今天是:2025年03月11日(星期二)
正在发生
2019年03月11日 | STM32F10x usart数据收发
2019-03-11 来源:eefocus
STM32F10x uart的数据发送接收就三种基本方式,轮询、中断和DMA
1. 轮询(polling)方式
以下是轮询的uart初始化以及发送接收的例子,发送和接收都用轮询的方式。
uint8_t TxBuffer[] = "Buffer Send from USARTy to USARTz using Flags";
uint8_t RxBuffer[TxBufferSize];
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  RCC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
/* USARTy and USARTz configuration ------------------------------------------------------*/
  /* USARTy and USARTz configured as follow:
        - BaudRate = 230400 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - Even parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = 230400;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_Even;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  /* Configure USARTy */
  USART_Init(USARTy, &USART_InitStructure);
  /* Configure USARTz */
  USART_Init(USARTz, &USART_InitStructure);
  /* Enable the USARTy */
  USART_Cmd(USARTy, ENABLE);
  /* Enable the USARTz */
  USART_Cmd(USARTz, ENABLE);
  while(TxCounter < TxBufferSize)
    /* Send one byte from USARTy to USARTz */
    USART_SendData(USARTy, TxBuffer[TxCounter++]);
        void USART_SendData(USART_TypeDef* USARTx, uint16_t Data)
          assert_param(IS_USART_ALL_PERIPH(USARTx));
          assert_param(IS_USART_DATA(Data));
          USARTx->DR = (Data & (uint16_t)0x01FF); //往DR写发送的数据
    /* Loop until USARTy DR register is empty */
    while(USART_GetFlagStatus(USARTy, USART_FLAG_TXE) == RESET)
    //到这里表示数据发送完毕(USART_FLAG_TXE可以参考STM32F10x usart寄存器描述)
    /* Loop until the USARTz Receive Data Register is not empty */
    while(USART_GetFlagStatus(USARTz, USART_FLAG_RXNE) == RESET)
    //到这里表示数据接收完毕(USART_FLAG_RXNE可以参考STM32F10x usart寄存器描述)
    /* Store the received byte in RxBuffer */
    RxBuffer[RxCounter++] = (USART_ReceiveData(USARTz) & 0x7F);
  //后面只是看发送接收数据是否一致,这与测试条件有关,不再赘述。
  /* Check the received data with the send ones */
  TransferStatus = Buffercmp(TxBuffer, RxBuffer, TxBufferSize);
  /* TransferStatus = PASSED, if the data transmitted from USARTy and
     received by USARTz are the same */
  /* TransferStatus = FAILED, if the data transmitted from USARTy and
     received by USARTz are different */
  while (1)
2. 中断方式读写
STM32F10x USART有很多类型的中断,每个中断类型都有一个使能标志位。
 这里写图片描述
中断设定以及使用ringbuffer输入输出的流程如下
(1) 中断的初始化
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Configure the NVIC Preemption Priority Bits */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  /* Enable the USARTy Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USARTy_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable USARTy Receive and Transmit interrupts */
  USART_ITConfig(USARTy, USART_IT_RXNE, ENABLE);
  USART_ITConfig(USARTy, USART_IT_TXE, ENABLE);
一般一个USART端口,输入输出都要设置一个中断位来触发输入输出中断,一般的输入输出只需要设置如下两个中断即可。
USART_IT_RXNE:Receive Data register not empty interrupt
USART_IT_TXE: Transmit Data Register empty interrupt
还有其他的中断位解释如下:
USART_IT_CTS: CTS change interrupt
USART_IT_LBD: LIN Break detection interrupt
USART_IT_TC: Transmission complete interrupt
USART_IT_IDLE: Idle line detection interrupt
USART_IT_PE: Parity Error interrupt
USART_IT_ERR: Error interrupt(Frame error, noise error, overrun error)
设置完USART_IT_RXNE和USART_IT_TXE中断之后,读写都会触发中断。
这里我们一般不用USART_IT_TC中断,因为一般来说使用发送数据寄存器空中断(USART_IT_TXE)
发送的效率会高一些。
下面用一个使用ringbuffer,且使用中断方式的例子来熟悉一下中断读写。
(参考http://blog.csdn.net/liyuanbhu/article/details/8886407)
中断处理函数的框架如下,如果检测到错误就清除错误,收到数了就处理。发完当前数据了就发下一个。
void USART1_IRQHandler(void)
    unsigned int data;
    if(USART1->SR & 0x0F)
        // See if we have some kind of error, Clear interrupt
        data = USART1->DR;
    else if(USART1->SR & USART_FLAG_RXNE) //Receive Data Reg Full Flag
        data = USART1->DR;
        // 对收到的数据进行处理,或者干些其他的事
    else if(USART1->SR & USART_FLAG_TXE)
        { // 可以发送数据了,如果没有数据需要发送,就在这里关闭发送中断
            USART1->DR =  something;        // Yes, Send character
下面给一个利用环形缓冲区的串口驱动程序。
#ifndef _COM_BUFFERED_H_
#define _COM_BUFFERED_H_
#define  COM1                   0
#define  COM2                   1
#define  COM_RX_BUF_SIZE        64                /* Number of characters in Rx ring buffer             */
#define  COM_TX_BUF_SIZE        64                /* Number of characters in Tx ring buffer             */
#define  COM_NO_ERR             0                /* Function call was successful                       */
#define  COM_BAD_CH             1                /* Invalid communications port channel                */
#define  COM_RX_EMPTY           2                /* Rx buffer is empty, no character available         */
#define  COM_TX_FULL            3                /* Tx buffer is full, could not deposit character     */
#define  COM_TX_EMPTY           4                /* If the Tx buffer is empty.                         */
 * function : COMGetCharB
 * parameter: char port, port can be COM1 / COM2
 * parameter: char* err   is a pointer to where an error code will be placed:
 *                   *err is set to COM_NO_ERR   if a character is available
 *                   *err is set to COM_RX_EMPTY if the Rx buffer is empty
 *                   *err is set to COM_BAD_CH   if you have specified an invalid channel
 * return   : char
 * usage    : This function is called by your application to obtain a character from the communications
 *               channel.
 * changelog:
unsigned char  COMGetCharB (unsigned char ch, unsigned char *err);
 * function : COMPutCharB
 * return   :    COMM_NO_ERR   if the function was successful (the buffer was not full)
 *               COMM_TX_FULL  if the buffer was full
 *               COMM_BAD_CH   if you have specified an incorrect channel
 * usage    : This function is called by your application to send a character on the communications
 *               channel.  The character to send is first inserted into the Tx buffer and will be sent by
 *               the Tx ISR.  If this is the first character placed into the buffer, the Tx ISR will be
 *               enabled.  If the Tx buffer is full, the character will not be sent (i.e. it will be lost)
 * changelog:
unsigned char COMPutCharB (unsigned char port, unsigned char c);
 * function : COMBufferInit
 * parameter:
 * return   :
 * usage    : This function is called by your application to initialize the communications module.  You
 *             must call this function before calling any other functions.
 * changelog:
void  COMBufferInit (void);
 * function : COMBufferIsEmpty
 * return   : char
 * usage    : This function is called by your application to see
 *            if any character is available from the communications channel.
 *            If at least one character is available, the function returns
 *            FALSE(0) otherwise, the function returns TRUE(1).
 * changelog:
unsigned char  COMBufferIsEmpty (unsigned char port);
 * function : COMBufferIsFull
 * return   : char
 * usage    : This function is called by your application to see if any more characters can be placed
 *             in the Tx buffer.  In other words, this function check to see if the Tx buffer is full.
 *             If the buffer is full, the function returns TRUE otherwise, the function returns FALSE.
 * changelog:
unsigned char COMBufferIsFull (unsigned char port);
#endif
 * file: com_buffered.c
 * author: Li Yuan
 * platform: STM32F107
 * date: 2013-5-5
 * version: 0.0.1
 * description: UART Ring Buffer
#include "stm32f10x_usart.h"
#include "com_buffered.h"
#define OS_ENTER_CRITICAL()     __set_PRIMASK(1)
#define OS_EXIT_CRITICAL()      __set_PRIMASK(0)
 *  Enables Transmiter interrupt.
static void COMEnableTxInt(unsigned char port)
    static USART_TypeDef* map[2] = {USART1, USART2};
    USART_ITConfig(map[port], USART_IT_TXE, ENABLE);
*                                               DATA TYPES
typedef struct {
    short  RingBufRxCtr;                   /* Number of characters in the Rx ring buffer              */
    unsigned char  *RingBufRxInPtr;                 /* Pointer to where next character will be inserted        */
    unsigned char  *RingBufRxOutPtr;                /* Pointer from where next character will be extracted     */
    unsigned char   RingBufRx[COM_RX_BUF_SIZE];     /* Ring buffer character storage (Rx)                      */
    short  RingBufTxCtr;                   /* Number of characters in the Tx ring buffer              */
    unsigned char  *RingBufTxInPtr;                 /* Pointer to where next character will be inserted        */
    unsigned char  *RingBufTxOutPtr;                /* Pointer from where next character will be extracted     */
    unsigned char   RingBufTx[COM_TX_BUF_SIZE];     /* Ring buffer character storage (Tx)                      */
} COM_RING_BUF;
*                                            GLOBAL VARIABLES
COM_RING_BUF  COM1Buf;
COM_RING_BUF  COM2Buf;
 * return   : char
 *               channel.
 * changelog:
unsigned char  COMGetCharB (unsigned char port, unsigned char *err)
//    unsigned char cpu_sr;
    unsigned char c;
    COM_RING_BUF *pbuf;
    switch (port)
    {                                          /* Obtain pointer to communications channel */
        case COM1:
             pbuf = &COM1Buf;
             break;
        case COM2:
             pbuf = &COM2Buf;
             break;
        default:
             *err = COM_BAD_CH;
             return (0);
    OS_ENTER_CRITICAL();
    if (pbuf->RingBufRxCtr > 0)                            /* See if buffer is empty                   */
        pbuf->RingBufRxCtr--;                              /* No, decrement character count            */
        c = *pbuf->RingBufRxOutPtr++;                      /* Get character from buffer                */
        if (pbuf->RingBufRxOutPtr == &pbuf->RingBufRx[COM_RX_BUF_SIZE])
            pbuf->RingBufRxOutPtr = &pbuf->RingBufRx[0];   /* Wrap OUT pointer     */
        OS_EXIT_CRITICAL();
        *err = COM_NO_ERR;
        return (c);
    } else {
        OS_EXIT_CRITICAL();
        *err = COM_RX_EMPTY;
        c    = 0;                                        /* Buffer is empty, return 0              */
        return (c);
 * changelog:
 *            1.first implimented by liyuan 2010.11.5
    COM_RING_BUF *pbuf;
    switch (port)
        case COM1:
             pbuf = &COM1Buf;
             break;
        case COM2:
             pbuf = &COM2Buf;
             break;
        default:
             return (COM_BAD_CH);
    if (pbuf->RingBufTxCtr < COM_TX_BUF_SIZE) {           /* See if buffer is full                    */
        pbuf->RingBufTxCtr++;                              /* No, increment character count            */
        *pbuf->RingBufTxInPtr++ = c;                       /* Put character into buffer                */
        if (pbuf->RingBufTxInPtr == &pbuf->RingBufTx[COM_TX_BUF_SIZE]) { /* Wrap IN pointer           */
            pbuf->RingBufTxInPtr = &pbuf->RingBufTx[0];
        if (pbuf->RingBufTxCtr == 1) {                     /* See if this is the first character       */
            COMEnableTxInt(port);                          /* Yes, Enable Tx interrupts                */
            OS_EXIT_CRITICAL();
        } else {
            OS_EXIT_CRITICAL();
        return (COM_NO_ERR);
    } else {
        OS_EXIT_CRITICAL();
        return (COM_TX_FULL);
 * parameter:
 * return   :
 * changelog:
    COM_RING_BUF *pbuf;
    pbuf                  = &COM1Buf;                     /* Initialize the ring buffer for COM0     */
    pbuf->RingBufRxCtr    = 0;
    pbuf->RingBufRxInPtr  = &pbuf->RingBufRx[0];
    pbuf->RingBufTxCtr    = 0;
    pbuf->RingBufTxOutPtr = &pbuf->RingBufTx[0];
    pbuf                  = &COM2Buf;                     /* Initialize the ring buffer for COM1     */
 * return   : char
 * changelog:
    unsigned char empty;
    COM_RING_BUF *pbuf;
    switch (port)
        case COM1:
             pbuf = &COM1Buf;
             break;
        case COM2:
             pbuf = &COM2Buf;
             break;
        default:
             return (1);
    {                                                      /* See if buffer is empty                   */
        empty = 0;                                         /* Buffer is NOT empty                      */
    else
        empty = 1;                                         /* Buffer is empty                          */
    OS_EXIT_CRITICAL();
    return (empty);
 * return   : char
 * changelog:
    char full;
    COM_RING_BUF *pbuf;
    switch (port)
        case COM1:
             pbuf = &COM1Buf;
             break;
        case COM2:
             pbuf = &COM2Buf;
             break;
        default:
             return (1);
        full = 0;                                      /* Buffer is NOT full                       */
    } else {
        full = 1;                                       /* Buffer is full                           */
    OS_EXIT_CRITICAL();
    return (full);
// This function is called by the Rx ISR to insert a character into the receive ring buffer.
static void  COMPutRxChar (unsigned char port, unsigned char c)
    COM_RING_BUF *pbuf;
    switch (port)
        case COM1:
             pbuf = &COM1Buf;
             break;
        case COM2:
             pbuf = &COM2Buf;
             break;
        default:
             return;
    if (pbuf->RingBufRxCtr < COM_RX_BUF_SIZE) {           /* See if buffer is full                    */
        pbuf->RingBufRxCtr++;                              /* No, increment character count            */
        *pbuf->RingBufRxInPtr++ = c;                       /* Put character into buffer                */
        if (pbuf->RingBufRxInPtr == &pbuf->RingBufRx[COM_RX_BUF_SIZE]) { /* Wrap IN pointer           */
// This function is called by the Tx ISR to extract the next character from the Tx buffer.
//    The function returns FALSE if the buffer is empty after the character is extracted from
//    the buffer.  This is done to signal the Tx ISR to disable interrupts because this is the
//    last character to send.
static unsigned char COMGetTxChar (unsigned char port, unsigned char *err)
    unsigned char c;
    COM_RING_BUF *pbuf;
    switch (port)
        case COM1:
             pbuf = &COM1Buf;
             break;
        case COM2:
             pbuf = &COM2Buf;
             break;
        default:
             *err = COM_BAD_CH;
             return (0);
    if (pbuf->RingBufTxCtr > 0) {                          /* See if buffer is empty                   */
        pbuf->RingBufTxCtr--;                              /* No, decrement character count            */
        c = *pbuf->RingBufTxOutPtr++;                      /* Get character from buffer                */
        if (pbuf->RingBufTxOutPtr == &pbuf->RingBufTx[COM_TX_BUF_SIZE])
            pbuf->RingBufTxOutPtr = &pbuf->RingBufTx[0];   /* Wrap OUT pointer     */
        *err = COM_NO_ERR;
        return (c);                                        /* Characters are still available           */
    } else {
        *err = COM_TX_EMPTY;
        return (0);                                      /* Buffer is empty                          */
    unsigned int data;
    unsigned char err;
        // Clear interrupt (do nothing about it!)
        data = USART1->DR;
        data = USART1->DR;
        COMPutRxChar(COM1, data);                    // Insert received character into buffer
        data = COMGetTxChar(COM1, &err);             // Get next character to send.
        if (err == COM_TX_EMPTY)
        {                                            // Do we have anymore characters to send ?
                                                     // No,  Disable Tx interrupts
            //USART_ITConfig(USART1, USART_IT_TXE| USART_IT_TC, ENABLE);
            USART1->CR1 &= ~USART_FLAG_TXE | USART_FLAG_TC;
        else
            USART1->DR = data;        // Yes, Send character
void USART2_IRQHandler(void)
    unsigned int data;
    unsigned char err;
    if(USART2->SR & 0x0F)
        data = USART2->DR;
    else if(USART2->SR & USART_FLAG_RXNE) //Receive Data Reg Full Flag
        data = USART2->DR;
        COMPutRxChar(COM2, data);                    // Insert received character into buffer
    else if(USART2->SR & USART_FLAG_TXE)
        data = COMGetTxChar(COM2, &err);             // Get next character to send.
            //USART_ITConfig(USART2, USART_IT_TXE| USART_IT_TC, ENABLE);
            USART2->CR1 &= ~USART_FLAG_TXE | USART_FLAG_TC;
        else
            USART2->DR = data;        // Yes, Send character
下面给个例子主程序,来演示如何使用上面的串口驱动代码。
#include "misc.h"
#include "stm32f10x.h"
void UART_PutStrB (unsigned char port, uint8_t *str)
    while (0 != *str)
        COMPutCharB(port, *str);
        str++;
void USART1_Init(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1, ENABLE);
    /* Configure USART Tx as alternate function push-pull */
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* Configure USART Rx as input floating */
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    USART_InitStructure.USART_BaudRate = 9600;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_Init(USART1, &USART_InitStructure );
        USART_Cmd(USART1, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
void USART2_Init(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
    USART_Init(USART2, &USART_InitStructure );
        USART_Cmd(USART2, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
int main(void)
    unsigned char c;
    unsigned char err;
    USART1_Init();
    USART2_Init();
    COMBufferInit();
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
    UART_PutStrB(COM1, "Hello World!\n");
    for(;;)
        c = COMGetCharB(COM1, &err);
        if(err == COM_NO_ERR)
            COMPutCharB(COM1, c);
上海晶丰明源(BPS)公司的发展小趣事
上海晶丰明源半导体股份有限公司的创立,标志着中国在半导体领域的又一重要布局。公司自成立之初,就专注于电源管理芯片的研发与销售,凭借对技术的深入理解和市场需求的敏锐洞察,迅速在行业中崭露头角。初步发展阶段,晶丰明源通过不断优化产品设计、提升生产工艺,逐步赢得了客户的信任,并在市场上占据了一席之地。
奇力新(chilisin)公司的发展小趣事
随着业务的不断发展和市场需求的增长,奇力新开始在全球范围内进行布局。公司先后在亚洲、欧洲、美洲等地设立了生产基地和研发中心,提升了产能和研发能力。同时,奇力新还积极寻求与国际知名企业的合作,共同开发新产品和新技术。这些举措不仅提升了奇力新的品牌影响力和市场竞争力,还为其未来的发展奠定了坚实的基础。
Gigabit Logic Inc公司的发展小趣事
采用集成电路等现代电子元器件,提高了电路的可靠性和稳定性。
CEVA, Inc公司的发展小趣事
面对不断变化的市场环境和技术挑战,CEVA公司积极应对,抓住机遇。例如,在执行编码标准并降低许可证风险方面,CEVA的DevOps/实时开发团队面临着在更高效地执行编码标准的同时降低许可证相关风险的挑战。公司通过优化开发流程、提升自动化水平等方式,成功应对了这一挑战。同时,CEVA也通过增加站点布局、拓建电商能力、提升产品竞争力等手段,抓住市场机遇,迎接未来。
Asia Pacific Microsystems Inc公司的发展小趣事
随着电子行业的快速发展,APM意识到只有不断创新才能在市场中立足。于是,公司加大了对研发的投入,积极引进高端人才,并与多所高校和研究机构建立了合作关系。经过几年的努力,APM成功研发出了一款具有自主知识产权的高性能模拟芯片,填补了国内市场的空白。这款芯片在信号处理、通信等领域具有广泛应用前景,为APM带来了可观的收益。
Hittite Microwave(ADI)公司的发展小趣事
APM公司由一群热衷于微电子技术的专家在亚太地区创立。初创时期,公司面临着资金紧张、市场竞争激烈以及技术瓶颈等多重挑战。然而,APM凭借其团队对技术的深刻理解和对市场的敏锐洞察,成功开发出一款具有竞争力的微控制器产品,迅速在市场中占据了一席之地。这款产品不仅性能稳定,而且价格适中,满足了当时市场对低成本、高性能微控制器的迫切需求。
发个工程师用的词典(只可以在电脑上应用)
英语学的不太过关,为了看懂各种技术资料 自己就在互联网上找了一个工程师专用的词典 感觉词汇挺全的,如果可以上网还支持谷歌词汇搜索。…
晒我的工作现场!!!
我是在实验室工作的,大部分时间都泡在实验室的!!! 我的小小工作间!!!那个绿色的小板子就是CC2510的无线单片机啦!!右边是我可爱的电脑和IBM的键盘。左边还有一些书!!! 聚焦我的书籍和无线单片机!! 全局看到我的小小工作间!!!就 ...…
打了wince 6.0 09年2月份的补丁后DirectDrawCreate不成功
有没有遇到过的兄弟 在没有打补丁之前 DirectDrawCreate 调用成功,但打上了09年2月份的补丁后,DirectDrawCreate调用失败,返回DDERR_GENERIC,查了下MSDN,DDERR_GENERIC There is an undefined error condition 我现在把补丁打到了09年5月, ...…
vc2005 加载动态库
各位大侠好,请问我想用VC++2005访问数据库(SQL Mobile生成的sdf文件拷贝到PDA上),好像要用到System.dll该如何加载呢?我用#import \"E:\\....dll\"编译时提示加载失败啊,请各位大侠指点(\"\"里面是我文件的路径),还有,是不是MFC程序里面不 ...…
怎样为pci寻找地址映射
怎样读取pci bar0中的地址,并且映射成可以使用的虚拟地址?2.6的内核。ioremap?ioportremap?dev_resource_start?…
一个很奇怪的问题,网络不通
还是dm9000的问题,在wince下把dm9000驱动加载了,奇怪的是我把镜像烧在memory时运行很好,但是烧在flash后就不通,也无法获取ip,其他功能都好的。有没有人遇到国这个情况。…
刷新
我创建了一个基于DLL的程序,用CreateWindowEx创建了一个窗口,并用BitBit函数往dc上画了一幅图片, 然后让位图在窗口上移动,用InValidateRect函数去刷新。然而窗口却不刷新,不知道为什么,请各位指教? 谢谢。…
用TREEVIEW控件如何加载大量数据
我有一些文本信息想通过TREEVIEW控件加载,不知如何编码?…
ADS1298——用于ECGEEG的完整模拟前端
$(\'swf_OcQ\').innerHTML=AC_FL_RunContent(\'width\', \'550\', \'height\', \'400\', \'allowNetworking\', \'internal\', \'allowScriptAccess\', \'never\', \'src\', encodeURI(\'http://player.youku.com/player.php/sid/XMzE2NTkzMzY4/v.sw ...…
【MSP430 编译器使用经验】CCS代码编辑的几个常用设置
本帖最后由 Rufer 于 2014-7-29 14:48 编辑 第一次发帖,分享几个我觉得比较常用的CCS代码编辑设置 1、代码的折叠 代码写多了很长,不方便查看,这时可以右键单击行号左边任意空白处,在弹出的菜单中选择Folding-->Enable Folding,这时每个函 ...…
