今天是:2025年03月29日(星期六)
2019年03月29日 | stm32串口点灯
2019-03-29 来源:eefocus
串口程序:
hal.h
#ifndef HAL_H
//输出宏定义 #define LED2_OFF GPIO_ResetBits(GPIOA, GPIO_Pin_7) #define LED3_OFF GPIO_ResetBits(GPIOC, GPIO_Pin_7) #define LED4_OFF GPIO_ResetBits(GPIOC, GPIO_Pin_5) #define LED5_OFF GPIO_ResetBits(GPIOB, GPIO_Pin_9) #define LED6_OFF GPIO_ResetBits(GPIOB, GPIO_Pin_8) #define LED7_OFF GPIO_ResetBits(GPIOB, GPIO_Pin_5) #define LED8_OFF GPIO_ResetBits(GPIOB, GPIO_Pin_0)
//串口
GPIO.c
#include "STM32Lib\\stm32f10x.h" /******************************************************************************* /* PB0,5,8,9输出 */ |
USART.c
#include "STM32Lib\\stm32f10x.h" /********************************************** void USART_Configuration(void) /* A9 USART1_Tx */ /* A10 USART1_Rx */
USART_ClockInit(USART1, &USART_ClockInitStructure); // A3 做R2X USART_ClockInit(USART2, &USART_ClockInitStructure); void USART1_Putc(unsigned char c) void USART1_Puts(char * str) void USART2_Putc(unsigned char c) void USART2_Puts(char * str) } |
RCC.c
#include "STM32Lib\\stm32f10x.h" RCC_ClocksTypeDef RCC_ClockFreq; void RCC_Configuration(void) /************************************************** |
NVIC.c
void NVIC_Configuration(void) |
main.c
/************************************************************ #include "STM32Lib\\stm32f10x.h" |
stm32f10x_it.c
/******************** (C) COPYRIGHT 2007 STMicroelectronics ********************
* stm32f10x_it.c
* 所有中断响应函数,一般如果中断比较简易,则直接在此编写,否则
* 可调用HAL模块中各自对应的处理函数处理中断。
/* Includes ------------------------------------------------------------------*/
/* Private typedef -----------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
#define countof(a) (sizeof(a) / sizeof(*(a)))
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name : NMI_Handler
* Description : This function handles NMI exception.
* Input : None
* Output : None
* Return : None
void NMI_Handler(void)
* Function Name : HardFault_Handler
* Description : This function handles Hard Fault exception.
* Input : None
* Output : None
* Return : None
void HardFault_Handler(void)
/* Go to infinite loop when Hard Fault exception occurs */
while (1)
* Function Name : MemManage_Handler
* Description : This function handles Memory Manage exception.
* Input : None
* Output : None
* Return : None
void MemManage_Handler(void)
/* Go to infinite loop when Memory Manage exception occurs */
while (1)
* Function Name : BusFault_Handler
* Description : This function handles Bus Fault exception.
* Input : None
* Output : None
* Return : None
void BusFault_Handler(void)
/* Go to infinite loop when Bus Fault exception occurs */
while (1)
* Function Name : UsageFaultException
* Description : This function handles Usage Fault exception.
* Input : None
* Output : None
* Return : None
void UsageFault_Handler(void)
/* Go to infinite loop when Usage Fault exception occurs */
while (1)
* Function Name : SVC_Handler
* Description : This function handles SVCall exception.
* Input : None
* Output : None
* Return : None
void SVC_Handler(void)
* Function Name : DebugMon_Handler
* Description : This function handles Debug Monitor exception.
* Input : None
* Output : None
* Return : None
void DebugMon_Handler(void)
* Function Name : PendSVC
* Description : This function handles PendSVC exception.
* Input : None
* Output : None
* Return : None
void PendSV_Handler(void)
* Function Name : SysTickHandler
* Description :
void SysTick_Handler(void)
* Function Name : WWDG_IRQHandler
* Description : This function handles WWDG interrupt request.
* Input : None
* Output : None
* Return : None
void WWDG_IRQHandler(void)
* Function Name : PVD_IRQHandler
* Description : This function handles PVD interrupt request.
* Input : None
* Output : None
* Return : None
void PVD_IRQHandler(void)
* Function Name : TAMPER_IRQHandler
* Description : This function handles Tamper interrupt request.
* Input : None
* Output : None
* Return : None
void TAMPER_IRQHandler(void)
* Function Name : RTC_IRQHandler
* Description : RTC中断中,
* Input : None
* Output : None
* Return : None
void RTC_IRQHandler(void)
* Function Name : FLASH_IRQHandler
* Description : This function handles Flash interrupt request.
* Input : None
* Output : None
* Return : None
void FLASH_IRQHandler(void)
* Function Name : RCC_IRQHandler
* Description : This function handles RCC interrupt request.
* Input : None
* Output : None
* Return : None
void RCC_IRQHandler(void)
* Function Name : EXTI0_IRQHandler
* Description : This function handles External interrupt Line 0 request.
* Input : None
* Output : None
* Return : None
void EXTI0_IRQHandler(void)
* Function Name : EXTI1_IRQHandler
* Description : This function handles External interrupt Line 1 request.
* Input : None
* Output : None
* Return : None
void EXTI1_IRQHandler(void)
* Function Name : EXTI2_IRQHandler
* Description : This function handles External interrupt Line 2 request.
* Input : None
* Output : None
* Return : None
void EXTI2_IRQHandler(void)
* Function Name : EXTI3_IRQHandler
* Description : This function handles External interrupt Line 3 request.
* Input : None
* Output : None
* Return : None
void EXTI3_IRQHandler(void)
* Function Name : EXTI4_IRQHandler
* Description : This function handles External interrupt Line 4 request.
* Input : None
* Output : None
* Return : None
void EXTI4_IRQHandler(void)
* Function Name : DMAChannel1_IRQHandler
* Description : This function handles DMA Stream 1 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel1_IRQHandler(void)
* Function Name : DMAChannel2_IRQHandler
* Description : This function handles DMA Stream 2 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel2_IRQHandler(void)
* Function Name : DMAChannel3_IRQHandler
* Description : This function handles DMA Stream 3 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel3_IRQHandler(void)
* Function Name : DMAChannel4_IRQHandler
* Description : This function handles DMA Stream 4 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel4_IRQHandler(void)
* Function Name : DMAChannel5_IRQHandler
* Description : This function handles DMA Stream 5 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel5_IRQHandler(void)
* Function Name : DMAChannel6_IRQHandler
* Description : This function handles DMA Stream 6 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel6_IRQHandler(void)
* Function Name : DMAChannel7_IRQHandler
* Description : This function handles DMA Stream 7 interrupt request.
* Input : None
* Output : None
* Return : None
void DMA1_Channel7_IRQHandler(void)
* Function Name : ADC_IRQHandler
* Description : This function handles ADC global interrupt request.
* Input : None
* Output : None
* Return : None
void ADC1_2_IRQHandler(void)
* Function Name : USB_HP_CAN_TX_IRQHandler
* Description : This function handles USB High Priority or CAN TX interrupts
* requests.
* Input : None
* Output : None
* Return : None
void USB_HP_CAN1_TX_IRQHandler(void)
* Function Name : USB_LP_CAN_RX0_IRQHandler
* Description : This function handles USB Low Priority or CAN RX0 interrupts
* requests.
* Input : None
* Output : None
* Return : None
void USB_LP_CAN1_RX0_IRQHandler(void)
* Function Name : CAN_RX1_IRQHandler
* Description : This function handles CAN RX1 interrupt request.
* Input : None
* Output : None
* Return : None
void CAN1_RX1_IRQHandler(void)
* Function Name : CAN_SCE_IRQHandler
* Description : This function handles CAN SCE interrupt request.
* Input : None
* Output : None
* Return : None
void CAN1_SCE_IRQHandler(void)
* Function Name : EXTI9_5_IRQHandler
* Description : This function handles External lines 9 to 5 interrupt request.
* Input : None
* Output : None
* Return : None
void EXTI9_5_IRQHandler(void)
* Function Name : TIM1_BRK_IRQHandler
* Description : This function handles TIM1 Break interrupt request.
* Input : None
* Output : None
* Return : None
void TIM1_BRK_IRQHandler(void)
* Function Name : TIM1_UP_IRQHandler
* Description : This function handles TIM1 overflow and update interrupt
* request.
* Input : None
* Output : None
* Return : None
void TIM1_UP_IRQHandler(void)
* Function Name : TIM1_TRG_COM_IRQHandler
* Description : This function handles TIM1 Trigger and commutation interrupts
* requests.
* Input : None
* Output : None
* Return : None
void TIM1_TRG_COM_IRQHandler(void)
* Function Name : TIM1_CC_IRQHandler
* Description : This function handles TIM1 capture compare interrupt request.
* Input : None
* Output : None
* Return : None
void TIM1_CC_IRQHandler(void)
* Function Name : TIM2_IRQHandler TIM2中断
* Description : This function handles TIM2 global interrupt request.
* Input : None
* Output : None
* Return : None
void TIM2_IRQHandler(void)
* Function Name : TIM3_IRQHandler
* Description : This function handles TIM3 global interrupt request.
* Input : None
* Output : None
* Return : None
void TIM3_IRQHandler(void)
* Function Name : TIM4_IRQHandler
* Description : This function handles TIM4 global interrupt request.
* Input : None
* Output : None
* Return : None
void TIM4_IRQHandler(void)
* Function Name : I2C1_EV_IRQHandler
* Description : This function handles I2C1 Event interrupt request.
* Input : None
* Output : None
* Return : None
void I2C1_EV_IRQHandler(void)
* Function Name : I2C1_ER_IRQHandler
* Description : This function handles I2C1 Error interrupt request.
* Input : None
* Output : None
* Return : None
void I2C1_ER_IRQHandler(void)
* Function Name : I2C2_EV_IRQHandler
* Description : This function handles I2C2 Event interrupt request.
* Input : None
* Output : None
* Return : None
void I2C2_EV_IRQHandler(void)
* Function Name : I2C2_ER_IRQHandler
* Description : This function handles I2C2 Error interrupt request.
* Input : None
* Output : None
* Return : None
void I2C2_ER_IRQHandler(void)
* Function Name : SPI1_IRQHandler
* Description : This function handles SPI1 global interrupt request.
* Input : None
* Output : None
* Return : None
void SPI1_IRQHandler(void)
* Function Name : SPI2_IRQHandler
* Description : This function handles SPI2 global interrupt request.
* Input : None
* Output : None
* Return : None
void SPI2_IRQHandler(void)
* Function Name : USART2_IRQHandler
* Description : This function handles USART2 global interrupt request.
* Input : None
* Output : None
* Return : None
void USART2_IRQHandler(void)
//接收中断
if(USART_GetITStatus(USART1,USART_IT_RXNE)==SET)
USART_ClearITPendingBit(USART1,USART_IT_RXNE);
Uart1_Get_Data=USART_ReceiveData(USART1);
Uart1_Get_Flag=1;
//溢出-如果发生溢出需要先读SR,再读DR寄存器 则可清除不断入中断的问题
if(USART_GetFlagStatus(USART1,USART_FLAG_ORE)==SET)
USART_ClearFlag(USART1,USART_FLAG_ORE); //读SR
USART_ReceiveData(USART1); //读DR
* Function Name : USART1_IRQHandler
* Description : This function handles USART1 global interrupt request.
* Input : None
* Output : None
* Return : None
extern u8 Uart1_Get_Flag;
extern u8 Uart1_Get_Data;
void USART1_IRQHandler(void)
//接收中断
Uart1_Get_Flag=1;
* Function Name : USART3_IRQHandler
* Description : This function handles USART3 global interrupt request.
* Input : None
* Output : None
* Return : None
void USART3_IRQHandler(void)
* Function Name : EXTI15_10_IRQHandler
* Description : This function handles External lines 15 to 10 interrupt request.
* Input : None
* Output : None
* Return : None
void EXTI15_10_IRQHandler(void)
* Function Name : RTCAlarm_IRQHandler
* Description : This function handles RTC Alarm interrupt request.
* Input : None
* Output : None
* Return : None
void RTCAlarm_IRQHandler(void)
* Function Name : USBWakeUp_IRQHandler
* Description : This function handles USB WakeUp interrupt request.
* Input : None
* Output : None
* Return : None
void USBWakeUp_IRQHandler(void)
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
上一篇:stm32 汇编点灯程序
下一篇:STM32的IO配置点灯
先用读卡器在windows FAT格式 格式化,再用单片机SPI总线读取SD卡,在初始化成功后,读取相关寄存器都成功,当读取第一个扇区时,数据始终不对,这是为什么? 地址0000处应该是启动扇区,里面有一些描述,但我读的一大部分是0x00,最后以0x55 0xAA结束.… 查看全部问答> |
各位,用protel生成了一个pdf格式的原理图,然后在pdf里面,我想去查引脚之间相连的情况,比如输入R1,但找到的却不是R1,而是SI03,SIO1,2,1,之类的,我用全字匹配去查,也是查到SIO3,SIO1,这样一来我看原理图就很不方便了,有没有哪位也碰到 ...… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 04:01 编辑 全国大学生电子设计竞赛论文写作指导大学生 全国电子设计竞赛论文写作指导 ——电子竞赛设计与总结报告 [书写格式] ××××××设计与总结报告 摘要 ...… 查看全部问答> |
问题1:我想使用STM32F103RE的TIM2的外部时钟模式1,通过CH2通道输入外部时钟,但是原来的引脚已经使用了,所以需要将TIM2的CH2通道映射到PB3,单是映射过去后TIM2一直没有时钟计数,向大家请教一下该如何设置;我的GPIO配置如下: RCC_APB2 ...… 查看全部问答> |
最近有个小项目需要用到USB,用了传说中的FT公司的芯片, 顺手就把板子做成了Espier 2.00版本可以扩展的子板。 这样不用再画一遍FPGA啦,省事。 呵呵。 今天拿到焊了下,手艺比较糙毕竟不专业啊。 连接是这样的 简单的写了下测试程序,速度和 ...… 查看全部问答> |
