今天是:2025年01月16日(星期四)
2019年01月16日 | STM32 SPI SLAVE
2019-01-16 来源:eefocus
一般使用SPI都用MASTER,但是用SLAVE没有用过.参考了ST的例子,发现不能满足自己的使用.于是,自己修改了一下.
初始化配置SPI
* @file app.c
* @author MCD Application Team
* @version V1.1.0
* @date 19-March-2012
* @brief This file provides all the Application firmware functions.
* @attention
© COPYRIGHT 2012 STMicroelectronics
* Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* http://www.st.com/software_license_agreement_liberty_v2
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Includes ------------------------------------------------------------------*/
#include "usbd_cdc_core.h"
#include "usbd_usr.h"
#include "usb_conf.h"
#include "usbd_desc.h"
#define RECV_SIZE (1024 * 16)
u8 g_cbRecvBuffer[RECV_SIZE] = {0};
SPI_InitTypeDef SPI_InitStructure;
RECV_STRUCT g_sRecvInfo = {0};
* @brief Configures the SPI Peripheral.
* @param None
* @retval None
static void SPI_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
/* Peripheral Clock Enable -------------------------------------------------*/
/* Enable the SPI clock */
SPIx_CLK_INIT(SPIx_CLK, ENABLE);
/* Enable GPIO clocks */
RCC_AHB1PeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK, ENABLE);
/* SPI GPIO Configuration --------------------------------------------------*/
/* GPIO Deinitialisation */
GPIO_DeInit(SPIx_SCK_GPIO_PORT);
GPIO_DeInit(SPIx_MISO_GPIO_PORT);
GPIO_DeInit(SPIx_MOSI_GPIO_PORT);
/* Connect SPI pins to AF5 */
GPIO_PinAFConfig(SPIx_SCK_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
GPIO_PinAFConfig(SPIx_MISO_GPIO_PORT, SPIx_MISO_SOURCE, SPIx_MISO_AF);
GPIO_PinAFConfig(SPIx_MOSI_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
GPIO_PinAFConfig(SPIx_NSS_GPIO_PORT, SPIx_NSS_SOURCE, SPIx_NSS_AF);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
/* SPI SCK pin configuration */
GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN;
GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
/* SPI MISO pin configuration */
GPIO_InitStructure.GPIO_Pin = SPIx_MISO_PIN;
GPIO_Init(SPIx_MISO_GPIO_PORT, &GPIO_InitStructure);
/* SPI MOSI pin configuration */
GPIO_InitStructure.GPIO_Pin = SPIx_MOSI_PIN;
GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
/* SPI NSS pin configuration */
GPIO_InitStructure.GPIO_Pin = SPIx_NSS_PIN;
GPIO_Init(SPIx_NSS_GPIO_PORT, &GPIO_InitStructure);
/* SPI configuration -------------------------------------------------------*/
SPI_I2S_DeInit(SPIx);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 0;
/* Configure the Priority Group to 1 bit */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* Configure the SPI interrupt priority */
NVIC_InitStructure.NVIC_IRQChannel = SPIx_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
* @brief Program entry point
* @param None
* @retval None
int main(void)
g_sRecvInfo.lpBuffer = g_cbRecvBuffer;
g_sRecvInfo.uWritePos = 0;
g_sRecvInfo.uReadPos = 0;
g_sRecvInfo.uSize = RECV_SIZE;
/* SPI configuration */
SPI_Config();
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
SPI_Init(SPIx, &SPI_InitStructure);
/* Enable the Rx buffer not empty interrupt */
SPI_I2S_ITConfig(SPIx, SPI_I2S_IT_RXNE, ENABLE);
/* Enable the Tx empty interrupt */
SPI_I2S_ITConfig(SPIx, SPI_I2S_IT_TXE, ENABLE);
/* Enable the SPI peripheral */
SPI_Cmd(SPIx, ENABLE);
/* Main loop */
while (1)
#ifdef USE_FULL_ASSERT
* @brief assert_failed
* Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param File: pointer to the source file name
* @param Line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
中断处理
* @brief This function handles SPI interrupt request.
* @param None
* @retval None
void SPIx_IRQHANDLER(void)
/* SPI in Receiver mode */
if (SPI_I2S_GetITStatus(SPIx, SPI_I2S_IT_RXNE) == SET)
SPI_I2S_ReceiveData(SPIx);
/* SPI in Transmitter mode */
if (SPI_I2S_GetITStatus(SPIx, SPI_I2S_IT_TXE) == SET)
if(g_sRecvInfo.uReadPos != g_sRecvInfo.uWritePos || g_sRecvInfo.bIsWriteNewCycle)
SPI_I2S_SendData(SPIx, *(g_sRecvInfo.lpBuffer + g_sRecvInfo.uReadPos));
if(++g_sRecvInfo.uReadPos == g_sRecvInfo.uSize)
g_sRecvInfo.bIsWriteNewCycle = 0;
else
/* Send Transaction data */
SPI_I2S_SendData(SPIx, 0xFF);
结构定义及对应IO定义
#include
#include "stm32f4xx_spi.h"
typedef struct _Recv_cb
u8 *lpBuffer;
u32 uWritePos;
u32 uReadPos;
u32 uSize;
u8 bIsWriteNewCycle;
}RECV_STRUCT;
#define BUFFERSIZE 100
#define SPIx SPI2
#define SPIx_CLK RCC_APB1Periph_SPI2
#define SPIx_CLK_INIT RCC_APB1PeriphClockCmd
#define SPIx_IRQn SPI2_IRQn
#define SPIx_IRQHANDLER SPI2_IRQHandler
#define SPIx_NSS_PIN GPIO_Pin_12
#define SPIx_NSS_GPIO_PORT GPIOB
#define SPIx_NSS_GPIO_CLK RCC_AHB1Periph_GPIOB
#define SPIx_NSS_SOURCE GPIO_PinSource12
#define SPIx_NSS_AF GPIO_AF_SPI2
#define SPIx_SCK_PIN GPIO_Pin_13
#define SPIx_SCK_GPIO_PORT GPIOB
#define SPIx_SCK_GPIO_CLK RCC_AHB1Periph_GPIOB
#define SPIx_SCK_SOURCE GPIO_PinSource13
#define SPIx_SCK_AF GPIO_AF_SPI2
#define SPIx_MISO_PIN GPIO_Pin_14
#define SPIx_MISO_GPIO_PORT GPIOB
#define SPIx_MISO_GPIO_CLK RCC_AHB1Periph_GPIOB
#define SPIx_MISO_SOURCE GPIO_PinSource14
#define SPIx_MISO_AF GPIO_AF_SPI2
#define SPIx_MOSI_PIN GPIO_Pin_15
#define SPIx_MOSI_GPIO_PORT GPIOB
#define SPIx_MOSI_GPIO_CLK RCC_AHB1Periph_GPIOB
#define SPIx_MOSI_SOURCE GPIO_PinSource15
#define SPIx_MOSI_AF GPIO_AF_SPI2
注意:另外MASTER设备需要,先发送一个字节的时钟,然后再读取N个字节的时钟.
下一篇:LPC1788启动代码分析
随着人们生活水平的提高和对通讯工具的需要,大部分人都选择用手机做自己最常用的沟通工具,工具多了自然问题也就多了,下面给大家介绍几种使用手机的过程中经常遇到的问题及解决办法。 1.如果手机万一被水淋湿,我们该采取何种保护措施? 在日常 ...… 查看全部问答> |
makefile中首先用ccarm -c将一堆.cc文件编译出了一堆.o中间文件 然后又调用ararm将它们做成了一个.a文件 问题是,如何将这个.a文件转换成可以下载到板子上的.o文件呢?… 查看全部问答> |
这两天看了一些关于SCSI Miniport Driver方面的代码和资料,但是还是有一些不明白的地方, 比如当我写了一个Miniport Driver的时候,那Port Driver是如果来知道这个驱动的存在的吗? 另一个我在看破别人的程序的时候看不出Miniport Driver与特定的设 ...… 查看全部问答> |
请问大家嵌入式开发和智能技术的关系?我对人工智能技术很感兴趣,目前是做web方面的程序开发,虽然只要做得好,哪里都可以拿高薪,但我更爱好智能技术,因此想转去做嵌入式开发,觉得那样似乎离智能更近一些。本人爱好研究算法和各种智能技术,觉 ...… 查看全部问答> |
要为三星的44BoX的板子的usb和串口写不加载os时类似驱动的程序,(相当于提供一些底层硬件的接口)请问应该看哪方面的资料,以前驱动也没写过,能给一个大致的框架。底层的我只懂一点arm汇编,不知道够不够?好像大部分程序用C,嵌一点汇编就可以了 ...… 查看全部问答> |
Using the infinite-gain, MFB filter topology in fully differential 本帖最后由 dontium 于 2015-1-23 13:38 编辑 Using the infinite-gain, MFB filter topology in fully differential active filters … 查看全部问答> |
ADI DSP BF518开发板交换一块TI原装9B96开发板,开包的也行。 ADI DSP BF518开发板交换一块TI原装9B96开发板,开包的也行。 有意的请联系qq:307799870 板子上带有usb烧写接口。没有仿真器忙调即可。… 查看全部问答> |
