今天是:2025年01月14日(星期二)
2019年01月14日 | stm32 通过串口进行信息交流 并控制led亮灭
2019-01-14 来源:eefocus
h 关闭黄色
l 关闭蓝色
g 关闭绿色
a 打开全部
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_USART1_UART_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1) //ËÀÑ»· ²é¿´Ö´ÐÐЧ¹û
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
uint8_t ch[10]="";
HAL_UART_Receive(&huart1, ch, 10, 200);
if(ch[0] == 'l')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_1, GPIO_PIN_SET);
HAL_UART_Transmit(&huart1, " blue off ", 10, 200);
HAL_Delay(500);
else if(ch[0]=='g')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_SET);
HAL_UART_Transmit(&huart1, " grean off ", 10, 200);
HAL_Delay(500);
else if(ch[0]=='h')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_2, GPIO_PIN_SET);
HAL_UART_Transmit(&huart1, " yellow off ", 10, 200);
HAL_Delay(500);
else if(ch[0]=='a')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_RESET);
HAL_UART_Transmit(&huart1, " all led on ", 10, 200);
HAL_Delay(500);
/* USER CODE END 3 */
简单开关控制
#include "main.h"
#include "stm32f0xx_hal.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval None
int main(void)
HAL_Init();
MX_GPIO_Init();
/* Infinite loop */
while (1)
uint8_t data = 0;
HAL_UART_Receive(&huart1, &data, 1, 0);
if(data == 'l')
HAL_UART_Transmit(&huart1, &data, 1, 0);
else if(data == 'h')
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_SET);
遇到大麻烦了,PB6.0在编译wince系统的时候 在NETCFV2_MODULES= dotnetv2处失败了。 一下子就没了头绪,网上只有问的却没有解答的。google了快一天了,没有答案。 编译日志如下 配置sysgen参数 User selected the following SYSGEN variables sysgen_as_base=1 sysgen_as_file=1 sysgen_audio=1 sysgen_auth=1 ............. ...… 查看全部问答> |
在文件过滤驱动中,如何禁止系统创建新的系统服务? 原来是想将注册表HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services设为只读, 但是发现系统有时会自己修改这个位置,比如说插入一个U盘, 设为只读会导致蓝屏。 所以问问大家,如何 ...… 查看全部问答> |
中国有多少工作很多年的电子工程师;中国每年有多少电子新手需要开始全新的技术生涯;他们有什么困惑需要去解开;他们最关心的问题是什么?他们对未来的期待是什么? 中国缺少什么样的电子工程师?中国缺少满嘴胡须的电子工程师;中国缺少坐轮椅 ...… 查看全部问答> |
IIC通信为什么第一次成功,关掉重新上电又不成功,一直是F5 我的程序是先把0到ff逐个存入EEPROM,然后再逐个读出,并用串行通信逐个传入电脑中,并用串口助手观察。 可是第一次成功,然后我把板子的开关关掉又重新上电,结果却又一直是F5. 所以希望谁能给我指点指点,或者给我一个成功的24c02n的EEPROM的IIC ...… 查看全部问答> |
因公司业务发展,急需招聘兼职人员,要求: 1、具有DSP/FPGA/ARM/CPLD方面的研发经验,熟悉数字电路、模拟电路设计; 2、熟悉嵌入式系统设计,熟练掌握C语言; 3、有4层以上PCB板设计经验,熟悉PCB板的设计规范; 4、对电磁兼容设计有了解; 5 ...… 查看全部问答> |
