今天是:2025年04月09日(星期三)
2019年04月09日 | STM32F429 DMA串口数据发送
2019-04-09 来源:eefocus
串口数据配置
void macUART4_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
RCC_AHB1PeriphClockCmd(macUART4_RX_GPIO_CLK|macUART4_TX_GPIO_CLK,ENABLE);
RCC_APB1PeriphClockCmd(macUART4_CLK, ENABLE);
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Pin = macUART4_TX_PIN ;
GPIO_Init(macUART4_TX_GPIO_PORT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = macUART4_RX_PIN;
GPIO_Init(macUART4_RX_GPIO_PORT, &GPIO_InitStructure);
GPIO_PinAFConfig(macUART4_RX_GPIO_PORT,macUART4_RX_SOURCE,macUART4_RX_AF);
GPIO_PinAFConfig(macUART4_TX_GPIO_PORT,macUART4_TX_SOURCE,macUART4_TX_AF);
USART_InitStructure.USART_BaudRate = macUART4_BAUDRATE;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(macUART4, &USART_InitStructure);
USART_Cmd(macUART4, ENABLE);
DMA配置函数,请和DMA串口接收数据配置函数对比
void DMA_Config(void)
DMA_InitTypeDef DMA_InitStructure; //
RCC_AHB1PeriphClockCmd(macUART4_DMA_CLK, ENABLE); //
DMA_DeInit(macUART4_TX_DMA_STREAM); //
while (DMA_GetCmdStatus(macUART4_TX_DMA_STREAM) != DISABLE){
DMA_InitStructure.DMA_Channel = macUART4_TX_DMA_CHANNEL; //
DMA_InitStructure.DMA_PeripheralBaseAddr = macUART4_DR_BASE; //
DMA_InitStructure.DMA_Memory0BaseAddr = (u32)SendBuff; //
DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; //
DMA_InitStructure.DMA_BufferSize = macUART4_SEND_BUFF_SIZE; //
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; //
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; //
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; //
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; //
DMA_Init(macUART4_TX_DMA_STREAM, &DMA_InitStructure); //
DMA_Cmd(macUART4_TX_DMA_STREAM, ENABLE);
while(DMA_GetCmdStatus(macUART4_TX_DMA_STREAM) != ENABLE)
主函数,调试串口和UART4同时发送数据,相互并不影响
int main(void)
int i;
SysTick_Init();
NVIC_Configuration();
Debug_USART_Config();
macUART4_Config();
DMA_Config();
printf("Hello World!nn");
for(i=0;i { SendBuff[i] = 'A'; } USART_DMACmd(macUART4, USART_DMAReq_Tx, ENABLE); while(1) { printf("Hello World!n"); } } 该程序中没有涉及中断程序,DMA的使用本应该尽量避免使用中断。
本帖最后由 paulhyde 于 2014-9-15 09:07 编辑 十天学会AVR单片机视频教程 第一讲:开发板和软件的操作使用 1、 介绍配件。 2、 安装软件(ICC AVR 和AVR STUDIO)及其使用,包括新建工程、程序下载,仿真调试;整板测试;板上资源。 3、 着 ...… 查看全部问答> |
时钟频率的提高带来的高功耗、深亚微米半导体制造工艺漏电流产生的高功耗以及更多的设计挑战促使处理器设计制造商开始将思路转向到多内核集成的解决方案上来。多核处理器技术是提高处理器性能的有效方法,因为处理器的实际性能是处理器在每个时钟周 ...… 查看全部问答> |
freescale S08&coldfire v1 GPIO教程 大家参考下原文见我的博客: http://blog.ednchina.com/bluehacker/1687754/message.aspx … 查看全部问答> |
Symbol(WinCE5) 使用keybd_event模拟扫描键 硬件设备:Symbol MC3000(作用是用来扫描条码) 系统:Wince5 Symbol MC3000设备上有一个扫描按键,按键的定义是(是厂家自己定义的,程序里按键消息名为WM_USER_TRIGGER): #define WM_USER_TRIGGER WM_USER + 0x ...… 查看全部问答> |
设计并制作一个线阵LED图文显示装置,装置的示意图如图1所示。 (1) 制作一个由16只 LED构成的线状点阵及其控制电路,安装于可旋转的平台上,在平台的中心设置一个按键,用于功能的切换,电机带动平台以合适速度旋转。(2) & ...… 查看全部问答> |
