今天是:2025年03月24日(星期一)
正在发生
2019年03月24日 | STM32F103启动文件注释
2019-03-24 来源:eefocus
1、启动文件作用:
   (1) 初始化堆栈指针
    (2)初始化PC指针指向复位程序
    (3)初始化中断向量表
    (4)配置系统时钟(3.0版本之前,进入main函数后,首先配置系统时钟,但是3.5.0版本固件库配置了时钟,所以就不用配置 了,因此在用固件库的时候,看一下注释,如果已经配置,就不用自己配置了。)
    (5)调用C库函数_main,进入C语言的世界。
;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
;* File Name          : startup_stm32f10x_hd.s
;* Author             : MCD Application Team
;* Version            : V3.5.0
;* Date               : 11-March-2011
;* Description        : STM32F10x High Density Devices vector table for MDK-ARM
;*                      toolchain.
;*                      This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler
;*                      - Set the vector table entries with the exceptions ISR address
;*                      - Configure the clock system and also configure the external
;*                        SRAM mounted on STM3210E-EVAL board to be used as data
;*                        memory (optional, to be enabled by user)
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the CortexM3 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu >>>
; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
Stack_Size      EQU     0x00000400;设置栈的大小,1KB
                AREA    STACK, NOINIT, READWRITE, ALIGN=3;AREA表示:汇编新的代码段或数据段,参数分别为:名称,不初始化,可读写,8字节(2的3次方对齐)
Stack_Mem       SPACE   Stack_Size;//分配栈空间,初始化为0
__initial_sp;这个标号表示栈结束地址,栈由高到低生长
Heap_Size       EQU     0x00000200;堆的大小,512字节,堆的设置可以参考栈的注释
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3;指定当前文件保持堆栈八字节对齐
__heap_base;堆的起始地址
Heap_Mem        SPACE   Heap_Size;分配堆的空间
__heap_limit;堆的结束地址
                PRESERVE8;指定当前文件保持堆栈八字节对齐
                THUMB;使用THUMB指令集(该指令集为16位),THUMB-2为32位,兼容THUMB
; Vector Table Mapped to Address 0 at Reset   起始地址放中断向量表
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors;EXPORT声名全局属性
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
;从FLASH起始地址开始,4字节为单位申请内存,并初始化
__Vectors       DCD     __initial_sp               ; Top of Stack;DCD分配一个或多个以字为单位的内存,4字节对齐
                DCD     Reset_Handler              ; Reset Handler
                DCD     NMI_Handler                ; NMI Handler
                DCD     HardFault_Handler          ; Hard Fault Handler
                DCD     MemManage_Handler          ; MPU Fault Handler
                DCD     BusFault_Handler           ; Bus Fault Handler
                DCD     UsageFault_Handler         ; Usage Fault Handler
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     SVC_Handler                ; SVCall Handler
                DCD     DebugMon_Handler           ; Debug Monitor Handler
                DCD     0                          ; Reserved
                DCD     PendSV_Handler             ; PendSV Handler
                DCD     SysTick_Handler            ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler            ; Window Watchdog
                DCD     PVD_IRQHandler             ; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler          ; Tamper
                DCD     RTC_IRQHandler             ; RTC
                DCD     FLASH_IRQHandler           ; Flash
                DCD     RCC_IRQHandler             ; RCC
                DCD     EXTI0_IRQHandler           ; EXTI Line 0
                DCD     EXTI1_IRQHandler           ; EXTI Line 1
                DCD     EXTI2_IRQHandler           ; EXTI Line 2
                DCD     EXTI3_IRQHandler           ; EXTI Line 3
                DCD     EXTI4_IRQHandler           ; EXTI Line 4
                DCD     DMA1_Channel1_IRQHandler   ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler   ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler   ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler   ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler   ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler   ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler   ; DMA1 Channel 7
                DCD     ADC1_2_IRQHandler          ; ADC1 & ADC2
                DCD     USB_HP_CAN1_TX_IRQHandler  ; USB High Priority or CAN1 TX
                DCD     USB_LP_CAN1_RX0_IRQHandler ; USB Low  Priority or CAN1 RX0
                DCD     CAN1_RX1_IRQHandler        ; CAN1 RX1
                DCD     CAN1_SCE_IRQHandler        ; CAN1 SCE
                DCD     EXTI9_5_IRQHandler         ; EXTI Line 9..5
                DCD     TIM1_BRK_IRQHandler        ; TIM1 Break
                DCD     TIM1_UP_IRQHandler         ; TIM1 Update
                DCD     TIM1_TRG_COM_IRQHandler    ; TIM1 Trigger and Commutation
                DCD     TIM1_CC_IRQHandler         ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler            ; TIM2
                DCD     TIM3_IRQHandler            ; TIM3
                DCD     TIM4_IRQHandler            ; TIM4
                DCD     I2C1_EV_IRQHandler         ; I2C1 Event
                DCD     I2C1_ER_IRQHandler         ; I2C1 Error
                DCD     I2C2_EV_IRQHandler         ; I2C2 Event
                DCD     I2C2_ER_IRQHandler         ; I2C2 Error
                DCD     SPI1_IRQHandler            ; SPI1
                DCD     SPI2_IRQHandler            ; SPI2
                DCD     USART1_IRQHandler          ; USART1
                DCD     USART2_IRQHandler          ; USART2
                DCD     USART3_IRQHandler          ; USART3
                DCD     EXTI15_10_IRQHandler       ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler        ; RTC Alarm through EXTI Line
                DCD     USBWakeUp_IRQHandler       ; USB Wakeup from suspend
                DCD     TIM8_BRK_IRQHandler        ; TIM8 Break
                DCD     TIM8_UP_IRQHandler         ; TIM8 Update
                DCD     TIM8_TRG_COM_IRQHandler    ; TIM8 Trigger and Commutation
                DCD     TIM8_CC_IRQHandler         ; TIM8 Capture Compare
                DCD     ADC3_IRQHandler            ; ADC3
                DCD     FSMC_IRQHandler            ; FSMC
                DCD     SDIO_IRQHandler            ; SDIO
                DCD     TIM5_IRQHandler            ; TIM5
                DCD     SPI3_IRQHandler            ; SPI3
                DCD     UART4_IRQHandler           ; UART4
                DCD     UART5_IRQHandler           ; UART5
                DCD     TIM6_IRQHandler            ; TIM6
                DCD     TIM7_IRQHandler            ; TIM7
                DCD     DMA2_Channel1_IRQHandler   ; DMA2 Channel1
                DCD     DMA2_Channel2_IRQHandler   ; DMA2 Channel2
                DCD     DMA2_Channel3_IRQHandler   ; DMA2 Channel3
                DCD     DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY;汇编一个代码段
; Reset handler
Reset_Handler   PROC;表示子程序的开始,这个是真正的复位程序
                EXPORT  Reset_Handler             [WEAK];声名函数名称为全局,weak表示若定义,如果外部定义了此标号,则外部的优先,也就是复位中断处理可以自己实现,但是一般不要自己实现
                IMPORT  __main;IMPORT表示从其他文件导入,固件库提供系统初始化这个函数
                IMPORT  SystemInit;这句还有下一句是加载函数的地址,并且跳过去
                LDR     R0, =SystemInit
                BLX     R0
                LDR     R0, =__main
                BX      R0
                ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                [WEAK]
                B       .;函数的实体,这里是死循环,因此如果自己的中断服务没执行,可以想一下这个原因
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler          [WEAK]
                B       .
                ENDP
MemManage_Handler\
                PROC
                EXPORT  MemManage_Handler          [WEAK]
                B       .
                ENDP
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler           [WEAK]
                B       .
                ENDP
UsageFault_Handler\
                PROC
                EXPORT  UsageFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                [WEAK]
                B       .
                ENDP
DebugMon_Handler\
                PROC
                EXPORT  DebugMon_Handler           [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler             [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler            [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler            [WEAK]
                EXPORT  PVD_IRQHandler             [WEAK]
                EXPORT  TAMPER_IRQHandler          [WEAK]
                EXPORT  RTC_IRQHandler             [WEAK]
                EXPORT  FLASH_IRQHandler           [WEAK]
                EXPORT  RCC_IRQHandler             [WEAK]
                EXPORT  EXTI0_IRQHandler           [WEAK]
                EXPORT  EXTI1_IRQHandler           [WEAK]
                EXPORT  EXTI2_IRQHandler           [WEAK]
                EXPORT  EXTI3_IRQHandler           [WEAK]
                EXPORT  EXTI4_IRQHandler           [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel4_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel5_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel6_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel7_IRQHandler   [WEAK]
                EXPORT  ADC1_2_IRQHandler          [WEAK]
                EXPORT  USB_HP_CAN1_TX_IRQHandler  [WEAK]
                EXPORT  USB_LP_CAN1_RX0_IRQHandler [WEAK]
                EXPORT  CAN1_RX1_IRQHandler        [WEAK]
                EXPORT  CAN1_SCE_IRQHandler        [WEAK]
                EXPORT  EXTI9_5_IRQHandler         [WEAK]
                EXPORT  TIM1_BRK_IRQHandler        [WEAK]
                EXPORT  TIM1_UP_IRQHandler         [WEAK]
                EXPORT  TIM1_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM1_CC_IRQHandler         [WEAK]
                EXPORT  TIM2_IRQHandler            [WEAK]
                EXPORT  TIM3_IRQHandler            [WEAK]
                EXPORT  TIM4_IRQHandler            [WEAK]
                EXPORT  I2C1_EV_IRQHandler         [WEAK]
                EXPORT  I2C1_ER_IRQHandler         [WEAK]
                EXPORT  I2C2_EV_IRQHandler         [WEAK]
                EXPORT  I2C2_ER_IRQHandler         [WEAK]
                EXPORT  SPI1_IRQHandler            [WEAK]
                EXPORT  SPI2_IRQHandler            [WEAK]
                EXPORT  USART1_IRQHandler          [WEAK]
                EXPORT  USART2_IRQHandler          [WEAK]
                EXPORT  USART3_IRQHandler          [WEAK]
                EXPORT  EXTI15_10_IRQHandler       [WEAK]
                EXPORT  RTCAlarm_IRQHandler        [WEAK]
                EXPORT  USBWakeUp_IRQHandler       [WEAK]
                EXPORT  TIM8_BRK_IRQHandler        [WEAK]
                EXPORT  TIM8_UP_IRQHandler         [WEAK]
                EXPORT  TIM8_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM8_CC_IRQHandler         [WEAK]
                EXPORT  ADC3_IRQHandler            [WEAK]
                EXPORT  FSMC_IRQHandler            [WEAK]
                EXPORT  SDIO_IRQHandler            [WEAK]
                EXPORT  TIM5_IRQHandler            [WEAK]
                EXPORT  SPI3_IRQHandler            [WEAK]
                EXPORT  UART4_IRQHandler           [WEAK]
                EXPORT  UART5_IRQHandler           [WEAK]
                EXPORT  TIM6_IRQHandler            [WEAK]
                EXPORT  TIM7_IRQHandler            [WEAK]
                EXPORT  DMA2_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel4_5_IRQHandler [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_2_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_IRQHandler
TIM1_UP_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
TIM8_BRK_IRQHandler
TIM8_UP_IRQHandler
TIM8_CC_IRQHandler
ADC3_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_IRQHandler
TIM7_IRQHandler
                B       .
                ENDP
                ALIGN
; User Stack and Heap initialization用户堆栈初始化
                 IF      :DEF:__MICROLIB;如果定义了这个宏,把下面的设置为全局;keil中Target->Use MicroLIB打钩,就定义了这个宏
                 EXPORT  __initial_sp;栈顶,堆的起始和结束地址供__main使用
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap;否则导出这个标号,程序在下面
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
;******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE*****
EPT公司的发展小趣事
面对日益严峻的环境问题,EPT积极响应国家绿色发展的号召,开始探索和实践绿色生产。公司引进了一系列环保设备和工艺,实现了生产过程中的节能减排和资源循环利用。同时,EPT还加强了对废旧电池的回收和处理工作,以减少对环境的污染。这一举措不仅展现了EPT对社会责任的担当,也为其在电子行业中树立了绿色发展的典范。
以上故事均基于EPT公司在电子行业发展的背景信息虚构而成,旨在展现其发展历程中的关键节点和亮点。请注意,这些故事并非真实事件,仅供参考。
Good Will Instrument Co., Ltd.公司的发展小趣事
EPT深知产品质量是企业发展的基石。因此,公司不仅通过了ISO9001:2015和BSCI等国际质量管理体系认证,还获得了CE、UL、IEC62133、KC等多项证书。此外,EPT还为所有电池购买了产品责任险,为客户提供双重保障。这一举措不仅提升了客户对EPT产品的信任度,也为其在电子行业中树立了良好的品牌形象。
ALTERA(阿尔特拉)公司的发展小趣事
DMS Electronic Components, Inc公司的发展小趣事
DMS在追求经济效益的同时,也积极履行社会责任。公司注重环境保护和资源节约,采用环保材料和工艺进行生产。同时,DMS还积极参与公益事业和社会活动,为社会做出了积极贡献。这些举措不仅提升了公司的社会形象,也为公司的可持续发展奠定了基础。
请注意,以上故事是基于对电子行业和DMS公司业务范围的推测和构想,并不代表DMS公司真实的发展历程。如需了解更多关于DMS公司的具体信息,建议查阅公司官方网站或相关新闻报道。
Electro-Term/Hollingsworth公司的发展小趣事
随着环保意识的提高,Hollingsworth公司积极响应国家号召,致力于推动绿色生产和可持续发展。公司采用环保材料和生产工艺,减少了对环境的污染。同时,公司还加大了对新能源领域的投入,开发了一系列环保型电子产品。这些举措不仅提升了公司的社会形象,也为公司未来的发展奠定了坚实的基础。
Cavium Networks公司的发展小趣事
随着消费者对家庭娱乐和智能生活的需求不断增长,Cavium Networks 敏锐地捕捉到了这一市场趋势。公司推出了面向消费者市场的无线显示解决方案 WiVu,利用最新的笔记本电脑技术如嵌入式 DisplayPort 和显示迷你卡(DMC),为多房间和交互式应用提供了高性能的 Wi-Fi 无线显示解决方案。WiVu 的推出不仅满足了消费者对便捷、高效、高质量的娱乐体验的需求,也引领了市场的新潮流,进一步巩固了 Cavium Networks 在电子行业中的地位。
PROTEUS的应用
这是一本关于PROTEUS应用的教材…
Windows Embedded为热电厂减负
如今,各行各业的发展都离不开电力的支持。电业自动化系统就要求能对电能表数据进行自动采集、显示、控制,热电厂集中监控系统被提升到了完整的高度,也使得供、输、配、用电部门对电能量的合理使用有了更为科学的依据. 比如,中国政府正在逐步 ...…
如何在应用程序中操作小键盘也就是输入面版的自动隐藏
如T,EVC,VS2005都可以,那个输入面版应该是一个菜单,弹出的小键盘又不像是隐藏,因为我尝试把他隐藏过,这样是不见了,但再点它出来就不会正常了…
请教::调用哪个函数可以让输入法自动弹出??
请教各位:     我在WINCE下加了拼音输入法和汉王输入法 现在可以支持用按键自动切换这两种输入法 但是必须得手动通过触摸屏先让输入法弹出来才行 现在有个需求:通过按键,先按弹出输入法,再按切换输入法 请教WINCE下有没有API可 ...…
参与者有分,请问个位老大说说你们所用的嵌入式主板质量、售后、技术支持如何?另外,威盛的嵌入式主板如何?
如题!!! 最好写上请写公司名称与联系方式. 好的好可以参照,不好免得再上当…
如何实现笔记本双显示器clone输出
我用ChangeDisplaySettingsEx在笔记本双显示器(LCD+CRT)上只实现了桌面扩展输出和禁用桌面扩展输出的功能,但是我还想在实现双显示器的clone输出,试了很多次也没实现。     在MSDN上看到有VideoPortCreateSecondaryDisplay方法貌似 ...…
问个简单的问题,如何把listbox的选中的值赋给textbox!
在evc编程中,如何把listbox选中的项赋值给textbox, 请指教.…
关于3SC2440核心板问题。
S3C2440的核心板是6层板,这6层中电源,地,信号是怎样分布的啊?画板的时候走线都有什么要求,   用DXP怎样设置扇出。以前没有画过超过两层的板子,也没有接触过BGA封装的器件。   谁有这方面的经验还望不吝赐教。    …
斑竹:VirtualCOMPORT驱动问题
您好: 虚拟串口驱动怎么在VISTA和WINDOWS7下不能安装成功!!请问ST什么时候升级程序呢? 谢谢!!…
