今天是:2025年04月09日(星期三)
2019年04月09日 | STM32使用HAL库实现串口通讯——理论原理详细讲解
2019-04-09 来源:eefocus
一、中断模式
1.中断接收。
1.1先看中断接收的流程(以 USART2 为例)
在启动文件中找到中断向量
USART2_IRQHandler
找到USART2_IRQHandler的函数定义
可以看到这里又转到另一个函数里去了,再找下去:
该函数的源码:
* @brief This function handles UART interrupt request.
* @param huart: pointer to a UART_HandleTypeDef structure that contains
* the configuration information for the specified UART module.
* @retval None
void HAL_UART_IRQHandler(UART_HandleTypeDef *huart)
uint32_t isrflags = READ_REG(huart->Instance->SR);
uint32_t cr1its = READ_REG(huart->Instance->CR1);
uint32_t cr3its = READ_REG(huart->Instance->CR3);
uint32_t errorflags = 0x00U;
uint32_t dmarequest = 0x00U;
/* If no error occurs */
errorflags = (isrflags & (uint32_t)(USART_SR_PE | USART_SR_FE | USART_SR_ORE | USART_SR_NE));
if(errorflags == RESET)
/* UART in mode Receiver -------------------------------------------------*/
if(((isrflags & USART_SR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET))
UART_Receive_IT(huart);
return;
/* If some errors occur */
if((errorflags != RESET) && (((cr3its & USART_CR3_EIE) != RESET) || ((cr1its & (USART_CR1_RXNEIE | USART_CR1_PEIE)) != RESET)))
/* UART parity error interrupt occurred ----------------------------------*/
if(((isrflags & USART_SR_PE) != RESET) && ((cr1its & USART_CR1_PEIE) != RESET))
huart->ErrorCode |= HAL_UART_ERROR_PE;
/* UART noise error interrupt occurred -----------------------------------*/
if(((isrflags & USART_SR_NE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
huart->ErrorCode |= HAL_UART_ERROR_NE;
/* UART frame error interrupt occurred -----------------------------------*/
if(((isrflags & USART_SR_FE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
huart->ErrorCode |= HAL_UART_ERROR_FE;
/* UART Over-Run interrupt occurred --------------------------------------*/
if(((isrflags & USART_SR_ORE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET))
huart->ErrorCode |= HAL_UART_ERROR_ORE;
/* Call UART Error Call back function if need be --------------------------*/
if(huart->ErrorCode != HAL_UART_ERROR_NONE)
/* UART in mode Receiver -----------------------------------------------*/
/* If Overrun error occurs, or if any error occurs in DMA mode reception,
consider error as blocking */
dmarequest = HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR);
if(((huart->ErrorCode & HAL_UART_ERROR_ORE) != RESET) || dmarequest)
/* Blocking error : transfer is aborted
Set the UART state ready to be able to start again the process,
Disable Rx Interrupts, and disable Rx DMA request, if ongoing */
UART_EndRxTransfer(huart);
/* Disable the UART DMA Rx request if enabled */
if(HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR))
CLEAR_BIT(huart->Instance->CR3, USART_CR3_DMAR);
/* Abort the UART DMA Rx channel */
if(huart->hdmarx != NULL)
/* Set the UART DMA Abort callback :
will lead to call HAL_UART_ErrorCallback() at end of DMA abort procedure */
huart->hdmarx->XferAbortCallback = UART_DMAAbortOnError;
if(HAL_DMA_Abort_IT(huart->hdmarx) != HAL_OK)
/* Call Directly XferAbortCallback function in case of error */
huart->hdmarx->XferAbortCallback(huart->hdmarx);
else
/* Call user error callback */
HAL_UART_ErrorCallback(huart);
else
else
/* Non Blocking error : transfer could go on.
Error is notified to user through user error callback */
huart->ErrorCode = HAL_UART_ERROR_NONE;
return;
} /* End if some error occurs */
/* UART in mode Transmitter ------------------------------------------------*/
if(((isrflags & USART_SR_TXE) != RESET) && ((cr1its & USART_CR1_TXEIE) != RESET))
UART_Transmit_IT(huart);
return;
/* UART in mode Transmitter end --------------------------------------------*/
if(((isrflags & USART_SR_TC) != RESET) && ((cr1its & USART_CR1_TCIE) != RESET))
UART_EndTransmit_IT(huart);
return;
也就是说,当串口中断触发以后,几经周转到了这里,该函数功能是读取寄存器的几个状态,判断无误后再转到另一个函数,就是上图小矩形框出来的UART_Receive_IT(huart);
然后我们再去看UART_Receive_IT(huart)这个函数原型:
回调函数就在这个UART_Receive_IT(huart)函数里:
在回调函数上边有两行很重要的代码:
这两行代码的作用是关闭串口接收中断,也就是说,在一次串口中断接收过程的最后,即串口接收完一组数据之后会关闭串口接收中断。(这个后面还会再讲,先记住)。
总结一下,串口中断接收的流程:
USART2_IRQHandler(void) -> HAL_UART_IRQHandler(UART_HandleTypeDef *huart) -> UART_Receive_IT(UART_HandleTypeDef *huart) -> HAL_UART_RxCpltCallback(huart);
Callback函数就是用户要重写在main.c里的回调函数。
再说明一下一个很重要的问题:STM32的每个串口中断有好几个(发送接收等),但是只要是与串口相关的中断发生系统都会先调用同一个函数,也就是中断向量表中的那个,比如usart2的话就是USART2_IRQHandler(void),然后这个函数再调用HAL_UART_IRQHandler,在HAL_UART_IRQHandler中去读取寄存器判断究竟是那几个位被置为1,确定好是哪个中断之后(接收还是发送)再调用不同的回调函数。
1.2如何使用接收中断。
在cube中配置完了之后并没有使能串口中断(有一个串口初始化函数,但是在这个函数中并未使能串口中断)需要用户手动使能。使能代码如下:
HAL_UART_Receive_IT(&huart2, (uint8_t *)kRxBuffer, 10);
什么意思呢?
HAL库的串口接收思路是这样的:用户你可以随便定义一个缓存区,大小随意,然后通过上边这个函数把这个缓存区对应到串口的接收,上面函数的意思就是把kRxBuffer(这是一个数组)作为缓存区,指定大小为10。然后usart2接收数据的时候就防到kRxBuffer这个数组中,只有当接收到10个数据之后才调用一次callback函数(回调函数)。当然不要忘了该函数的使能串口接收中断功能, 在:二、中断模式 的1.1节中说到了串口接收完数据后会关闭使能,所以,在回调函数中一定要再写一次HAL_UART_Receive_IT(&huart2, (uint8_t *)kRxBuffer, 10),使能接收中断。
小小的总结下串口中断接收怎么用:
(1)指定一个缓存区(串口接收到的数据会全部堆到这个缓存区)
(2)使能串口接收中断,并把缓存区对应到串口
(3)在回调函数中实现接收到数据之后的操作(比如处理数据)并再次使能串口接收中断。
所以更具体一下串口接收的流程就是这样的:
(1)串口一个接一个的接收到数据填充到缓存区
(2)缓存区满(大小是用户定义的)程序几经辗转最后会调用到回调函数。
(3)执行用户在回调函数中实现的功能。
2.中断发送。
2.1发送中断的触发流程。
由于在STM32中usart2的入口中断只有一个:
就是上图的中断向量表中红框标出来的。其他的所有中断其实都是从这里出发的,我们再和捋接收一样捋一遍发送。
首先是USART2_IRQHandler,找到这个函数原型(这一步和接收完全一样):
再找HAL_UART_IRQHandler(&huart2);原型:
到这里还是和接收完全一样,注意是完全一样,源码也就是上面接收贴出来的一样。这次我们主要注意该函数最后几行(可以翻上去看源码):
把中间代码收起来以后看最后红框,这就很明显了,这里触发了发送中断(软件触发)
接着去找这个UART_EndTransmit_IT(huart)的函数原型:
第一个红框里清除了发送中断使能(同接收一样,在用完之后就关掉,但是不同于接收,发送完成就不用再在回调函数中使能了,因为在中断发送的时候就会使能),第二个红框调用回调函数。
2.2如何使用发送中断。
中断发送的意思,非常类似于中断接收,但其中有一些不同,看下面这个函数:
HAL_UART_Transmit_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
一个非常类似于中断接收使能的函数。接收中断使能函数的作用是绑定接收缓存区并使能接收中断,但是对于发送,该函数的作用是发送指定长度的指定数据并使能发送中断。
比如有一个unsigned char 数组a[10],HAL_UART_Transmit_IT(&huart2, a, 10),这一句的意思是用usart2(串口2)发送a数组中的10个数据,然后使能发送中断。
当发送完成之后(或者发送一半,发送一半也有个中断)就会执行回调函数。
总结一下发送中断:
使用HAL_UART_Transmit_IT函数发送指定长度的数据,并使能发送中断,发送到一半和发送结束会触发中断(相关的回调函数是HAL_UART_TxHalfCpltCallback()和HAL_UART_TxCpltCallback())中断触发后发送中断使能会被清除,然后调用回调函数,回调函数执行完成之后结束本次发送。
上一篇:STM32串口环形缓冲区
【ATMEL技术问题】ADS平台AT91R4008的FLASH引导程序 在ADS平台下,对AT91R40008进行FLASH程序引导,目前问题运行,现在把BOOT_FLASH.S 分享给大家,程序如下 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; boot from FLASH: initialization & ...… 查看全部问答> |
我的T43机器显卡是Mobil Intel 915GM,在windows xp环境下最大显示分辨率就是1024×768,这个是最大分辨率吗,如果能更大分辨率,怎样设置。… 查看全部问答> |
编译基于2440的工程出错,哪位大侠解答一下?好像是串口的问题,但不知道怎么改,BSP的串口驱动已经加进去了,还是不行! BUILD: [01:0000000338:ERRORE] NMAKE : U1073: don\'t know how to make \'D:\\WINCE500\\PBWorkspaces\\QT244 ...… 查看全部问答> |
我们的无线设备是一个黑盒子,目的就是用无线网卡给黑盒子里发送数据以及接收盒子发过来的数据.但是每次都是第一次建立连接后没问题,然后停止后再次发送数据到盒子就会得到GetLastError=31,设备未发挥作用. 这个是怎么回事啊? 在停止后binding并没有 ...… 查看全部问答> |
[hide] LED在开始工作时,不需要预热和触发脉冲;在正常工作时,可以在特低安全电压下工作,这些都是LED较其它气体放电光源来说独特的优点。为了充分利用LED的这些优点,设计性能优良的LED控制装置是保证照明LED的优点得到充分发挥的重要工作。在 ...… 查看全部问答> |
问题 verilog 中定义的存储型寄存器组,例如,reg [16:1]mem [255:0];这应该是可综合的,可是综合之后消耗的是 芯片中 分布式 LE 组成的 RAM 呢 还是 存储模块里的RAM 呢?(假定芯片中有存储模块RAM 区) 分析: 如果没有专门去调用芯片的RAM资 ...… 查看全部问答> |
