今天是:2025年04月10日(星期四)
2019年04月10日 | STM32F103利用定时器2与串口接收指令控制LED亮度
2019-04-10 来源:eefocus
通过串口接收到的数据改变PA8输出的占空比来控制LED小灯的亮度
主函数
char *str_light = "LIGHT:";
unsigned char PWM_BUF = 0;
int main(void)
PWM_Init();
USART3_TIM2_Init(115200);
delay_init();
while(1)
if(RX_SATA == 1)
if(strstr(RX_BUF,str_light) != 0)
delay_ms(1);
PWM_BUF =(RX_BUF[6]-0x30)*10+(RX_BUF[7]-0x30);
TIM_SetCompare1(TIM1,PWM_BUF);
RX_SATA = 0;
count = 0;
memset(RX_BUF,0,strlen(RX_BUF));
配置USART3和TIM2
char RX_BUF[20] = {0};
u8 count = 0;
u8 RX_SATA = 0;// 0表示接受未完成 ;1表示接收完成
void USART3_TIM2_Init(u32 bound)
NVIC_InitTypeDef NVIC_InitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
//开启GPIOB 和 复用功能时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO,ENABLE);
//开启USART3的时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
//PB10 ->Tx 配置为复用推挽式输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//PB11 ->Rx 配置为浮空输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//配置串口
USART_InitStructure.USART_BaudRate = bound;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
USART_Init(USART3, &USART_InitStructure);
USART_ITConfig(USART3,USART_IT_RXNE,ENABLE);//配置串口接收为中断模式
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_Cmd(USART3,ENABLE);
USART_GetFlagStatus(USART3,USART_FLAG_TC);//防止第一个字符被吞
//使能定时器2的时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
TIM_TimeBaseStructure.TIM_Period = (100-1);//ARR
TIM_TimeBaseStructure.TIM_Prescaler = (7200-1);//PSC
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, & TIM_TimeBaseStructure);
//使能定时器2的中断
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
//配置定时器2的中断优先等级
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
//使能定时器2
TIM_Cmd(TIM2,DISABLE);
void USART3_IRQHandler(void)
USART_ClearFlag(USART3,USART_FLAG_RXNE);
RX_BUF[count] = USART_ReceiveData(USART3);
count++;
TIM_SetCounter(TIM2,0);
TIM_Cmd(TIM2,ENABLE);
void TIM2_IRQHandler(void)
TIM_ClearFlag(TIM2,TIM_FLAG_Update);
RX_SATA = 1;
配置PWM
void PWM_Init(void)
TIM_OCInitTypeDef TIM_OCInitStructure;
//初始化PA8管脚为复用推挽式输出
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽式输出
GPIO_Init(GPIOA, &GPIO_InitStructure);
//初始化定时器1的时基单元
//使能定时器1的时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
TIM_TimeBaseStructure.TIM_Prescaler = (72-1);//PSC
TIM_TimeBaseInit(TIM1, & TIM_TimeBaseStructure);
//初始化PWM输出配置
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
TIM_OC1Init(TIM1,&TIM_OCInitStructure);
//使能PWM外设
TIM_CtrlPWMOutputs(TIM1,ENABLE);
//激活CCR寄存器
TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
//激活ARR寄存器
TIM_ARRPreloadConfig(TIM1,ENABLE);
//使能定时器1
TIM_Cmd(TIM1,ENABLE);
关于ARM中断处理的问题----《ARM嵌入式系统开发-软件设计与优化》第九章中疑问 各位过年好哦~ 呵呵,小弟这里有点疑惑相同大家讨论讨论~,这个问题是《ARM嵌入式系统开发-软件设计与优化》一书中的见下: 第九章-中断处理 9.3.2嵌套中断 在这一节中,描述了如何处理嵌套式的中断(不能单纯的在IRQ模式下打开中断允许位) ...… 查看全部问答> |
找了一些资料,但还是有点不明白, http://topic.eeworld.net/u/20090319/17/48afc467-5061-476c-ac41-5a0f8fdd4622.html这位仁兄也问了差不多的问题 方法是不是主要将%_WINCEROOT%\\Public\\Common\\Oak\\Drivers\\Serial\\COM16550目录复制到 ...… 查看全部问答> |
This file should only be compiled with iccavr or aavr with processor option -v1 #error This file should only be compiled with iccavr or aavr with processor option -v1 有人用IAR AVR遇到过这个问题吗?… 查看全部问答> |
ECC检验有什么优势,我不明白,请玩过Nand flash 的朋友谈谈 搞了半天都没明白ECC的原理是什么?但根据网友提供的代码,基本上知道怎么去调用它,但我有点纳闷:还不如自己写完一个Sector后,写个函数再读出这个扇区一个一个字节与原数据做比较,不一一对应,擦除再写,直到写对为止,难道ECC算法查到某位写错后,不用经 ...… 查看全部问答> |
家电控制板的小体积,低成本决定了在线路中不会使用高成本的材料来解决其电磁干扰问题。家电控制板的干扰主要来自三大方面:一是控制板本身产生的干扰,二是来自负载的干扰,三是来自线路上的干扰。解决这些干扰可以分别采用不同的方案来达成。 控 ...… 查看全部问答> |
请教,stm8a的芯片,有没有位寻址功能,我看没大量资料,没有看到有关说明,求解用过大侠们~~~~~~~~~~~~~~~~~~~~~~ ...… 查看全部问答> |
FPGA的I2C对摄像头配置怎么没有地址,只有数据呢。谁能解释下。///////////// Config Data LUT ////////////////////////// alwaysbegin case(LUT_INDEX) // Audio Config Data 0 : LUT_DATA <= 16\'h0000; 1 : LUT_DATA <= 16\'h1140; ...… 查看全部问答> |
