今天是:2025年01月29日(星期三)
2019年01月29日 | STM32 UART串口驱动程序
2019-01-29 来源:eefocus
示例1.通过UART1进行数据发送
UART 1 的初始化
* @brief UART1 Initialise.
* @param None.
* @retval None.
void UART1_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //UART1 选择对应UART的RCC时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //选择串口对应引脚的RCC时钟
//UART1_TX GPIOA_Pin_9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //GPIOC_Pin_9
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //
GPIO_Init(GPIOA, &GPIO_InitStructure); //
//UART1_RX GPIOA_Pin_10
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //GPIOA_Pin_10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//UART1通讯参数配置
USART_InitStructure.USART_BaudRate = 115200; //通讯波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //8个数据位
USART_InitStructure.USART_StopBits = USART_StopBits_1; //1个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; //
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
将数据0xBA通过UART1发送出
USART_SendData(USART1,0xBA); //Send Data 0xBA
示例2.通过对UART1进行接收中断配置,收到外部数据后进入中断读取数据
UART 1 的初始化 开启接收中断
@param None.
@retval None.
@brief Data transfer PC
NVIC_InitTypeDef NVIC_InitStructure;
//UART1通讯参数配置
//Uart1 NVIC 中断配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //数据接收中断使能
NVIC_Init(&NVIC_InitStructure);
中断入口函数,变量rxdat用于存放接收到的1个字节数据
void USART1_IRQHandler(void)
unsigned char rxdat ;
if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
USART_ClearITPendingBit(USART1, USART_IT_RXNE); //Clear flag
rxdat = USART_ReceiveData(USART1);
想学linux嵌入式开发,请各位前辈给出中肯的建议,谢谢各位 我想学嵌入式linux开发,有c和汇编基础,大学没能顺利毕业, 现在的想法是抱一个培训班,不知道培训的效果会不会比自学好很多, 没有大学学历,找工作会不会希望特别渺茫, 上海尚观培训怎么样呢 ? 然后请过来人推荐一个 ...… 查看全部问答> |
我写了个今日插件,用CWnd::Create创建的窗体,回调函数用AfxWndProc 在wm5下好用,换到wm6下有问题,有些机器上Create失败,有些机器上虽然成功了 窗体被覆盖后收不到WM_PAINT消息,谁遇到过类似问题吗;后来也改用APIC创建窗体, 但是还要在上 ...… 查看全部问答> |
两个程序相互切的时候怎么会有白屏? 程序1: 我是用 CreateWindowEx(WS_EX_TOPMOST, szWindowClass, szTitle, WS_POPUP | WS_WYWMENU, &nb ...… 查看全部问答> |
我现在遇到两首mp3,在pc上看到属性为mp3, 立体声,16bit,44.1k 我在系统中加了mp3 cedec,MPEG-1 Layer 1 and 2 Audio Codec,但就是播放不了。 从驱动的private_WaveOpen中发现lpFormat->wFormatTag=80,正常应该是1即WAVE_FORMAT_PCM,只支持PC ...… 查看全部问答> |
我最近在学习将UC0S移植到S3C2410上,是ARM9,在网上下的别人的移植的代码,自己稍加修改,可以跑多个任务,我想,既然是操作系统移植到ARM板上,就可以管理外部硬件资源了,之前我在裸板上有个按键控制LED亮灭的程序,我想添加个任务,用UCOS来管 ...… 查看全部问答> |
