今天是:2025年03月08日(星期六)
2019年03月08日 | STM32之I2C例程(24C02)
2019-03-08 来源:eefocus
#include "stm32f10x.h"
#include
#define SCL_H (GPIOB->BSRR = GPIO_Pin_6)
#define SCL_L (GPIOB->BRR = GPIO_Pin_6)
#define SDA_H (GPIOB->BSRR = GPIO_Pin_7)
#define SDA_L (GPIOB->BRR = GPIO_Pin_7)
#define SCL_READ (GPIOB->IDR & GPIO_Pin_6)
#define SDA_READ (GPIOB->IDR & GPIO_Pin_7)
#define I2C_DELAY (I2C_delay())
/* RCC时钟配置 */
void RCC_config(void)
ErrorStatus HSEStartUpStatus;
/* RCC寄存器设置为默认配置 */
RCC_DeInit();
/* 打开外部高速时钟 */
RCC_HSEConfig(RCC_HSE_ON);
/* 等待外部高速时钟稳定 */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* 设置HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* 设置PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* 设置PCLK1 = HCLK / 2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
// /* 设置FLASH代码延时 */
// FLASH_SetLatency(FLASH_Latency_2);
// /* 使能预取址缓存 */
// FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* 设置PLL时钟源为HSE倍频9 72MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* 使能PLL */
RCC_PLLCmd(ENABLE);
/* 等待PLL稳定 */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
/* 设置PLL为系统时钟源 */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* 等待系统时钟源切换到PLL */
while(RCC_GetSYSCLKSource() != 0x08);
/* GPIO配置 */
void GPIO_config(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* 时钟配置 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
/* SDA、SCL开漏输出 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* 毫秒延时函数 */
void delay_ms(uint16_t time)
uint16_t i = 0;
while(time--)
i = 12000;
while(i--);
/* I2C延时函数 */
void I2C_delay(void)
uint8_t i = 100;
while(i)
i--;
/* I2C开始信号 */
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_DELAY;
if(!SDA_READ)
return false;
SDA_L;
I2C_DELAY;
if(SDA_READ)
return false;
SDA_L;
I2C_DELAY;
return true;
/* I2C停止信号 */
void I2C_Stop(void)
SCL_L;
I2C_DELAY;
SDA_L;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SDA_H;
I2C_DELAY;
/* I2C响应信号 */
void I2C_Ack(void)
SCL_L;
I2C_DELAY;
SDA_L;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SCL_L;
I2C_DELAY;
/* I2C未响应信号 */
void I2C_NoAck(void)
SCL_L;
I2C_DELAY;
SDA_H;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SCL_L;
I2C_DELAY;
/* 等待应答信号 */
bool I2C_WaitAck(void)
SCL_L;
I2C_DELAY;
SDA_H;
I2C_DELAY;
SCL_H;
I2C_DELAY;
if(SDA_READ)
SCL_L;
return false;
SCL_L;
return true;
/* I2C发送一个字节 */
void I2C_SendByte(uint8_t SendByte)
uint8_t i = 8;
while(i--)
SCL_L;
I2C_DELAY;
if(SendByte & 0x80)
SDA_H;
else
SDA_L;
SendByte <<= 1;
I2C_DELAY;
SCL_H;
I2C_DELAY;
SCL_L;
/* I2C接收一个字节 */
uint8_t I2C_ReceiveByte(void)
uint8_t i = 8;
uint8_t ReceiveByte = 0;
SDA_H;
while(i--)
ReceiveByte<<=1;
SCL_L;
I2C_DELAY;
SCL_H;
I2C_DELAY;
if(SDA_READ)
ReceiveByte|=0x01;
SCL_L;
return ReceiveByte;
#define CTRL_CODE 0xA0
/* 写一个字节 */
bool EEPROM_Write_Byte(uint8_t block, uint8_t addr, uint8_t *data)
uint8_t cnt = 10;
/* 确认写周期结束,并写入控制字 */
do
I2C_Start();
I2C_SendByte((CTRL_CODE | (block & 0x0E)) & 0xFE);
}while((I2C_WaitAck() == false) && (--cnt > 0));
if(cnt == 0)
I2C_Stop();
return false;
/* 写入地址 */
I2C_SendByte(addr);
if(I2C_WaitAck() == false)
I2C_Stop();
return false;
/* 写入数据 */
I2C_SendByte(*data);
I2C_Stop();
return false;
I2C_Stop();
return true;
/* 读一个字节 */
bool EEPROM_Read_Byte(uint8_t block, uint8_t addr, uint8_t *data)
uint8_t cnt = 10;
do
I2C_Start();
if(cnt == 0)
I2C_Stop();
return false;
/* 写入地址 */
I2C_SendByte(addr);
I2C_Stop();
return false;
/* 写入控制字 */
I2C_Start();
I2C_SendByte(CTRL_CODE | (block & 0x0E) | 0x01);
I2C_Stop();
return false;
/* 读出数据 */
*data = I2C_ReceiveByte();
I2C_NoAck();
I2C_Stop();
return true;
/* 主函数 */
int main(void)
uint8_t data = 3;
/* RCC时钟配置 */
RCC_config();
/* GPIO配置 */
GPIO_config();
EEPROM_Write_Byte(0, 0, &data);
data = 6;
EEPROM_Read_Byte(0, 0, &data);
while(1)
delay_ms(1000);
上一篇:STM32之BKP原理
下一篇:STM32之I2C原理
电路板算价工器,值得收藏:http://www.sz-jlc.com/home/order_add.jsp 做电路板价比三家,因为电路板的工艺多,询价是一个很麻烦的事,现在不用愁了,只要你收藏这个网址,随时随地都能算价,无论是在哪家下单做板,它可以做一个 ...… 查看全部问答> |
这几天论坛有两个关于232芯片的讨论帖子 232烧坏咋办 https://bbs.eeworld.com.cn/thread-98986-1-1.html 大家说说sp3223与max3223的区别? https://bbs.eeworld.com.cn/thread-98677-1-1.html 看了仙猫等大侠的分析评论,实在是大开眼界,受 ...… 查看全部问答> |
最近发现 keil Debug下可以通过编写ini文件仿真,比如我的项目里就有一个I2C通信的ini文件 代码如下: DEFINE int SADR ...… 查看全部问答> |
系统中使用64MB的NAND,512Byte 小页模式。前20个block保留给EBOOT。MBR在第21个block。后边的28M格式化成BINFS用来保存NK镜像。把之后的剩余空间格式化成PART_EXT(也试过DOS32)用作存储空间。参考了eeworld上的相关讨论之后,已经可以在文件浏览 ...… 查看全部问答> |
求助:Linux下AD驱动,用的是ads7842的片子。帮助做个ADS7842的驱动,并采集一些简单的信号。 如果有人熟悉这方面的,请联系:QQ:35590495.报酬面议!在北京!急!!!… 查看全部问答> |
测试程序通过仿真口load成功,但是同时显示断点错误:Can\'t Set Breakpoint at 0x7638: Error 0x00000008/-1076 Error during: Break Point, Cannot set erify breakpoint at 0x00007638 Sequence ID: 7 Error Code: -1076 ...… 查看全部问答> |
