今天是:2025年02月19日(星期三)
正在发生
2019年02月19日 | 51单片机PS2键盘解码实验--C51源代码
2019-02-19 来源:eefocus
#include
#include "KBCODE.H"
#define LCM_RS    P2_0
#define LCM_RW    P2_1 //定义LCD引脚
#define LCM_E     P2_2
#define LCM_Data  P0
#define Busy 0x80 //用于检测LCM状态字中的Busy标识
#define Key_Data  P3_2 //定义Keyboard引脚
#define Key_CLK   P3_3
void LCMInit(void);
void DisplayOneChar(unsigned char X,unsigned char Y,unsigned char DData);
void DisplayListChar(unsigned char X,unsigned char Y,unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadStatusLCM(void);
unsigned char code cdle_net[] = {"RICHMCU PS2 TEST"};
unsigned char code email[] = {"WWW.RICHMCU.COM"};
unsigned char code Cls[] =   {"                "};
static unsigned char IntNum = 0; //中断次数计数
static unsigned char KeyV; //键值
static unsigned char DisNum = 0; //显示用指针
static unsigned char Key_UP=0, Shift = 0;//Key_UP是键松开标识,Shift是Shift键按下标识
static unsigned char BF = 0; //标识是否有字符被收到
void main(void)
    unsigned char TempCyc;
    Delay400Ms(); //启动等待,等LCM讲入工作状态
    LCMInit(); //LCM初始化
    DisplayListChar(0, 0, cdle_net);
    DisplayListChar(0, 1, email);
    for(TempCyc=0; TempCyc<10; TempCyc++) {
        Delay400Ms(); //延时
    DisplayListChar(0, 1, Cls);
    IT1 = 0; //设外部中断1为低电平触发
    EX1 = 1; //开中断
    EA = 1;
    while(1) {
        if(BF)
            Decode(KeyV);
        else {
            EA = 1; //开中断
//写数据
    ReadStatusLCM(); //检测忙
    LCM_Data = WDLCM;
    LCM_RS = 1;
    LCM_RW = 0;
    LCM_E = 0; //若晶振速度太高可以在这后加小的延时
    LCM_E = 0; //延时
    LCM_E = 1;
//写指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
    if(BuysC)
        ReadStatusLCM(); //根据需要检测忙
    LCM_Data = WCLCM;
    LCM_RS = 0;
    LCM_RW = 0;
    LCM_E = 0;
    LCM_E = 0;
    LCM_E = 1;
//读状态
    LCM_Data = 0xFF;
    LCM_RS = 0;
    LCM_RW = 1;
    LCM_E = 0;
    LCM_E = 1;
    while(LCM_Data & Busy); //检测忙信号
    return(LCM_Data);
void LCMInit(void) //LCM初始化
    LCM_Data = 0;
    WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
    Delay5Ms();
    Delay5Ms();
    Delay5Ms();
    Delay5Ms();
    Delay5Ms();
    Delay5Ms();
    WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
    WriteCommandLCM(0x08,1); //关闭显示
    WriteCommandLCM(0x01,1); //显示清屏
    WriteCommandLCM(0x06,1); // 显示光标移动设置
    WriteCommandLCM(0x0F,1); // 显示开及光标设置
//按指定位置显示一个字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
    Y &= 0x1;
    X &= 0xF; //限制X不能大于15,Y不能大于1
    if(Y)
        X |= 0x40; //当要显示第二行时地址码+0x40;
    X |= 0x80; //算出指令码
    WriteCommandLCM(X, 1); //发命令字
    WriteDataLCM(DData); //发数据
//按指定位置显示一串字符
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
    unsigned char ListLength;
    ListLength = 0;
    Y &= 0x1;
    while (DData[ListLength]>0x19) {//若到达字串尾则退出
        if(X <= 0xF) {//X坐标应小于0xF
            DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
            ListLength++;
            X++;
//5ms延时
void Delay5Ms(void)
    unsigned int TempCyc = 5552;
    while(TempCyc--);
//400ms延时
    unsigned char TempCycA = 5;
    unsigned int TempCycB;
    while(TempCycA--) {
        TempCycB=7269;
        while(TempCycB--);
void Keyboard_out(void) interrupt 2
    if[[IntNum > 0) && (IntNum < 9]] {
        KeyV >>= 1;//因键盘数据是低>>高,结合上一句所以右移一位
        if(Key_Data) {
            KeyV |= 0x80;//当键盘数据线为1时为1到最高位
    IntNum++;
    while(!Key_CLK);//等待PS/2CLK拉高
    if(IntNum > 10) {
        IntNum = 0;//当中断10次后表示一帧数据收完,清变量准备下一次接收
        BF = 1;//标识有字符输入完了
        EA = 0;//关中断等显示完后再开中断
//注意:如SHIFT+G为12H 34H F0H 34H F0H 12H,也就是说shift的通码+G的通码+shift的断码+G的断码
    if(!Key_UP) {//当键盘松开时
        switch(ScanCode) {
            case 0xF0 ://当收到0xF0,Key_UP置1表示断码开始
                Key_UP = 1;
                break;
            case 0x12:// 左 SHIFT
                Shift = 1;
                break;
            case 0x59:// 右 SHIFT
                Shift = 1;
                break;
            default:
                if(DisNum > 15) {
                    DisplayListChar(0,1,Cls);//清LCD第二行
                    DisNum = 0;
            if(Shift == 1) {//如果按下SHIFT
                for(TempCyc = 0;(Shifted[TempCyc][0]!=ScanCode)&&(TempCyc<59); TempCyc++); //查表显示
                if(Shifted[TempCyc][0] == ScanCode)
                    DisplayOneChar(DisNum,1,Shifted[TempCyc][1]);
                DisNum++;
            else {//没有按下SHIFT
                for(TempCyc = 0; (UnShifted[TempCyc][0]!=ScanCode)&&(TempCyc<59);TempCyc++); //查表显示
                if(UnShifted[TempCyc][0] == ScanCode) {
                    DisplayOneChar(DisNum,1,UnShifted[TempCyc][1]);
                DisNum++;
            break;
    else {
        Key_UP = 0;
        switch(ScanCode) {//当键松开时不处理判码,如G 34H F0H 34H 那么第二个34H不会被处理
                Shift = 0;
                break;
                Shift = 0;
                break;
            default:
                break;
    BF = 0;//标识字符处理完了
unsigned char code UnShifted[61][2] = {
    0x1C, 'a',
    0x32, 'b',
    0x21, 'c',
    0x23, 'd',
    0x24, 'e',
    0x2B, 'f',
    0x34, 'g',
    0x33, 'h',
    0x43, 'i',
    0x3B, 'j',
    0x42, 'k',
    0x4B, 'l',
    0x3A, 'm',
    0x31, 'n',
    0x44, 'o',
    0x4D, 'p',
    0x15, 'q',
    0x2D, 'r',
    0x1B, 's',
    0x2C, 't',
    0x3C, 'u',
    0x2A, 'v',
    0x1D, 'w',
    0x22, 'x',
    0x35, 'y',
    0x1A, 'z',
    0x45, '0',
    0x16, '1',
    0x1E, '2',
    0x26, '3',
    0x25, '4',
    0x2E, '5',
    0x36, '6',
    0x3D, '7',
    0x3E, '8',
    0x46, '9',
    0x0E, '`',
    0x4E, '-',
    0x55, '=',
    0x5D, '\\',
    0x29, ' ',
    0x54, '[',
    0x5B, ']',
    0x4C, ';',
    0x52, '\'
FOTEK公司的发展小趣事
随着业务的不断拓展,福禄克意识到全球化布局的重要性。1970年代,公司在英国设立了首个海外生产基地,随后又在荷兰和中国等地建立工厂。这一系列举措不仅降低了生产成本,还使福禄克能够更贴近全球市场需求,提供更加快速和灵活的服务。同时,福禄克在全球范围内建立了广泛的销售和服务网络,进一步巩固了其市场地位。
Amphenol(安费诺)公司的发展小趣事
Anaren Ceramics公司的发展小趣事
Anaren Ceramics公司在电子行业中崭露头角,首先得益于其在陶瓷材料技术方面的重大突破。公司研发了一种新型的陶瓷材料,具有优异的绝缘性能和高温稳定性,这为当时的电子行业提供了前所未有的解决方案。随着这种新型陶瓷材料在市场上的广泛应用,Anaren Ceramics公司的知名度逐渐提升,逐渐成为了行业内的佼佼者。
Antex公司的发展小趣事
到了1965年,Antex公司迎来了一次重要的技术突破。公司成功研发出“环形件轧机”,这一创新技术不仅提高了生产效率,还大幅提升了产品的精度和稳定性。这一技术的成功应用,使得Antex的业务范围得到了进一步扩大,公司在电子行业中的地位也愈发稳固。
Anderson Power Products公司的发展小趣事
面对日新月异的电子行业发展趋势,Antex公司始终保持敏锐的市场洞察力和创新精神。公司积极推进技术开发、设备强化,不断探索新的生产技术和应用领域。同时,Antex还注重人才培养和团队建设,为公司的未来发展储备了丰富的人才资源。
这些故事只是Antex公司发展历程中的一部分,它们展示了公司在电子行业中的不断努力和追求卓越的精神。未来,随着技术的不断进步和市场的不断变化,Antex将继续保持创新和发展,为电子行业的繁荣做出更大的贡献。
请注意,以上内容仅为概述,并未详细展开每个故事的每一个细节。如果需要更具体、更详细的故事,建议查阅Antex公司的官方资料或相关新闻报道,以获取更准确、更全面的信息。
Elcos AG公司的发展小趣事
随着全球对环保和可持续发展的重视,Elcos AG也开始注重自身的环保责任和可持续发展战略。公司采用环保材料和生产工艺,减少了对环境的污染和资源的浪费。同时,Elcos AG还积极参与社会公益事业和环保活动,通过捐款、赞助和志愿服务等方式回馈社会。这些举措不仅提升了公司的社会形象和品牌价值,也为公司的长期发展奠定了坚实的基础。
ARM2210的智能移动机器人人机界面设计
摘要: 移动机器人人机界面为移动机器人的运动控制提供直观的路径图形、运动速度和角度、障碍物信息等。通过ARM2210的串口UART0接收中心处理器PC104的运动信息,利用东芝公司的液晶控制器T6963C驱动STN液晶屏YL240128A,以及ZLG/GUI软件包提供的基 ...…
SJA1000的中英文对照应用指南
中英文对照SJA1000的应用指南,经常用到CAN的朋友可以看下,希望有帮助…
坛友们是否都还在祭祖氛围中,还没找回上班的状态
上班都半天多了,坛友还没来坛的报道,看来你们还处在祭先人的氛围中。或悲伤或萧杀…
EMC测试和其他测试项目
EMC 测试       随着电子产品越来越多地采用低功耗、高速度、高集成度的 LSI 电路,使得这些系统比以往任何时候更容易受到电磁干扰的威胁。而与此同时,大功率设备及移动通讯和无线寻呼的广泛应用等,又大大增加了电磁骚扰的 ...…
LPC2114 I/O配置问题
我现在在做一个东西,大概的框架是这样的,首先将模拟信号通过两路AD转换之后,通过一定的算法输出,由于LPC2114没有DA转换,所以这里我使用了LPC2114里面的PWM,通过PWMDAC代替DA转换输出模拟值控制执行器。现在目前的问题是,我采用了四个PWM输出 ...…
CDMA 1X连接的域名解析
GSM模块(华为的900c)有个AT指令,AT%DNSR可以把域名解析成IP地址。但是在CDMA(EM200)模块上面,却没有找到相类似的命令。CDMA是否有支持域名解析的命令呢?或者是要自己构建数据包发送到域名服务器解析?…
单片机放电问题
做产品的时候发现一个问题,关电源后短时间内重启,发现有残留电荷影响,有什么方法可以放电??…
MC55发送AT指令没有回应,请高手指点
我用的是西门子MC55模块,用笔记本,通过USB转RS232连接到模块上,MC55的外围电路是我自己搭的。开机后,VDD显示是2.88V,CCVCC上电正常,开机不久后,接SYNC的发光二极管会闪几秒钟,之后就不闪了。 问题是,用串口调试程序发送AT指令,都任何没 ...…
应用程序不能实现触摸屏右键功能?急
触摸屏右键功能和鼠标右键有什么区别么?我在桌面上或者在wince浏览器中电击触摸屏都可以弹出右键功能的,我自己的应用程序在点击鼠标右键也能弹出菜单. 但是使用触摸屏就不能弹出右键菜单.   并且在wince下自带的图片浏览器中也一样 ...…
基于MAX4472的血压传感电路及滤波和放大电路
如下图所示,本电路采用BP01型压力传感器和运放MAX4472。BP01型压力传感器是为检测血压而专门设计的,主要用于便携式电子血压计。它采用精密厚膜陶瓷芯片和尼龙塑料封装,具有高线性、低噪声和外界应力小的特点;采用内部标定和温度补偿方式,提高 ...…
