߣºÌìϵÄÈË
*ÈÕ    ÆÚ£º2012Äê3ÔÂ23ÈÕ
#include "main.h"
#include "stdio.h"
#include "MagicBlueSTM32BSP.h"
#include "stm32f4_spi.h"
#include "stm32f4x7_eth_bsp.h"
#include "stm32f4x7_eth.h"
uint8_t TxBuffer[] = "SPI Interrupt Example: Communication between two SPI using Interrupts";
__IO uint32_t TimeOut = 0;
#ifdef SPI_SLAVE
__IO uint8_t RxBuffer[RXBUFFERSIZE];
__IO uint8_t Rx_Idx = 0 ;
#endif
uint8_t Buff[BuffSize] = {  0xAA,0x00,0x00,0xAA,
    0x00,0x00,0x00,0xAA};
uint8_t Buffer[64];
uint16_t *Data=0;
void Delay(__IO uint32_t nCount);
void SPI1Init(void);
#ifdef SPI_SLAVE
static void Fill_Buffer(__IO uint8_t *pBuffer,uint16_t BufferLength);
#endif
int main()
// uint8_t i=0;
ETH_BSP_Config();
ETH_WritePHYRegister(0x01,0x00,(0x0001<<11));
SPI1Init();
SysTickConfig();
#ifdef SPI_SLAVE
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
SPI_I2S_ITConfig(SPIx,SPI_I2S_IT_RXNE,ENABLE);
UART1_Init(115200);
UART6_Init(115200);
// SPI1_DMA_Congiguration();
KeyInit();
printf("init success!\n");
LED_Init();
LED_ON(1);
LED_OFF(2);
LED_ON(3);
    Rx_Idx = 0;
Fill_Buffer(RxBuffer,TXBUFFERSIZE);
while(1)
// DMA_DeInit(SPIx_DMA_STREAM);
// DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)Buff;
// DMA_InitStructure.DMA_BufferSize = BuffSize;
// DMA_Init(SPIx_DMA_STREAM, &DMA_InitStructure);
// SPI_I2S_DMACmd(SPIx,SPI_DMAReq_Rx,ENABLE);
// DMA_Cmd(SPIx_DMA_STREAM,ENABLE);
while(RxBuffer[0] == CMD_NONE){}
TimeOut = 1;
while (TimeOut != 0x00)
//printf("%d",RxBuffer[0]);
// printf("%s\r\n",RxBuffer);
// printf("%d",RxBuffer[1]);
switch(RxBuffer[0])
case CMD_UP:
if(Buffercmp(TxBuffer,&RxBuffer[1],CMD_UP_SIZE) != FAILED)
LED_ON(1);
LED_ON(2);
LED_OFF(3);
printf("CMD_UP recieve!");
Rx_Idx = 0;
break;
case CMD_SEL:
if(Buffercmp(TxBuffer,&RxBuffer[1],CMD_SEL_SIZE)!= FAILED)
LED_OFF(1);
LED_OFF(2);
LED_OFF(3);
printf("CMD_SEL recieve!");
Rx_Idx = 0;
else
printf("CMD_SEL_SIZE== FAILED\r\nARxBuffer[1]=%s\r\nRxBuffer[2]=%s\r\n",&RxBuffer[1],TxBuffer);
break;
default:
printf("\r\n enter default");
Rx_Idx = 0;
break;
#endif
  /* Setup SysTick Timer for 10ms interrupts  */
    /* Capture error */
    while (1);
  * @brief  Fills buffer.
  * @param  pBuffer: pointer on the Buffer to fill
  * @param  BufferLength: size of the buffer to fill
  * @retval None
static void Fill_Buffer(__IO uint8_t *pBuffer, uint16_t BufferLength)
  uint32_t index = 0;
  /* Put in global buffer same values */
  for (index = 0; index < BufferLength; index++ )
    pBuffer[index] = 0x00;
static TestStatus Buffercmp(uint8_t* pBuffer1, __IO uint8_t* pBuffer2, uint16_t BufferLength)
  while (BufferLength--)
    if (*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
  * @brief  Reports the name of the source file and the source line number
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
//------------------- The end ---------------------------------
    mian.h
//#include "stm32f4xx.h"
//#include "stm32f4xx_conf.h"
//#include
////#include"core_cm4.h";
//#include "STM32F4_UART.h"
//#include "SysTick.h"
//#include "MagicBlueSTM32BSP.h"
#ifndef __MAIN_H
#define __MAIN_H
#ifdef __cplusplus
 extern "C" {
#endif
#include
//#include "stm324xg_eval.h"
//#include "stm324xg_eval_ioe.h"
#define SPI_SLAVE
void SPI1_IRQHandler(void);
#define CMD_UP                           0x33
#ifdef __cplusplus
#endif
工作的原理大致就是,配置完SPI后就打开SPI中断,首先判断是不是命令,否则判断字节长度是不是小于设定的字节数,然后SPI就发送一个字节,直至达到要发送的字节数,关闭发送中断。接收会触发一个接收中断,然后把接收到数据和TxBuffer进行比较,如果成功就亮起灯或者熄灭灯。注意:接收到的第一个字节是命令。从第二个字节后开始比较。
整个流程就是这样。谢谢您的注意。
AEC Design公司的发展小趣事
随着公司规模的扩大和市场地位的提升,AEC Design公司开始注重品牌建设。通过精心策划的品牌推广活动、优质的客户服务以及完善的售后服务体系,公司的品牌形象逐渐深入人心。消费者对公司的信任度和忠诚度不断提高,为公司的长期发展奠定了坚实基础。
Dawn Electronics Inc公司的发展小趣事
在技术创新的基础上,Dawn Electronics Inc公司开始积极拓展市场。公司加强了与国内外客户的合作,通过提供优质的产品和服务,赢得了客户的信任和支持。同时,公司还注重品牌建设,积极参与行业展会和交流活动,提高了品牌知名度和影响力。这些努力为公司赢得了更多的市场份额和合作机会。
永丰盈(CST)公司的发展小趣事
深圳市永丰盈电子有限公司(CST)成立于2003年,初始阶段,公司只有几名员工和几台设备,专注于电子接插件产品的生产与销售。在创始人坚定的信念和团队不懈的努力下,CST逐步在市场上崭露头角。公司秉持“诚信、踏实、齐心、努力”的经营理念,通过严格的质量控制和持续的技术创新,赢得了客户的信任。
Global Communications公司的发展小趣事
温度传感器和晶体振荡器都可能受到外界噪声的干扰,影响测量和补偿的准确性。因此,在电路设计中需要采取屏蔽、滤波等措施来降低噪声干扰。
Bomar公司的发展小趣事
90年代初,电子行业的竞争日益激烈,Bomar公司为了保持市场领先地位,开始寻求与全球优秀制造商的合作。在这一背景下,公司与一些精选的亚洲工厂建立了密切的合作关系。这些工厂按照Bomar公司的规格和标准进行生产,确保了产品质量的稳定性和一致性。通过与亚洲工厂的合作,Bomar公司成功降低了生产成本,提高了生产效率,进一步巩固了其在全球市场的地位。
国盛科技(BOCHEN)公司的发展小趣事
国盛科技(BOCHEN)的前身是成都国正电子有限责任公司,由周正军先生于1999年创立,初期便致力于电子元器件的制造。面对当时行业内的技术壁垒和专利限制,国盛科技坚持以创新驱动,不断加大研发投入,逐渐在电子元器件领域站稳脚跟。这一时期,公司通过引进和培养核心技术人员,逐步建立起一支具备国内一流研发水平的团队,为后续的快速发展奠定了坚实基础。
干尸鼠标[胆小勿用]
相信大家见过很多种BT的鼠标了,不过像这种恐怖的干尸鼠标确实很少见的。大家不要担心,这个不是真的用尸骨做的,只是一种打造出来的效果而已。…
s3c2440为什么要用两片sdram?
最近想学习ARM的设计,发现大多数开发板都采用了两片sdram。我不明白为什么不用1片大容量的sdram替换呢?…
怎么在isr 中 打印调试消息, 加DEBUGMSG 怎么link失败
我想在ISR中打印调试信息,加了DEBUGMSG怎么Link失败 error LNK2019: unresolved external symbol _NKDbgPrintfW referenced in function _ISRHandler 这是我的Source文件,高手看看缺啥啊,我和系统带的串口中断 ISR16550 DLL的Source文件对比过 ...…
请GPS方面的高手来
说是GPS方面的问题但又不全是,我这里从一个仪表里读到的数据是0183格式发送出来的TTL电平,是测水深和流速等的仪表,经过232转换为232格式数据,在计算机上用软件监测COM端口,但不知道它的波特率等协议格式,读到的数据显示出来的都是乱码,也不知道是不 ...…
FPGA中遇到的一个小问题
最近在编一个数字解调器,要用到数字低通滤波器,我找了一个核,但是在使用MegaWizard plug进行设置之后,元件的图形发生了变化,就是16个输入在图形上只显示了4个,中间的12个都用省略号代替了。不知道有没有人遇到过类似的情况没啊?我Google找过 ...…
STM32的CAN通信时,RX方没有接收到数据,TX端却显示数据发送
在调试CAN通信,发现出现一个问题,详细描述如下为了调试方便,我把CAN总线上的节点简化到只有2个节点,一个收一个发。(1)当接收端滤波器设置为全接收,则可以接收到发送端数据,发送端显示发送成功。(2)当接收端滤波器设置了过滤条件,则 ...…
求助:16进制转换为10进制汇编程序
哪位大虾有16进制转换为10进制430汇编程序,可否提供一下,在下不甚感激。…
降低低功耗蓝牙的功耗
Bluetooth SIG的蓝牙核心规格版本 4.0 不仅仅是用来随便看看的的,它是共六册总计2302页的详细的资料文件。这项规格于2010年被采用,它描述了silicon vendor 如何设计才能使蓝牙 v4.0芯片与其他厂家的芯片相连接。这是蓝牙无线技术的关键点:它已成 ...…
C2000 LaunchPad的SCI串口简单通信
#include #include Uint16 sendchar; Uint16 recechar; void sci_init() {    EALLOW;    GpioCtrlRegs.GPAMUX2.bit.GPIO28=1;    GpioCtrlRegs.GPAMUX2.bit.GPIO29=1;//设置GPIO28/29为通信端口    EDIS; ...…
请问TO-can package是什么封装方式,中文是什么?谢谢!!
TO-can package是什么封装方式,翻译成中文是什么?…
